EUC-042SxxxDS(PS)
42W Constant Current IP66 Driver
Rev. Q
Features
High Efficiency (Up to 90%)
Second Generation with Improved Performance
Active Power Factor Correction (Typical 0.95)
Constant Current Output
Waterproof (IP66) and Damp Location
Dimming Control
All-Around Protection: OVP, SCP,OLP,OTP
SELV and Class 2
UL Type TL (Temperature Limited)
Description
The EUC-042SxxxDS(PS) series operates from a 90 ~ 305 Vac input range. They are designed to be highly
efficient and highly reliable. Features include dimming control, over voltage protection, short circuit
protection, over load protection, and over temperature protection.
Models
Output
Current
Input
Voltage
Range(1)
Output
Voltage
Range
Max.
Output
Power
Typical
Power Factor
Efficiency
120Vac
220Vac
(2)
350 mA
90 ~ 305 Vac
60~120Vdc
42 W
90.0%
0.96
0.95
EUC-042S035DS(PS)(3)
450 mA
90 ~ 305 Vac
47~94 Vdc
42 W
89.0%
0.96
0.95
EUC-042S045DS(PS)(3)
530 mA
90 ~ 305 Vac
40~79 Vdc
42 W
89.0%
0.96
0.95
EUC-042S053DS(PS)(3)
700 mA
90 ~ 305 Vac
28~56 Vdc
39 W
89.0%
0.96
0.95
EUC-042S070DS(PS)(4)(6)
1050 mA
90 ~ 305 Vac
20~38 Vdc
40 W
88.0%
0.96
0.95
EUC-042S105DS(PS)(5)(6)
1280 mA
90 ~ 305 Vac
17~32 Vdc
42 W
87.0%
0.96
0.95
EUC-042S128DS(PS)(5)(6)
1400 mA
90 ~ 305 Vac
15~30 Vdc
42 W
87.0%
0.96
0.95
EUC-042S140DS(PS)(5)(6)
1750 mA
90 ~ 305 Vac
12~24 Vdc
42 W
87.0%
0.96
0.95
EUC-042S175DS(PS)(5)
Model Number
Notes: (1) UL, FCC certified input voltage range: 100-277Vac; other certified input voltage range except UL, FCC:
100-240Vac.
(2) Measured at full load and 220 Vac input.
(3) Non-Class 2 output (USR & CNR).
(4) Class 2 output (USR), Non-Class 2 output (CNR).
(5) Class 2 output (USR & CNR).
(6) Meet with KC Certification.
Input Specifications
Parameter
Min.
Typ.
Max.
Input Voltage
90 V
305 V
Input Frequency
47 Hz
63 Hz
Notes
1 / 11
Specifications are subject to changes without notice.
www.inventronics-co.com
Tel: 86-571-56565800
Fax: 86-571-86601139
sales@inventronics-co.com
EUC-042SxxxDS(PS)
Rev. Q
Input Specifications (Continued)
Parameter
Min.
Typ.
Max.
Notes
0.75 MIU
UL8750; 277Vac/ 60Hz
0.70 mA
IEC60598-1; 240Vac/ 60Hz
0.7 A
Measured at full load and 100 Vac input.
0.3 A
0.32 A s
0.90
20%
Parameter
Min.
Typ.
Max.
Output Current Tolerance
-5% IO
5% IO
132 V
104 V
87 V
59 V
42 V
37 V
34 V
27 V
50%IO
Related to V-I Curve of the LED
10%IO
At full load condition
Line Regulation
±1%
Measured at full load condition
Load Regulation
±3%
0.40 s
0.75 s
Measured at 120Vac input,
75%load-100%load
0.30 s
0.50 s
Measured at 220Vac input,
75%load-100%load
0.2%/C
10.8 V
12 V
13.2 V
0 mA
20 mA
Leakage Current
Input AC Current
2
Inrush Current(I t)
Power Factor
2
At 220Vac input 25℃ Cold Start. Duration=200 μs,
10%Ipk-10%Ipk. See Inrush Current Waveform for
the details.
At 100-277Vac, 75%-100%load(31.5~42W)
THD
Output Specifications
No Load Output Voltage
IO = 350 mA
IO = 450 mA
IO = 530 mA
IO = 700 mA
IO = 1050 mA
IO = 1280 mA
IO = 1400 mA
IO = 1750 mA
Total Output Current Ripple
(pk-pk)
Output Current Overshoot /
Undershoot
Turn-on Delay Time
Temperature Coefficient of
Iomax
12V Auxiliary Output
Voltage
12V Auxiliary Output Source
Current
Notes
Case temperature = 0C ~Tc max
Return terminal is “Dim-”.
