EUM-200S105BG
EUM-200S105BG
    INVENTRONICS(英飞特)
EUM-200S105BG 数据手册
EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A Features  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with NFC  DALI-2 and D4i Certified  3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 24Vdc,125mA,3W (Transient Peak Power up to 10W)  Integrated 16Vdc Bus Power Supply based on DALI-2  Integrated Power Monitoring with High Accuracy up to ±1%  Output Lumen Compensation  End-of-Life Indicator  Thermal Sensing and Protection for LED Module  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IUVP, IOVP, OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  7 Year Warranty Description The EUM-200SxxxBx series is a 200W, constant-current, NFC programmable and IP66/IP67 rated LED driver that operates from 90-305Vac input with excellent power factor. Created for intra-luminaire solutions and health monitoring applications, this family provides integrated AC power monitoring with an auxiliary voltage and dimto-off functionality for powering low voltage, wireless controls. The dimming control supports two-way communication via DALI-2 and complies with D4i. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 105-1500mA 1050-1500mA 1050 mA 127~300 Vdc 90~305 Vac/ 180-2800mA 1800-2800mA 2100 mA 127~300 Vdc 90~305 Vac/ 350-5600mA 3500-5600mA 4200 mA 127~300 Vdc 70-1050mA 700-1050mA 700 mA Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 120Vac 220Vac Model Number (5) 95~286 Vdc 200 W 93.5% 0.99 0.96 EUM-200S105Bx 67~190 Vdc 200 W 93.5% 0.99 0.96 EUM-200S150Bx 36~111 Vdc 200 W 93.0% 0.99 0.96 EUM-200S280Bx 18 ~ 57 Vdc 200 W 92.0% 0.99 0.96 EUM-200S560Bx (4) Notes: (1) Output current range with constant power at 200W (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models; x = B are BIS models. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com (4) EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A I-V Operation Area EUM-200S105Bx EUM-200S150Bx % 65 ad Lo EUM-200S280Bx EUM-200S560Bx Input Specifications Parameter Min. Typ. Max. Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/60Hz - - 0.70 mA IEC60598-1; 240Vac/60Hz,  - - 2.12 A Measured at 100%load and 120 Vac input. - - 1.12 A Measured at 100%load and 220 Vac input. - - 4.65 A s Leakage Current Input AC Current 2 Inrush Current(I t) 2 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes At 220Vac input, 25C cold start, duration=584 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 180 mA 350 mA - 1050 mA 1500 mA 2800 mA 5600 mA 700 mA 1050 mA 1800 mA 3500 mA - 1050 mA 1500 mA 2800 mA 5600 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUM-200S105Bx EUM-200S150Bx EUM-200S280Bx EUM-200S560Bx - - 360 V 240 V 120 V 75 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% - - 0.5 s - - 1.0 s - 0.03%/C - PF Notes At 100-277Vac, 50-60Hz, 65%-100% load (130-200W) At 220-240Vac, 50-60Hz, 75%-100% load (150-200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUM-200S105Bx EUM-200S150Bx EUM-200S280Bx EUM-200S560Bx Output Current Setting Range with Constant Power EUM-200S105Bx EUM-200S150Bx EUM-200S280Bx EUM-200S560Bx Total Output Current Ripple (pk-pk) Turn-on Delay Time Temperature Coefficient of Ioset 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes At 100%load condition At 100%load condition. 20 MHz BW At 100%load condition. Only this component of ripple is associated with visible flicker. At 100%load condition Measured at 100%load Measured at all dimming modes except DA LI-2,and 120-277Vac input,65%-100%Load Measured at DALI-2 dimming mode, and 120-277Vac input, 65%-100% Load Case temperature = 0C~Tc max All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A Output Specifications (Continued) Parameter Min. Typ. Max. Notes 24V Auxiliary Output Voltage 21.6 V 24 V 26.4 V 24V Auxiliary Output Source Current 0 mA - 125 mA 24V Auxiliary Output Transient Peak Current@6W - - 250 mA 24V Auxiliary Output Transient Peak Current@10W - - 425 mA Integrated DALI-2 Bus Power Supply Voltage 12 Vdc 16 Vdc 20 Vdc Voltage is depending on loading. Integrated DALI-2 Bus Power Supply Current 50 mA - 60 mA Return terminal is “DA−“ Return terminal is “DA−“ 250mA peak for a maximum duration of 2.2 ms in a 6.0ms period during which time the average should not exceed 125mA. 425mA peak for a maximum duration of 1.3 ms in a 5.2ms period during which time the average should not exceed 125mA. Notes: (1) DALI-2 bus power supply is enabled by default and can be disabled via programming interface. (2) DALI-2 bus power supply supports automatic shut-down and restart after short-circuit. General Specifications Parameter Efficiency at 120 Vac input: EUM-200S105Bx Io= 700 mA Io=1050 mA EUM-200S150Bx Io=1050 