EBV-200S048SV
EBV-200S048SV
    INVENTRONICS(英飞特)
EBV-200S048SV 数据手册
EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B Features  High Efficiency (up to 93.5%)  Constant Voltage Output  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OCP, OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Independent Design  5 Years Warranty Description The EBV-200SxxxSV series is a 200W, constant-voltage, the LED driver that operates from 176-305 Vac input with excellent power factor. It is created for architectural lighting, decorative lighting, signage lighting and similar applications requiring industry safety compliance, superior electrical performance and robust packaging for challenging environments. The high efficiency of the driver and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power(2) Typical Efficiency (3) Power Factor 12 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 16.7 A 200 W 91.5% 0.96 EBV-200S012SV 24 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 8.4 A 200 W 93.0% 0.96 EBV-200S024SV 36 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 5.6 A 200 W 92.5% 0.96 EBV-200S036SV 48 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 4.2 A 200 W 93.5% 0.96 EBV-200S048SV Model Number(4)(5) 220Vac Notes: (1) CCC certified input voltage range: 220/230/240 Vac; other certified input voltage range except CCC: 200-240 Vac or 190-250Vdc (except BIS, KCC and KS). (2) Operating input voltage range: 90-305Vac, and 90-176Vac is for safety operation (see below “Derating” curve for details) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) For BIS models add suffix -3000. Input Specifications Parameter Min. Typ. Max. 176 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 1.1 A Input Voltage Notes 190-250 Vdc IEC60598-1; 240Vac/ 60Hz Measured at 100% load and 220Vac input. 1 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B Input Specifications (Continued) Parameter Min. Typ. Max. - - 2.22 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -2.5%Vo - 2.5%Vo 2 Inrush Current(I t) PF 2 Notes At 220Vac input, 25C cold start, duration=808 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 220-240Vac, 50-60Hz, 60%100%load(120-200W) At 220-240Vac, 50-60Hz, 75%100%load(150-200W) Output Specifications Parameter Output Voltage Tolerance Notes At 100% load condition Measured at 220-240VacVac input, 0% 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 μF ceramic capacitor and a 10 μF electrolytic capacitor. Total Output Voltage Ripple (pk-pk) - - 2%Vo Startup Overshoot/ Undershoot - - 5% At 100% load condition Line Regulation - - ±0.5% Measured at 100% load Load Regulation - - ±1% Turn-on Delay Time - - 0.5 s Output Deviation - - 5%VO Settling Time - - 10 ms Temperature Coefficient of Vo - 0.03%/C - Load Dynamic Response Measured at 220Vac input, 100% load R/S: 1 A/μs Load: 25% ~ 100% load. Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Efficiency at 220Vac input: EBV-200S012SV EBV-200S024SV EBV-200S036SV EBV-200S048SV 89.5% 91.0% 90.5% 91.5% 91.5% 93.0% 92.5% 93.5% MTBF - 437,000 Hours - Lifetime - 106,000 Hours - -40°C - +90°C Operating Case Temperature for Safety Tc_s Max. Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) - Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details 2 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B General Specifications (Continued) Parameter Min. Typ. Max. Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 7.48 × 2.66 x 1.56 190 × 67.5 x 39.7 6.65 x 2.66 x 1.56 169 x 67.5 x 39.7 Net Weight - Notes 900 g - Note: All specifications are typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category Standard CE & ENEC EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 BIS IS 15885(PART2/SEC13) KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2/KN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3/KN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4/KN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5/KN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6/KN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8/KN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11/KN 61000-4-11 EN 61547/KN 61547 Voltage Dips Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 3 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B Derating Lifetime vs. Case Temperature 4 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B Inrush Current Waveform Efficiency vs. Load EBV-200S012SV EBV-200S024SV EBV-200S036SV EBV-200S048SV 5 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. 6 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B Mechanical Outline EBV-200S012SV INPUT VDE H05RN-F 3C*1.0mm 2 7.2) OUTPUT (VDE H07RN-F 2C*1.5mm 2 AC/L(BROWN) AC/N (BLUE) GND(YELLOW/GREEN) 9.4) V+(BROWN) V- (BLUE) V+(BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 Note: The 2 DC output cables are connected in parallel internally because one 1.5mm2 wire can only carry 14.5A. Please connect the 2 brown wires together and 2 blue wires together in application, or ensure each cable carries same current. 7 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B EBV-200S024SV INPUT VDE H05RN-F 3C*1.0mm2 7.2) OUTPUT (VDE H07RN-F 2C*1.5mm2 AC/L(BROWN) AC/N (BLUE) GND(YELLOW/GREEN) 9.4) V+(BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 EBV-200S036/048SV INPUT (VDE H05RN-F 3C*1.0mm 2 7.2) OUTPUT (VDE H05RN-F 2C*1.0mm 2 AC/L(BROWN) AC/N (BLUE) GND(YELLOW/GREEN) 6.8) V+(BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 8 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B RoHS Compliance Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 9 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-200SxxxSV 200W Constant Voltage IP67 Driver Rev. B Revision History Description of Change Change Date Rev. 2018-12-14 A 2019-01-25 Item From To Datasheet Release / / KCC certificate / Added Notes of Models (1) CCC certified input voltage range: 220/230/240 Vac; other certified input voltage range except CCC: 200-240 Vac or 190-250Vdc (except BIS and KS). (1) CCC certified input voltage range: 220/230/240 Vac; other certified input voltage range except CCC: 200-240 Vac or 190-250Vdc (except BIS, KCC and KS). B Dimensions Inches (L × W × H) 6.50 x 2.66 x 1.56 Millimeters (L × W × H) 165 x 67.5 x 39.7 Safety & EMC Compliance / 6.65 x 2.66 x 1.56 169 x 67.5 x 39.7 Updated 10 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EBV-200S048SV 价格&库存
很抱歉,暂时无法提供与“EBV-200S048SV”相匹配的价格&库存,您可以联系我们找货
EBV-200S048SV
