ECS-80-8-33-JGN-TR3
ECS-80-8-33-JGN-TR3
    ECSINC.(ECS )
    SMD4
    ECS-80-8-33-JGN-TR3
ECS-80-8-33-JGN-TR3 数据手册
ECX-32 SMD CRYSTAL The sub miniature ECX-32 is a compact SMD Crystal. The 3.2 x 2.5 x 0.8 mm ceramic package is ideal for LoRa WAN, wireless, and high density applications. Request a Sample OPERATING CONDITIONS / ELECTRICAL CHARACTERISTICS ECX-32 SMD CRYSTAL PARAMETERS CONDITIONS ECX-32 MIN Frequency 54.000 MHz @ +25°C ± 50 ppm -20 ~ +70°C ± 50 ppm Shunt Capacitance Co 5 pF Load Capacitance Specify in P/N Series pF 100 μW Frequency Tolerance* Frequency Stability* Low Profile 3.2 x 2.5 mm Footprint Extended Temp. Range Option RoHS Compliant Drive Level Fundamental 4 20 DL Operating Temperature* Topr -20 +70 °C Storage Temperature Tstg -55 +125 °C ±5 ppm Aging (First Year) DIMENSIONS (mm) MAX 8.000 Mode of Oscillation • • • • TYP UNITS @ +25°C ±3°C Equivalent Series Resistance ggested land pattern Frequency (MHz) 8.000 ~ 9.999 10.000 ~ 15.999 16.000 ~ 19.999 20.000 ~ 23.999 24.000 ~ 54.000 Pad Connections 1 In/Out 2 Gnd 3 Out/In 4 Gnd Figure 1) Top, Side, and Bottom Crystal is symmetrical, pad 1 & 3 are interchangeable. Chamfer on the bottom can be on pad 4 or pad 1 and has no electrical significance. ESR Ω Max. 400 100 80 60 40 Figure 2) Suggested land pattern PART NUMBERING GUIDE: Example ECS-200-20-33-TR ECS - FREQUENCY ABBREVIATION ECS 200 = 20.000 MHz See P/N Guide LOAD CAPACITANCE 20 = 20 pF S = Series * Specify available options in P/N. † Contact ECS for availability over extended temp range. PACKAGE AVAILABLE OPTIONS Tolerance 33 = ECX-32 Blank = Std A = ± 25 ppm J = ± 20 ppm R = ± 15 ppm C = ± 10 ppm Stability Blank= Std D= ±100 ppm E = ± 50 ppm G = ± 30 ppm H = ± 25 ppm T = ± 20 ppm † W = ±15 ppm † K = ± 10 ppm † PACKAGING Temp Range Blank= Std L = -10 ~ +70°C M = -20 ~ +70°C Y = -30 ~ +85°C N = -40 ~ +85°C P = -40 ~ +105°C S = -40 ~ +125°C U = -55 ~ +125°C TR =1K TR3=3K Qty/Reel Rev.2021 15351 West 109th Street | Lenexa, KS 66219 | Phone: 913.782.7787 | Fax: 913.782.6991 | www.ecsxtal.com ECX-32 SMD CRYSTAL POCKET TAPE DIMENSIONS (mm) SOLDER PROFILE Peak solder Temp +260°C Max 10 sec Max. 2 Cycles Max. MSL 1, Lead Finish Au Figure 1) Suggested Reflow Profile DEVELOPED FREQUENCIES Abbreviation Frequency (MHZ) 80 100 120 122.8 143 147.4 160 184 192 196 200 240 245.7 250 260 270 300 320 360 400 480 8.000 10.000 12.000 12.288 14.31818 14.7456 16.000 18.432 19.200 19.6608 20.000 24.000 24.576 25.000 26.000 27.000 30.000 32.000 36.000 40.000 48.000 15351 West 109th Street | Lenexa, KS 66219 | Phone: 913.782.7787 | Fax: 913.782.6991 | www.ecsxtal.com
ECS-80-8-33-JGN-TR3
- 物料型号:ECX-32 SMD晶体振荡器,具有3.2 x 2.5 x 0.8 mm的紧凑尺寸,适用于LoRa WAN、无线和高密度应用。 - 器件简介:ECX-32是一款小型化的表面贴装晶体,具有低剖面尺寸和RoHS合规性。 - 引脚分配:引脚1和3是可互换的输入/输出和输出/输入端,引脚2和4是接地端。 - 参数特性:包括频率范围8.000 MHz至54.000 MHz,基本振荡模式,频率容差±50 ppm,频率稳定性±50 ppm,负载电容4至20 pF,驱动电平100 mW,工作温度范围-20至+70℃,存储温度范围-55至+125℃,以及首年老化±5 ppm。 - 功能详解:提供了等效串联电阻(ESR)的最大值,随频率变化。 - 应用信息:适用于LoRa WAN、无线通信等高密度应用。 - 封装信息:提供了详细的封装尺寸和建议的焊盘布局,以及卷带封装尺寸和焊接曲线。
ECS-80-8-33-JGN-TR3 价格&库存
很抱歉,暂时无法提供与“ECS-80-8-33-JGN-TR3”相匹配的价格&库存,您可以联系我们找货
