ECS-160-8-36CKM-TR3
ECS-160-8-36CKM-TR3
    ECSINC.(ECS )
    XO-4P_2520(METRIC)
    ECS-160-8-36CKM-TR3
ECS-160-8-36CKM-TR3 数据手册
ECX-2236 SMD CRYSTAL The miniature ECX-2236 is a compact SMD Crystal. The industry standard 2.5 x 2.0 x 0.55 mm is ideal for bluetooth, LoRa WAN, and wireless applications. Request a Sample OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS ECX-2236 SMD CRYSTAL PARAMETERS CONDITIONS ECX-2236 MIN Frequency 80.000 MHz @ +25°C ± 50 ppm -20 ~ +70°C ± 50 ppm Shunt Capacitance Co 5 pF Load Capacitance Specify in P/N Frequency Tolerance* Frequency Stability* Low Profile 2.5 x 2.0 mm Footprint Extended Temp. Range IOT/Wearable applications Drive Level Fundamental 8 pF DL 100 μW Operating Temperature* Topr -20 +70 °C Storage Temperature Tstg -55 +125 °C ±5 ppm Aging (First Year) DIMENSIONS (mm) MAX 12.000 Mode of Oscillation • • • • TYP UNITS @ +25°C ±3°C Frequency (MHz) 12.000 ~ 15.999 16.000 ~ 19.999 20.000 ~ 29.999 30.000 ~ 34.999 35.000 ~ 80.000 Pad Connections 1 In/Out 2 Gnd 3 Out/In 4 Gnd Figure 1) Top, Side, and Bottom Crystal is symmetrical, pad 1 & 3 are interchangeable. Chamfer on the bottom pad has no electrical significance. ESR Ω Max. 150 80 60 50 40 Figure 2) Suggested land pattern PART NUMBERING GUIDE: Example ECS-240-8-36-TR ECS - FREQUENCY ABBREVIATION ECS 240 = 24.000 MHz See P/N Guide LOAD CAPACITANCE 8 = 8 pF 10=10 pF * Specify available options in P/N. † Contact ECS for availability over extended temp range. PACKAGE AVAILABLE OPTIONS Tolerance -36 = ECX-2236 Blank = Std A = ± 25 ppm J = ± 20 ppm R = ± 15 ppm C = ± 10 ppm Stability Blank= Std D= ±100 ppm E = ± 50 ppm G = ± 30 ppm H = ± 25 ppm T = ± 20 ppm † W = ±15 ppm † K = ± 10 ppm † PACKAGING Temp Range Blank= Std L = -10 ~ +70°C M = -20 ~ +70°C Y = -30 ~ +85°C N = -40 ~ +85°C P = -40 ~ +105°C S = -40 ~ +125°C U = -55 ~ +125°C TR =1K TR3=3K Qty/Reel Rev.2021 15351 West 109th Street | Lenexa, KS 66219 | Phone: 913.782.7787 | Fax: 913.782.6991 | www.ecsxtal.com ECX-2236 SMD CRYSTAL POCKET TAPE DIMENSIONS (mm) SOLDER PROFILE Peak solder Temp +260°C Max 10 sec Max. 2 Cycles Max. MSL 1, Lead Finish Au DEVELOPED FREQUENCIES Abbreviation Frequency (MHZ) 120 12.000 160 16.000 192 19.200 200 20.000 240 24.000 245.7 24.576 250 25.000 260 26.000 270 27.000 300 30.000 320 32.000 360 36.000 400 40.000 480 48.000 Figure 1) Suggested Reflow Profile 15351 West 109th Street | Lenexa, KS 66219 | Phone: 913.782.7787 | Fax: 913.782.6991 | www.ecsxtal.com
ECS-160-8-36CKM-TR3
- 物料型号:ECX-2236 SMD晶体振荡器 - 器件简介:ECX-2236是一款小型SMD晶体,尺寸为2.5 x 2.0 x 0.55 mm,适用于蓝牙、LoRa WAN和无线应用。 - 引脚分配:1号引脚为输入/输出,2号和3号引脚为地,3号引脚为输出/输入,引脚1和3可互换。 - 参数特性: - 频率范围:12.000 MHz 至 80.000 MHz - 振荡模式:基频 - 频率容差:±50 ppm(25°C时) - 频率稳定性:-20°C至+70°C范围内±50 ppm - 并联电容:5 pF - 负载电容:根据产品编号指定,典型值为8 pF - 驱动电平:100 uW - 工作温度范围:-20°C至+70°C - 存储温度:-55°C至+125°C - 首年老化率:±5 ppm - 功能详解:文档提供了晶体振荡器的详细电气特性和操作条件。 - 应用信息:适用于IOT/可穿戴设备应用。 - 封装信息:ECX-2236封装,提供了详细的尺寸图和引脚连接信息。 - 老化和温度特性:提供了不同频率下的ESR最大值和建议的回流焊接温度曲线。
ECS-160-8-36CKM-TR3 价格&库存
很抱歉,暂时无法提供与“ECS-160-8-36CKM-TR3”相匹配的价格&库存,您可以联系我们找货
