ED-038
ED-038
    BRAINBOXES
    ETHERNET TO 3 RELAY + 3 DIGITAL
ED-038 数据手册
ED-038 3 Port Digital In + 3 Relays ED-038 Ethernet to Digital IO Relay • 3 Digital Inputs and 3 Form A Relays • 1 Ethernet Port • Drives high current and high voltage loads ideal for inductive, capacitive and resistive loads • User friendly software interface Simple web based configuration, monitoring and control • Legacy compatible Digital Channels Inputs Relay Outputs Input Channels 3 non-isolated input channels NPN/PNP Jumper selectable pull up for NPN, active low, type sensors and pull down for PNP, active high, type sensors Logic Level 0: 0V to +1V Logic Level 1: +3.5V to +30V Latched Inputs: Triggered by user programmable positive or negative edges, stays true until acknowledged Counter Inputs: User programmable- counts positive or negative transitions 0-65335 Relay Type 3 Form A (SPST: Single Pole Single Throw) - Normally Open When power is removed from the ED-038 the relay is Open Contact Rating 5 A @ 30 VDC, 5 A @ 250VAC, 5 A @ 110 VAC Inductive Load 2A Resistive Load 5A Breakdown Voltage 500 VAC Relay On/Off Time 1500 ms (Max) Initial Insulation Resistance 1G min @ 500 VDC Expected Life 100,000 times (Typical) Initial Contact Resistance 30 milli-ohms (Max) Pulse Output 0.3 Hz at rated load ED-038 3 Port selectable DI + 3 Relays Ethernet to DIO Device Server: The Ethernet to DIO device is implemented using a Windows COM port driver that is completely compatible with all popular PC packages such as LabView, MATLAB and Agilent VEE and support a range of popular APIs. Continue to get value from your existing development and process control system. Our software allows hassle free installation, configuration and monitoring via our easy to use webpage. The software gives local COM ports that are backwards compatible enabling legacy applications and the device to work with a myriad of different 3rd party software. Relay: A relay is an electrically operated switch used to control a circuit by a low-power signal giving complete electrical isolation between the control and the controlled circuits. Relays are often used where several circuits must be controlled by one signal. Familiar ASCII Command Protocol: The ED range of devices uses the de facto industry standard ASCII command protocol implemented in the popular ADAM/NuDAM/EDAM modules. Typical examples include: $01M read the name of device address 01 !01ED-588 device 01 replies that its name is ED-588 $01F read firmware version number of device address 01 !012.54 firmware version of device 01 is 2.54 @01 read digital input output status of device 01 >1A45 device 01 digital input data= 1A (=00011010) digital output data = 45 (=01000101) $012 read configuration of device 01 !01400500 device 01 40=typecode, 05 =gateway RS485 port is at 4800 Baud, 00=No checksum The ED device’s webpage has an interactive console where any command can be entered and it is immediately executed showing the device’s response. Wide Range Power Input: +5VDC to +30VDC accommodates variation in the +24VDC factory floor and allows alternative power sources. Watchdog feature: Allows independent known good states to be set for power up, comms link watchdog and hardware watchdog. Programmable time range allows full control. Lifetime Warranty and Support: We can help with every aspect of your project, from getting you up and running to custom application. ED-038 3 Port selectable DI + 3 Relays Software Development COM Port on Windows On a PC running the Microsoft Windows family of OS’s the ED Boost.IO Manager provides a standard COM port interface so enabling thousands of proven legacy applications to work straight out of the box. COM port compatibility allows you to continue to get value from your existing application software investment. Moreover your engineers don’t need to retrain to use the Brainboxes ED range of I/O devices. Industry Standard Packages The COM port based driver means that ED-xxx devices are completely compatible with all popular packages such as: LabView, MATLAB, Agilent VEE. You can continue to get value from your existing development and process control system. Hundreds of thousands program with these packages every day. Software Platforms The future is mobile, with