EUK-200S105DT
EUK-200S105DT
    INVENTRONICS(英飞特)
EUK-200S105DT 数据手册
EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Features  Ultra High Efficiency (Up to 93.5%)  Full Power at Wide Output Current Range (Constant Power)  0-10V/10V PWM Dimmable (DT models) 3 Timer Modes Dimmable (TT models)  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location   SELV Output TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUK-200SxxxDT(TT) series is a 200W, constant-current, programmable IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, sports and roadway. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Output Max. Typical Power Factor Voltage Output Efficiency Range Power (3) 120Vac 220Vac 90~305 Vac/ 95~286Vdc 127~300 Vdc 90~305 Vac/ 1050 mA 67~190Vdc 127~300 Vdc 90~305 Vac/ 1400 mA 48~143Vdc 127~300 Vdc 90~305 Vac/ 2800 mA 29 ~ 82Vdc 127~300 Vdc 90~305 Vac/ 4900 mA 18 ~ 52Vdc 127~300 Vdc Model Number 70-1050mA 700-1050mA 700 mA 200W 93.5% 0.99 0.96 EUK-200S105DT(TT) 105-1500mA 1050-1500mA 200W 93.5% 0.99 0.96 EUK-200S150DT(TT) 200W 93.0% 0.99 0.96 EUK-200S210DT(TT) 200W 93.0% 0.99 0.96 EUK-200S350DT(TT) (4) 200W 92.0% 0.99 0.96 EUK-200S560DT(TT) (4) 140-2100mA 1400-2100mA 245-3500mA 2450-3500mA 385-5600mA 3850-5600mA Notes: (1) Output current range with constant power at 200W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D I-V Operating Area EUK-200S105DT(TT) EUK-200S150DT(TT) EUK-200S210DT(TT) EUK-200S350DT(TT) EUK-200S560DT(TT) 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU - - 0.70 mA - - 2.15 A Measured at 100% load and 120 Vac input. - - 1.1 A Measured at 100% load and 220 Vac input. - - 1.95A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 140 mA 245 mA 385 mA - 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA 700 mA 1050 mA 1400 mA 2450 mA 3850 mA - 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUK-200S105DT(TT) EUK-200S150DT(TT) EUK-200S210DT(TT) EUK-200S350DT(TT) EUK-200S560DT(TT) - - 320 V 220 V 160 V 100 V 60 V Leakage Current Notes 127~300 Vdc UL8750; 277Vac/ 60Hz, grounding effectively IEC60598-1; 240Vac/ 60Hz, grounding effectively Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25C cold start, duration=1.40ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (140-200W) At 220-240Vac, 50-60Hz, 75%-100% Load (150-200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUK-200S105DT(TT) EUK-200S150DT(TT) EUK-200S210DT(TT) EUK-200S350DT(TT) EUK-200S560DT(TT) Output Current Setting Range with Constant Power EUK-200S105DT(TT) EUK-200S150DT(TT) EUK-200S210DT(TT) EUK-200S350DT(TT) EUK-200S560DT(TT) Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes 100% load 100% load. 20 MHz BW 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Output Specifications (Continued) Parameter Min. Typ. Max. Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - Turn-on Delay Time Temperature Coefficient of Ioset Notes 100% load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUK-200S105DT(TT) Io= 700 mA Io=1050 mA EUK-200S150DT(TT) Io=1050 mA Io=1500 mA EUK-200S210DT(TT) Io=1400 mA Io=2100 mA EUK-200S350DT(TT) Io=2450 mA Io=3500 mA EUK-200S560DT(TT) Io=3850 mA Io=5600 mA Efficiency at 220 Vac input: EUK-200S105DT(TT) Io= 700 mA Io=1050 mA EUK-200S150DT(TT) Io=1050 mA Io=1500 mA EUK-200S210DT(TT) Io=1400 mA Io=2100 mA EUK-200S350DT(TT) Io=2450 mA Io=3500 mA EUK-200S560DT(TT) Io=3850 mA Io=5600 mA Min. Typ. Max. 88.5% 86.0% 90.5% 88.0% - 88.0% 86.0% 90.0% 88.0% - 88.0% 85.5% 90.0% 87.5% - 87.5% 85.0% 89.5% 87.0% - 87.0% 84.5% 89.0% 86.5% - 91.5% 90.0% 93.5% 92.0% - 91.5% 89.5% 93.5% 91.5% - 91.0% 88.5% 93.0% 90.5% - 91.0% 88.5% 93.0% 90.5% - 90.0% 88.0% 92.0% 90.0% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 90.5% 94.0% 92.5% - 92.0% 90.0% 94.0% 92.0% - 91.5% 89.0% 93.5% 91.0% - 91.5% 89.0% 93.5% 91.0% - 90.5% 88.0% 92.5% 90.0% - MTBF - 329,000 Hours - Lifetime - 85,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUK-200S105DT(TT) Io= 700 mA Io=1050 mA EUK-200S150DT(TT) Io=1050 mA Io=1500 mA EUK-200S210DT(TT) Io=1400 mA Io=2100 mA EUK-200S350DT(TT) Io=2450 mA Io=3500 mA EUK-200S560DT(TT) Io=3850 mA Io=5600 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 8.70 × 2.66 × 1.56 221× 67.5 × 39.7 7.95 × 2.66 × 1.56 202 × 67.5 × 39.7 - Notes 1100 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter DT Models Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Recommended Dimming Range for 0-10V -20 V - 20 V 200 uA 300 uA 450 uA 0V - 10 V PWM_in High Level - 10V - PWM_in Low Level - 0V - PWM_in Frequency Range 200 Hz - 2 KHz PWM_in Duty Cycle 0% - 100% Notes Vdim(+) = 0 V 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Dimming Specifications Parameter Min. Typ. Max. 10% - 100% Hold Time 0 Hours - 18 Hours Fade Time 0 Minutes - 60 Minutes 1 - 6 Dimming Level TT Models Dimming Step Dimming Output Range EUK-200S105DT(TT) EUK-200S150DT(TT) EUK-200S210DT(TT) EUK-200S350DT(TT) EUK-200S560DT(TT) 10%Ioset - Ioset EUK-200S105DT(TT) EUK-200S150DT(TT) EUK-200S210DT(TT) EUK-200S350DT(TT) EUK-200S560DT(TT) 70 mA 105 mA 140 mA 245 mA 385 mA - Ioset Notes Default is Traditional Timer. Dimming mode set to Self AdaptingMidnight or Self Adapting-Percentage in PC interface. 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS (2) 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Safety &EMC Compliance EMS Standards Notes EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Inrush Current Waveform Efficiency vs. Load EUK-200S105DT(TT)(lo=700mA) EUK-200S105DT(TT)(lo=1050mA) EUK-200S150DT(TT)(lo=1050mA) EUK-200S150DT(TT)(lo=1500mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D EUK-200S210DT(TT)(lo=1400mA) EUK-200S210DT(TT)(lo=2100mA) EUK-200S350DT(TT)(lo=2450mA) EUK-200S350DT(TT)(lo=3500mA) EUK-200S560DT(TT)(lo=3850mA) EUK-200S560DT(TT)(lo=5600mA) 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT) 200W Programmable IP67 Driver Rev. D Dimming  0-10V Dimming (Only DT models) The recommended implementation of the dimming control is provided below. Implementation 1 Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. If 0-10V dimming is not used, Dim + should be open.  10V PWM Dimming (Only DT models) Implementation 2 Notes: If PWM dimming is not used, Dim + should be open. 11 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-200SxxxDT(TT)  200W Programmable IP67 Driver Rev. D Time Dimming (Only TT models) Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUK-200S105DT 价格&库存
很抱歉,暂时无法提供与“EUK-200S105DT”相匹配的价格&库存,您可以联系我们找货
