EBV-350SxxxSV
350W Constant Voltage IP67 Driver
Rev. B
Features
High Efficiency (up to 93.5%)
Constant Voltage Output
Input Surge Protection: 4kV line-line, 6kV line-earth
All-Around Protection: OCP, OVP, SCP, OTP
Waterproof (IP67)
SELV Output
Suitable for Independent Use
5 Years Warranty
Description
The EBV-350SxxxSV series is a 350W, constant-voltage IP67 LED driver that operates from 176-305 Vac input
with excellent power factor. It is created for many lighting applications including architectural, decorative and
signage. The high efficiency of the driver and compact metal case enables them to run cooler, significantly
improving reliability and extending product life. To ensure trouble-free operation, protection is provided against
input surge, over current, output over voltage, short circuit, and over temperature.
Models
Output
Voltage
Input
Voltage
Range(1)(2)
Output
Current
Range
Max.
Output
Power
Typical
Efficiency
(3)
Power Factor
12 V
176 ~ 305 Vac
190 ~ 250 Vdc
0 ~ 25.0 A
300 W
91.5%
0.96
EBV-350S012SV
24 V
176 ~ 305 Vac
190 ~ 250 Vdc
0 ~ 14.6 A
350 W
93.5%
0.96
EBV-350S024SV
36 V
176 ~ 305 Vac
190 ~ 250 Vdc
0 ~ 9.8 A
350 W
93.5%
0.96
EBV-350S036SV
48 V
176 ~ 305 Vac
190 ~ 250 Vdc
0 ~ 7.3 A
350 W
93.0%
0.96
EBV-350S048SV
Model Number(4)(5)
220Vac
Notes: (1) CCC certified input voltage range: 220/230/240 Vac; other certified input voltage range except CCC: 200-240
Vac or 190-250Vdc (except BIS).
(2) Operating input voltage range: 90-305Vac, and 90-176Vac is for safety operation (see below “Derating” curve
for details)
(3) Measured at 100% load and 220Vac input (see below “General Specifications” for details).
(4) SELV output.
(5) For BIS models add suffix -3000.
Input Specifications
Parameter
Min.
Typ.
Max.
176 Vac
305 Vac
Input Frequency
47 Hz
63 Hz
Leakage Current
0.70 mA
Input AC Current
1.91 A
Input Voltage
Notes
190-250 Vdc
IEC60598-1; 240Vac/ 60Hz
Measured at 100% load and 220Vac input.
1/9
Specifications are subject to changes without notice.
www.inventronics-co.com
Tel: 86-571-56565800
Fax: 86-571-86601139
sales@inventronics-co.com
EBV-350SxxxSV
Rev. B
Input Specifications (Continued)
Parameter
Min.
Typ.
Max.
3.776 A s
0.9
THD
20%
THD
10%
At 220-240Vac, 50-60Hz, 75%-100% load
(262.5~350W)
Min.
Typ.
Max.
Notes
-2.5%Vo
2.5%Vo
2
Inrush Current(I t)
PF
Notes
2
At 220Vac input, 25C cold start,
duration=1.38ms, 10%Ipk-10%Ipk. See
Inrush Current Waveform for the details.
At 220-240Vac, 50-60Hz, 60%-100% load
(210~350W)
Output Specifications
Parameter
Output Voltage Tolerance
At 100% load condition
Total Output Voltage Ripple
(pk-pk)
2%Vo
Measured at 220-240Vac input, 0% - 100%
load condition. Measured by 20 MHz
bandwidth oscilloscope and the output
paralleled a 0.1 μF ceramic capacitor and a
10 μF electrolytic capacitor.
Startup Overshoot /
Undershoot
5%Vo
Line Regulation
±0.5%
Load Regulation
±1%
Turn-on Delay Time
0.5 s
Output
Deviation
5%VO
Settling Time
10 ms
Temperature Coefficient of Vo
0.03%/C
Load
Dynamic
Response
Measured at 220Vac input, 100% load
R/S: 1 A/μs
Load: 25%~100% load
Case temperature = 0C~Tc max.
Note: All specifications are typical at 25C unless otherwise stated.
Parameter
Min.
Typ.
Max.
Efficiency at 220Vac input:
EBV-350S012SV
EBV-350S024SV
EBV-350S036SV
EBV-350S048SV
89.5%
91.5%
91.5%
91.0%
91.5%
93.5%
93.5%
93.0%
MTBF
258,000
Hours
Lifetime
114,000
Hours
-40 °C
+90 °C
Operating Case Temperature
for Safety Tc_s
Notes
Measured at 100% load and steady-state
temperature in 25C ambient;
(Efficiency will be about 2.0% lower if
measured immediately after startup.)
Measured at 220Vac input, 80%Load and
25C ambient temperature (MIL-HDBK217F)
70C case temperature; See lifetime vs. Tc
curve for the details
2/9
EBV-350SxxxSV
Rev. B
General Specifications (Continued)
Parameter
Min.
Typ.
Max.
for Warranty Tc_w
-40 °C
+75 C
Case temperature for 5 years warranty.
