EUR-096S210DT
EUR-096S210DT
    INVENTRONICS(英飞特)
EUR-096S210DT 数据手册
EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Features  Inventronics patented metal case (Patent NO.: 201530552642.8)  High Efficiency (Up to 92%)   Full Power at Wide Output Current Range (Constant Power) Adjustable Output Current (AOC) with Potentiometer (ST models) Adjustable Output Current (AOC) with Programmability (DT models)   0-10V/PWM Dimmable (Only DT models)  Input Surge Protection: 4kV line-line, 4kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP65) and UL Dry / Damp / Wet Location  Class 2 & SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUR-096SxxxDT(ST) series is a 96W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is designed in round shape and specially created for bay lighting. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 140-2100mA 1400-2100mA 2000mA 1400-2100mA 1400-2100mA 2000mA 175-2150mA 1750-2150mA 2000mA 245-3500mA 2450-3500mA 2700mA 2450-3500mA 2450-3500mA 2700mA Input Voltage Range (2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (4) 24 ~ 69Vdc 96 W 91.5% 0.99 0.96 EUR-096S210DT 24 ~ 69Vdc 96 W 91.5% 0.99 0.96 EUR-096S210ST 24 ~ 55Vdc 96 W 92.0% 0.99 0.96 EUR-096S215DT 14 ~ 39Vdc 96 W 91.0% 0.99 0.96 EUR-096S350DT 14 ~ 39Vdc 96 W 91.0% 0.99 0.96 EUR-096S350ST (4) (5) (5) (5) Notes: (1) Output current range with constant power at 96W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS). (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV Output. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E I-V Operation Area EUR-096S210DT EUR-096S210ST 72 90 (1400,69) (10%Ioset,96/Ioset) 60 Output Voltage(V) 60 (1400,69) (Ioset,96/Ioset) 10 % 70 45 0% Lo Lo ad Output Voltage(V) (980,69) (140,69) 75 (2100,46) ad (2100,32) 30 (2100,24) 48 (2100,46) 36 70 % 24 Load (2100,32) (1400,24) (2100,24) 12 Programmed Operating Area Good Performance Area Allowed Operating Area 800 400 1200 1600 2000 Allowed Operating Area Good Performance Area 0 0 (1400,48) (Ioset,24) (210,24) 15 100 % Load 0 1200 2400 1380 1560 1740 1920 Output Current (mA) Output Current (mA) Note: 1400mA≤Ioset≤2100mA Note: 1400mA≤Ioset≤2100mA 2100 2280 EUR-096S215DT 60 (1225,55) (175,55) (1750,55) (10%Ioset,96/Ioset) (Ioset,96/Ioset) 10 70 Output Voltage(V) 50 % 0% Lo Lo 40 ad (2150,44.5) ad (2150,31) 30 (215,24) 20 10 (Ioset,24) (2150,24) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 800 400 1200 1600 2000 2400 Output Current (mA) Note: 1750mA≤Ioset≤2150mA EUR-096S350DT EUR-096S350ST 48 42 (2450,39) (1715,39) (2450,39) (10%Ioset,96/Ioset) 35 (Ioset,96/Ioset) 32 10 70 0% Lo % 24 Lo ad (3500,27.5) ad Output Voltage(V) 40 (3500,19) 16 (Ioset,14) (350,14) 8 Good Performance Area Allowed Operating Area (3500,14) Output Voltage(V) (245,39) 100 % Load 28 (3500,27.5) (2450,27) 21 70% 14 Load (3500,19) (3500,14) (2450,14) 7 Programmed Operating Area 0 Good Performance Area Allowed Operating Area 2300 3200 0 0 700 1400 2100 2800 3500 4200 Output Current (mA) 2000 2600 2900 3500 3800 Output Current (mA) Note: 2450mA≤Ioset≤3500mA Note: 2450mA≤Ioset≤3500mA 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 1.32 A Measured at 100%load and 100Vac input. - - 0.60 A Measured at 100%load and 220Vac input. - - 1.60 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (72-96W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 140 mA 1400 mA 175 mA 245 mA 2450 mA - 2100 mA 2100 mA 2150 mA 3500 mA 3500 mA 1400 mA 1400 mA 1750 mA 2450 mA 2450 mA - 2100 mA 2100 mA 2150 mA 3500 mA 3500 mA - 5%Iomax 10%Iomax - 2%Iomax - 100%load Startup Overshoot Current - - 10%Iomax 100%load No Load Output Voltage EUR-096S210DT/ST EUR-096S215DT EUR-096S350DT/ST - - 90 V 59 V 50 V Line Regulation - - ±0.5% 127~30 