EUK-320S220DT
EUK-320S220DT
    INVENTRONICS(英飞特)
EUK-320S220DT 数据手册
EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Features  Ultra High Efficiency (Up to 93.5%)  Full Power at Wide Output Current Range (Constant Power)  Isolated 0-10V/10V PWM Dimmable (DT models) 3-Timer-Modes Dimmable (TT models)  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67 and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUK-320SxxxDT(TT) series is a 320W, constant-current, programmable IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, aquaculture and sport, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range (1) Current Range 105-1500mA 1050-1500mA 1400 mA 154-2200mA 1540-2200mA 2100 mA 224-3200mA 2240-3200mA 2800 mA 322-4600mA 3220-4600mA 4200 mA 469-6700mA 4690-6700mA 6700 mA Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (5) 107~305Vdc 320 W 93.5% 0.99 0.96 EUK-320S150DT(TT) 73~208Vdc 320 W 93.5% 0.99 0.96 EUK-320S220DT(TT) 50~143Vdc 320 W 92.5% 0.99 0.96 EUK-320S320DT(TT) 35~100Vdc 320 W 92.5% 0.99 0.96 EUK-320S460DT(TT)(4) 24 ~ 68Vdc 320 W 92.5% 0.99 0.96 EUK-320S670DT(TT)(4) Notes: (1) Output current range with constant power at 320W. (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise: 100-240Vac or 127-250Vdc. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) All the models are certificated to KCC, except EUK-320SxxxTT. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D I-V Operating Area EUK-320S220DT(TT) EUK-320S320DT(TT) EUK-320S460DT(TT) Lo % 60 EUK-320S150DT(TT) ad EUK-320S670DT(TT) 78 (469,68) (2814,68) (4690,68) 65 (Ioset,320/Ioset) (10%Ioset,320/Ioset) 52 10 Lo % 60 oa d (6700,47.5) ad 39 0% L 26 (Ioset,24) (670,24) 13 (6700,28.5) (6700,24) Good Performance Area Allowed Operating Area Programmed Operating Area 1350 5400 0 0 2700 4050 6750 8100 Output Current (mA) Note: 4690mA Ioset 6700mA 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz,  - - 3.20 A - - 1.70 A - - 1.30 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 105 mA 154 mA 224 mA 322 mA 469 mA - 1500 mA 2200 mA 3200 mA 4600 mA 6700 mA 1050 mA 1540 mA 2240 mA 3220 mA 4690 mA - 1500 mA 2200 mA 3200 mA 4600 mA 6700 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUK-320S150DT(TT) EUK-320S220DT(TT) EUK-320S320DT(TT) EUK-320S460DT(TT) EUK-320S670DT(TT) - - 350 V 250 V 170 V 120 V 85 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 Notes 127~300 Vdc Measured at 100% load and 120 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input, 25C cold start, duration=3.92 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 60%-100%Load (192-320W) At 220-240Vac, 50-60Hz, 75%-100% Load (240-320W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUK-320S150DT(TT) EUK-320S220DT(TT) EUK-320S320DT(TT) EUK-320S460DT(TT) EUK-320S670DT(TT) Output Current Setting Range with Constant Power EUK-320S150DT(TT) EUK-320S220DT(TT) EUK-320S320DT(TT) EUK-320S460DT(TT) EUK-320S670DT(TT) Total Output Current Ripple (pk-pk) Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUK-320S150DT(TT) Io=1050mA Io=1500mA EUK-320S220DT(TT) Io=1540mA Io=2200mA EUK-320S320DT(TT) Io=2240mA Io=3200mA EUK-320S460DT(TT) Io=3220mA Io=4600mA EUK-320S670DT(TT) Io=4690mA Io=6700mA Efficiency at 220 Vac input: EUK-320S150DT(TT) Io=1050mA Io=1500mA EUK-320S220DT(TT) Io=1540mA Io=2200mA EUK-320S320DT(TT) Io=2240mA Io=3200mA EUK-320S460DT(TT) Io=3220mA Io=4600mA EUK-320S670DT(TT) Io=4690mA Io=6700mA Min. Typ. Max. 89.50% 89.00% 91.50% 91.00% - 89.00% 89.00% 91.00% 91.00% - 