ESD-240S460DT
ESD-240S460DT
    INVENTRONICS(英飞特)
ESD-240S460DT 数据手册
ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Features  Ultra High Efficiency (Up to 94%)  Full Power at Wide Output Current Range (Constant Power)  0-10V/PWM/Timer Dimmable  Dim-to-Off with Standby Power ≤ 1.5 W  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The ESD-240SxxxDT series is a 240W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, sports and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) Output Voltage Range Model Number 249~528 Vac 120~343Vdc 240 W 352~500 Vdc 94.0% 0.96 0.95 ESD-240S100DT 105-1500mA 1050-1500mA 1400 mA 249~528 Vac 80~229Vdc 352~500 Vdc 240 W 93.5% 0.96 0.95 ESD-240S150DT 154-2200mA 1540-2200mA 2100 mA 249~528 Vac 55~156Vdc 352~500 Vdc 240 W 93.0% 0.96 0.95 ESD-240S220DT 224-3200mA 2240-3200mA 2800 mA 249~528 Vac 38~107Vdc 352~500 Vdc 240 W 93.0% 0.96 0.95 ESD-240S320DT (4) 322-4600mA 3220-4600mA 4200 mA 249~528 Vac 352~500 Vdc 27~75Vdc 240 W 93.0% 0.96 0.95 ESD-240S460DT (4) 462-6600mA 4620-6600mA 4900 mA 249~528 Vac 352~500 Vdc 19~52Vdc 240 W 92.5% 0.96 0.95 ESD-240S660DT (4) 70-1000mA 700-1000mA 700 mA Notes: (1) Output current range with constant power at 240W (2) Certified voltage range: 277-480Vac or 352-500Vdc (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV Output 1 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E I-V Operating Area ESD-240S150DT ESD-240S220DT ESD-240S320DT ESD-240S460DT ESD-240S660DT 60 Lo % ad Output Voltage(V) ESD-240S100DT 2 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Input Specifications Parameter Input Voltage Input Frequency Leakage Current Input AC Current 2 Inrush Current(I t) Min. Typ. Max. 249 Vac - 528 Vac 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/ 60Hz - - 0.70 mA IEC60598-1; 480Vac/ 60Hz - - 1.1 A - - 0.6 A 2 Notes 352-500Vdc Measured at 100% load and 277 Vac input. Measured at 100% load and 480 Vac input. At 480Vac input, 25°C Cold Start, Duration=1.43 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. - - 2.9 A s 0.90 - - - - 20% At 277-480Vac, 50-60Hz, 60%-100% Load (144-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 105 mA 154 mA 224 mA 322 mA 462 mA - 1000 mA 1500 mA 2200 mA 3200 mA 4600 mA 6600 mA 700 mA 1050 mA 1540 mA 2240 mA 3220 mA 4620 mA - 1000 mA 1500 mA 2200 mA 3200 mA 4600 mA 6600 mA Output Current Ripple(pk-pk) - 5%Iomax 10%Iomax 100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage ESD-240S100DT ESD-240S150DT ESD-240S220DT ESD-240S320DT ESD-240S460DT ESD-240S660DT - - 355 V 248 V 170 V 120 V 90 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - 0.5 s 0.75 s Temperature Coefficient of Ioset - 0.03%/°C - PF THD Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESD-240S100DT ESD-240S150DT ESD-240S220DT ESD-240S320DT ESD-240S460DT ESD-240S660DT Output Current Setting Range with Constant Power ESD-240S100DT ESD-240S150DT ESD-240S220DT ESD-240S320DT ESD-240S460DT ESD-240S660DT 100% load Measured at 100% load Measured at 277Vac and 480Vac input, 60%-100% Load Case temperature = 0°C ~Tc max 3 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Output Specifications (Continued) Parameter Min. Typ. Max. 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Notes Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 277 Vac input: ESD-240S100DT Io=700 mA Io=1000mA ESD-240S150DT Io=1050mA Io=1500mA ESD-240S220DT Io=1540mA Io=2200mA ESD-240S320DT Io=2240mA Io=3200mA ESD-240S460DT Io=3220mA Io=4600mA ESD-240S660DT Io=4620mA Io=6600mA Efficiency at 347 Vac input: ESD-240S100DT Io=700 mA Io=1000mA ESD-240S150DT Io=1050mA Io=1500mA ESD-240S220DT Io=1540mA Io=2200mA ESD-240S320DT Io=2240mA Io=3200mA ESD-240S460DT Io=3220mA Io=4600mA ESD-240S660DT Io=4620mA Io=6600mA Min. Typ. Max. 90.0% 89.5% 92.0% 91.5% - 90.0% 89.0% 92.0% 91.0% - 89.5% 89.5% 91.5% 91.5% - 89.5% 88.5% 91.5% 90.5% - 89.5% 88.0% 91.5% 90.0% - 89.0% 88.0% 91.0% 90.0% - 91.0% 90.5% 93.0% 92.5% - 91.0% 90.0% 93.0% 92.0% - 90.0% 90.0% 92.0% 92.0% - 90.0% 89.5% 92.0% 91.5% - 90.0% 89.0% 92.0% 91.0% - 90.0% 89.0% 92.0% 91.0% - Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E General Specifications (Continued) Parameter Efficiency at 480 Vac input: ESD-240S100DT Io=700 mA Io=1000mA ESD-240S150DT Io=1050mA Io=1500mA ESD-240S220DT Io=1540mA Io=2200mA ESD-240S320DT Io=2240mA Io=3200mA ESD-240S460DT Io=3220mA Io=4600mA ESD-240S660DT Io=4620mA Io=6600mA Standby power Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 91.5% 91.5% 93.5% 93.5% - 91.0% 91.0% 93.0% 93.0% - 91.0% 90.0% 93.0% 92.0% - 91.0% 89.5% 93.0% 91.5% - 90.5% 89.5% 92.5% 91.5% - - - 1.5 W Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) - 209,000 Hours - Lifetime - 114,000 Hours - -40°C - +89°C -40°C - +75°C -40°C - +85°C Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Case temperature for 5 years warranty With