ECS-80-10-33-CGN-TR3 数据手册
ECX-32
SMD CRYSTAL
The sub miniature ECX-32 is a compact SMD Crystal. The
3.2 x 2.5 x 0.8 mm ceramic package is ideal for LoRa WAN,
wireless, and high density applications.
Request a Sample
OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS
ECX-32 SMD CRYSTAL
PARAMETERS
CONDITIONS
ECX-32
MIN
Frequency
54.000
MHz
@ +25°C
± 50
ppm
-20 ~ +70°C
± 50
ppm
Shunt Capacitance
Co
5
pF
Load Capacitance
Specify in P/N
Series
pF
100
μW
Frequency Tolerance*
Frequency Stability*
Low Profile
3.2 x 2.5 mm Footprint
Extended Temp. Range Option
RoHS Compliant
Drive Level
Fundamental
4
DL
Operating Temperature*
Topr
-20
+70
°C
Storage Temperature
Tstg
-55
+125
°C
±5
ppm
Aging (First Year)
DIMENSIONS (mm)
MAX
8.000
Mode of Oscillation
TYP
UNITS
@ +25°C ±3°C
Equivalent Series Resistance
ggested land pattern
Frequency (MHz)
8.000 ~ 9.999
10.000 ~ 15.999
16.000 ~ 19.999
20.000 ~ 23.999
24.000 ~ 54.000
Pad Connections
1
In/Out
2
Gnd
3
Out/In
4
Gnd
Figure 1) Top, Side, and Bottom
Crystal is symmetrical, pad 1 & 3 are interchangeable.
Chamfer on the bottom can be on pad 4 or pad 1 and
has no electrical significance.
ESR Ω Max.
400
100
80
60
40
Figure 2) Suggested land
pattern
PART NUMBERING GUIDE: Example ECS-200-20-33-TR
ECS - FREQUENCY ABBREVIATION
ECS
200 = 20.000 MHz
See P/N Guide
LOAD
CAPACITANCE
20 = 20 pF
S = Series
* Specify available options in P/N.
† Contact ECS for availability over extended temp range.
PACKAGE
AVAILABLE OPTIONS
Tolerance
33 =
ECX-32
Blank = Std
A = ± 25 ppm
J = ± 20 ppm
R = ± 15 ppm
C = ± 10 ppm
Stability
Blank= Std
D= ±100 ppm
E = ± 50 ppm
G = ± 30 ppm
H = ± 25 ppm
T = ± 20 ppm †
W = ±15 ppm †
K = ± 10 ppm †
PACKAGING
Temp Range
Blank= Std
L = -10 ~ +70°C
M = -20 ~ +70°C
Y = -30 ~ +85°C
N = -40 ~ +85°C
P = -40 ~ +105°C
S = -40 ~ +125°C
U = -55 ~ +125°C
TR =1K
TR3=3K
Qty/Reel
Rev.2021
15351 West 109th Street | Lenexa, KS 66219 | Phone: 913.782.7787 | Fax: 913.782.6991 | www.ecsxtal.com
ECX-32
SMD CRYSTAL
POCKET TAPE DIMENSIONS (mm)
SOLDER PROFILE
Peak solder Temp +260°C Max 10 sec Max.
2 Cycles Max.
MSL 1, Lead Finish Au
Figure 1) Suggested Reflow Profile
DEVELOPED FREQUENCIES
Abbreviation
Frequency (MHZ)
80
100
120
122.8
143
147.4
160
184
192
196
200
240
245.7
250
260
270
300
320
360
400
480
8.000
10.000
12.000
12.288
14.31818
14.7456
16.000
18.432
19.200
19.6608
20.000
24.000
24.576
25.000
26.000
27.000
30.000
32.000
36.000
40.000
48.000
ECS-80-10-33-CGN-TR3 价格&库存
很抱歉,暂时无法提供与“ECS-80-10-33-CGN-TR3”相匹配的价格&库存,您可以联系我们找货