88.00% 88.00% 90.00% 90.00% - 88.50% 88.00% 90.50% 90.00% - 88.00% 87.00% 90.00% 89.00% - 91.50% 91.50% 93.50% 93.50% - 91.50% 91.50% 93.50% 93.50% - 90.50% 90.00% 92.50% 92.00% - 90.50% 90.00% 92.50% 92.00% - 90.50% 89.50% 92.50% 91.50% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Typ. Max. 92.00% 91.50% 94.00% 93.50% - 92.00% 91.50% 94.00% 93.50% - 90.50% 90.50% 92.50% 92.50% - 90.50% 90.50% 92.50% 92.50% - 91.00% 90.00% 93.00% 92.00% - MTBF - 282,000 Hours - Lifetime - 86,000 Hours - -40°C - +85°C -40°C - +75C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUK-320S150DT(TT) Io=1050mA Io=1500mA EUK-320S220DT(TT) Io=1540mA Io=2200mA EUK-320S320DT(TT) Io=2240mA Io=3200mA EUK-320S460DT(TT) Io=3220mA Io=4600mA EUK-320S670DT(TT) Io=4690mA Io=6700mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight With mounting ear 9.89 × 3.15 × 1.57 251 × 80 × 39.7 8.82 × 3.15 × 1.57 224 × 80 × 39.7 - Notes 1530 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter DT Models Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Recommended Dimming Range for 0-10V -20 V - 20 V 200 μA 300 μA 450 μA 0V - 10 V PWM_in High Level - 10V - PWM_in Low Level - 0V - PWM_in Frequency Range 200 Hz - 2 KHz PWM_in Duty Cycle 0% - 100% Notes Vdim(+) = 0 V 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Dimming Specifications (Continued) TT Models Parameter Min. Typ. Max. Dimming Level 10% - 100% Hold Time 0 Hours - 18 Hours Fade Time 0 Minutes - 60 Minutes 1 - 6 Dimming Step Dimming Output Range EUK-320S150DT(TT) EUK-320S220DT(TT) EUK-320S320DT(TT) EUK-320S460DT(TT) EUK-320S670DT(TT) 10%Ioset - Ioset EUK-320S150DT(TT) EUK-320S220DT(TT) EUK-320S320DT(TT) EUK-320S460DT(TT) EUK-320S670DT(TT) 105 mA 154 mA 224 mA 322 mA 469 mA - Ioset Notes Default is Traditional Timer. Dimming mode set to Self AdaptingMidnight or Self Adapting-Percentage in PC interface. 1050 mA ≤ Ioset ≤ 1500 mA 1540 mA ≤ Ioset ≤ 2200 mA 2240 mA ≤ Ioset ≤ 3200 mA 3220 mA ≤ Ioset ≤ 4600 mA 4690 mA ≤ Ioset ≤ 6700 mA 105 mA ≤ Ioset < 1050 mA 154 mA ≤ Ioset < 1540 mA 224 mA ≤ Ioset < 2240 mA 322 mA ≤ Ioset < 3220 mA 469 mA ≤ Ioset < 4690 mA Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 EAC ГОСТ Р МЭК 61347-1, ГОСТ IEC 61347-2-13 EMI Standards Notes (1) EN 55015/ KN 15 Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes ANSI C63.4 Class B EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV(2) EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Safety &EMC Compliance (Continued) EMS Standards EN 61547 Notes Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Inrush Current Waveform Efficiency vs. Load EUK-320S150DT(TT)(lo=1050mA) EUK-320S150DT(TT)(lo=1500mA) EUK-320S220DT(TT)(lo=1540mA) EUK-320S220DT(TT)(lo=2200mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D EUK-320S320DT(TT)(lo=2240mA) EUK-320S320DT(TT)(lo=3200mA) EUK-320S460DT(TT)(lo=3220mA) EUK-320S460DT(TT)(lo=4600mA) EUK-320S670DT(TT)(lo=4690mA) EUK-320S670DT(TT)(lo=6700mA) 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-320SxxxDT(TT) 320W Programmable IP67 Driver Rev. D Dimming  0-10V Dimming (Only DT models) The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2.  If 0-10V dimming is not used, Dim + should be open. 10V PWM Dimming (Only DT models) The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic Notes: If PWM dimming is not used, Dim + should be open.  Time Dimming (Only TT models) Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUK-320S220DT 价格&库存
很抱歉,暂时无法提供与“EUK-320S220DT”相匹配的价格&库存,您可以联系我们找货