mounting ear 10.32 × 2.66 × 1.56 262 × 67.5 × 39.7 9.49 × 2.66 × 1.56 241 × 67.5 × 39.7 - Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details MTBF Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Notes 1400 g - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA Notes Vdim(+) = 0 V 5 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Dimming Specifications (Continued) Parameter Min. Typ. Max. ESD-240S100DT ESD-240S150DT ESD-240S220DT ESD-240S320DT ESD-240S460DT ESD-240S660DT 10%Ioset - Ioset ESD-240S100DT ESD-240S150DT ESD-240S220DT ESD-240S320DT ESD-240S460DT ESD-240S660DT 70 mA 105 mA 154 mA 224 mA 322 mA 462 mA - Ioset 0V - 10 V Dim off Voltage 0.2 V 0.4 V 0.6 V Dim on Voltage 0.4 V 0.6 V 0.8 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 2% 4% 7% 4% 6% 9% 93% 96% 98% 91% 94% 96% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes 700mA ≤ Ioset ≤ 1000mA 1050mA ≤ Ioset ≤ 1500mA 1540mA ≤ Ioset ≤ 2200mA 2240mA ≤ Ioset ≤ 3200mA 3220mA ≤ Ioset ≤ 4600mA 4620mA ≤ Ioset ≤ 6600mA 70mA ≤ Ioset < 700mA 105mA ≤ Ioset < 1050mA 154mA ≤ Ioset < 1540mA 224mA ≤ Ioset < 2240mA 322mA ≤ Ioset < 3220mA 462mA ≤ Ioset < 4620mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 °C unless stated otherwise. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 6 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Safety & EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 7 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Inrush Current Waveform Efficiency vs. Load ESD-240S100DT(Io=700mA) ESD-240S100DT(Io=1000mA) ESD-240S150DT(Io=1050mA) ESD-240S150DT(Io=1500mA) 8 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E ESD-240S220DT(Io=1540mA) ESD-240S220DT(Io=2200mA) ESD-240S320DT(Io=2240mA) ESD-240S320DT(Io=3200mA) ESD-240S460DT(Io=3220mA) ESD-240S460DT(Io=4600mA) 9 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E ESD-240S660DT(Io=4620mA) ESD-240S660DT(Io=6600mA) Power Factor Total Harmonic Distortion 10 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic 11 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming Set the timing curve by pulling the sliders. 12 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Programming Connection Diagram Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 (Programmer) datasheet for details. Mechanical Outline ESD-240S100DT INPUT(UL STW 3*18AWG DIMMING WIRE (UL 21996 3*22AWG 9.5) 5.0) BLACK/WHITE PURPLE GRAY AC/L (BLACK) AC/N (WHITE) GND (GREEN) V+ (RED) V- (BLUE) Tc OUTPUT(UL STW 2*18AWG 8.9) PROJ: Unspecified toleranc:±1 13 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Other Models INPUT(UL STW 3*18AWG DIMMING WIRE (UL 21996 3*22AWG 5.0) 9.5) BLACK/WHITE PURPLE GRAY AC/L (BLACK) AC/N (WHITE) GND (GREEN) V+ (RED) V- (BLUE) Tc OUTPUT(UL SJTW 2*18AWG 7.3) PROJ: Unspecified toleranc:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 14 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Revision History Description of Change Change Date Rev. 2014-09-10 A 2016-5-30 2017-11-21 Item B C 2018-04-26 D 2018-11-28 E From To Datasheets Release / / General Specifications Case Temperature Operating Case Temperature for Safety General Specifications Operating Case Temperature for Warranty Added Tc_w General Specifications Storage Temperature Added General Specifications With mounting ear Added General Specifications Net Weight Added Environmental Specifications / Deleted Safety &EMC Compliance Notes Added Programming Connection Diagram / Updated Mechanical Outline / Updated Features 5 Years Warranty Updated Input AC Current / Updated Input Specifications Leakage Current Updated Input Specifications Inrush Current(I2t) Updated Input Specifications PF/THD(Note) Updated Output Specifications Turn-on Delay Time Updated Output Specifications Temperature Coefficient of Ioset Updated General Specifications Lifetime Updated General Specifications Operating Case Temperature for Warranty Updated Tc_w Safety &EMC Compliance / Updated Lifetime vs. Case Temperature / Updated Mechanical Outline / Updated UL / Updated Description / Updated CE / Added Features / Updated 15 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-240SxxxDT 240W Programmable IP67 Driver Rev. E Revision History Change Date Description of Change Rev. Item From Models / Updated I-V Operating Area / Updated Input Specifications Leakage Current Updated Output Current Setting(Ioset) Range Output Current Setting Range with Constant Power Output Specifications Output Specifications 2018-11-28 E To Updated Updated Output Specifications Turn-on Delay Time Updated General Specifications Dimensions Updated Dimming Specifications Dimming Output Range Updated Safety & EMC Compliance / Updated Derating / Deleted Mechanical Outline / Updated 16 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
ESD-240S460DT 价格&库存
很抱歉,暂时无法提供与“ESD-240S460DT”相匹配的价格&库存,您可以联系我们找货
