EAM-150S105SB
EAM-150S105SB
    INVENTRONICS(英飞特)
EAM-150S105SB 数据手册
EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B Features  Input Over Voltage Protection at 440Vac with 48 Hours  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Potentiometer  Non-dimming Control  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: IOVP, OVP, SCP, OTP  IP67  5 Years Warranty Description The EAM-150S105SB series is a 150W, constant-current, AOC LED driver that operates from 90-305Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway lights, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) 525-1050mA 700-1050mA Default Output Current 700mA Input Voltage Range(2) Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range 90~305 Vac/ 72~214 Vdc 127~300 Vdc 150W 92.0% 0.99 0.96 Model Number (4) EAM-150S105SB Notes: (1) Output current range with constant power at 150W. (2) Certified input voltage range: 100-240Vac. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) To order CB approved model, please use suffix “SG” in place of “SB” (ex: EAM-150S105SG). I-V Operation Area 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.50 A Measured at 100% load and 120 Vac input. - - 0.80 A Measured at 100% load and 220 Vac input. - - 0.86 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 525 mA - 1050 mA 700 mA - 1050 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EAM-150S105SB - - 240 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 127~300 Vdc IEC60598-1; 240Vac/ 60Hz, Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25C cold start, duration=280 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (90-150W) At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EAM-150S105SB Output Current Setting Range with Constant Power EAM-150S105SB Total Output Current Ripple (pk-pk) At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset Notes At 100% load condition Measured at 100% load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B General Specifications Parameter Min. Efficiency at 120 Vac input: EAM-150S105SB Io= 700 mA Io=1050 mA Efficiency at 220 Vac input: EAM-150S105SB Io= 700 mA Io=1050 mA Efficiency at 277 Vac input: EAM-150S105SB Io= 700 mA Io=1050 mA Typ. Max. Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details 87.00% 88.00% 89.00% 90.00% - 89.50% 90.00% 91.50% 92.00% - 90.00% 90.50% 92.00% 92.50% - MTBF - 457,000 Hours - Lifetime - 109,000 Hours - -20°C - +90°C -20°C - +80C Case temperature for 5 years warranty -20°C - +85°C Humidity: 5%RH to 100%RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 7.01 × 2.36 × 1.34 178 × 60 × 34 6.34 × 2.36 × 1.34 161 × 60 × 34 Net Weight - 680 g - Note: All specifications are typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category Standard CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 BIS IS 15885(PART2/SEC13) EAC ГОСТ Р МЭК 61347-1, ГОСТ IEC 61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating Lifetime vs. Case Temperature 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B Inrush Current Waveform Efficiency vs. Load EAM-150S105SB(Io=700mA) EAM-150S105SB(Io=1050mA) Power Factor 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Over Voltage Protection  Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 320 Vac 340 Vac 360 Vac 300 Vac 320 Vac 340 Vac - - 440 Vac Turn off the output when the input voltage exceeds protection voltage. Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive for 48 hours with input voltage stress of 440Vac. Input Over Voltage Protection Diagram Io Recovery Protection 340 Vac 320 Vac Vin 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B Output Current vs. Potentiometer Setting  EAM-150S105SB Output Current Setting (Ioset) Output Voltage Range Typ. Min. Max. 1050mA 72V 143V … … … 700mA 107V 214V … … … 525mA 143V 214V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. Notes: Endcap covering potentiometer must be tight to insure IP67 rating. Mechanical Outline INPUT (BIS 3*1.0mm2 7.25 ) OUTPUT (BIS 2*1.0mm2 6.85) Tc AC/L (RED) AC/N (BLACK) V+ (RED) V- (BLACK) GND (YELLOW/GREEN) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EAM-150S105SB 150W AOC IP67 Driver with 440Vac Protection Rev. B Revision History Description of Change Change Date Rev. 2019-10-24 A 2019-12-05 B Item From To Datasheets Release / / EAC Logo / Added Safety &EMC Compliance EAC Added 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EAM-150S105SB 价格&库存
很抱歉,暂时无法提供与“EAM-150S105SB”相匹配的价格&库存,您可以联系我们找货
EAM-150S105SB