mA Io=1500 mA EUM-200S280Bx Io=1800 mA Io=2800 mA EUM-200S560Bx Io=3500 mA Io=5600 mA Efficiency at 220 Vac input: EUM-200S105Bx Io= 700 mA Io=1050 mA EUM-200S150Bx Io=1050 mA Io=1500 mA EUM-200S280Bx Io=1800 mA Io=2800 mA EUM-200S560Bx Io=3500 mA Io=5600 mA Min. Typ. Max. 88.5% 89.0% 90.5% 91.0% - 88.5% 88.5% 90.5% 90.5% - 88.0% 88.0% 90.0% 90.0% - 87.0% 87.0% 89.0% 89.0% - 91.5% 91.5% 93.5% 93.5% - 91.5% 91.5% 93.5% 93.5% - 91.0% 91.0% 93.0% 93.0% - 90.0% 89.5% 92.0% 91.5% - 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 92.0% 94.0% 94.0% - 92.0% 92.0% 94.0% 94.0% - 91.5% 91.5% 93.5% 93.5% - 90.5% 90.0% 92.5% 92.0% - -1% - 1% Standby Power - - 0.5 W MTBF - 205,000 Hours - Lifetime - 102,000 Hours - -40°C - +90°C -40°C - +75°C Case temperature for 7 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 277 Vac input: EUM-200S105Bx Io= 700 mA Io=1050 mA EUM-200S150Bx Io=1050 mA Io=1500 mA EUM-200S280Bx Io=1800 mA Io=2800 mA EUM-200S560Bx Io=3500 mA Io=5600 mA Power Monitoring Accuracy Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input and 100%Load Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 7.40 × 2.66 × 1.44 188 × 67.5 × 36.5 6.73 × 2.66 × 1.44 171 × 67.5 × 36.5 - 1000 g - Parameter Min. Typ. Max. DA+, DA- High Level 9.5 V 16 V 22.5 V DA+, DA- Low Level -6.5 V 0V 6.5 V DA+, DA- Current 0 mA - 2 mA Dimming Specifications Dimming Output Range EUM-200S105Bx EUM-200S150Bx EUM-200S280Bx EUM-200S560Bx 10%Ioset - Ioset EUM-200S105Bx EUM-200S150Bx EUM-200S280Bx EUM-200S560Bx 70 mA 105 mA 180 mA 350 mA - Ioset 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1800 mA ≤ Ioset ≤ 2800 mA 3500 mA ≤ Ioset ≤ 5600 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 180 mA ≤ Ioset < 1800 mA 350 mA ≤ Ioset < 3500 mA All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A Safety &EMC Compliance Safety Category Standard UL/CUL UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 BIS IS 15885(Part2/Sec13) Global Mark AS/NZS 61347.1, AS/NZS 61347.2.13 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT: level 3, criteria A EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment DALI-2 Standards (2) DALI-2 Notes IEC 62386-101, -102 & -207 Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) DALI parts: 101, 102, 150, 207, 250, 251, 252, 253. 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A Derating Lifetime vs. Case Temperature Inrush Current Waveform 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A Efficiency vs. Load EUM-200S105Bx(Io=700mA) EUM-200S105Bx(Io=1050mA) EUM-200S150Bx(Io=1050mA) EUM-200S150Bx(Io=1500mA) EUM-200S280Bx(Io=1800mA) EUM-200S280Bx(Io=2800mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A EUM-200S560Bx(Io=3500mA) EUM-200S560Bx(Io=5600mA) Power Factor Total Harmonic Distortion 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx 200W NFC Driver with DALI-2 and D4i Rev. A Protection Functions Parameter External Thermal Protection Min. Typ. Max. Notes R1 (Start derating) - 1.67 kΩ - The output current starts to decrease linearly when the actual NTC resistance value is lower than R1, until R2 is reached. R2 (Stop derating) - 1.27 kΩ - When the actual NTC resistance value is lower than R2, the output current will stay at the programmed Protection Current Floor. 10%Ioset 20%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 20%) Iomin 20%Ioset 100%Ioset 10%Ioset ≤ Iomin (default setting is 20%) Protection Current Floor Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection (IUVP) Input Over Voltage Protection Input Under Voltage Protection Input Under Voltage Recovery Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 70 Vac 80 Vac 90 Vac Turn off the output when the input voltage falls below protection voltage. 75 Vac 85 Vac 95 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 310 Vac 320 Vac 330 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 310 Vac 320 Vac - - 350 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive stabilized input over voltage conditions up to 350Vac for a total of 8 hours. Note: (1) The recommended NTC type is 10kΩ NTC, Murata NCP18XH103J03RB.  Input Under Voltage Protection Diagram 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx  200W NFC Driver with DALI-2 and D4i Rev. A Input Over Voltage Protection Diagram Io Recovery Protection 320 Vac 310 Vac Vin Dimming  DALI-2 Dimming The recommended implementation of the dimming control is provided below. Implementation: DALI-2 Dimming 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxBx  200W NFC Driver with DALI-2 and D4i Rev. A Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-200S105BG 价格&库存
很抱歉,暂时无法提供与“EUM-200S105BG”相匹配的价格&库存,您可以联系我们找货
EUM-200S105BG
    EUM-200S105BG
      库存:1351