Note: All specifications are typical at 25°C unless otherwise stated.
2 / 11
EUC-042SxxxDS(PS)
Rev. Q
General Specifications
Parameter
Efficiency at 120 Vac input:
IO = 350 mA
IO = 450 mA
IO = 530 mA
IO = 700 mA
IO = 1050 mA
IO = 1280 mA
IO = 1400 mA
IO = 1750 mA
Efficiency at 220 Vac input:
IO = 350 mA
IO = 450 mA
IO = 530 mA
IO = 700 mA
IO = 1050 mA
IO = 1280 mA
IO = 1400 mA
IO = 1750 mA
Efficiency at 277 Vac input:
IO = 350 mA
IO = 450 mA
IO = 530 mA
IO = 700 mA
IO = 1050 mA
IO = 1280 mA
IO = 1400 mA
IO = 1750 mA
No Load Power Dissipation
MTBF
Life Time
Operating Case
Temperature for Safety
Tc_s
Operating Case
Temperature for Warranty
Tc_w
Operating Case
Temperature
for Type TL Tc_TL
Storage Temperature
Min.
Typ.
Max.
87%
86%
86%
86%
85%
84%
84%
84%
89%
88%
88%
88%
86%
86%
85%
85%
88%
87%
87%
87%
86%
85%
85%
85%
90%
89%
89%
89%
88%
87%
87%
87%
88%
87%
87%
87%
86%
85%
85%
85%
90%
89%
89%
89%
88%
87%
87%
87%
6W
327,000
Hours
116,000
Hours
-40 ℃
+90 ℃
-40 ℃
+70 ℃
-40 ℃
-40 ℃
Dimensions
Inches (L × W × H)
Millimeters (L × W × H)
Net Weight
Notes
Measured at full load and steady-state
temperature in 25℃ ambient.
Measured at 120Vac input, 80%Load and 25C
ambient temperature (MIL-HDBK-217F)
Measured at 120Vac input, 80%Load and 60C
Case temperature. See life time vs. Tc curve for
the details
Humidity: 10% RH to 100% RH.
+72 ℃
+85 ℃
Humidity: 5% RH to 100% RH
3.74 × 2.76 × 1.26
95 × 70 × 32
390 g
Note: All specifications are typical at 25C unless otherwise stated.
3 / 11
EUC-042SxxxDS(PS)
Rev. Q
Dimming Specifications
Parameter
Min.
Typ.
Max.
Absolute Maximum Voltage
on the 0~10V Input Pin
0V
15 V
Source Current on 0~10V
Input Pin
0 uA
200 uA
250 uA
Dimming Output Range
10%Iomax
Recommended Dimming
Input Range
0V
Notes
100%Iomax
10 V
Safety & EMC Compliance
Safety Category
UL/CUL
Standard
UL 8750,UL 1310,CAN/CSA-C22.2 No. 250.13-12,CAN/CSA-C22.2 No. 223-M91
CE
EN 61347-1, EN61347-2-13
CCC
GB 19510.1, GB 19510.14
KS
KS C 7655: 2011
EMI Standards
(1)
EN 55015
Notes
Conducted emission Test & Radiated emission Test
EN 61000-3-2
Harmonic Current Emissions
EN 61000-3-3
Voltage Fluctuations & Flicker
ANSI C63.4:2009 Class B
(1)
FCC Part 15
This device complies with Part 15 of the FCC Rules. Operation is subject to the following
two conditions: [1] this device may not cause harmful interference, and [2] this device
must accept any interference received, including interference that may cause undesired
operation.
EMS Standards
Notes
EN 61000-4-2
Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge
EN 61000-4-3
Radio-Frequency Electromagnetic Field Susceptibility Test-RS
EN 61000-4-4
Electrical Fast Transient / Burst-EFT
EN 61000-4-5
Surge Immunity Test: AC Power Line: line to line 2 kV
EN 61000-4-6
Conducted Radio Frequency Disturbances Test-CS
EN 61000-4-8
Power Frequency Magnetic Field Test
EN 61000-4-11
Voltage Dips
EN 61547
Electromagnetic Immunity Requirements Applies To Lighting Equipment
4 / 11
EUC-042SxxxDS(PS)
Rev. Q
Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it
depends also on the other devices connected to the driver and on the fixture itself.
