EUV-150S042ST
EUV-150S042ST
    INVENTRONICS(英飞特)
    EUC Series 150 W 3.57 A 42 V Outdoor LED Driver Module
EUV-150S042ST 数据手册
EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Features  High Efficiency (Up to 93%)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OVP, OCP, SCP, OTP  IP67 and UL Dry / Damp / Wet Location  SELV  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUV-150SxxxST series is a 150W, constant-Voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, over current, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Power Factor Efficiency 110Vac 220Vac (2) 12 Vdc 90 ~ 305 Vac 0~12.5 A 150 W 92% 0.99 0.96 EUV-150S012ST 24 Vdc 90 ~ 305 Vac 0~6.25 A 150 W 93% 0.99 0.96 EUV-150S024ST 36 Vdc 90 ~ 305 Vac 0~4.17 A 150 W 93% 0.99 0.96 EUV-150S036ST 42 Vdc 90 ~ 305 Vac 0~3.57 A 150 W 93% 0.99 0.96 EUV-150S042ST 48 Vdc 90 ~ 305 Vac 0~3.13 A 150 W 93% 0.99 0.96 EUV-150S048ST 54 Vdc 90 ~ 305 Vac 0~2.78 A 150 W 93% 0.99 0.96 EUV-150S054ST Model Number (3) Notes: (1) UL Certified input voltage range: 100-277Vac; otherwise 100-240Vac (except KS). (2) Measured at 100% load and 220 Vac input. (3) SELV output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz, grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively Leakage Current 1/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 1.93 A Measured at 100% load and 100 Vac input. - - 0.85 A Measured at 100% load and 220 Vac input - - 1.5 A s 0.90 - - - - 20% Min. Typ. Max. -2.5% - 2.5% -5% - 5% Ripple and Noise (pk-pk) - - 2% VO Output Overshoot / Undershoot - - 10% When power on or off. Line Regulation - - ±1% At 100% load condition. Load Regulation - - ±2% - 0.9 s 1.5 s Measured at 110Vac input, 100% Load - 0.5 s 1.0 s Measured at 220Vac input, 100% Load Output Deviation - - 5% VO Settling Time - - 10 mS - 0.03%/C - Parameter Min. Typ. Max. Efficiency at 110 Vac input: VO = 12 V VO = 24 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V 88% 89% 89% 89% 89% 89% 89% 90% 90% 90% 90% 90% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) Efficiency at 220 Vac input: VO = 12 V VO = 24 V VO = 36 V VO = 48 V VO = 42 V VO = 54 V 91% 92% 92% 92% 92% 92% 92% 93% 93% 93% 93% 93% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25℃ cold start, duration=1.2 ms, 10%Ipk-10%Ipk. At 100-277Vac, 50-60Hz, 100% Load THD Output Specifications Parameter Notes EUV-150S042ST. At 100% load condition. Output Voltage Tolerance Others. At 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Load Dynamic Response Temperature coefficient R/S: 1 A/ uS Load: 25% ~ 75% 100% load. Case temperature = 0C ~Tc max General Specifications 2/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S General Specifications (Continued) Parameter Min. Typ. Max. No Load Power Dissipation - - 3W MTBF - 260,900 hours - Lifetime - 77,200 hours - -35 °C - +90 C @90-305 Vac -40°C - +90 C @198-305 Vac -35 °C - +65 ºC -40 °C - +65 ºC -40 °C - +85 °C Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Notes Measured at 110Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 220Vac input, 80%Load and 60C case temperature; See life time vs. Tc curve for the details Dimensions Inches (L × W × H) Millimeters (L × W × H) - 1100 g Humidity: 5%RH to 100%RH With mounting ear 8.90 × 2.66 × 1.56 226 × 67.5 × 39.5 7.83 × 2.66 × 1.56 199 × 67.5 × 39.5 Net Weight @90-305 Vac, Case temperature for 5 years warranty @198-305 Vac, Case temperature for 5 years warranty - Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies to Lighting Equipment 3/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Curve Lifetime vs. Case Temperature Curve 4/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Protection Functions Parameter Min. Over Current Protection 110% IO Typ. 135% IO Max. Notes 200% IO Hiccup mode. The power supply shall be selfrecovery when the fault condition is removed. Over Temperature Protection Auto Recovery, returning to normal after over temperature is removed. Short Circuit Protection No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Mechanical Outline EUV-150S012ST INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*18AWG 7.8) AC/L (BLACK) AC/N (WHITE) GND (GREEN) 7.3) V+ (RED) V- (BLACK) Tc V+ (RED) V- (BLACK) PROJ: Unspecified tolerance:±1 Note: The 2 DC output cables are connected in parallel internally because one AWG #18 wire can only carry 10A. Please connect the 2 red wires together and 2 black wires together in application, or ensure each cable carries same current. 