EUC-036S070DT
EUC-036S070DT
    INVENTRONICS(英飞特)
    EUC Series 36 W 700mA 52Vdc Out Max Dimmable Outdoor Constant Current LED Driver
EUC-036S070DT 数据手册
EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Features  High Efficiency (Up to 89%)  Second Generation with Improved Performance  Active Power Factor Correction (Typical 0.95)  Constant Current Output  0-10V Dimmable  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OVP, SCP, OLP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  Class 2 and SELV Output Description The EUC-036SxxxDT(ST) series is a 36W, constant-current IP67 LED driver that operates from 90~305 Vac input with excellent power factor. It is created for architecture lighting, decorative lighting, tunnel and street lighting. The high efficiency of these drivers and metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, over load and over temperature. Models Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Power Factor Efficiency 120Vac 220Vac (2) 350 mA 90 ~ 305 Vac 52 ~ 103 Vdc 36 W 89% 0.96 0.95 EUC-036S035DT(ST) 450 mA 90 ~ 305 Vac 40 ~ 80 Vdc 36 W 88% 0.96 0.95 EUC-036S045DT(ST) 700 mA 90 ~ 305 Vac 26 ~ 52 Vdc 36 W 88% 0.96 0.95 EUC-036S070DT(ST) 1050 mA 90 ~ 305 Vac 18 ~ 35 Vdc 36 W 87% 0.96 0.95 EUC-036S105DT(ST) 1400 mA 90 ~ 305 Vac 13 ~ 26 Vdc 36 W 86% 0.96 0.95 EUC-036S140DT(ST) 1750 mA 90 ~ 305 Vac 11 ~ 21 Vdc 36 W 85% 0.96 0.95 EUC-036S175DT(ST) Model Number (6) (6) (3)(6) (4)(6) (5)(6) (5)(6) Notes: (1) UL, FCC certified input voltage range: 100-277Vac; other certified input voltage range except UL & FCC: 100-240Vac. (2) Measured at full load and 220 Vac input. (3) Class 2 output (USR), Non-Class 2 output (CNR). (4) Class 2 output (USR), Class 2 output (CNR) only for wet location. (5) Class 2 output (USR) and Class 2 output (CNR) for wet location. (6) SELV output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Notes 1 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Input Specifications (Continued) Parameter Min. Typ. Max. - - 0.75 MIU UL8750; 277Vac/60Hz - - 0.70 mA IEC60598-1; 240Vac/60Hz - - 0.6 A Measured at full load and 100 Vac input. - - 0.3 A Measured at full load and 220 Vac input. - - 0.57 A s 0.90 - - - - 20% Min. Typ. Max. -5%Io - 5%Io - - 114 V 87 V 58 V 39 V 31 V 26 V - - 50%Io Related to V-I Curve of the LED - - 10%Io At full load condition. Line Regulation - - ±1% Load Regulation - - ±3% - 0.6 s 1.0 s - 0.3 s 0.5 s - 0.2%/C - 12V Output Voltage 10.8 V 12 V 13.2 V 12V Output Source Current 0 mA - 20 mA Leakage Current Notes Input AC Current 2 Inrush Current(I t) Power Factor THD 2 At 220Vac input 25℃ Cold Start. Duration=400 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100Vac-277Vac, 75%load-100%load (27~36W) Output Specifications Parameter Output Current Tolerance No load output voltage IO = 350 mA IO = 450 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA Total Output Current Ripple (pk-pk) Output Current Overshoot / Undershoot Turn-on Delay Time Temperature coefficient Notes Measured at full load condition. Measured at 120Vac input, 75%load-100%load Measured at 220Vac input, 75%load-100%load Case temperature = 0C~Tc max Return terminal is “Dim-”. Note: All specifications are typical at 25C unless otherwise stated. 2 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L General Specifications Parameter Min. Typ. Max. Efficiency at 120 Vac input: IO = 350 mA IO = 450 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA 87% 86% 86% 85% 85% 84% 89% 88% 87% 86% 86% 85% - Efficiency at 220 Vac input: IO = 350 mA IO = 450 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA 87% 86% 86% 85% 85% 84% 89% 88% 88% 87% 86% 85% - Efficiency at 277 Vac input: IO = 350 mA IO = 450 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA 86% 86% 86% 85% 85% 84% 88% 88% 88% 87% 86% 85% - No Load Power Dissipation - - 6W 371,000 Hours - - 111,700 Hours - -40 C - +90 C -40 C - +70 C Humidity: 10% RH to 100% RH. -40 C - +85 C Humidity: 5% RH to 100% RH MTBF Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) - Measured at full load and steady-state temperature in 25C ambient. Measured at full load and steady-state temperature in 25C ambient. Measured at full load and steady-state temperature in 25C ambient. Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 60C case temperature; See life time vs. Tc curve for the details With mounting ear 7.60 × 1.77 × 1.38 193 × 45.0 × 35.0 6.77 × 1.77 × 1.38 172 × 45.0 × 35.0 Net Weight Notes 520 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the 0~10V Input Pin Source Current on 0~10V Input Pin Min. Typ. Max. 0V - 15 V 0 uA 200 uA 250 uA Dimming Output Range 10%Iomax Recommended Dimming Input Range 0V Notes 100%Iomax - 10 V 3 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750,UL 1310,CAN/CSA-C22.2 No. 250.13,CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic Current Emissions EN 61000-3-3 Voltage Fluctuations & Flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 4 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Lifetime vs. Case Temperature Inrush Current Waveform 5 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Efficiency vs. Load EUC-036S035DT(ST) EUC-036S045DT(ST) EUC-036S070DT(ST) EUC-036S105DT(ST) EUC-036S140DT(ST) EUC-036S175DT(ST) 6 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. 7 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Dimming  0-10V Dimming The dimmer control may be operated from either a dimmer or from an input signal of 0 – 10 Vdc. The recommended implementation is provided below. Implementation 1: DC Input Implementation 2: External Resistor Implementation 3: External Resistor Notes: 1. Do not connect the GND of dimming to the output; otherwise, the LED driver cannot work normally. 2. If 0-10V dimming is not used, Dim + can be either open or connected to Vaux. 8 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Mechanical Outline EUC-036SxxxDT INPUT(UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL21996 3*22AWG AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5.0) BLACK/WHITE PURPLE GRAY V+ (RED) V- (BLACK) Tc OUTPUT(UL SJTW 2*18AWG 7.3 ) PROJ: Unspecified tolerance:±1 EUC-036SxxxST INPUT(UL SJTW 3*18AWG AC/L (BLACK) AC/N (WHITE) GND (GREEN) 7.8 ) OUTPUT(UL SJTW 2*18AWG 7.3 ) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 9 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-036SxxxDT(ST) 36W Constant Current IP67 Driver Rev. L Revision History Description of Change Change Date Rev. 2012-2-20 A 2012-05-25 B 2012-06-06 C 2012-07-02 D 2012-7-17 E 2012-7-30 F 2012-8-16 2012-11-21 Item G H From Datasheets Release / / EN 61000-4-5--- line to line 4 kV, line to earth 6 kV / Corrected Life time / 50,000 Hours Life time vs. Tc Curve / Added Notes of life time / Updated Description of OTP / Updated Max Case Temperature / Updated Mechanical Outline— wire length 320±20mm / Corrected Min Operating Temperature -35℃ -40℃ Derating Curve / Updated Inrush Current(I t) / Added Temperature coefficient / Added Life time Min 50,000hrs Typical 111,700hrs Life time Curve / Updated Mechanical Outline / Updated THD Curve / Added Io/Ir Vs Rx Curve / Added EFF and PF Curve of other models / Added Warranty Tc_w / 2 2 2015-07-21 2016-04-18 2017-02-27 2017-08-29 I J K L To Added 2 2 Inrush Current(I t) 0.2 A s 0.57 A s Power Factor Characteristics / Updated Total Harmonic Distortion Curve / Updated Inrush Current Waveform / Added Dimming Control - Source Current on 0~10V Input Pin 200 uA Max. 250 uA Net Weight 480 g 520 g KS certificate Regulation / Added Note of EMI Standard / Added Dimensions (L × W × H) 172 × 42.4 × 34.0 172 × 45.0 × 35.0 Mechanical Outline / Updated Features / Updated Description / Updated Mechanical Outline - EUC-036SxxxDT / Updated 10 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-036S070DT 价格&库存
很抱歉,暂时无法提供与“EUC-036S070DT”相匹配的价格&库存,您可以联系我们找货