Vdc Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25C cold start, duration=760 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (67-96W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUR-096S210DT EUR-096S210ST EUR-096S215DT EUR-096S350DT EUR-096S350ST Output Current Setting Range with Constant Power EUR-096S210DT EUR-096S210ST EUR-096S215DT EUR-096S350DT EUR-096S350ST Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 100%load 100%load. 20 MHz BW 100%load 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Output Specifications (Continued) Parameter Min. Typ. Max. - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Load Regulation Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 86.5% 87.0% 89.5% 90.0% - 87.0% 86.5% 90.0% 89.5% - 86.0% 85.5% 89.0% 88.5% - 89.5% 89.5% 91.5% 91.5% - 90.0% 89.5% 92.0% 91.5% - 89.0% 88.5% 91.0% 90.5% - 90.0% 90.0% 92.0% 92.0% - 90.0% 89.5% 92.0% 91.5% - 89.5% 88.5% 91.5% 90.5% - MTBF - 354,000 Hours - Lifetime - 85,000 Hours - Efficiency at 120 Vac input: EUR-096S210DT/ST Io=1400 mA Io=2100 mA EUR-096S215DT Io=1750 mA Io=2150 mA EUR-096S350DT/ST Io=2450 mA Io=3500 mA Efficiency at 220 Vac input: EUR-096S210DT/ST Io=1400 mA Io=2100 mA EUR-096S215DT Io=1750 mA Io=2150 mA EUR-096S350DT/ST Io=2450 mA Io=3500 mA Efficiency at 277 Vac input: EUR-096S210DT/ST Io=1400 mA Io=2100 mA EUR-096S215DT Io=1750 mA Io=2150 mA EUR-096S350DT/ST Io=2450 mA Io=3500 mA Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E General Specifications (Continued) Parameter Min. Typ. Max. Notes Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Dimensions ∅5.12 x 2.76 ∅130 x 70 Inches (∅ × H) Millimeters (∅ × H) Net Weight - 1150 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset 140 mA 175 mA 245 mA - Ioset 0V - 10 V PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin EUR-096S210DT EUR-096S215DT Dimming EUR-096S350DT Output EUR-096S210DT Range EUR-096S215DT EUR-096S350DT Recommended Dimming Input Range PWM_in Duty Cycle Notes Vdim(+) = 0 V 1400 mA ≤ Ioset ≤ 2100 mA 1750 mA ≤ Ioset ≤ 2150 mA 2450 mA ≤ Ioset ≤ 3500 mA 140 mA ≤ Ioset < 1400 mA 175 mA ≤ Ioset < 1750 mA 245 mA ≤ Ioset < 2450 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Safety & EMC Compliance (Continued) EMI Standards Notes EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 4kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Inrush Current Waveform Efficiency vs. Load EUR-096S210DT/ST(Io=1400mA) EUR-096S210DT/ST(Io=2100mA) EUR-096S215DT(Io=1750mA) EUR-096S215DT(Io=2150mA) 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E EUR-096S350DT/ST(Io=2450mA) EUR-096S350DT/ST(Io=3500mA) Power Factor Total Harmonic Distortion 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+(RED) L Vac N V-(BLU) Inventronics LED Driver Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) 0 (1)-10V Dimmer Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. V+(RED) L Vac N V-(BLU) Inventronics LED Driver Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) PWM Signal Implementation 2: Positive logic 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E V+(RED) L Vac N V-(BLU) Inventronics LED Driver Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) PWM Signal Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. Programming Connection Diagram (Only DT models) Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 Multi-Programmer datasheet for details. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Installations Part Number Suffix -0000 -0001 Product Type Center Wire Feed Outside Wire Feed Product Appearance Installation Type Caution: 1. Complete visual inspection prior to assembly to insure driver is received in proper condition. 