ES-257
ES-257
    BRAINBOXES
    ES-257
ES-257 数据手册
N EW ES-257 ETHERNET TO SERIAL DEVICE SERVER Ethernet 2 Port RS232 CONNECT, CONFIGURE, CONTROL YOUR SERIAL DEVICES Features l 2 port RS232 l Max baud rate 1,000,000 1 MegaBaud l 10/100Base TX Ethernet port l User friendly interface, simple to use, powerful in operation l Web configuration and RFC2217 compliant interface for non-Windows users l IP-30 rated enclosure l LED status indication l Optional DIN rail mounting kit l Serial Port Tunneling (individually configurable) allows serial cable replacement over any distance, no software required l Power supply included (power input 5-30V DC) l Simple operation for each and every operating system! Description Ethernet to Serial device server providing access to two RS232 serial ports. Data transfer rates up to 1,000,000 baud, coupled with 1Mbit/s line drivers deliver uncompromising performance. Our ES range provides simple instant networked serial ports. A web interface allows secure configuration and control of the serial ports over a local network or the internet using any browser. For Windows our in-house designed 32 bit and 64 bit driver gives you local COM ports, retaining existing software applications and allowing you to connect across your network to remote devices just as if they were attached locally. Serial Port Tunnelling individually configurable allows serial cable replacement over any distance, no software required. You can access the device via TCP/IP sockets from any networked device like an Android tablet, PC or phone. On Windows OS TCP/IP sockets are handled by the Winsock API, this will differ on other OSs. Windows Users - Our software drivers gives you local COM ports, allowing you to retain your existing software applications and connect to your devices over the network. COM Port can be assigned from COM1 to COM255 and the Brainboxes Ethernet to serial device remembers your COM Port assignment on reboots. Web Interface Users (Linux/Apple OS/Android) - Alternatively access the device via TCP/IP socket from any networked device. Configure options via web interface. Extend your reach! Remote serial devices with local control. With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! Example Application Industrial PC WWW ES-257 CNC Machine(s) +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-257 Ethernet 2 Port RS232 EW Box Information 97 29 77 101 LED Information Status LED Serial Port LEDs Network LED Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Green light on Port Open Flashing Green Data RX / TX Green light on Link Established Flashing Green Data RX / TX Port Ports 2 port RS232 Connector DB9 Connector - 9 Pin Male Power Input 5 - 30V DC input, reverse polarity protected Power Consumption 0.92W Typical +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-257 Ethernet 2 Port RS232 EW Port Settings - RS232 Baud Rate From 110 - 1,000,000 1 MegaBaud Data Bits 5,6,7 or 8 Parity Odd, Even, None, Mark or Space Stop Bits 1 or 2 Flow Control RTS/CTS, DSR/DTR, XON/XOFF Tx/Rx Modes Point to Point Port Settings - Ethernet Data Rate 10/100 Mega bits/second Cabling Normal / Crossover auto-sensing (Auto-MDIX) Environmental o Operating Temperature 0 to 55 c Storage Temperature -20 to 85 c Ambient Relative Humidity 5 to 95% (non-condensing) Housing IP-30 rated case o Software Network Protocols ICMP, IP, TCP, UDP, DHCP, BOOTP, Telnet, HTTP, RFC2217 Data Transfer Protocol TCP Configuration Options Windows Utility, Web Interface OS Compatibility Microsoft Windows 7 32 bit 64 bit Editions / Windows Server 2008 32 bit 64 bit Editions / Windows Vista 32 bit 64 bit Editions /Windows Server 2003 32 bit 64 bit Editions / Windows XP 32 bit 64 bit Editions / Microsoft Windows 2000 / Fully RFC2217 compliant / Interface for other OS’s & Linux Approvals Industry Approvals AEO C-TPAT Microsoft Certified Gold Partner WEEE RoHS EMC: CE TAA Microsoft Approvals Microsoft Certified Gold Partner Microsoft Signed Drivers Windows 8 32 bit 64 bit Editions Windows 7 32 bit 64 bit Editions Packing Information Packaging Quick Start Guide, Country Specific Power Supply, Installation CD including manual, Microsoft signed drivers & utilities Device Ethernet 2 Port RS232 Accessory Items Global Power Supply - PW-800 (included), DIN-Rail Mounting Kit - MK-048 Packaged Weight 0.379 kg Packaged Dims 200l x 135w x 80h mm +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-257 Ethernet 2 Port RS232 EW Product Support Warranty Lifetime - online registration required Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Additional Information OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards ‘Manufacturer of the Year’ Customisable Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info: sales@brainboxes.com Accessory Items ORDER CODE - DIN-Rail Mounting Kit - MK-048 ORDER CODE - Additional Global Power Supply - PW-800 +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
ES-257 价格&库存
很抱歉,暂时无法提供与“ES-257”相匹配的价格&库存,您可以联系我们找货
ES-257
    • 1+1818.368201+236.38200
    库存:5
    ES-257
    • 1+1830.646651+237.97814
    ES-257
    • 1+1666.00025
    库存:10
