EBS-080S150BT2
EBS-080S150BT2
    INVENTRONICS(英飞特)
EBS-080S150BT2 数据手册
EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B Features • Full Power at Wide Output Current Range (Constant Power) • Adjustable Output Current (AOC) with NFC • DALI-2 and D4i Certified • AC Dim/3-Timer-Modes Dimmable • Dim-to-Off with Standby Power ≤ 0.5 W • Always-on Auxiliary Power: 24Vdc, 125mA, 3W (Transient Peak Power up to 10W) • Integrated 16Vdc Bus Power Supply Based on DALI-2 • Integrated Power Monitoring with High Accuracy up to ±1% • Output Lumen Compensation • End-of-Life Indicator • Thermal Sensing and Protection for LED Module • Long Lifetime Over 100K Hours at 75°C Case Temperature • • Input Surge Protection: DM 6 kV, CM 10 kV All-Around Protection: IUVP, IOVP, OVP, SCP, OTP • IP20 Design and Suitable for Outdoor Applications in Luminaires with IP>54 • Suitable for Luminaires with Protection Class I and II • Complies with Zhaga Interface Specification Book 13 • 8 Year Warranty Description The EBS-080SxxxBT2 series is a 80W, constant-current, NFC programmable and IP20 rated LED driver that operates from 176-305 Vac input with excellent power factor. Created for many lighting applications including street, tunnel and low bay, etc., this family provides integrated AC power monitoring with an auxiliary voltage and dim-to-off functionality for powering low voltage, wireless controls. The dimming control supports two-way communication via DALI-2 and complies with D4i. The high efficiency of these drivers and better thermal design enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature of both the driver and the external LED array. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current Input Voltage Range(2) Output Voltage Range Typical Max. Typical Power Output Efficiency Factor Power (3) (3) 45-700mA 450-700mA 530 mA 176~305 Vac 171~275 Vdc 57~178Vdc 80 W 92.5% 0.98 EBS-080S070BT2 70-1050mA 700-1050mA 700 mA 176~305 Vac 171~275 Vdc 38~114Vdc 80 W 92.5% 0.98 EBS-080S105BT2 105-1500mA 1050-1500mA 1050 mA 176~305 Vac 171~275 Vdc 27 ~ 76Vdc 80 W 92.0% 0.98 EBS-080S150BT2 Model Number (5) (4) (4) Notes: (1) Output current range with constant power at 80W. (2) CCC certified input voltage range: 220-240 Vac; other certified input voltage range except CCC: 200-240 Vac. (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) All the models are certificated to BIS, except EBS-080S070BT2. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B I-V Operating Area EBS-080S070BT2 EBS-080S105BT2 EBS-080S150BT2 Input Specifications Parameter Min. Typ. Max. Input AC Voltage 176 Vac - 305 Vac Input DC Voltage 171 Vdc - 275 Vdc Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.44 A 2 - - 1.84 A s 0.90 - - Inrush Current(I t) PF 2 Notes IEC60598-1; 240Vac/60Hz Measured at 100%load and 220 Vac input. At 220Vac input, 25°C Cold Start, Duration =256 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 200-240Vac, 50-60Hz, 60%-100%load (48-80W) 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B Input Specifications (Continued) Parameter Min. Typ. Max. Notes THD - - 20% At 200-240Vac, 50-60Hz, 60%-100%load (48-80W) THD - - 10% At 220-240Vac, 50-60Hz, 70%-100%load (56-80W) Min. Typ. Max. -5%Ioset - 5%Ioset 45 mA 70 mA 105 mA - 700 mA 1050 mA 1500 mA 450 mA 700 mA 1050 mA - 700 mA 1050 mA 1500 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EBS-080S070BT2 EBS-080S105BT2 EBS-080S150BT2 - - 210 V 120 V 90 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% - - 0.5 s - - 1.0 s - 0.03%/°C - 24V Auxiliary Output Voltage 21.6 V 24 V 26.4 V 24V Auxiliary Output Source Current 0 mA - 125 mA 24V Auxiliary Output Transient Peak Current @ 6W - - 250 mA 24V Auxiliary Output Transient Peak Current @ 10W - - 425 mA 12 Vdc 16 Vdc 20 Vdc Voltage is depending on loading. 50 mA - 60 mA Return terminal is “DA−“ Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EBS-080S070BT2 EBS-080S105BT2 EBS-080S150BT2 Output Current Setting Range with Constant Power EBS-080S070BT2 EBS-080S105BT2 EBS-080S150BT2 Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Integrated DALI-2 Bus Power Supply Voltage Integrated DALI-2 Bus Power Supply Current At 100%load condition At 100%load condition, 20 MHz BW At 100%load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset Notes At 100%load condition Measured at 100%load Measured at all dimming modes except DALI2, and 220Vac input, 60%-100%load Measured at DALI-2 dimming mode, and 220Vac input, 60%-100%load Case temperature = 0°C~Tc max Return terminal is “DA−“ 250mA peak for a maximum duration of 2.2m s in a 6.0ms period during which time the aver age should not exceed 125mA. 425mA peak for a maximum duration of 1.3m s in a 5.2ms period during which time the aver age should not exceed 125mA. Notes: (1) DALI-2 bus power supply is enabled by default and can be disabled via programming interface. (2) DALI-2 bus power supply supports automatic shut-down and restart after short-circuit. 