BL-875
BL-875
    BRAINBOXES
BL-875 数据手册
RoHS Compliant BL-875 BLUETOOTH 2xRS232 PAIRED DEVICES “SERIAL CARDS ENGINEERED TO EXCEED EXPECTATIONS” Description Compact, Award winning Brainboxes Pre-paired RS232 adaptors for cable replacement without the need for any additional software. Ideal for Bluetooth enabling dumb RS232 devices such as dataloggers etc. With option to power from Pin 9. Based on fully tested Bluetooth silicon, Allowing communications at the full Bluetooth data rates. No visible antenna. BLUETOOTH 2xRS232 PAIRED DEVICES Features With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! • Class :Class 2 Bluetooth device • Suitable for ANY device with serial port Software • Handshaking flow control • Range - Office: Field: 30m Office: 10mm • Subject to local environment conditions • Power on Pin 9 • • • • Configuration Utility (for Windows) Remote Configuration Over Bluetooth Link Command line Configuration Bulletin Board Configuration • Intergral Antenna • Upgradeable onboard flash memory for latest Bluetooth Features • 4 ways to Configure As well as: full product documentation, a thorough troubleshooting guide and terminal software. Detailed sample source code for many popular programming languages. Further OS support on next page. • Up to 1.0 Megabaud RS232 • 9 Pin Male and Female Options Options BL-875: BLUETOOTH 2xRS232 PAIRED DEVICES ORDER Description Code BLUETOOTH 2xRS232 PAIRED DEVICES BL-875 +44(0) 151 220 2500 | sales@brainboxes.com | www.brainboxes.com BLUETOOTH 2xRS232 PAIRED DEVICES BL-875: Full Specification Bluetooth General Bluetooth Qualification 1.1 Qualified Bluetooth Radio Class Of Device Class 2 Radio Frequency 2.45 GHz Integral Antenna  Yes Receiver Sensitivity  -83 Output Power  > 0 dBm < 4 dBm Operating Distance (Typical) Metres* Field: 30m Office: 10m Max Transfer rate (Kb/s)  723 Configurable Local Device Name and Device Class Yes Pairing Options  Enable/Disable/Link key expiry/2 proximity modes Client and Server Mode Yes Configurable Discoverability, Security mode and PIN number Yes PICONET & SCATTERNET capable Yes PARK and SNIFF mode  Yes Factory Reset Yes Baud Rate (KB/s) 921,600 Data Bits 8 Parity Odd, Even, None Stop Bits 1 or 2 Flow Control RTS/CTS, DTR/DSR Encryption ‘None’ , ‘Point to Point’ or ‘Point to Point and Broadcast’ PIN Authentication PIN: Select from list or enter custom (16 character limit) Security Levels  Low, Medium & High (Security Mode 1,2 & 3) Power Source External Power Device: 110mA @ 5V Or Power On Pin 9: 5V - 13.6 V LEDs Combined power and Bluetooth link LED Power Consumption Depends on usage Storage Temperature Range 0 °C to +70 °C / +32 °F to +131 °F Weight 0.053 kg Size WxDxH (mm) Each Adapter is 75(l) x 34(w) x 19(h) mm, 2.95(l) x 1.34(w) x 0.75(h) inches RS232 Connector 9 pin male OS Compatibility Suitable for any device with Serial Port Configuration Windows Utility software or Remote/terminal Config Approvals Other Approvals WEEE, RoHS, EMC: CEFCC Compliant, FCC Compliant, Bluetooth Qualified, TAA Product Support Warranty 3 Years Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Bluetooth Settings Serial Port Settings Bluetooth Security General Interface Additional Made in the UK OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards “Manufacturer of the Year” Customisable Brainboxes operate a “Perfect Fit Custom Design” policy for volume users. More Info: sales@brainboxes.com Other Brainboxes Ranges: PCI Express | Bluetooth Serial Adapter | Ethernet to Serial Adapter | PCMCIA Serial Card | ExpressCard Serial Adapter | USB to Serial    +44(0) 151 220 2500 | sales@brainboxes.com | www.brainboxes.com
BL-875 价格&库存
很抱歉,暂时无法提供与“BL-875”相匹配的价格&库存,您可以联系我们找货
