CNV-SNAP-DD2
CNV-SNAP-DD2
    INVENTRONICS(英飞特)
CNV-SNAP-DD2 数据手册
CNV-SNAP-DD2 Rev. B Wireless Network Interface Module for Synapse Networks Features  Compatible with Synapse SimplySNAP  DALI-2 Compatible  0-10V Dimming  2 DC Sensor Inputs, Occupancy/Motion, Photocell, or Switch  Powered by Driver Auxiliary Supply  Convenient Mounting Options: Inside or Outside Luminaire  Indoor / Outdoor - Rated for IP65 and UL Dry/Damp/Wet Location  Suitable for Direct Sunlight Applications  Supports Driver Dim-to-Off  External Antenna, with Range up to 1km* Description The CNV-SNAP-DD2 wireless control module opens an exciting integration path for LED luminaires. This compact, DC powered wireless controller is versatile enough to be embedded in nearly any size LED luminaire. The mounting bracket and 1/2” NPT mount allows for ease of installation. The CNV-SNAP-DD2 features two sensors inputs that can control an individual light or a zone of lights and are configurable using Synapse SimplySNAP software. Pairing the CNV-SNAP-DD2 with a SimplySNAP Gateway makes it easy for users to comply with Title 24, ASHRAE 90.1, and other energy saving requirements for today and in the future. The CNV-SNAP-DD2 is DALI D4i compatible, allowing for the ability to read information from D4i certified LED drivers. Also included is a 0-10V dimming interface to allow for use with traditional Controls Ready drivers. This control module operates at 2.4GHz and is FCC certified. For added flexibility, an antenna bulkhead is utilized to facilitate the use of an external antenna, offering an effective range of approximately 1km*. The CNV-SNAPDD2 is an ideal solution for applications including high bay, stadium, horticulture, mast, and parking lot lighting. Synapse Illuminate  *With compatible antenna. Antenna not included. 1/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com CNV-SNAP-DD2 Wireless Network Interface Module for Synapse Networks Rev. B Models P/N CNV-SNAP-DD2 Connection to LED Driver Connection to Synapse System UL Wire (BLACK/WHITE, PURPLE/WHITE, GRAY/WHITE, PURPLE, GRAY, YELLOW, SNAP Mesh Network ORANGE) Input Specifications Parameter Min. Typ. Max. 5V 12 V 24 V - 60 mA - 0V - 10 V Dim+ Sink Current 0 mA - 10 mA DALI-2 Bus Voltage - 16 V 22.5 V DALI-2 Bus Current - - 250 mA Sensor A+ 0V - 24 V Sensor B+ 0V - 24 V Min. Typ. Max. Vaux Voltage Iaux (Vaux Current) at 12V Dim+ Voltage Notes Support the maximum output current of LED driver to 100%Io 0.7W Max. Analog: 0-10V; Digital: 0-24V Selectable in SimplySNAP software General Specifications Parameter Notes Dimensions Inches (L × W × H) Millimeters (L × W × H) 3.62 x 2.71 x 1.14 92 x 69 x 29 Net Weight Without the bracket - 230 g - With the bracket and nut Min. Typ. Max. Operating Temperature -40 C - +70 C Humidity: 10% RH to 95% RH; Storage Temperature -40 C - +85 C Humidity: 5% RH to 95% RH; Environmental Specifications Parameter Notes Radio Specifications  Synapse SNAP 2.4GHz; 802.15.4  +20 dBm Transmit Power  -103 dBm Receive Sensitivity 2/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com CNV-SNAP-DD2 Rev. B Wireless Network Interface Module for Synapse Networks Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, CAN/CSA-C22.2 No. 250.13 EN 61347-2-11, EN 61347-1, EN 62479, ETSI EN 300 220-1 V2.4.1, ETSI EN 300 220-2 V2.4.1, ETSI EN 301 489-1 V1.9.2, ETSI EN 301 489-3 V1.6.1 CE EMI Standards (1) EN 55022 Notes Conducted emission Test & Radiated emission Test ANSI C63.4 Class B This device complies with Part 15 of the FCC Rules. Operation is subject to the (1) FCC Part 15 following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS Note: (1) The CNV-SNAP-DD2 is considered as a component that will be operated in combination with final equipment. since EMI performance without the bracket will be affected by the complete installation, the final equipment manufacturers must re-qualify EMI Directive on the complete installation again. Function Definition of Interface (Connection to LED Driver) Wire Color Name Description BLACK/WHITE Vaux Input from driver’s 12V or 24V auxiliary power PURPLE/WHITE Dim+ The dimming signal output to control the driver GRAY/WHITE Dim- Return for Vaux, Dim+, Sensor A, and Sensor B PURPLE DA+ DALI-2 Bus + GRAY DA- / Return DALI-2 Bus - / Return YELLOW Sensor A+ Sensor A Input ORANGE Sensor B+ Sensor B Input 3/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com CNV-SNAP-DD2 Rev. B Wireless Network Interface Module for Synapse Networks Wiring D4i Enabled LED Driver Wiring Diagram 0-10V Controls Ready Driver Diagram Note: It is required to terminate any unused connections. Operation Notes   For more operation details, check https://help.synapsewireless.com/ Please note that for any Synapse network to operate, a SimplySNAP Site Controller is required. 4/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com CNV-SNAP-DD2 Wireless Network Interface Module for Synapse Networks Rev. B Antenna Installation     Antennas need to be installed properly. Using a wrench will break the pin in the bulkhead. RP-SMA antennas are required, and SMA antennas cannot be used or substituted. For more information on best practices for antenna installation, see: https://help.synapsewireless.com/resources/best-practices/simplysnap-install.html For installation instructions, please see CNV-SNAP-DD2 Installation Notes Recommended Antennas Manufacturer Part Number Manufacturer Application HGT Inch Antenna Type Avg Gain (dBi) W1027 Pulse Articulating Indoor 4.9 Dipole 3.2 W5010 Pulse Straight Outdoor 5.12 Dipole 1.5 W5001 Pulse Right Angle Outdoor 5.04 Dipole 1.5 *An antenna is not included with CNV‐SNAP‐DD2.   Compatible Driver List  Compatible driver list please refer to the: CNV-SNAP-DD2 Compatible List Compatible Sensor Lists  Compatible Motion Sensors  Compatible Photocell Sensors  Compatible Daylight Harvesting Sensors Mechanical Outline DIMMING WIRE (UL 21996 7*22 AWG 6.5) YELLOW ORANGE GRAY/WHITE PURPLE GRAY PURPLE/WHITE BLACK/WHITE PROJ: Unspecified tolerance:±1 5/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com CNV-SNAP-DD2 Rev. B Wireless Network Interface Module for Synapse Networks RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 6/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com CNV-SNAP-DD2 Wireless Network Interface Module for Synapse Networks Rev. B Revision History Description of Change Change Date Rev. 2020-12-22 A 2021-03-25 Item B From To Datasheet Release / / Product image / Updated Wiring - D4i Enabled LED Driver Wiring Diagram / Updated Wiring - 0-10V Controls Ready Driver Diagram / Updated 7/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com
CNV-SNAP-DD2 价格&库存
很抱歉,暂时无法提供与“CNV-SNAP-DD2”相匹配的价格&库存,您可以联系我们找货
CNV-SNAP-DD2
