EUW-060D105DF
EUW-060D105DF
    INVENTRONICS(英飞特)
EUW-060D105DF 数据手册
EUW-060DxxxDx 60W Programmable IP66/IP67 Tunable White Driver Rev.B Features  Adjust color temperature continuously  Adjust intensity and color temperature separately  60W Max each channel with total 60W load  1% Min each channel with total 10% Min dimming  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 1-5V/1-10V/10V PWM/3-Timer-Modes Dimmable  Flicker free  Output Lumen Compensation  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OVP, SCP, OTP  IP66 / IP67 (DV model) IP66 and UL Dry / Damp Location (DF model)  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUW-060DxxxDx series is a 60W, constant-current, programmable IP66/IP67 LED driver that operates from 90-305Vac input with excellent power factor. Created to enhance tunnel, low bay, signage, or wall pack type applications by offering a simplified white color tuning solution. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range (1) Current Range Input Voltage Range(2) Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 120Vac 220Vac 90~305 Vac/ 28~86 Vdc 60W 89.0% 0.99 0.96 127~300 Vdc Notes: (1) Output current range with constant power at 60W (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details) (4) SELV Output (5) x = V is CCC and CE model; x = F are UL Recognized model 7-1050mA 700-1050mA 700 mA 1 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Model Number (4) EUW-060D105Dx All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx 60W Programmable IP66/IP67 Tunable White Driver Rev.B I-V Operation Area EUW-060S105Dx 120 (7,86) 80 (700,86) (525,86) 10 (1%Ioset,60/Ioset) (Ioset,60/Ioset) 0% % 75 60 Lo ad ad Lo Output Voltage(V) 100 (1050,57) (1050,42.8) 40 20 (10.5,28) (1050,28) (Ioset,28) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 210 420 630 840 1050 1260 Output Current (mA) Note: 700mA≤Ioset≤1050mA Input Specifications Parameter Min. Typ. Max. Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, - - 0.66 A Measured at 100% load and 120 Vac input. - - 0.35 A Measured at 100% load and 220 Vac input. - - 0.01 A2s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (45-60W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 7 mA - 1050 mA 700 mA - 1050 mA - 5%Iomax 10%Iomax Leakage Current Input AC Current Inrush Current(I2t) PF Notes At 220Vac input, 25C cold start, duration=1.32 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 75%-100% Load (45-60W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUW-060D105Dx Output Current Setting Range with Constant Power EUW-060D105Dx Total Output Current Ripple (pk-pk) 2 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 At 100% load condition At 100% load condition. 20 MHz BW All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx 60W Programmable IP66/IP67 Tunable White Driver Rev.B Output Specifications (Continued) Parameter Min. Typ. Max. Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUW-060S105Dx - - 120 V Line Regulation - - ±1% Load Regulation - - ±5% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.06%/C - Min. Typ. Max. Notes At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 120-277Vac input, 75%-100% Load Case temperature = 0C ~Tc max General Specifications Parameter Efficiency at 120 Vac input: EUW-060S105Dx Io= 700 mA Io=1050 mA Efficiency at 220 Vac input: EUW-060S105Dx Io= 700 mA Io=1050 mA Efficiency at 277 Vac input: EUW-060S105Dx Io= 700 mA Io=1050 mA Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details 85.0% 82.5% 87.0% 84.5% - 87.0% 84.5% 89.0% 86.5% - 86.0% 84.0% 88.0% 86.0% - MTBF - 522,000 Hours - Lifetime - 106,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +80C Case temperature for 5 years warranty Humidity: 10%RH to 95%RH Storage Temperature -40°C - +85°C Humidity: 5%RH to 95%RH Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight - 612 g - 3 / 12 Specifications are subject to changes without notice. www.inventronics-co.com With mounting ear 5.59 × 2.52 × 1.44 142 × 64 × 36.5 4.92 × 2.52 × 1.44 125 × 64 × 36.5 Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx 60W Programmable IP66/IP67 Tunable White Driver Rev.B Dimming Specifications Parameter Min. Typ. Max. -20 V - 20 V 80 uA 130 uA 180 uA 1%Ioset - Ioset 700 mA ≤ Ioset ≤ 1050 mA 7 mA - Ioset 7 mA ≤ Ioset < 700 mA 0.25 V - 4.75 V 0 - 5 CCT:I1 off Voltage 4.35 4.5 4.65 CCT:I1 on Voltage 4.15 4.3 4.45 CCT:I2 off Voltage 0.35 0.5 0.65 CCT:I2 on Voltage 0.55 0.7 0.85 Recommended Dimming Range for 1-10V 1V - 9V 0 - 9V CCT:I1 off Voltage 8.35 8.5 8.65 CCT:I1 on Voltage 8.15 8.3 8.45 CCT:I2 off Voltage 0.35 0.5 0.65 CCT:I2 on Voltage 0.55 0.7 0.85 PWM_in High Level - - 10V PWM_in Low Level - 0V - 200 Hz - 2 KHz PWM_in Duty Cycle 0% - 100% CCT:I1 off Voltage 83% 85% 87% CCT:I1 on Voltage 81% 83% 85% CCT:I2 off Voltage 3% 5% 7% CCT:I2 on Voltage 5% 7% 9% Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming EUW-060S105Dx Output EUW-060S105Dx Range Recommended Dimming Range for 1-5V CCT Range for 0-5V CCT Range for 0-10V PWM_in Frequency Range Notes Vdim(+) = 0 V, Dimming mode set to 1-5V in PC interface. Default 1-10V dimming mode with positive logic. Notes: (1) I1 current flows between V+ and V1-; (2) I2 current flows between V+ and V2-. Safety &EMC Compliance Safety Category UL/CUL CCC CE Standard UL8750,CAN/CSA-C22.2 No. 250.13 GB 19510.1, GB 19510.14 EN 61347-1, EN 61347-2-13 4 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx Rev.B 60W Programmable IP66/IP67 Tunable White Driver Safety &EMC Compliance (Continued) EMI Standards EN 55015/GB 17743(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 5 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx Rev.B 60W Programmable IP66/IP67 Tunable White Driver Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUW-060D105DV(lo=700 mA) EUW-060D105DV(lo=1050 mA) 6 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx Rev.B 60W Programmable IP66/IP67 Tunable White Driver Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  1-5V Dimming The recommended implementation of the dimming control is provided below which shows total output current in dimming voltage related diagram and I1(black), I2(blue) distribution in CCT voltage related diagram based on full power. 7 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx V+ L N 60W Programmable IP66/IP67 Tunable White Driver Rev.B Vac V1V2- Inventronics LED Driver I1 I2 CCT Dim+ G DimDimmer Dimmer Implementation 1: Positive logic V+ L N Vac V1V2- Inventronics LED Driver I1 I2 CCT Dim+ G DimDimmer Dimmer Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 1-5V voltage source signal or passive components like zener. 3. When 1-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  1-10V Dimming The recommended implementation of the dimming control is provided below which shows total output current in dimming voltage related diagram and I1(black), I2(blue) distribution in CCT voltage related diagram based on full power. V+ L N Vac Inventronics LED Driver G V1V2- I1 I2 CCT Dim+ DimDimmer Dimmer Implementation 3: Positive logic 8 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUW-060DxxxDx V+ L N 60W Programmable IP66/IP67 Tunable White Driver Rev.B Vac V1V2- Inventronics LED Driver I1 I2 CCT Dim+ G DimDimmer Dimmer Implementation 4: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 1-10V voltage source signal or passive components like zener. 3. When 1-10V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  10V PWM Dimming The recommended implementation of the dimming control is provided below which shows total output current in PWM duty cycle related diagram and I1(black), I2(blue) distribution in CCT voltage related diagram based on full power. V+ V1- L Vac N Inventronics LED Driver I1 I2 V2CCT Dim+ G PWM Signal Dim- Implementation 5: Positive logic V+ V1- L Vac N G Inventronics LED Driver V2- I1 I2 CCT Dim+ Dim- PWM Signal Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will output maximum current.  Time Dimming for Dim and CCT Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUW-060D105DF 价格&库存
很抱歉,暂时无法提供与“EUW-060D105DF”相匹配的价格&库存,您可以联系我们找货
EUW-060D105DF
    EUW-060D105DF
