EUP-200S105ST
EUP-200S105ST
    INVENTRONICS(英飞特)
EUP-200S105ST 数据手册
EUP-200SxxxST 200W AOC IP67 Driver Rev. B Features           Ultra High Efficiency (Up to 93.5%) Full Power at Wide Output Current Range (Constant Power) Adjustable Output Current (AOC) with Dip-switch Non-dimming Control Input Surge Protection: 6kV line-line, 10kV line-earth All-Around Protection: OVP, SCP, OTP Waterproof (IP67) and UL Dry / Damp / Wet Location SELV Output TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location 5 Years Warranty Description The EUP-200SxxxST series is a 200W, constant-current, AOC IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, arena and roadway. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 500-1050mA 700-1050mA 700 mA 850-1500mA 1050-1500mA 1050 mA 1000-2100mA 1400-2100mA 1400 mA 1750-3500mA 2450-3500mA 2800 mA 3150-5600mA 3850-5600mA 4900 mA Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number 95~286Vdc 200W 93.5% 0.99 0.96 EUP-200S105ST 67~190Vdc 200W 93.5% 0.99 0.96 EUP-200S150ST 48~143Vdc 200W 93.0% 0.99 0.96 EUP-200S210ST 29 ~ 82Vdc 200W 93.0% 0.99 0.96 EUP-200S350ST(4) 18 ~ 52Vdc 200W 92.0% 0.99 0.96 EUP-200S560ST(4) Notes: (1) Output current range with constant power at 200W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz 127~300 Vdc 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 0.75 MIU UL8750; 277Vac/ 60Hz, grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively - - 2.15 A Measured at 100% load and 120 Vac input. - - 1.1 A Measured at 100% load and 220 Vac input. - - 1.95 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 500 mA 850 mA 1000 mA 1750 mA 3150mA - 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA 700 mA 1050 mA 1400 mA 2450 mA 3850 mA - 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load. Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUP-200S105ST EUP-200S150ST EUP-200S210ST EUP-200S350ST EUP-200S560ST - - 320 V 220 V 160 V 100 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25C cold start, duration=1.40 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (140-200W) At 220-240Vac, 50-60Hz, 75%-100% Load (150-200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUP-200S105ST EUP-200S150ST EUP-200S210ST EUP-200S350ST EUP-200S560ST Output Current Setting Range with Constant Power EUP-200S105ST EUP-200S150ST EUP-200S210ST EUP-200S350ST EUP-200S560ST Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes 100% load 100% load. 20 MHz BW 100% load 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUP-200S105ST Io= 700 mA Io=1050 mA EUP-200S150ST Io=1050 mA Io=1500 mA EUP-200S210ST Io=1400 mA Io=2100 mA EUP-200S350ST Io=2450 mA Io=3500 mA EUP-200S560ST Io=3850 mA Io=5600 mA Efficiency at 220 Vac input: EUP-200S105ST Io= 700 mA Io=1050 mA EUP-200S150ST Io=1050 mA Io=1500 mA EUP-200S210ST Io=1400 mA Io=2100 mA EUP-200S350ST Io=2450 mA Io=3500 mA EUP-200S560ST Io=3850 mA Io=5600 mA Min. Typ. Max. 88.5% 86.0% 90.5% 88.0% - 88.0% 86.0% 90.0% 88.0% - 88.0% 85.5% 90.0% 87.5% - 87.5% 85.0% 89.5% 87.0% - 87.0% 84.5% 89.0% 86.5% - 91.5% 90.0% 93.5% 92.0% - 91.5% 89.5% 93.5% 91.5% - 91.0% 88.5% 93.0% 90.5% - 91.0% 88.5% 93.0% 90.5% - 90.0% 88.0% 92.0% 90.0% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 90.5% 94.0% 92.5% - 92.0% 90.0% 94.0% 92.0% - 91.5% 89.0% 93.5% 91.0% - 91.5% 89.0% 93.5% 91.0% - 90.5% 88.0% 92.5% 90.0% - MTBF - 329,000 Hours - Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Lifetime - 85,000 Hours - Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Operating Case Temperature for Safety Tc_s -40°C - +89°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUP-200S105ST Io= 700 mA Io=1050 mA EUP-200S150ST Io=1050 mA Io=1500 mA EUP-200S210ST Io=1400 mA Io=2100 mA EUP-200S350ST Io=2450 mA Io=3500 mA EUP-200S560ST Io=3850 mA Io=5600 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) With mounting ear 8.70 × 2.66 × 1.56 