Lifetime vs. Case Temperature Curve
5 / 11
EUC-042SxxxDS(PS)
Rev. Q
Efficiency vs. Load
EUC-042S035DS(PS)
EUC-042S045DS(PS)
EUC-042S053DS(PS)
EUC-042S070DS(PS)
EUC-042S105DS(PS)
EUC-042S128DS(PS)
6 / 11
EUC-042SxxxDS(PS)
Rev. Q
EUC-042S140DS(PS)
EUC-042S175DS(PS)
Power Factor Characteristics
Total Harmonic Distortion
7 / 11
EUC-042SxxxDS(PS)
Rev. Q
Protection Functions
Parameter
Notes
Over Voltage Protection
Limits output voltage at no load and in case the normal voltage limit fails.
Short Circuit Protection
Auto Recovery. No damage shall occur when any output operating in a short circuit
condition. The power supply shall be self-recovery when the fault condition is removed.
Over Temperature Protection
Auto Recovery. Returning to normal after over temperature is removed.
Dimming Control
0-10V Dimming
The dimmer control may be operated from either a dimmer or from an input signal of 0 - 10 Vdc. The
recommended implementation is provided below.
Implementation 1: DC Input
Implementation 2: External Resistor
8 / 11
EUC-042SxxxDS(PS)
Rev. Q
Implementation 3: External Resistor
Notes:
1. Do not connect the Dim- to the V-, otherwise, the LED driver cannot work normally.
2. If 0-10V dimming is not used, Dim + can be either open or connected to Vaux.
Mechanical Outline
EUC-042SxxxDS
EUC-042SxxxPS
Tc
Tc
YELLOW
PURPLE
GRAY
DIMMING WIRE
(UL1015 22AWG)
WHITE
(ACN)
BLACK
(ACL)
AC INPUT
(UL1015 18AWG)
WHITE BLACK
(ACN) (ACL)
BLACK RED
(V+)
(V-)
DC OUTPUT
(UL1015 18AWG)
AC INPUT (UL 1015 AWG#18)
BLACK RED
(V+)
(V-)
DC OUTPUT (UL 1015 AWG#18)
PROJ:
PROJ:
Unspecified tolerance:±1
RoHS Compliance
Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other
hazardous substances from electronic products.
9 / 11
EUC-042SxxxDS(PS)
Rev. Q
Revision History
Description of Change
Change
Date
Rev.
2012-02-17
A
Preliminary Datasheets First Release
2012-03-21
B
EUC-042S105DS(PS) CUL Class 2 added
EUC-042S105DS(PS)-0001
Added
EN 61000-4-5--- line to line 2 kV, line to earth 4 kV
Corrected
Life time
50,000 Hours
EUC-042S070DS(PS)-0001
Added
EUC-042S070DS(PS)-0001,
Deleted
Notes of life time
Updated
Life time vs. Tc Curve
Added
2012-05-25
2012-06-06
Item
From
To
C
D
2012-07-02
E
Description of OTP
Updated
2012-07-17
F
Max Case Temperature
Updated
2012-7-30
G
Min Operating Temperature
-20℃
-40℃
Derating Curve
Updated
Inrush Current
60A
70A
Inrush Current(I2t)
Added
Temperature coefficient
Added
Life time
Min 50,000hrs
Typical 116,000hrs
Life time Curve
Updated
Io/Ir Vs Rx Curve
Added
THD Curve
Added
EFF and PF Curve of other models
Added
2012-08-20
2012-11-16
H
I
2
2013-05-22
2013-11-25
2014-05-27
J
2
2
Inrush Current(I t) corrected
0.16 A s
0.32 A s
Duration of Inrush Current corrected
100 μs
200 μs
Mechanical Outline---cable length corrected
Updated
Model 530mA
Added
Mechanical Outline-Dimming wires updated
UL1015 26AWG
UL1015 22AWG
ENEC certificate
Added
K
L
10 / 11
EUC-042SxxxDS(PS)
Rev. Q
Revision History (Continued)
Change
Date
2015-08-04
2015-12-31
2016-04-18
Rev.
Item
From
To
Warranty Tc
Added
Environmental Specifications
Deleted
Added
CCC certificate
Added
CQC certificate
Deleted
Source Current on 0~10V Input Pin Max.
200 uA
250 uA
KS Certification
Added
KC Certification-EUC-042S070/105/128/140DS(PS) /
Added
Net Weight
350 g
390 g
UL Type TL
Added
KS Certificate Regulation
Added
Note of EMI Standard
Added
M
N
O
2016-08-02
P
Turn-on Delay Time at 120Vac
Max.=1.0 s
Max.=0.75 s
2019-04-17
Q
Mechanical Outline
Updated
11 / 11
很抱歉,暂时无法提供与“EUC-042S105DS”相匹配的价格&库存,您可以联系我们找货
