EUD-600S12ADT
EUD-600S12ADT
    INVENTRONICS(英飞特)
    600W 12A DIM 0-10
EUD-600S12ADT 数据手册
EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Features  Ultra High Efficiency (Up to 95.0%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes)  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  7 Years Warranty Description The EUD-600SxxxDT series is a 600W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, aquaculture and sports, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range 0.11–1.40A 1.10–1.40A 1.4 A 0.136-1.70A 1.36–1.70A 1.7A 0.168–2.10A 1.68–2.10A 2.1A 0.224-2.80A 2.24–2.80A 2.8 A 0.336-4.20A 3.36–4.20A 4.2 A 0.448-5.60A 4.48–5.60A 5.6 A 0.592-7.40A 5.92–7.40A 7.0 A 0.784-9.80A 7.84–9.80A 9.8 A 1.0 – 12.5 A 10 – 12.5 A 12.5 A Input Voltage Range(2) 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~300Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency Power (3) 120Vac 220Vac Model Number 214 ~ 545Vdc 600 W 95.0% 0.99 0.96 EUD-600S140DT 176 ~ 441Vdc 600 W 94.0% 0.96 0.95 EUD-600S170DT 143 ~ 357Vdc 600 W 94.5% 0.99 0.96 EUD-600S210DT 108 ~ 268Vdc 600 W 95.0% 0.99 0.96 EUD-600S280DT 72 ~ 178Vdc 600 W 94.5% 0.99 0.96 EUD-600S420DT 54 ~ 134Vdc 600 W 94.5% 0.99 0.96 EUD-600S560DT 41 ~ 101Vdc 600 W 94.0% 0.99 0.96 EUD-600S740DT (4) 31 ~ 76Vdc 600 W 94.0% 0.99 0.96 EUD-600S980DT (4) 24 ~ 60Vdc 600 W 94.0% 0.99 0.96 EUD-600S12ADT(4) 1 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Notes: (1) Output current range with constant power at 600W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output I-V Operating Area EUD-600S140DT EUD-600S170DT EUD-600S210DT EUD-600S280DT 330 (10%Ioset,600/Ioset) 220 oa d (2800,214) (Ioset,600/Ioset) Lo % 60 165 ad Output Voltage(V) (2240,268) 10 0% L (1344,268) 275 (224,268) (2800,129) 110 (280,108) 55 (Ioset,108) (2800,108) Good Performance Area Allowed Operating Area Programmed Operating Area 550 2200 0 0 1100 1650 2750 3300 Output Current (mA) Note: 2240mA Ioset 2800mA 2 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E EUD-600S420DT EUD-600S560DT EUD-600S740DT EUD-600S980DT EUD-600S12ADT % 60 ad Lo 3 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU - - 0.70 mA - - 6.0 A - - 3.5 A - - 4.70 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (450 - 600W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 110 mA 136 mA 168mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - 1400 mA 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA 1100 mA 1360 mA 1680 mA 2240 mA 3360 mA 4480 mA 5920 mA 7840 mA 10000 mA - 1400 mA 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load - - 10%Iomax 100% load Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 Notes 127-300Vdc UL8750; 277Vac/ 60Hz, grounding effectively IEC60598-1; 240Vac/ 60Hz, grounding effectively Measured at 100% load and 120 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input, 25℃ cold start, duration=7.64 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 60%-100% Load (360 - 600W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-600S140DT EUD-600S170DT EUD-600S210DT EUD-600S280DT EUD-600S420DT EUD-600S560DT EUD-600S740DT EUD-600S980DT EUD-600S12ADT Output Current Setting Range with Constant Power EUD-600S140DT EUD-600S170DT EUD-600S210DT EUD-600S280DT EUD-600S420DT EUD-600S560DT EUD-600S740DT EUD-600S980DT EUD-600S12ADT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Startup Overshoot Current 100% load 100% load, 20 MHz BW 4 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Output Specifications (Continued) Parameter Min. Typ. Max. No Load Output Voltage EUD-600S140DT EUD-600S170DT EUD-600S210DT EUD-600S280DT EUD-600S420DT EUD-600S560DT EUD-600S740DT EUD-600S980DT EUD-600S12ADT - 600 V 475 V 410 V 290 V 190 V 150 V 118 V 87 V 70 V 605V 480 V 415 V 295 V 200 V 155 V 120 V 95 V 80 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Turn-on Delay Time Temperature Coefficient of Ioset Notes 100% load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-600S140DT lo= 1100 mA lo= 1400 mA EUD-600S170DT Io= 1360 mA Io= 1700 mA EUD-600S210DT lo= 1680 mA lo= 2100 mA EUD-600S280DT Io= 2240 mA Io= 2800 mA EUD-600S420DT Io= 3360 mA Io= 4200 mA EUD-600S560DT Io= 4480 mA Io= 5600 mA EUD-600S740DT Io= 5920 mA Io= 7400 mA EUD-600S980DT Io= 7840 mA Io= 9800 mA EUD-600S12ADT lo= 10000 mA lo= 12500 mA Min. Typ. Max. 90.5% 90.0% 92.5% 92.0% - 90.0% 89.5% 92.0% 91.5% - 90.0% 