2. Thread length for mounting accessory (hook, ring, etc.) should be 16-22mm. After mounting accessory (hook, ring, etc.) is installed an M4 set screw should be secured in the open location on the driver collar. 3. Maximum weight of combined luminaire/driver assembly should not exceed 11Kg. 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com 1 3 4 5 6 7 8 DEUR096S00008 A MECHANICAL OUTLINE DRAWING A EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Mechanical Outline B EUR-096SxxxDT-0000 B INPUT (UL SJTW 3*18AWG 7.8) OUTPUT (UL SJTW 2*18AWG 7.3) Hositing thread: DN15 C C V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) GRAY PURPLE BLACK/WHITE D D M4 Dimming Wire(UL21996 3*22AWG 5.0 ) REFERENCE DRAWING NO. E E PROJ: Tc Unspecified tolerance:±1.5 DRAWN CHECKED B B B F EUR-096SxxxST-0000 ASSEMBLE NO. 1 C 2 3 4 Hositing thread: DN15 C C POTENTIOMETER V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) D E 2 D D INPUT (UL SJTW 3*18AWG M4 7.8) OUTPUT (UL SJTW 2*18AWG 7.3) REFERENCE DRAWING NO. E E DRAWN Tc PROJ: Unspecified tolerance:±1.5 CHECKED F F ASSEMBLE NO. 12 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com A MECHANICAL OUTLINE DRAWING A EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E B B EUR-096SxxxDT-0001 Dimming Wire(UL21996 3*22AWG OUTPUT (UL SJTW 2*18AWG 5.0) 7.3) Hositing thread: C C GRAY PURPLE BLACK/WHITE V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) D D INPUT (UL SJTW 3*18AWG 7.8) M4 1 2 3 4 5 6 7 8 DEUR096S00007 REFERENCE DRAWING NO. A E A E MECHANICAL OUTLINE DRAWING Unspecified tolerance:±1.5 PROJ: Tc DRAWN CHECKED ASSEMBLE NO. F B B EUR-096SxxxST-0001 2 1 3 4 5 7 8 AUTHORIZE: Hositing thread: C C V+ (RED) V- (BLUE) POTENTIOMETER AC/L (BLACK) AC/N (WHITE) GND (GREEN) D D M4 INPUT (UL SJTW 3*18AWG 7.8) OUTPUT (UL SJTW 2*18AWG 7.3) REFERENCE DRAWING NO. E E Tc DRAWN PROJ: Unspecified tolerance:±1.5 CHECKED F ASSEMBLE NO. 1 2 3 4 13 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Optional Metal Parts HKK-D1500 BLT-M1000 M10*1.5 DN15 PROJ: PROJ: Unspecified tolerance:±1 Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. REFERENCE DRAWING NO. 14 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-096SxxxDT(ST) 96W AOC Driver for High Bay Rev. E Revision History Change Date Rev. 2016-07-08 A 2017-02-05 B 2017-07-06 2018-03-05 2018-03-20 C D E Description of Change Item From To Datasheets Release / / Features / Updated Mechanical Outline / Updated Input Specifications PF/THD (Notes) Updated Output Specifications Temperature Ioset Safety & EMC Compliance / Updated Mechanical Outline / Updated Features 5 Years Warranty Added Description / Updated Models EUR-096S215DT/ST Added Models Notes(2) Updated I-V Operation Area EUR-096S215DT/ST Added Output Current Setting(Ioset) Range EUR-096S215DT/ST Added Output Current Setting Range with EUR-096S215DT/ST Constant Power Added No Load Output Voltage EUR-096S215DT/ST Added Efficiency at 120 Vac input EUR-096S215DT/ST Added Efficiency at 220 Vac input EUR-096S215DT/ST Added Efficiency at 277 Vac input EUR-096S215DT/ST Added General Specifications Case temperature for 5 years Updated warranty Dimming Output Range EUR-096S215DT Added Efficiency vs. Load EUR-096S215DT/ST Added Mechanical Outline Optional Metal Parts Added Features High Efficiency Updated Models / Updated I-V Operation Area / Updated Output Current Setting(Ioset) Range / Output Current Setting Range with / Constant Power No Load Output Voltage / Updated Efficiency at 120 Vac input / Updated Efficiency at 220 Vac input / Updated Efficiency at 277 Vac input / Updated Efficiency vs. Load / Updated Coefficient of Updated Updated Updated 15 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUR-096S210DT 价格&库存
很抱歉,暂时无法提供与“EUR-096S210DT”相匹配的价格&库存,您可以联系我们找货
