EUV-200S012ST
EUV-200S012ST
    INVENTRONICS(英飞特)
    EUV Series 200 W 15 A 12 Vdc Out Max Outdoor Constant Voltage LED Driver
EUV-200S012ST 数据手册
EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Features  High Efficiency (Up to 92.5%)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OVP, OCP, SCP, OTP  IP67 and UL Dry / D amp / Wet Location  SELV  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty    Description The EUV-200SxxxST series is a 200W, constant-Voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, sports and roadway, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, over current, short circuit, and over temperature. Models Power Factor Typical Efficiency (2) 120Vac 220Vac Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power 12 Vdc 90 ~ 305 Vac 0~15.0 A 180 W 91.0% 0.99 0.97 EUV-200S012ST 24 Vdc 90 ~ 305 Vac 0~8.33 A 200 W 92.0% 0.99 0.97 EUV-200S024ST 36 Vdc 90 ~ 305 Vac 0~5.56 A 200 W 92.0% 0.99 0.97 EUV-200S036ST 42 Vdc 90 ~ 305 Vac 0~4.76 A 200 W 92.5% 0.99 0.97 EUV-200S042ST 48 Vdc 90 ~ 305 Vac 0~4.17 A 200 W 92.5% 0.99 0.97 EUV-200S048ST 54 Vdc 90 ~ 305 Vac 0~3.70 A 200 W 92.5% 0.99 0.97 EUV-200S054ST Model Number (3) Notes: (1) UL Certified input voltage range: 100-277Vac; otherwise 100-240Vac (except KS). (2) Measured at 100% load and 220 Vac input. (3) SELV output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz, grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively Leakage Current 1 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 2.5 A Measured at 100% load and 100 Vac input. - - 1.1 A Measured at 100% load and 220 Vac input. - - 1.5 A s 0.90 - - - - 20% Min. Typ. Max. Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input 25℃ Cold Start, duration=1.2 ms, 10%Ipk-10%Ipk At 100-277Vac, 50-60Hz, 100% Load; THD Output Specifications Parameter -2.5% 2.5% Notes EUV-200S042ST. At 100% load condition. Output Voltage Tolerance -5% - 5% Others. At 100% load condition. Ripple and Noise (pk-pk) - - 2% VO Output Overshoot / Undershoot - - 10% When power on or off. Line Regulation - - ±1% At 100% load condition. Load Regulation - - ±2% - 0.9 s 1.5 s Measured at 110Vac input, 100% Load - 0.5 s 1.0 s Measured at 220Vac input, 100% Load Output Deviation - - 5% VO Settling Time - - 10 mS - 0.05%/C - Min. Typ. Max. Notes 88.0% 89.0% 89.0% 89.5% 89.5% 89.5% 89.0% 90.0% 90.0% 90.5% 90.5% 90.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 90.0% 91.0% 91.0% 91.5% 91.5% 91.5% 91.0% 92.0% 92.0% 92.5% 92.5% 92.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Load Dynamic Response Temperature coefficient R/S: 1 A/uS Load: 25% ~ 75% 100% load. Case temperature = 0C ~Tc max General Specifications Parameter Efficiency at 110 Vac input: VO = 12 V VO = 24 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Efficiency at 220 Vac input: VO = 12 V VO = 24 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V 2 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q General Specifications (Continued) Parameter Min. Typ. Max. No Load Power Dissipation - - 3W MTBF - 276,000 hours - Lifetime - 95,200 hours - -35 °C - +88.2 ºC -40 °C - +88.2 ºC Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Measured at 110Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 220Vac input, 80%Load and 60C case temperature; See life time vs. Tc curve for the details -35 °C - +70 ºC -40 °C - +70 ºC -40 °C - +85 °C Dimensions Inches (L × W × H) Millimeters (L × W × H) - 1150 g @90-305 Vac @198-305 Vac @90-305 Vac, Case temperature for 5 years warranty @198-305 Vac, Case temperature for 5 years warranty Humidity: 5%RH to 100%RH With mounting ear 8.90 × 2.66 × 1.56 226 × 67.5 × 39.5 7.83 × 2.66 × 1.56 199 × 67.5 × 39.5 Net Weight Notes - Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015/KN 15 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV (2) EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment 3 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Curve Efficiency vs. Load 4 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Power Factor Characteristics 5 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Total Harmonic Distortion Curve (24V) Protection Functions Parameter Over Current Protection Min. Typ. Max. Notes 120% IO 140% IO 200% IO Hiccup mode. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Auto Recovery, returning to normal after over temperature is removed. Short Circuit Protection No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 6 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Mechanical Outline EUV-200S012ST INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*18AWG 7.8) AC/L (BLACK) AC/N (WHITE) GND (GREEN) 7.3) V+ (RED) V- (BLACK) Tc V+ (RED) V- (BLACK) PROJ: Unspecified tolerance:±1 Note: The 2 DC output cables are connected in parallel internally because one AWG #18 wire can only carry 10A. Please connect the 2 red wires together and 2 black wires together in application, or ensure each cable carries same current. Others INPUT (UL SJTW 3*18AWG 7.8) AC/L (BLACK) AC/N (WHITE) GND (GREEN) OUTPUT (UL SJTW 2*18AWG 7.3) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Revision History Change Date Description of Change Rev. Item From To 2009-12-03 A Change the Max. output current/power and efficiency of 12V. Update the Ambient Temperature Derating Curve 2009-12-16 B Add note for mechanical outline. C Add star rank for recommended / models Add Leakage Current in Input / Specifications Standardize the tolerance in / Mechanical Outline Max. 0.75 mA 50Hz input 42V,50V,52V, 81V, 105V Models Deleted 2010-05-31 ☆: Popular model. At 277Vac / / 0.7 s 1.0 s 0.9 s 1.5 s 0.3 s 0.5 s 0.5 s 1.0 s Turn-on delay time 2012-06-12 2012-7-17 2012-8-14 D E Efficiency of EUV-200S054ST @ 110 Vac / 1 % lower Life Time Curve / Added Mechanical Outline / Updated Max Case Temperature / Updated Efficiency of 54V Model @220 Vac / 0.5% Lower Efficiency of 36V Model / 0.5% Lower OCP Typ 1.3Io MTBF, life time Typical / Added Min PF / Added Max THD / Added Temperature Coefficient / Added Life time Curve / Updated EN61000-4-5 line to line 2 kV, line to earth line to line 4 kV, line to earth 6 4 kV kV 2012-12-28 Max 1.8Io F 2 2012-12-6 Max 1.7Io Typ 1.4Io G Inrush Current(I t) / Added No Load Power Dissipation 2W 3W Derating Curve / Updated Efficiency Curve of all models / Added PF Curve of all models / Added THD Curve of 24V Model / Added H 2013-11-26 I Input Specifications--Load Range of 75%load-100%load PF & THD 100%load 2015-09-11 M Format Update / 8 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Revision History (Continued) Change Date 2015-09-11 2016-04-05 2017-11-14 Description of Change Rev. Item M N From External Grounding Screw Solution / / Features / Update Description / Update Models EUV-150S042SV Added General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature Added for Warranty Tc_w General Specifications Storage Temperature Added Environmental Specifications / Delete Safety & EMC Compliance / Update Protection Functions / Update Mechanical Outline / Update KS / Added Models / Update General Specifications With mounting ear Added General Specifications Net Weight Update Safety & EMC Compliance / Update Features 5 years warranty Added Input Specifications Leakage Current Updated PF/THD Notes Updated Turn-on Delay Time Notes Updated Temperature coefficient Max 0.05%/C Typ 0.05%/C O Operating Case Temperature Updated for Safety Tc_s Operating Case Temperature Updated for Warranty Tc_w General Specifications General Specifications 2019-03-12 2020-01-06 To Mechanical Outline / Updated Description / Updated General Specifications - Net Weight 1080g 1150g KCC Logo / Added Features 4kV line-line, 6kV line-earth DM 4kV, CM 6kV Features Waterproof (IP67) IP67 P Q 9 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxST 200W Constant Voltage IP67 Driver Rev. Q Revision History (Continued) Change Date 2020-01-06 Description of Change Rev. Item Q From (1) To (1) EN 55015/KN 15 Safety &EMC Compliance EN 55015 Safety &EMC Compliance EN 61000-4-5 Updated Derating Curve / Deleted RoHS Compliance / Updated Format Page footer Updated 10 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com
EUV-200S012ST 价格&库存
很抱歉,暂时无法提供与“EUV-200S012ST”相匹配的价格&库存,您可以联系我们找货
