EUK-150S150DT
EUK-150S150DT
    INVENTRONICS(英飞特)
    EUK Series 150W 50~143Vdc 1050mA LED DRIVER IP67
EUK-150S150DT 数据手册
EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Features  High Efficiency (Up to 93%)  Full Power at Wide Output Current Range (Constant Power)  Isolated 0-10V/10V PWM Dimmable (DT models) 3-Timer-Modes Dimmable (TT models)  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUK-150SxxxDT(TT) series is a 150W, constant-current, programmable IP67 LED driver that operates from 90-305Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 1050 mA 127~300 Vdc 90~305 Vac/ 1400 mA 127~300 Vdc 90~305 Vac/ 3150 mA 127~300 Vdc 90~305 Vac/ 4200 mA 127~300 Vdc Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number 70-1050mA 700-1050mA 700 mA 75~214 Vdc 150W 93.0% 0.99 0.96 EUK-150S105DT(TT) 105-1500mA 1050-1500mA 50~143Vdc 150W 93.0% 0.99 0.96 EUK-150S150DT(TT) 38~107 Vdc 150W 92.5% 0.99 0.96 EUK-150S210DT(TT) (4) 22 ~ 61 Vdc 150W 91.5% 0.99 0.96 EUK-150S350DT(TT) (4) 14 ~ 39 Vdc 150W 90.5% 0.99 0.96 EUK-150S560DT(TT) (4) 140-2100mA 1400-2100mA 245-3500mA 2450-3500mA 385-5600mA 3850-5600mA Notes: (1) Output current range with constant power at 150W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS). (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D I-V Operation Area EUK-150S105DT(TT) EUK-150S150DT(TT) EUK-150S210DT(TT) EUK-150S350DT(TT) EUK-150S560DT(TT) 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz,  - - 1.60 A Measured at 100% load and 120 Vac input. - - 0.90 A Measured at 100% load and 220 Vac input. - - 2.60 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 140 mA 245 mA 385 mA - 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA 700 mA 1050 mA 1400 mA 2450 mA 3850 mA - 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUK-150S105DT(TT) EUK-150S150DT(TT) EUK-150S210DT(TT) EUK-150S350DT(TT) EUK-150S560DT(TT) - - 240 V 160 V 120 V 80 V 50 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 Notes 127~300 Vdc At 220Vac input, 25C cold start, duration=456μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz,70%-100% Load (105-150W) At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUK-150S105DT(TT) EUK-150S150DT(TT) EUK-150S210DT(TT) EUK-150S350DT(TT) EUK-150S560DT(TT) Output Current Setting Range with Constant Power EUK-150S105DT(TT) EUK-150S150DT(TT) EUK-150S210DT(TT) EUK-150S350DT(TT) EUK-150S560DT(TT) Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes 100% load 100% load. 20 MHz BW 100% load 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUK-150S105DT(TT) Io= 700 mA Io=1050 mA EUK-150S150DT(TT) Io=1050 mA Io=1500 mA EUK-150S210DT(TT) Io=1400 mA Io=2100 mA EUK-150S350DT(TT) Io=2450 mA Io=3500 mA EUK-150S560DT(TT) Io=3850 mA Io=5600 mA Efficiency at 220 Vac input: EUK-150S105DT(TT) Io= 700 mA Io=1050 mA EUK-150S150DT(TT) Io=1050 mA Io=1500 mA EUK-150S210DT(TT) Io=1400 mA Io=2100 mA EUK-150S350DT(TT) Io=2450 mA Io=3500 mA EUK-150S560DT(TT) Io=3850 mA Io=5600 mA Min. Typ. Max. 89.0% 87.5% 91.0% 89.5% - 89.0% 87.5% 91.0% 89.5% - 88.5% 86.5% 90.5% 88.5% - 87.0% 86.0% 89.0% 88.0% - 86.0% 84.5% 88.0% 86.5% - 91.0% 90.0% 93.0% 92.