BL-830
BL-830
    BRAINBOXES
BL-830 数据手册
N EW BL-830 / Default Value BLUETOOTH 1xRS232 FEMALE DCE - CLASS “SERIAL CARDS ENGINEERED TO EXCEED EXPECTATIONS” RoHS Compliant Description a Features • Class 2.4 Bluetooth device • Suitable for ANY device with serial port • Power on Pin 9 • Intergral Antenna • Upgradeable onboard flash memory for latest Bluetooth Features Software Microsoft signed drivers (easy installation & robust operation) for: • • • • Configuration Utility (for Windows) Remote Configuration Over Bluetooth Link Command line Configuration Bulletin Board Configuration ft Dra • Range - Office: 723m Field:10m Subject to local environment conditions With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! ary • Handshaking \\puma\Marketing_Dept\ Literature\Datasheets\Datasheet_Preparation\ INDESIGN_FILES\Images\Pinout\BL830Pinout. eps imin Prel Compact, Award winning Brainboxes RS232 Adaptor (female connector) allows any device with an RS232 port to communicate with anotherBluetooth device without the need for any additionalsoftware. Ideal for Bluetooth enabling ‘dumb’ RS232 devices such asdataloggers etc. with option to power from Pin 9. Based onfully tested Bluetooth silicon, allowing communications at thefull Bluetooth data rates. Integral antenna. As well as: full product documentation, a thorough troubleshooting guide and terminal software. Detailed sample source code for many popular programming languages. Further OS support on next page. • 4 ways to Configure • Up to 1.0 Megabaud RS232 Options BL-830: BLUETOOTH 1xRS232 FEMALE DCE - CLASS 2 \\puma\Marketing_Dept\ Literature\Datasheets\ Datasheet_Preparation\ INDESIGN_FILES\Images\ Feature Value Default Value Yes ORDER Description Code BLUETOOTH 1xRS232 FEMALE DCE - CLASS 2 BL-830 \\puma\Marketing_Dept\Literature\Datasheets\Datasheet_Preparation\INDESIGN +44(0) 151 220 2500 | sales@brainboxes.com | www.brainboxes.com BL-830 BLUETOOTH 1xRS232 FEMALE DCE - CLASS 2 BL-830: Full Specification Bluetooth General Bluetooth Qualification 1 Qualified Bluetooth Radio Class Of Device Class 2.4 Radio Frequency -83 Integral Antenna 1.1 Receiver Sensitivity > 0 dBm < +4 dBm Output Power 30 Operating Distance (Typical) Metres* Field: 10 Office: 723 Yes Configurable Local Device Name and Device Class Enable/Disable/Link key expiry/2 proximity modes Pairing Options Yes Client and Server Mode Yes Configurable Discoverability, Security mode and PIN number Yes PICONET & SCATTERNET capable Yes PARK and SNIFF mode Yes Factory Reset 921,600 Baud Rate (KB/s) 8 Data Bits Odd, Even, None Parity 1 or 2 Stop Bits RTS/CTS, DTR/DSR Flow Control \\puma\Marketing_Dept\Literature\Datasheets\Datasheet_Preparation\INDESIGN_ Encryption PIN: Select from list or enter custom (16 character limit) PIN Authentication Low, Medium & High (Security Mode 1,2 & 3) Security Levels External Power Device: 110mA @ 5V Or Power On Pin 9: 5V - 13.6 V Power Source Combined power and Bluetooth link LED LEDs 9 pin female Power Consumption Depends on usage Weight 0.024 Size WxDxH (mm) 35x75x20 RS232 Connector Feature Value OS Compatibility \\puma\Marketing_Dept\Literature\Datasheets\Datasheet_Preparation\INDESIGN_ FILES\Images\ Configuration Windows Utility software or Remote/terminal Config Approvals Other Approvals EMC: CEThe CE marking (also known as CE mark) is a mandatory conformity mark on many products placed on the single market in the European Economic Area (EEA).Official Qualified Bluetooth Device Product Support Warranty 3 Years Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards “Manufacturer of the Year” Customisable Brainboxes operate a “Perfect Fit Custom Design” policy for volume users. More Info: sales@brainboxes.com Serial Port Settings Additional Made in the UK raft Interface D ary General imin Bluetooth Security Prel Max Transfer rate (Kb/s) Bluetooth Settings
BL-830 价格&库存
很抱歉,暂时无法提供与“BL-830”相匹配的价格&库存,您可以联系我们找货