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B General Specifications Parameter Min. Typ. Max. 90.5% 90.5% 92.5% 92.5% - 89.5% 90.5% 91.5% 92.5% - 89.5% 90.0% 91.5% 92.0% - -1% - 1% Measured at 220Vac input and 100%load Standby Power - - 0.5 W Measured at 230Vac/50Hz; Dimming off MTBF - 203,000 Hours - Lifetime - 100,000 Hours - -40°C - +90°C Efficiency at 220 Vac input: EBS-080S070BT2 Io= 450 mA Io= 700 mA EBS-080S105BT2 Io= 700 mA Io=1050 mA EBS-080S150BT2 Io=1050 mA Io=1500 mA Power Monitoring Accuracy Operating Case Temperature for Safety Tc_s Notes Measured at 100%load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%load and 25°C ambient temperature (MIL-HDBK-217F) Measured at 220Vac input, 80%load and 75°C case temperature; See lifetime vs. Tc curve for the details Operating Case Temperature for Warranty Tc_w -40°C - +75°C Storage Temperature -40°C - +85°C Case temperature for 8 years warranty. Please see Inventronics Warranty Statement for complete details. Humidity: 10% RH to 90% RH; No condensation Humidity: 5% RH to 95% RH; No condensation Dimensions Inches (L × W × H) Millimeters (L × W ×H) Net Weight 5.24 x 3.03 x 1.42 133 x 77 x 36 - 330 g - Parameter Min. Typ. Max. DA+, DA- High Level 9.5 V 16 V 22.5 V DA+, DA- Low Level -6.5 V 0V 6.5 V DA+, DA- Current 0 mA - 2 mA Start Input Voltage 180 Vac - 250 Vac Start Output Level 30% - 100% Stop Input Voltage 160 Vac - 230 Vac 30% - 85% 20 Vac - - - 1 Vac - - 1% - Dimming Specifications DALI-2 AC Dim Stop Output Level Gap between Start and Stop Input Voltage Increment of Start and Stop Input Voltage Increment of Start and Stop Output Level Notes Default is 220 Vac Default is 100% Default is 170 Vac Default is 30% 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B Dimming Specifications (Continued) Parameter EBS-080S070BT2 EBS-080S105BT2 Dimming EBS-080S150BT2 Output EBS-080S070BT2 Range EBS-080S105BT2 EBS-080S150BT2 Min. Typ. Max. 10%Ioset - Ioset 45 mA 70 mA 105 mA - Ioset Notes 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA Safety &EMC Compliance Safety Category Standard ENEC EN 61347-1, EN61347-2-13 CE EN 61347-1, EN61347-2-13, EN 301 489-1 V2.2.3, EN 301 489-1 V2.1.1, EN 300 330 V2.1.1, EN 62479+EN 50663/EN 50665 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 BIS IS 15885(Part2/Sec13) KS KS C 7655 EMI Standards EN 55015/GB 17743 Notes (1) EN 61000-3-2/GB 17625.1 EN 61000-3-3 Conducted emission Test &Radiated emission Test Harmonic current emissions Class C Voltage Fluctuations & Flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge(ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient/Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 8 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61547 Electromagnetic Immunity Requirements Applies to Lighting Equipment DALI-2 Standards (2) DALI-2 Notes IEC 62386-101, -102 & -207 Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) DALI parts: 101, 102, 150, 207, 250, 251, 252, 253. 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EBS-080S070BT2(Io=450mA) EBS-080S070BT2(Io=700mA) 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B EBS-080S105BT2(Io=700mA) EBS-080S105BT2(Io=1050mA) EBS-080S150BT2(Io=1050mA) EBS-080S150BT2(Io=1500mA) Power Factor 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B Total Harmonic Distortion Protection Functions Parameter External Thermal Protection Min. Typ. Max. R1 (Start derating) - 1.67 kΩ - R2 (Stop derating) - 1.27 kΩ - 10%Ioset 20%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 20%) Iomin 20%Ioset 100%Ioset 10%Ioset ≤ Iomin (default setting is 20%) Protection Current Floor Notes The output current starts to decrease linearly when the actual NTC resistance value is lower than R1, until R2 is reached. When the actual NTC resistance value is lower than R2, the output current will stay at the programmed Protection Current Floor. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection (IUVP) Input Over Voltage Protection (IOVP) Input Under Voltage Protection Input Under Voltage Recovery Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 140 Vac 150 Vac 160 Vac Turn off the output when the input voltage falls below protection voltage. 150 Vac 160 Vac 170 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 310 Vac 320 Vac 330 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 310 Vac 320 Vac - - 350 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive stabilized input over voltage conditions up to 350Vac for a total of 8 hours. Note: (1) The recommended NTC type is 10kΩ NTC, Murata NCP18XH103J03RB. 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B  Input Under Voltage Protection Diagram  Input Over Voltage Protection Diagram Io Recovery Protection 320 Vac 310 Vac Vin Dimming  DALI-2 Dimming The recommended implementation of the dimming control is provided below. 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EBS-080SxxxBT2 80W Class I/II NFC Driver with DALI-2 and D4i Rev. B Implementation 1: DALI-2 Dimming   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EBS-080S150BT2 价格&库存
很抱歉,暂时无法提供与“EBS-080S150BT2”相匹配的价格&库存,您可以联系我们找货
EBS-080S150BT2
    库存:30
    EBS-080S150BT2
      库存:6