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 89.0% 92.5% 91.0% - 89.5% 88.5% 91.5% 90.5% - 88.5% 87.0% 90.5% 89.0% - Notes Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Typ. Max. 91.5% 90.5% 93.5% 92.5% - 91.5% 90.0% 93.5% 92.0% - 90.5% 89.0% 92.5% 91.0% - 90.0% 88.5% 92.0% 90.5% - 88.5% 87.0% 90.5% 89.0% - MTBF - 271,000 Hours - Lifetime - 81,000 Hours - -40°C - +85°C -40°C - +75C -40°C - +85°C Efficiency at 277 Vac input: EUK-150S105DT(TT) Io= 700 mA Io=1050 mA EUK-150S150DT(TT) Io=1050 mA Io=1500 mA EUK-150S210DT(TT) Io=1400 mA Io=2100 mA EUK-150S350DT(TT) Io=2450 mA Io=3500 mA EUK-150S560DT(TT) Io=3850 mA Io=5600 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Case temperature for 5 years warranty Humidity: 5%RH to 100%RH With mounting ear 7.56 × 2.66 × 1.44 192 × 67.5 × 36.5 6.74 × 2.66 × 1.44 171 × 67.5 × 36.5 - Notes 890 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter DT Models Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Recommended Dimming Range for 0-10V -20 V - 20 V 200 uA 300 uA 450 uA 0V - 10 V PWM_in High Level - 10V - PWM_in Low Level - 0V - 200 Hz - 2 KHz 0% - 100% PWM_in Frequency Range PWM_in Duty Cycle Notes Vdim(+) = 0 V 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Dimming Specifications (Continued) Parameter Min. Typ. Max. 10% - 100% Hold Time 0 Hours - 18 Hours Fade Time 0 Minutes - 60 Minutes 1 - 6 Dimming Level TT Models Dimming Step EUK-150S105DT(TT) EUK-150S150DT(TT) EUK-150S210DT(TT) EUK-150S350DT(TT) Dimming EUK-150S560DT(TT) Output EUK-150S105DT(TT) Range EUK-150S150DT(TT) EUK-150S210DT(TT) EUK-150S350DT(TT) EUK-150S560DT(TT) 10%Ioset - Ioset 70 mA 105 mA 140 mA 245 mA 385 mA - Ioset Notes Default is Traditional Timer. Dimming mode set to Self AdaptingMidnight or Self Adapting-Percentage in PC interface. 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT: level 3, criteria A EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test (2) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Safety &EMC Compliance (Continued) EMS Standards EN 61000-4-11 EN 61547 Notes Voltage Dips Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Inrush Current Waveform Efficiency vs. Load EUK-150S105DT(TT)(Io=700mA) EUK-150S105DT(TT)(Io=1050mA) EUK-150S150DT(TT)(Io=1050mA) EUK-150S150DT(TT)(Io=1500mA) 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D EUK-150S210DT(TT)(Io=1400mA) EUK-150S210DT(TT)(Io=2100mA) EUK-150S350DT(TT)(Io=2450mA) EUK-150S350DT(TT)(Io=3500mA) EUK-150S560DT(TT)(Io=3850mA) EUK-150S560DT(TT)(Io=5600mA) 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-150SxxxDT(TT) 150W Programmable IP67 Driver Rev. D Dimming  0-10V Dimming (Only DT models) The recommended implementation of the dimming control is provided below. Implementation 1 Notes: 1.The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2.If 0-10V dimming is not used, Dim + should be open.  10V PWM Dimming (Only DT models) Implementation 2 Notes: If PWM dimming is not used, Dim + should be open.  Time Dimming (Only TT models) Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUK-150S150DT
物料型号: - EUK-150SxxxDT(TT)系列,其中xxx代表不同的型号,如EUK-150S105DT(TT)、EUK-150S150DT(TT)等。
器件简介: - 这是一个150W恒流可编程IP67 LED驱动器,适用于90-305Vac输入电压,具有出色的功率因数。这些驱动器适用于高棚灯、隧道灯和道路灯等多种照明应用。
引脚分配: - 输入端子包括AC/L(黑色)、AC/N(白色)和GND(绿色)。 - 输出端子包括V+(红色)和V-(蓝色)。 - 调光控制线包括Dim+和Dim-。
参数特性: - 高效率(高达93%)。 - 宽输出电流范围内满功率(恒功率)。 - 隔离的0-10V/10V PWM调光(DT型号)。 - 3-定时器模式调光(TT型号)。 - 输入浪涌保护:6kV线对线,10kV线对地。 - 全方位保护:过压保护、短路保护、过温保护。 - 防水(IP67)和UL干/湿/潮湿位置。 - SELV输出。 - 适用于I类,II区危险(分类)位置。
功能详解: - 提供了详细的输入和输出规格,包括输入电压、频率、漏电流、输入交流电流、突波电流、功率因数和总谐波失真。 - 输出规格包括输出电流容差、设置范围、启动过冲电流、空载输出电压、线路调节和负载调节。 - 调光规格包括0-10V调光、PWM调光和时间调光。
应用信息: - 适用于多种照明应用,如高棚灯、隧道灯和道路灯。
封装信息: - 提供了机械外形图和尺寸信息,以及重量。
安全和EMC合规性: - 符合UL/CUL、CE、KS和FCC Part 15等安全标准。 - 符合EN 55015、EN61000-3-2、EN61000-3-3等EMI标准。 - 符合EN61000-4-2、EN61000-4-3、EN61000-4-4等EMS标准。
修订历史: - 文档记录了从2017年到2019年的修订历史,包括新功能的添加和规格的更新。
EUK-150S150DT 价格&库存
很抱歉,暂时无法提供与“EUK-150S150DT”相匹配的价格&库存,您可以联系我们找货
