EUV-150S024DVA
EUV-150S024DVA
    INVENTRONICS(英飞特)
    CV, 150W, DIM, 2nd GEN
EUV-150S024DVA 数据手册
EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C Features  High Efficiency (Up to 90.5%)  Isolated 0-10V Dimmable(DVA models) Non-Dimmable (SVA models)  Deep Dimming down to 0.1%  Constant Voltage PWM Output Frequency up to 1.5kHz  Dim-to-Off with Standby Power ≤ 0.5 W  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OCP, OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  5 Years Warranty Description The EUV-150SxxxDVA(SVA) series is a 150W, constant-voltage IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including LED strip, architectural, decorative and signage. The high efficiency of the driver and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, over temperature, and short circuit. Models Input Voltage Range (1) Output Voltage 90~305 Vac 127~250 Vdc 90~305 Vac 127~250 Vdc 12 V 24 V Output Current Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (2) Model Number(3) 0 ~ 12.5 A 150 W 90.0% 0.99 0.96 EUV-150S012DVA(SVA) 0 ~ 6.25 A 150 W 90.5% 0.99 0.96 EUV-150S024DVA(SVA) Notes: (1) Certified input Voltage range: 100-240Vac or 127-250Vdc (except CCC and KS). (2) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (3) SELV output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.6 A Measured at 100% load and 120Vac input. - - 0.9 A Measured at 100% load and 220Vac input. 127~250Vdc IEC60598-1; 240Vac/60Hz Input AC Current 1 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. - - 2.56 A s 0.90 - - THD - - 20% THD - - 10% Min. Typ. Max. -2.5%Vo - 2.5%Vo At 100% load condition - 12.5 V 24.2 V - At 100% load condition Total Output Voltage Ripple (pk-pk) - - 2%Vo Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Startup Overshoot/ Undershoot - - 5%Vo At 100% load condition Line Regulation - - ±0.5% Measured at 100% load Load Regulation - - ±1.5% - - 1.0 s Measured at 120Vac input, 60%-100%load - - 0.5 s Measured at 220Vac input, 60%-100%load - 15 ms - Output Deviation - - 5%Vo Settling Time - - 10 ms Temperature Coefficient of Vo - 0.03%/C - 2 Inrush Current(I t) PF 2 Notes At 220Vac input, 25C cold start, duration=760 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% load(90-150W) At 220-240Vac, 50-60Hz, 75%-100% load(112.5-150W) Output Specifications Parameter Output Voltage Tolerance Output Voltage EUV-150S012DVA(SVA) EUV-150S024DVA(SVA) Notes Turn-on Delay Time Hold up Time Load Dynamic Response Measured at 220Vac input, 100%load R/S: 1A/μs Load: 25% ~ 75% load Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120Vac input: EUV-150S012DVA(SVA) EUV-150S024DVA(SVA) Min. 85.5% 85.5% Typ. Max. 87.5% 87.5% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 2 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Typ. Max. Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Efficiency at 220Vac input: EUV-150S012DVA(SVA) EUV-150S024DVA(SVA) 88.0% 88.5% 90.0% 90.5% - Efficiency at 277Vac input: EUV-150S012DVA(SVA) EUV-150S024DVA(SVA) 88.5% 88.5% 90.5% 90.5% - Standby Power - - 0.5 W MTBF - 258,000 Hours - Lifetime - 89,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details Dimensions Inches (× W × H) Millimeters ((× W × H) Net Weight With mounting ear 7.91 x 2.66 x 1.44 201 x 67.5 x 36.5 7.08 x 2.66 x 1.44 180 x 67.5 x 36.5 - Measured at 230Vac/50Hz; Dimming off 950 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 135 μA 150 μA 165 μA 0.1% - 100% 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - Dimming Output Range Recommended Dimming Input Range Hysteresis Notes Vdim(+) = 0 V Note: All specifications are typical at 25 C unless stated otherwise. 3 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA)  150W Constant Voltage IP67 Driver Rev. C Dimming Principle for PWM Style Output Parameter Output PWM frequency Min. Typ. Max. Notes - 0 Hz - Vdim(+) =9.0-10.0 V - 1.5 kHz - Vdim(+) =1.4-9.0 V 300 Hz - 1.5 kHz Vdim(+) = 1.0-1.4 V Note: Dimming is achieved by varying the duty cycle of the output current when driving LED strips. Safety & EMC Compliance Safety Category CE Standard EN 61347-1, EN61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment 4 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating Lifetime vs. Case Temperature 5 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C Inrush Current Waveform Efficiency vs. Load EUV-150S012DVA(SVA) EUV-150S024DVA(SVA) Power Factor 6 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input 7 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener diode. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  Resister Dimming Implementation 2: External Resistor Mechanical Outline EUV-150S012DVA INPUT (VDE H05RN-F 3*1.0mm2 7.2) DIMMING WIRE (VDE 2*0.5mm2 6.3) Tc V+(BROWN) V-(BLUE) AC/L(BROWN) GRAY PURPLE AC/N(BLUE) GND(YELLOW/GREEN) OUTPUT (VDE H07RN-F 2*1.5mm2 9.4) PROJ: Unspecified tolerance:±1 8 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C EUV-150S024DVA INPUT (VDE H05RN-F 3*1.0mm 2 7.2) DIMMING WIRE (VDE 2*0.5mm 2 6.3) Tc V+(BROWN) V-(BLUE) AC/L(BROWN) GRAY PURPLE AC/N(BLUE) GND(YELLOW/GREEN) OUTPUT (VDE H05RN-F 2*1mm 2 6.8) PROJ: Unspecified tolerance:±1 EUV-150S012SVA INPUT (VDE H05RN-F 3*1.0mm 2 7.2) OUTPUT (VDE H07RN-F 2*1.5mm 2 9.4) Tc V+(BROWN) V-(BLUE) AC/L(BROWN) AC/N(BLUE) GND(YELLOW/GREEN) PROJ: Unspecified tolerance:±1 9 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C EUV-150S024SVA INPUT (VDE H05RN-F 3*1.0mm 2 OUTPUT (VDE H05RN-F 2*1mm 2 7.2) 6.8) Tc V+(BROWN) V-(BLUE) AC/L(BROWN) AC/N(BLUE) GND(YELLOW/GREEN) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 10 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDVA(SVA) 150W Constant Voltage IP67 Driver Rev. C Revision History Description of Change Change Date Rev. 2018-02-05 A 2018-03-09 B Note of Dimming Specifications - Dimming Output / Range Deleted 2018-07-12 C ENEC Certificate Added Item From To Datasheet Release / / Features / Updated / 11 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-150S024DVA 价格&库存
很抱歉,暂时无法提供与“EUV-150S024DVA”相匹配的价格&库存,您可以联系我们找货
