EUV-300S024ST
EUV-300S024ST
    INVENTRONICS(英飞特)
    EUV Series 300 W 24 V Outdoor Constant Voltage LED Driver Module
EUV-300S024ST 数据手册
EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S Features  High Efficiency (Up to 93.0%)  Constant Voltage Output  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OVP, OCP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location Description The EUV-300SxxxST series is a 300W, constant-voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, sports and roadway. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, over current, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Power Factor Efficiency 110Vac 220Vac (2) 12 Vdc 90 ~ 305 Vac 0~22.9 A 275 W 91.5% 0.99 0.93 EUV-300S012ST 24 Vdc 90 ~ 305 Vac 0~12.5 A 300 W 91.0% 0.99 0.96 EUV-300S024ST 28 Vdc 90 ~ 305 Vac 0~10.71 A 300 W 91.5% 0.99 0.96 EUV-300S028ST 36 Vdc 90 ~ 305 Vac 0~8.33 A 300 W 92.0% 0.99 0.96 EUV-300S036ST 42 Vdc 90 ~ 305 Vac 0~7.14 A 300 W 92.0% 0.99 0.96 EUV-300S042ST 48 Vdc 90 ~ 305 Vac 0~6.25 A 300 W 92.5% 0.99 0.96 EUV-300S048ST 54 Vdc 90 ~ 305 Vac 0~5.56 A 300 W 93.0% 0.99 0.96 EUV-300S054ST Model Number (3) Notes: (1) Certified input voltage range: UL 100-277Vac; otherwise 100-240Vac (2) Measured at 100% load and 220 Vac input. (3) SELV output Input Specifications Parameter Min. Typ. Max. Notes Input Voltage Range 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.75 mA At 277Vac 60Hz input , grounding effectively - - 3.6 A Measured at 100% load and 100 Vac input. - - 1.6 A Measured at 100% load and 220 Vac input. Input AC Current 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S Input Specifications (Continued) Parameter Min. Typ. Max. - - 2.33 A s 0.90 - - - - 20% Min. Typ. Max. Output Voltage Tolerance -5% - 5% Ripple and Noise (pk-pk) - - 2%VO - - 10% When power on or off. Line Regulation - - ±1% At 100% load condition. Load Regulation - - ±3% - 0.4 s 1.0 s Measured at 110Vac input,75%-100%load - 0.4 s 1.0 s Measured at 220Vac input,75%-100%load Output Deviation - - 5% VO Settling Time - - 10 mS - - 0.02%/C 2 Inrush Current(I t) Power Factor THD 2 Notes At 220Vac input, 25℃ cold start, duration=3 ms, 10%Ipk-10%Ipk. At 100-277Vac, 50-60Hz,75%-100% load (225-300W) Output Specifications Parameter Output Overshoot/ Undershoot Notes At 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Load Dynamic Response Temperature Coefficient R/S: 1 A / uS Load: 25% ~ 75% load. Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. General Specifications Parameter Min. Typ. Max. Efficiency at 110 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Efficiency at 220 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V 89.0% 88.5% 89.0% 89.5% 90.5% 90.5% 91.0% 89.5% 89.0% 89.5% 90.0% 91.0% 91.0% 91.5% - 91.0% 90.5% 91.0% 91.5% 91.5% 92.0% 92.5% 91.5% 91.0% 91.5% 92.0% 92.0% 92.5% 93.0% - No Load Power Dissipation - - 5W MTBF - 278,000 hours - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) Measured at 110Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S General Specifications (Continued) Parameter Min. Typ. Max. Notes - 58,000 hours - Measured at 220Vac input, 80%Load ,Case temperature=60℃ @ Tc point. See life time vs. Tc curve for the details -40 C - +90 C -40 C - +60 C -40 C - +85 C Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 9.88 × 3.86 × 1.75 251 × 98 × 44.5 8.82 × 3.86 × 1.75 224 × 98 × 44.5 Net Weight - 1700g Humidity: 5% RH to 100% RH - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S Derating Curve EUV-300S012ST Others Lifetime vs. Case Temperature Curve Protection Functions Parameter Over Current Protection Min. Typ. Max. Notes 130% IO 165% IO 200% IO Hiccup mode. The power supply shall be selfrecovery when the fault condition is removed. Over Temperature Protection Auto Recovery, returning to normal after over temperature is removed. Short Circuit Protection No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S Mechanical Outline EUV-300S012ST AC INPUT (UL SJTW 3*18AWG) DC OUTPUT (UL SJTW 2*18AWG) RED (V+) BLACK (V-) WHITE (ACN) BLACK (ACL) GREEN (GND) PROJ: Unspecified tolerance:±1 Note: The 3 DC output cables are connected in parallel internally because one AWG #18 wire can only carry 10A. Please connect the 3 red wires together and 3 black wires together in application, or ensure each cable carries same current. EUV-300S024/036/042ST DC OUTPUT (UL SJTW 2*18AWG) AC INPUT (UL SJTW 3*18AWG) RED (V+) BLACK (V-) WHITE (ACN) BLACK (ACL) GREEN (GND) PROJ: Unspecified tolerance:±1 Note: The 2 DC output cables are connected in parallel internally because one AWG #18 wire can only carry 10A. Please connect the 2 red wires together and 2 black wires together in application, or ensure each cable carries same current. 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S EUV-300S028ST DC OUTPUT (UL SJTW 2*14AWG) AC INPUT (UL SJTW 3*18AWG) RED (V+) BLACK (V-) WHITE (ACN) BLACK (ACL) GREEN (GND) PROJ: Unspecified tolerance:±1 Others AC INPUT (UL SJTW 3*18AWG) DC OUTPUT (UL SJTW 2*18AWG ) RED (V+) BLACK (V-) WHITE (ACN) BLACK (ACL) GREEN (GND) PROJ: Unspecified tolerance:± RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S Revision History Change Date Description of Change Rev. Item From To Delete “UL1310 Class2” in Safety & EMC Compliance Change the efficiency of 12V. Change the Max. Output Current and Power of 12V. Change the description of Short Circuit Protection 2009-10-15 A 2009-10-23 B 2009-11-10 C Change notes of efficiency. 2009-12-04 D Update Mechanical Outline. 2009-12-16 E Add note for mechanical outline. Add a new model of 28V 2010-03-11 F Add Leakage Current in Input Specifications Standardize the tolerance in Mechanical Outline / Max. 0.75 Ma At 277Vac 50Hz input / / 2010-05-31 G Add star rank for recommended model / ☆: Popular model. 2011-01-14 H Update MTBF & Life Time Data For One Model For Two Models MTBF Delete 24V Add 28V 2011-07-20 I Life Use Tcase data to replace the old test condition Notes of Life time / / VO = 150 V 91.5% 93.0% 94.0% 94.0% 93.5% 93.5% 93.5% 94.0% 94.0% 94.0% 94.0% 94.0% 94.0% 91.5% 91.0% 91.5% 92.0% 93.0% 93.5% 93.5% 94.0% 94.0% 94.0% 94.0% 94.0% 94.0% Life time & MTBF / Corrected 2012-3-27 J Typ. Efficiency @220 Vac 2012-5-04 VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 52 V VO = 54 V VO = 56 V VO = 60 V VO = 84 V VO = 105 V H Models 2012-06-13 I VO = 42 V VO = 52 V VO = 56 V / VO = 60 V VO = 84 V VO = 105 V Deleted VO = 150V Life time curve / Added Mechanical Outline / Updated EN61000-4-5 line to line 2 kV, line to earth 4 kV line to line 4 kV, line to earth 6 kV 2012-7-17 J Max Case Temperature / Updated 2012-8-10 K Life time / Updated Operating Temperature -35 ℃ -40 ℃ 2012-11-15 L Derating Curve / Updated 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxST 300W Constant Voltage IP67 Driver Rev. S Revision History (Continued) Change Date 2013-01-05 Description of Change Rev. Item M From To Inrush current 50° 150° Min PF and max THD / Added Temperature coefficient / Added MTBF Min 250,000 hours Typ.278,000 hours Life time Min 50,000 hours Typ.58,000 hours Life time curve / Updated Input AC current@100Vac Max 3.3° Typ3.3°, Max3.5° 2013-02-26 N Efficiency of 48V, 54V / 0.5%lower 2013-03-11 O Over Current Protection 110%,155%,180% 130%,165%,200% 2013-12-13 P Turn-on delay time 0.1s,0.2s 0.4s,1.0s Derating curve / Updated Derating curve of EUV-300S012ST / Added Mechanical outline of EUV200S012ST / Updated Format / Updated External Grounding Screw Solution / / Features / Updated Description / Updated Models EUV-300S042ST Added General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature for Warranty Tc_w Added Safety & EMC Compliance / Updated Mechanical Outline / Updated Header outdoor IP67 Description / Updated Models notes Updated Input Specifications Power Factor/ THD Updated General Specifications - Net Weight 1540g 1700g General Specifications With mounting ear Added Safety & EMC Compliance Note Added 2014-09-25 2015-09-07 2019-03-01 Q R S 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-300S024ST 价格&库存
很抱歉,暂时无法提供与“EUV-300S024ST”相匹配的价格&库存,您可以联系我们找货