Humidity: 10% RH to 100% RH.
Storage Temperature
-40 °C
+85 °C
Humidity: 5%RH to 100%RH
Dimensions
Inches (L × W × H)
Millimeters ((L × W × H)
With mounting ear
8.94 x 3.15 x 1.65
227 x 80 x 42
7.87 x 3.15 x 1.65
200 x 80 x 42
Net Weight
Notes
1350 g
Safety & EMC Compliance
Safety Category
Standard
CE & ENEC
EN 61347-1, EN61347-2-13
CB
IEC 61347-1, IEC 61347-2-13
CCC
GB 19510.1, GB 19510.14
BIS
IS 15885(PART2/SEC13)
EMI Standards
Notes
(1)
EN 55015/GB 17743
Conducted emission Test & Radiated emission Test
EN 61000-3-2/GB 17625.1
Harmonic current emissions
EN 61000-3-3
Voltage fluctuations & flicker
EMS Standards
Notes
EN 61000-4-2
Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge
EN 61000-4-3
Radio-Frequency Electromagnetic Field Susceptibility Test-RS
EN 61000-4-4
Electrical Fast Transient / Burst-EFT
EN 61000-4-5
Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV
EN 61000-4-6
Conducted Radio Frequency Disturbances Test-CS
EN 61000-4-8
Power Frequency Magnetic Field Test
EN 61000-4-11
Voltage Dips
EN 61547
Electromagnetic Immunity Requirements Applies To Lighting Equipment
Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it
depends also on the other devices connected to the driver and on the fixture itself.
3/9
EBV-350SxxxSV
Rev. B
Derating
Lifetime vs. Case Temperature
4/9
EBV-350SxxxSV
Rev. B
Efficiency vs. Load
EBV-350S012SV
EBV-350S024SV
EBV-350S036SV
EBV-350S048SV
5/9
EBV-350SxxxSV
Rev. B
Power Factor
Total Harmonic Distortion
Protection Functions
Parameter
Notes
Over Current Protection
Auto Recovery. The driver shall be self-recovery when the fault condition is removed.
Over Voltage Protection
Limits output voltage at no load and in case the normal voltage limit fails.
Short Circuit Protection
Auto Recovery. No damage will occur when any output is short circuited. The output
shall return to normal when the fault condition is removed.
Over Temperature Protection
Auto Recovery. Returning to normal after over temperature is removed.
6/9
EBV-350SxxxSV
Rev. B
Mechanical Outline
EBV-350S012/024SV
INPUT (VDE H05RN-F 3C*1.0mm
2
OUTPUT (VDE H07RN-F 2C*1.5mm
7.2)
AC/L (BROWN)
AC/N (BLUE)
GND(YELLOW/GREEN)
Tc
2
9.4)
V+ (BROWN)
V- (BLUE)
V+ (BROWN)
V- (BLUE)
PROJ:
Unspecified tolerance:±1
Note: The 2 DC output cables are connected in parallel internally because one 1.5mm2 wire can only carry
14.5A. Please connect the 2 brown wires together and 2 blue wires together in application, or ensure each
cable carries same current.
7/9
EBV-350SxxxSV
Rev. B
EBV-350S036/048SV
2
7.2)
AC/L (BROWN)
AC/N (BLUE)
GND (YELLOW/GREEN)
2
9.4)
Tc
V+ (BROWN)
V- (BLUE)
PROJ:
RoHS & Compliance
Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other
hazardous substances from electronic products.
8/9
EBV-350SxxxSV
Rev. B
Revision History
Description of Change
Change
Date
Rev.
2018-06-22
A
2018-12-29
Item
B
From
To
Datasheet Release
Product image
Updated
CE certificate
Added
CB certificate
Added
ENEC certificate
Added
BIS certificate
Added
Models
EBV-350S012SV
EBV-350S036SV
EBV-350S048SV
Added
Notes of Models
(1) Certified input
voltage range: 200240Vac or 190-250Vdc
(except CCC, KS and
BIS).
voltage range:
range except CCC:
200-240 Vac or 190250Vdc (except BIS).
Notes of Models
(4) SELV output.
Added
Notes of Models
Added
suffix -3000.
Input AC Current
2.1 A
2
1.91 A
2
Inrush Current(I t)
2.55 A s
3.776 A s
Hold Up Time
Deleted
EBV-350S012SV
EBV-350S036SV
EBV-350S048SV
Added
MTBF
285,000Hours
258,000Hours
Updated
Updated
Efficiency vs. Load curve
EBV-350S012SV
EBV-350S036SV
EBV-350S048SV
Added
Power Factor curve
Updated
Total Harmonic Distortion curve
Updated
Mechanical Outline
EBV-350S012SV
EBV-350S024SV
Updated
Mechanical Outline – note of EBV-350S012/024SV
Added
Mechanical Outline
EBV-350S036SV
EBV-350S048SV
Added
2
9/9
很抱歉,暂时无法提供与“EBV-350S024SV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 32+341.4715632+44.37510
