EUG-200S105DT
EUG-200S105DT
    INVENTRONICS(英飞特)
EUG-200S105DT 数据手册
EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Features • Ultra High Efficiency (Up to 94.0%) • Full Power at Wide Output Current Range (Constant Power) • 0-5V/0-10V/PWM/Timer Dimmable • Input Surge Protection: 6kV line-line, 10kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) and UL Dry / Damp / Wet Location • SELV Output • TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location • UL Type TL (Temperature Limited) • 7 Years Warranty Description The EUG-200SxxxDT series is a 200W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. It is created for high bay, high mast, arena and roadway lights. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 140-2100mA 1400-2100mA 1400 mA 127~300 Vdc 90~305 Vac/ 245-3500mA 2450-3500mA 2800 mA 127~300 Vdc 90~305 Vac/ 385-5600mA 3850-5600mA 4900 mA 127~300 Vdc 70-1050mA 700-1050mA 700 mA Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number (4) 95~286Vdc 200W 94.0% 0.99 0.96 EUG-200S105DT 48~143Vdc 200W 94.0% 0.99 0.96 EUG-200S210DT 29 ~ 82Vdc 200W 93.5% 0.99 0.96 EUG-200S350DT (5) 18 ~ 52Vdc 200W 92.5% 0.99 0.96 EUG-200S560DT (5) Notes: (1) Output current range with constant power at 200W (2) Certified voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to KS, except EUG-200S105DT (5) SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D I-V Operation Area EUG-200S105DT EUG-200S210DT EUG-200S350DT EUG-200S560DT Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 2.64 A Measured at full load and 100 Vac input. - - 1.20 A Measured at full load and 220 Vac input. - - 2.65 A s 0.9 - - THD - - 20% THD - - 10% Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 Notes 127~300 Vdc At 220Vac input, 25°C cold start, duration=1.36 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (140-200W) At 220-240Vac, 50-60Hz, 75%-100% Load (150-200W) 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Output Specifications Parameter Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 140 mA 245 mA 385 mA - 1050 mA 2100 mA 3500 mA 5600 mA 700 mA 1400 mA 2450 mA 3850 mA - 1050 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUG-200S105DT EUG-200S210DT EUG-200S350DT EUG-200S560DT - - 330 V 170 V 95 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Output Current Tolerance Output Current Setting(Ioset) Range EUG-200S105DT EUG-200S210DT EUG-200S350DT EUG-200S560DT Output Current Setting Range with Constant Power EUG-200S105DT EUG-200S210DT EUG-200S350DT EUG-200S560DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition. 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset Notes At full load condition Measured at full load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUG-200S105DT Io= 700mA Io=1050mA EUG-200S210DT Io=1400mA Io=2100mA EUG-200S350DT Io=2450mA Io=3500mA EUG-200S560DT Io=3850mA Io=5600mA Min. Typ. Max. 89.0% 88.0% 91.0% 90.0% - 89.5% 88.0% 91.5% 90.0% - 88.5% 87.0% 90.5% 89.0% - 88.0% 87.0% 90.0% 89.0% - Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 92.0% 90.5% 94.0% 92.5% - 91.5% 89.5% 93.5% 91.5% - 90.5% 89.5% 92.5% 91.5% - 92.5% 91.5% 94.5% 93.5% - 92.5% 91.0% 94.5% 93.0% - 91.5% 90.0% 93.5% 92.0% - 91.0% 90.0% 93.0% 92.0% - MTBF - 230,000 Hours - Lifetime - 95,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Operating Case Temperature for Type TL Tc_TL -40°C - +83°C Storage Temperature -40°C - +85°C Efficiency at 220 Vac input: EUG-200S105DT Io= 700mA Io=1050mA EUG-200S210DT Io=1400mA Io=2100mA EUG-200S350DT Io=2450mA Io=3500mA EUG-200S560DT Io=3850mA Io=5600mA Efficiency at 277 Vac input: EUG-200S105DT Io= 700mA Io=1050mA EUG-200S210DT Io=1400mA Io=2100mA EUG-200S350DT Io=2450mA Io=3500mA EUG-200S560DT Io=3850mA Io=5600mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details 1180 g Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Humidity: 5%RH to 100%RH With mounting ear 8.70 × 2.66 × 1.56 221 × 67.5 × 39.7 7.87 × 2.66 × 1.56 200 × 67.5 × 39.7 - Notes - Note: All specifications are typical at 25°C unless otherwise stated. 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA EUG-200S105DT EUG-200S210DT EUG-200S350DT EUG-200S560DT 10%Ioset - Ioset EUG-200S105DT EUG-200S210DT EUG-200S350DT EUG-200S560DT 70 mA 140 mA 245 mA 385 mA - Ioset 0V - 5V Dimming mode set to 0-5V in PC interface. 0V - 10 V Default 0-10V dimming mode with positive logic. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Dimming Output Range Recommended Dimming Range for 0-5V Recommended Dimming Range for 0-10V Dimming mode set to PWM in PC interface. PWM_in Duty Cycle Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Inrush Current Waveform Efficiency vs. Load EUG-200S105DT(Io=700mA) EUG-200S105DT(Io=1050mA) EUG-200S210DT(Io=1400mA) EUG-200S210DT(Io=2100mA) 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D EUG-200S350DT(Io=2450mA) EUG-200S350DT(Io=3500mA) EUG-200S560DT(Io=3850mA) EUG-200S560DT(Io=5600mA) Power Factor 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-5V Dimming The recommended implementation of the dimming control is provided below. V+(RED) L Vac N Inventronics LED Driver V-(BLU) Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) 0 - 5V Dimmer Implementation 1: Positive logic 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-5V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-5V dimming is not used, Dim + should be open. 4. When 0-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 4. When 0-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  PWM Dimming Implementation 5: Positive logic Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 11 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT  200W Programmable IP67 Driver Rev. D Time Dimming Set the timing curve by pulling the sliders. Programming Connection Diagram 12 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 (Programmer) datasheet for details. Mechanical Outline INPUT(UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL 21996 3*22AWG AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5.0) V+ (RED) V- (BLUE) BLACK/WHITE PURPLE GRAY Tc OUTPUT(UL SJTW 2*18AWG 7.3) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 13 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-200SxxxDT 200W Programmable IP67 Driver Rev. D Revision History Description of Change Change Date Rev. 2016-01-05 A 2016-04-07 2017-08-02 2017-10-26 Item B C D From To Datasheets Release / / Features / Updated General Specifications Operating Case Temperature for Type Added TL Tc_TL General Specifications With mounting ear Added General Specifications Net Weight Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Features / Updated Models / Updated Input Specifications PF/THD Updated Temperature Coefficient of Ioset / Updated Dimensions / Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Features 7 Years Warranty Added Operating Case Temperature for Warranty Tc_w / Updated 14 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUG-200S105DT 价格&库存
很抱歉,暂时无法提供与“EUG-200S105DT”相匹配的价格&库存,您可以联系我们找货