221× 67.5 × 39.7 7.96 × 2.66 × 1.56 202 × 67.5 × 39.7 Net Weight Notes 1100 g - Note: All specifications are typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B Safety &EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUP-200S105ST(lo=700mA) EUP-200S105ST(lo=1050mA) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B EUP-200S150ST(lo=1050mA) EUP-200S150ST(lo=1500mA) EUP-200S210ST(lo=1400mA) EUP-200S210ST(lo=2100mA) EUP-200S350ST(lo=2450mA) EUP-200S350ST(lo=3500mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B EUP-200S560ST(lo=3850mA) EUP-200S560ST(lo=5600mA) Power Factor Total Harmonic Distortion 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Output Current vs. Dip Switch Setting  EUP-200S105ST Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1050mA 95V 190V ON ON ON OFF 1000mA 100V 200V ON ON OFF ON 950mA 105V 210V ON ON OFF OFF 900mA 111V 222V ON OFF ON ON 850mA 118V 235V ON OFF ON OFF 800mA 125V 250V ON OFF OFF ON 750mA 133V 266V ON OFF OFF OFF 700mA 143V 286V OFF ON ON ON 650mA 154V 286V OFF ON ON OFF 600mA 167V 286V OFF ON OFF ON 550mA 182V 286V OFF ON OFF OFF 500mA 200V 286V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST  200W AOC IP67 Driver Rev. B EUP-200S150ST Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1500mA 67V 133V ON ON ON OFF 1450mA 69V 138V ON ON OFF ON 1400mA 72V 143V ON ON OFF OFF 1350mA 74V 148V ON OFF ON ON 1300mA 77V 154V ON OFF ON OFF 1250mA 80V 160V ON OFF OFF ON 1200mA 84V 167V ON OFF OFF OFF 1150mA 87V 174V OFF ON ON ON 1100mA 91V 182V OFF ON ON OFF 1050mA 95V 190V OFF ON OFF ON 1000mA 100V 190V OFF ON OFF OFF 950mA 105V 190V OFF OFF ON ON 900mA 111V 190V OFF OFF ON OFF 850mA 118V 190V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST  200W AOC IP67 Driver Rev. B EUP-200S210ST Output Current Setting(Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 2100mA 48V 95V ON ON ON OFF 2000mA 50V 100V ON ON OFF ON 1900mA 53V 105V ON ON OFF OFF 1800mA 56V 111V ON OFF ON ON 1700mA 59V 118V ON OFF ON OFF 1600mA 63V 125V ON OFF OFF ON 1500mA 67V 133V ON OFF OFF OFF 1400mA 72V 143V OFF ON ON ON 1300mA 77V 143V OFF ON ON OFF 1200mA 84V 143V OFF ON OFF ON 1100mA 91V 143V OFF ON OFF OFF 1000mA 100V 143V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. EUP-200S350ST Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 3500mA 29V 57V ON ON ON OFF 3325mA 30V 60V ON ON OFF ON 3150mA 32V 63.5V ON ON OFF OFF 2975mA 34V 67V ON OFF ON ON 2800mA 36V 71.5V ON OFF ON OFF 2625mA 38V 76V ON OFF OFF ON 2450mA 41V 82V ON OFF OFF OFF 2275mA 44V 82V OFF ON ON ON 2100mA 48V 82V OFF ON ON OFF 1925mA 52V 82V OFF ON OFF ON 1750mA 57V 82V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 11 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST  200W AOC IP67 Driver Rev. B EUP-200S560ST Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. OFF ON ON ON 5600mA 18V 35.5V OFF ON ON OFF 5250mA 19V 38V OFF ON OFF ON 4900mA 21V 41V OFF ON OFF OFF 4550mA 22V 44V OFF OFF ON ON 4200mA 24V 47.5V OFF OFF ON OFF 3850mA 26V 52V OFF OFF OFF ON 3500mA 28V 52V OFF OFF OFF OFF 3150mA 31V 52V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. Notes: 1. 2. Dip switch must be set in the setting range as specified to insure the driver operates as expected. Endcap covering dip switch must be tight to insure IP67 rating. Mechanical Outline INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*18AWG 7.8 ) 7.3) AC/L(BLACK) AC/N (WHITE) GND(GREEN) V+(RED) V- (BLUE) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 12 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-200SxxxST 200W AOC IP67 Driver Rev. B Revision History Description of Change Change Date Rev. 2017-10-19 A 2018-04-25 B Item From To Datasheets Release / / Description / Updated Mechanical Outline / Updated 13 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUP-200S105ST 价格&库存
很抱歉,暂时无法提供与“EUP-200S105ST”相匹配的价格&库存,您可以联系我们找货
EUP-200S105ST
