EUC-042S045DS
EUC-042S045DS
    INVENTRONICS(英飞特)
EUC-042S045DS 数据手册
EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Features  High Efficiency (Up to 90%)  Second Generation with Improved Performance  Active Power Factor Correction (Typical 0.95)  Constant Current Output  Waterproof (IP66) and Damp Location  Dimming Control  All-Around Protection: OVP, SCP,OLP,OTP  SELV and Class 2  UL Type TL (Temperature Limited) Description The EUC-042SxxxDS(PS) series operates from a 90 ~ 305 Vac input range. They are designed to be highly efficient and highly reliable. Features include dimming control, over voltage protection, short circuit protection, over load protection, and over temperature protection. Models Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Power Factor Efficiency 120Vac 220Vac (2) 350 mA 90 ~ 305 Vac 60~120Vdc 42 W 90.0% 0.96 0.95 EUC-042S035DS(PS)(3) 450 mA 90 ~ 305 Vac 47~94 Vdc 42 W 89.0% 0.96 0.95 EUC-042S045DS(PS)(3) 530 mA 90 ~ 305 Vac 40~79 Vdc 42 W 89.0% 0.96 0.95 EUC-042S053DS(PS)(3) 700 mA 90 ~ 305 Vac 28~56 Vdc 39 W 89.0% 0.96 0.95 EUC-042S070DS(PS)(4)(6) 1050 mA 90 ~ 305 Vac 20~38 Vdc 40 W 88.0% 0.96 0.95 EUC-042S105DS(PS)(5)(6) 1280 mA 90 ~ 305 Vac 17~32 Vdc 42 W 87.0% 0.96 0.95 EUC-042S128DS(PS)(5)(6) 1400 mA 90 ~ 305 Vac 15~30 Vdc 42 W 87.0% 0.96 0.95 EUC-042S140DS(PS)(5)(6) 1750 mA 90 ~ 305 Vac 12~24 Vdc 42 W 87.0% 0.96 0.95 EUC-042S175DS(PS)(5) Model Number Notes: (1) UL, FCC certified input voltage range: 100-277Vac; other certified input voltage range except UL, FCC: 100-240Vac. (2) Measured at full load and 220 Vac input. (3) Non-Class 2 output (USR & CNR). (4) Class 2 output (USR), Non-Class 2 output (CNR). (5) Class 2 output (USR & CNR). (6) Meet with KC Certification. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 V - 305 V Input Frequency 47 Hz - 63 Hz Notes 1 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 0.7 A Measured at full load and 100 Vac input. - - 0.3 A Measured at full load and 220 Vac input. - - 0.32 A s 0.90 - - - - 20% Parameter Min. Typ. Max. Output Current Tolerance -5% IO - 5% IO - - 132 V 104 V 87 V 59 V 42 V 37 V 34 V 27 V - - 50%IO Related to V-I Curve of the LED - - 10%IO At full load condition Line Regulation - - ±1% Measured at full load condition Load Regulation - - ±3% Measured at full load condition - 0.40 s 0.75 s Measured at 120Vac input, 75%load-100%load - 0.30 s 0.50 s Measured at 220Vac input, 75%load-100%load - - 0.2%/C 10.8 V 12 V 13.2 V 0 mA - 20 mA Leakage Current Input AC Current 2 Inrush Current(I t) Power Factor 2 At 220Vac input 25℃ Cold Start. Duration=200 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 75%-100%load(31.5~42W) THD Output Specifications No Load Output Voltage IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1280 mA IO = 1400 mA IO = 1750 mA Total Output Current Ripple (pk-pk) Output Current Overshoot / Undershoot Turn-on Delay Time Temperature Coefficient of Iomax 12V Auxiliary Output Voltage 12V Auxiliary Output Source Current Notes Case temperature = 0C ~Tc max Return terminal is “Dim-”. Note: All specifications are typical at 25°C unless otherwise stated. 2 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q General Specifications Parameter Efficiency at 120 Vac input: IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1280 mA IO = 1400 mA IO = 1750 mA Efficiency at 220 Vac input: IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1280 mA IO = 1400 mA IO = 1750 mA Efficiency at 277 Vac input: IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1280 mA IO = 1400 mA IO = 1750 mA No Load Power Dissipation MTBF Life Time Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Operating Case Temperature for Type TL Tc_TL Storage Temperature Min. Typ. Max. 87% 86% 86% 86% 85% 84% 84% 84% 89% 88% 88% 88% 86% 86% 85% 85% - 88% 87% 87% 87% 86% 85% 85% 85% 90% 89% 89% 89% 88% 87% 87% 87% - 88% 87% 87% 87% 86% 85% 85% 85% 90% 89% 89% 89% 88% 87% 87% 87% - - - 6W 327,000 Hours - - - 116,000 Hours - -40 ℃ - +90 ℃ -40 ℃ - +70 ℃ -40 ℃ -40 ℃ Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at full load and steady-state temperature in 25℃ ambient. Measured at full load and steady-state temperature in 25℃ ambient. Measured at full load and steady-state temperature in 25℃ ambient. Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 120Vac input, 80%Load and 60C Case temperature. See life time vs. Tc curve for the details Humidity: 10% RH to 100% RH. +72 ℃ - +85 ℃ Humidity: 5% RH to 100% RH 3.74 × 2.76 × 1.26 95 × 70 × 32 - 390 g - Note: All specifications are typical at 25C unless otherwise stated. 3 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the 0~10V Input Pin 0V - 15 V Source Current on 0~10V Input Pin 0 uA 200 uA 250 uA Dimming Output Range 10%Iomax Recommended Dimming Input Range 0V Notes 100%Iomax - 10 V Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750,UL 1310,CAN/CSA-C22.2 No. 250.13-12,CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655: 2011 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic Current Emissions EN 61000-3-3 Voltage Fluctuations & Flicker ANSI C63.4:2009 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 2 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment 4 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature Curve Inrush Current Waveform 5 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Efficiency vs. Load EUC-042S035DS(PS) EUC-042S045DS(PS) EUC-042S053DS(PS) EUC-042S070DS(PS) EUC-042S105DS(PS) EUC-042S128DS(PS) 6 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q EUC-042S140DS(PS) EUC-042S175DS(PS) Power Factor Characteristics Total Harmonic Distortion 7 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Dimming Control  0-10V Dimming The dimmer control may be operated from either a dimmer or from an input signal of 0 - 10 Vdc. The recommended implementation is provided below. Implementation 1: DC Input Implementation 2: External Resistor 8 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Implementation 3: External Resistor Notes: 1. Do not connect the Dim- to the V-, otherwise, the LED driver cannot work normally. 2. If 0-10V dimming is not used, Dim + can be either open or connected to Vaux. Mechanical Outline EUC-042SxxxDS EUC-042SxxxPS Tc Tc YELLOW PURPLE GRAY DIMMING WIRE (UL1015 22AWG) WHITE (ACN) BLACK (ACL) AC INPUT (UL1015 18AWG) WHITE BLACK (ACN) (ACL) BLACK RED (V+) (V-) DC OUTPUT (UL1015 18AWG) AC INPUT (UL 1015 AWG#18) BLACK RED (V+) (V-) DC OUTPUT (UL 1015 AWG#18) PROJ: PROJ: Unspecified tolerance:±1 Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 9 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Revision History Description of Change Change Date Rev. 2012-02-17 A Preliminary Datasheets First Release / / 2012-03-21 B EUC-042S105DS(PS) CUL Class 2 added / / EUC-042S105DS(PS)-0001 / Added EN 61000-4-5--- line to line 2 kV, line to earth 4 kV / Corrected Life time / 50,000 Hours EUC-042S070DS(PS)-0001 / Added EUC-042S070DS(PS)-0001, EUC-042S105DS(PS)-0001 / Deleted Notes of life time / Updated Life time vs. Tc Curve / Added 2012-05-25 2012-06-06 Item From To C D 2012-07-02 E Description of OTP / Updated 2012-07-17 F Max Case Temperature / Updated 2012-7-30 G Min Operating Temperature -20℃ -40℃ Derating Curve / Updated Inrush Current 60A 70A Inrush Current(I2t) / Added Temperature coefficient / Added Life time Min 50,000hrs Typical 116,000hrs Life time Curve / Updated Io/Ir Vs Rx Curve / Added THD Curve / Added EFF and PF Curve of other models / Added 2012-08-20 2012-11-16 H I 2 2013-05-22 2013-11-25 2014-05-27 J 2 2 Inrush Current(I t) corrected 0.16 A s 0.32 A s Duration of Inrush Current corrected 100 μs 200 μs Mechanical Outline---cable length corrected / Updated Model 530mA / Added Mechanical Outline-Dimming wires updated UL1015 26AWG UL1015 22AWG ENEC certificate / Added K L 10 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-042SxxxDS(PS) 42W Constant Current IP66 Driver Rev. Q Revision History (Continued) Change Date 2015-08-04 2015-12-31 2016-04-18 Description of Change Rev. Item From To Warranty Tc / Added Environmental Specifications / Deleted Inrush Current Waveform / Added CCC certificate / Added CQC certificate ./ Deleted Source Current on 0~10V Input Pin Max. 200 uA 250 uA KS Certification / Added KC Certification-EUC-042S070/105/128/140DS(PS) / Added Net Weight 350 g 390 g UL Type TL / Added KS Certificate Regulation / Added Note of EMI Standard / Added M N O 2016-08-02 P Turn-on Delay Time at 120Vac Max.=1.0 s Max.=0.75 s 2019-04-17 Q Mechanical Outline / Updated 11 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-042S045DS 价格&库存
很抱歉,暂时无法提供与“EUC-042S045DS”相匹配的价格&库存,您可以联系我们找货