data available everywhere on demand; Brainboxes has designed a software suite which allows you to design your new systems with mobile in mind with most popular platforms and development environments supported. With APIs and sample program code for: Microsoft .NET, C#, Visual Basic, C++, JavaScript, PHP, Java, Objective-C Devices Supported The ED sample codes running on Operating Systems such as Windows XP, Server 2008, Server 2012, Windows 7, Windows 8, and Linux based systems such as Android and Raspberry Pi allow you to run your applications on Servers, Desktops, Laptops, Tablets, Phones or low cost embedded devices, almost any device you wish. Configuration Options Windows Utility, Web Interface: Boost.IO driver provides familiar Serial COM port interface OS Compatibility Legacy COM porty drivers for: Microsoft Windows 8 32 bit & 64 bit Editions / Microsoft Windows 7 32 bit & 64 bit Editions / Windows Server 2008 32 bit & 64 bit Editions / Windows Server 2008 & Windows 2000 / Windows Vista 32 bit & 64 bit Editions / Windows Server 2003 32 bit & 64 bit Editions. TCP and web browser interface for other OS’s & Linux, e.g. Android, Raspberry Pi Ethernet Ethernet Port 1 x RJ45 jack, 10/100Mhz autosensing, crossover auto sensing (Auto MDIX) Protection 1,500Volts magnetic isolation between I/O ports and network Network Protocols ICMP, IP, TCP, DHCP, Telnet, HTTP Connection to Network Ethernet 10BaseT / 100BaseTX Watchdog Power up On power up all outputs go to user programmable power on known good state Watchdog coms link On loss of communications link all outputs go to a user programmable watchdog comms known good state. Watchdog hardware timer If the firmware does not refresh the watchdog timer within a predetermined interval then all outputs go to a user programmable watchdog hardware good state E-Stop function When a user programmable input transitions to a preconfigured high or low state then all outputs go to a user programmable E-Stop known good state Browser Interface Webserver Interface Configure IP address, monitor state of i/o lines, set the Watchdog Timers Output Reset Value, Set Power on digital output value. Use the interface consol to talk to the device, accepts the full ASCII command set. Monitor CPU temperature and see visual display of inputs and outputs. GB AEOF 00031/11 ED-038 3 Port selectable DI + 3 Relays Housing and connectors IP-30 rated non-conducting polyamide case with integrated DIN rail mount DIO Terminal 10 way x 0.2inch/5.08mm pitch removable screw terminal block Power Terminal 3 way x 0.2inch/5.08mm removable screw terminal block Power Supply Environmental Power Consumption 2.5 Watt Max Operating Temperature Power Supply input unregulated +5V to +30Volts DC, reverse polarity protection Storage Temperature o o 0 C to +60 C, +32ºF to +140ºF o o -40 C to +85 C, -40ºF to +185ºF Isolation 1500VRMS Magnetic isolation from Ethernet Ambient Relative Humidity 5 to 95% (non-condensing) LED Information Status LED Link LED Activity Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Green light on Network Link Established Flashing Green Network Data RX/TX Flashing Green Output set / Input Read Flashing Red Output overload Packaging Information Packaging Installation CD including manual, Microsoft signed drivers & utilities, Quick Start Guide Packaged Weight 0.210 kg, 0.46 pounds Packaged Dims 150(l) x 150(w) x 50(h) mm, 5.9(l) x 5.9(w) x 2.0(h) inches GTIN Universal Code 837324009835 Approvals Industry Approvals CCC-Mark, C-Tick, Microsoft Certified Gold Partner, WEEE, RoHS, METL Microsoft Approvals AEO (C-TPAT) Microsoft Signed Drivers Windows 8 32 bit & 64 bit Editions Windows 7 32 bit & 64 bit Editions Windows Server 2008 32 bit & 64 bit Editions Windows Server 2008 & Windows 2000 Windows Vista 32 bit & 64 bit editions PW-600 Optional Global Power supply MK-048 Optional DIN Rail Mount Power supply with connectors for UK, USA, EU and AUS mains socket. ‘Tails’ are suitable for connecting to screw terminal blocks Can be attached to device to enable snap on DIN rail mounting Trademarks and logos are the property of Brainboxes Ltd. All other trademarks are the property of their respective owners.
ED-038 价格&库存
很抱歉,暂时无法提供与“ED-038”相匹配的价格&库存,您可以联系我们找货
ED-038
  • 1+1215.74258
库存:4