89.5% 92.0% 91.5% - 91.0% 90.0% 93.0% 92.0% - 90.5% 89.5% 92.5% 91.5% - 90.0% 89.5% 92.0% 91.5% - 89.5% 89.0% 91.5% 91.0% - 90.0% 89.5% 92.0% 91.5% - 89.5% 89.0% 91.5% 91.0% - Notes Measured at100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 5 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E General Specifications (Continued) Parameter Efficiency at 220 Vac input: EUD-600S140DT lo= 1100 mA lo= 1400 mA EUD-600S170DT Io= 1360 mA Io= 1700 mA EUD-600S210DT lo= 1680 mA lo= 2100 mA EUD-600S280DT Io= 2240 mA Io= 2800 mA EUD-600S420DT Io= 3360 mA Io= 4200 mA EUD-600S560DT Io= 4480 mA Io= 5600 mA EUD-600S740DT Io= 5920 mA Io= 7400 mA EUD-600S980DT Io= 7840 mA Io= 9800 mA EUD-600S12ADT lo= 10000 mA lo= 12500 mA Efficiency at 277 Vac input: EUD-600S140DT lo= 1100 mA lo= 1400 mA EUD-600S170DT Io= 1360 mA Io= 1700 mA EUD-600S210DT lo= 1680 mA lo= 2100 mA EUD-600S280DT Io= 2240 mA Io= 2800 mA EUD-600S420DT Io= 3360 mA Io= 4200 mA EUD-600S560DT Io= 4480 mA Io= 5600 mA EUD-600S740DT Io= 5920 mA Io= 7400 mA EUD-600S980DT Io= 7840 mA Io= 9800 mA EUD-600S12ADT lo= 10000 mA lo= 12500 mA Min. Typ. Max. 92.5% 92.0% 94.5% 94.0% - 92.0% 92.0% 94.0% 94.0% - 92.5% 92.0% 94.5% 94.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 92.0% 94.5% 94.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.5% 94.0% 93.5% - 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 92.0% 94.5% 94.0% - 92.5% 92.0% 94.5% 94.0% - 93.0% 92.5% 95.0% 94.5% - 93.0% 92.0% 95.0% 94.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 91.5% 94.5% 93.5% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.5% 94.0% 93.5% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 6 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E General Specifications (Continued) Parameter Min. Typ. Max. Standby power - - 0.5 W MTBF - 200,000 Hours - Lifetime - 90,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 10.83× 5.67 × 1.91 275 × 144 × 48.5 9.84 × 5.67 × 1.91 250 × 144 × 48.5 - Notes 3515 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA EUD-600S140DT EUD-600S170DT EUD-600S210DT EUD-600S280DT EUD-600S420DT EUD-600S560DT EUD-600S740DT EUD-600S980DT EUD-600S12ADT 10%Ioset - Ioset EUD-600S140DT EUD-600S170DT EUD-600S210DT EUD-600S280DT EUD-600S420DT EUD-600S560DT EUD-600S740DT EUD-600S980DT EUD-600S12ADT 110 mA 136 mA 168 mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - Ioset Notes Vdim(+) = 0 V 1100 mA ≤ Ioset ≤ 1400 mA 1360 mA ≤ Ioset ≤ 1700 mA 1680 mA ≤ Ioset ≤ 2100 mA 2240 mA ≤ Ioset ≤ 2800 mA 3360 mA ≤ Ioset ≤ 4200 mA 4480 mA ≤ Ioset ≤ 5600 mA 5920 mA ≤ Ioset ≤7400 mA 7840 mA ≤ Ioset ≤ 9800 mA 10000 mA ≤ Ioset ≤ 12500 mA 110 mA ≤ Ioset < 1100 mA 136 mA ≤ Ioset < 1360 mA 168 mA ≤ Ioset <1680 mA 224 mA ≤ Ioset< 2240 mA 336 mA ≤ Ioset < 3360 mA 448 mA ≤ Ioset < 4480 mA 592 mA ≤ Ioset < 5920 mA 784 mA ≤ Ioset < 7840 mA 1000 mA ≤ Ioset < 10000 mA 7 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Dimming Specifications (Continued) Parameter Min. Typ. Max. 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV (2) 8 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Safety &EMC Compliance EMS Standards Notes EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 9 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Inrush Current Waveform Efficiency vs. Load EUD-600S140DT(Io=1100mA) EUD-600S140DT(Io=1400mA) EUD-600S170DT(Io=1360mA) EUD-600S170DT(Io=1700mA) 10 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E EUD-600S210DT(Io=1680mA) EUD-600S210DT(Io=2100mA) EUD-600S280DT(Io=2240mA) EUD-600S280DT(Io=2800mA) EUD-600S420DT(Io=3360mA) EUD-600S420DT(Io=4200mA) 11 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E EUD-600S560DT(Io=4480mA) EUD-600S560DT(Io=5600mA) EUD-600S740DT(Io=5920mA) EUD-600S740DT(Io=7400mA) EUD-600S980DT(Io=7840mA) EUD-600S980DT(Io=9800mA) 12 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E EUD-600S12ADT(Io=10000mA) EUD-600S12ADT(Io=12500mA) Power Factor Total Harmonic Distortion 13 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT 600W Programmable IP67 Driver Rev.E Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 14 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDT  600W Programmable IP67 Driver Rev.E PWM Dimming Implementation 2: Positive logic Implementation 3: Negative logic   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-600S12ADT 价格&库存
很抱歉,暂时无法提供与“EUD-600S12ADT”相匹配的价格&库存,您可以联系我们找货