5/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Others INPUT (UL SJTW 3*18AWG 7.8) AC/L (BLACK) AC/N (WHITE) GND (GREEN) OUTPUT (UL SJTW 2*18AWG 7.3) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 6/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Revision History Description of Change Change Date Rev. 2009-08-14 A Change Max. Output Current and Efficiency. 2009-09-02 B Change MTBF and Life Time. 2009-09-11 C Change Turn-on Delay Time 2009-10-15 D Delete “UL1310 Class2” in Safety & EMC Compliance 2009-11-10 E Change notes of efficiency. Change “No Load Power Dissipation”. 2009-11-13 F Add the Mechanical Outline of 12V. 2009-12-16 G Add note for mechanical outline. / ☆: Popular model. H Add star rank for recommended models Add Leakage Current in Input Specifications Standardize the tolerance in Mechanical Outline / Max. 1 mA At 277Vac 50Hz input / / EUV-150S020ST / Add New Model 2010-05-31 2011-12-09 Item I From To Models VO = 40 V VO = 50 V VO = 52 V / VO = 56 V VO = 81 V VO = 105 V Deleted 0.6 s 1.0 s 0.9 s 1.5 s 0.3 s 0.6 s 0.5 s 1.0 s Turn-on delay time 2012-06-12 2012-7-17 2012-8-24 J K Efficiency of EUV-150S020ST @ 110 Vac / 1 % lower MTBF 584,000 Hours 250,000 Hours Life time / 50,000 Hours at Tc 60C Life time Curve / Added Mechanical outline / Updated Max Case Temperature / Updated EN61000-4-5 line to line 2 kV, line to earth 4 line to line 4 kV, line to earth 6 kV kV Min PF / Added Max THD / Added Temperature Co-efficient / Added 42V Model / Deleted / Added L 2 Inrush Current(I t) 7/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Revision History (Continued) Description of Change Change Date Rev. 2012-10-12 M 2013-01-18 2013-11-26 2015-09-11 2017/11/14 Item From To Life Time Typical Value 69,000 hours 77,200 hours Life Time Curve / Updated N No Load Power Dissipation 2W 3W O Input Specifications--Load Range of PF & THD 75%load-100%load 100%load Format / Updated External Grounding Screw Solution / / Features / Updated Description / Updated Models EUV-150S042ST Added Models EUV-150S020ST Delete General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature Added for Warranty Tc_w General Specifications Storage Temperature Added Environmental Specifications / Delete Safety & EMC Compliance / Updated Protection Functions / Updated Mechanical Outline / Updated KS / Added Features 5 years warranty Added Input Specifications Leakage Current Updated PF/THD Notes Updated Turn-on Delay Time Notes Updated Temperature coefficient Max 0.02%/C Typ 0.03%/C P Q General Specifications General Specifications Operating Case Temperature Updated for Safety Tc_s Operating Case Temperature Updated for Warranty Tc_w General Specifications With mounting ear Added Safety & EMC Compliance / Updated Mechanical Outline / Updated 8/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxST 150W Constant Voltage IP67 Driver Rev. S Revision History (Continued) Change Date 2019-03-18 2020-01-06 Description of Change Rev. Item R From To Header outdoor IP67 Description / Updated General Specifications - Net Weight 1000g 1100g Features 4kV line-line, 6kV line-earth DM 4kV, CM 6kV Features Waterproof (IP67) IP67 Safety &EMC Compliance EN 61000-4-5 Updated Derating Curve Ambient Temperature(°C) Deleted RoHS Compliance / Updated Format Page footer Updated S 9/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com
EUV-150S042ST 价格&库存
很抱歉,暂时无法提供与“EUV-150S042ST”相匹配的价格&库存,您可以联系我们找货
