BL-819
BL-819
    BRAINBOXES
BL-819 数据手册
BL-819 / BL-830 RoHS Compliant BLUETOOTH 1xRS232 MALE DTE - CLASS 2 “SERIAL CARDS ENGINEERED TO EXCEED EXPECTATIONS” Description Compact, Award winning Brainboxes RS232 Adaptor (male connector) allows any device with an RS232 port to communicate with anotherBluetooth device without the need for any additionalsoftware. Ideal for Bluetooth enabling ‘dumb’ RS232 devices such asdataloggers etc. with option to power from Pin 9. Based onfully tested Bluetooth silicon, allowing communications at thefull Bluetooth data rates. Integral antenna. The brainboxes Bluetooth Range Features • Class feature Value Bluetooth device • Suitable for ANY device with serial port • Handshaking RTS/CTS, DTR/DSR • Range - Office: 10m Field:30m Subject to local environment conditions • Power on Pin 9 • Intergral Antenna • Upgradeable onboard flash memory for latest Bluetooth Features • 4 ways to Configure • Up to 1.0 Megabaud RS232 With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! Software Microsoft signed drivers (easy installation & robust operation) for: • • • • Configuration Utility (for Windows) Remote Configuration Over Bluetooth Link Command line Configuration Bulletin Board Configuration As well as: full product documentation, a thorough troubleshooting guide and terminal software. Detailed sample source code for many popular programming languages. Further OS support on next page. • 9 Pin Male and Female Options Options BL-819: BLUETOOTH 1xRS232 MALE DTE - CLASS 2 Class 2 RS232 Bluetooth Adaptor: 9 Pin Female BL-830 *Class 1 devices see: BL-521 & BL-730 ORDER Description Code BLUETOOTH 1xRS232 MALE DTE - CLASS 2 Class 2 RS232 Bluetooth Adaptor: 9 Pin Female BL-819 BL-830 +44(0) 151 220 2500 | sales@brainboxes.com | www.brainboxes.com BL-819 BLUETOOTH 1xRS232 MALE DTE - CLASS 2 BL-819: Full Specification Bluetooth General Bluetooth Qualification 1.1 Qualified Bluetooth Radio Class Of Device Class feature Value Radio Frequency 10m Integral Antenna Yes Receiver Sensitivity -83 Output Power > 0 dBm < +4 dBm Operating Distance (Typical) Metres* Field: 30 Office: 10 Max Transfer rate (Kb/s) 723 Configurable Local Device Name and Device Class Yes Pairing Options Enable/Disable/Link key expiry/2 proximity modes Client and Server Mode Yes Configurable Discoverability, Security mode and PIN number Yes PICONET & SCATTERNET capable Yes PARK and SNIFF mode Yes Factory Reset Yes Baud Rate (KB/s) 921,600 Data Bits 8 Parity Odd, Even, None Stop Bits 1 or 2 Flow Control RTS/CTS, DTR/DSR Encryption ‘None’ , ‘Point to Point’ or ‘Point to Point and Broadcast’ PIN Authentication PIN: Select from list or enter custom (16 character limit) Security Levels Low, Medium & High (Security Mode 1,2 & 3) Power Source External Power Device: 110mA @ 5V Or Power On Pin 9: 5V - 13.6 V LEDs Combined power and Bluetooth link LED Power Consumption Depends on usage Weight 0.024 Size WxDxH (mm) 35x75x20 RS232 Connector 9 pin male OS Compatibility Suitable for any device with Serial Port Configuration Windows Utility software or Remote/terminal Config Approvals Other Approvals http://www.fcc.gov/EMC: CEBluetooth Qualified Product Support Warranty 3 Years Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards “Manufacturer of the Year” Customisable Brainboxes operate a “Perfect Fit Custom Design” policy for volume users. More Info: sales@brainboxes.com Bluetooth Settings Serial Port Settings Bluetooth Security General Interface Additional Made in the UK Datasheet Version: 3.58 Published on: 2009/7/17
BL-819 价格&库存
很抱歉,暂时无法提供与“BL-819”相匹配的价格&库存,您可以联系我们找货
