ES-842
ES-842
    BRAINBOXES
    8 PORT RS422/485 ETHERNET TO SER
ES-842 数据手册
N EW ES-842 ETHERNET TO SERIAL DEVICE SERVER Ethernet 8 Port RS422/485 CONNECT, CONFIGURE, CONTROL YOUR SERIAL DEVICES Features l l l l l l l l l l l l l 8 port RS422/485 Max baud rate 1,000,000 1 MegaBaud 10/100Base TX Ethernet port User friendly interface, simple to use, powerful in operation Web configuration and RFC2217 compliant interface IP-30 rated enclosure LED status indication Optional DIN rail mounting kit Serial Port Tunneling (individually configurable) allows serial cable replacement over any distance, no software required Power supply included with screw fix connector (5-30V DC) Simple operation for each and every operating system! Lifetime Warranty Lifetime Support Description Ethernet to Serial device server providing access to eight RS422/485 serial ports. Data transfer rates up to 1,000,000 baud, coupled with 1Mbit/s line drivers deliver uncompromising performance. Our ES range provides simple instant networked serial ports. RS485 - 1 twisted pair - half duplex configuration with autogating provides trouble free data transmission due to automatic control of data direction. A web interface allows secure configuration and control of the serial ports over a local network or the internet using any browser. For Windows our in-house designed 32 bit and 64 bit driver gives you local COM ports, retaining existing software applications and allowing you to connect across your network to remote devices just as if they were attached locally. Serial Port Tunneling individually configurable allows serial cable replacement over any distance, no software required. You can access the device via TCP/IP sockets from any networked device like an Android tablet, PC or phone. On Windows OS TCP/IP sockets are handled by the Winsock API, this will differ on other OSs. Windows Users - Our software drivers gives you local COM ports, allowing you to retain your existing software applications and connect to your devices over the network. COM Port can be assigned from COM1 to COM255 and the Brainboxes Ethernet to serial device remembers your COM Port assignment on reboots. Web Interface Users (Linux/Apple OS/Android) - Alternatively access the device via TCP/IP socket from any networked device. Configure options via web interface. Extend your reach! Remote serial devices with local control. With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! Example Application Server ES-842 Stepper Motor Control +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-842 Ethernet 8 Port RS422/485 EW Box Information Top Pinout Side 122.5mm Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 RS422/485 Pinout (9 Pin) Pin 1 Pin 5 Pin 6 Pin 9 56mm 215mm Front Back STATUS 56mm ETHERNET TO SERIAL ES-842 8xRS422/485 TXDTXD+ RTSRTS+ GND RXDRXD+ CTS CTS+ NETWORK 215mm Box Size - 122.5 x 215.0 x 56.0 mm Weight - 0.870 kg IP-30 rated case LED Information Status LED Serial Port LEDs Network LED Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Green light on Port Open Flashing Green Data RX / TX Green light on Link Established Flashing Green Data RX / TX Port Ports 8 port RS422/485 Connector DB9 Connector - 9 Pin Male Power Input 5 - 30V DC input, reverse polarity protected Power Consumption 2.86W Typical +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-842 Ethernet 8 Port RS422/485 EW Port Settings - RS422/485 Baud Rate From 110 - 1,000,000 1 MegaBaud Data Bits 5,6,7 or 8 Parity Odd, Even, None, Mark or Space Stop Bits 1, 1.5 or 2 Flow Control RTS/CTS, XON/XOFF Tx/Rx Modes RS422 Standard: RS422 allows one transmitter and up to 10 receivers with data transmitter rates up to 10 megabits per second for distances up to 40 feet and up to 100 Kilobits per second for distances up to 4,000 feet (1219 metres). To achieve good long distance noise immunity, 2 wires are used to carry each signal, configured as a twisted pair of cables. The TXD pair and RXD pair are used to carry the data whilst the RTS pair and CTS pair lines are used for handshaking. Thus 2 twisted pairs are used without handshaking and 4 twisted pair cable is used with handshaking both these schemes allow full duplex data communications. RS485 Standard: RS485, based on the RS422 standard allows up to 32 driver/receivers pairs on a standard load or 128 low load devices per port can be connected. Whilst only one of these should be transmitting data at any time, the rest can all simultaneously listen to the data. Handshaking is performed by software protocol. Two twisted pairs form a full duplex system. Often only one twisted pair cable is used as the TXD and RXD lines are tied together; this is known as half duplex mode. Brainboxes RS422/485 products implement a state of the art hardware autogating circuit ensuring error free communications in half duplex configurations. Port Settings - Ethernet Data Rate 10/100 Mega bits/second Cabling Normal / Crossover auto-sensing (Auto-MDIX) Environmental o Operating Temperature 0 to 55 c Storage Temperature -20 to 85 c Ambient Relative Humidity 5 to 95% (non-condensing) Housing IP-30 rated case o Software Network Protocols ICMP, IP, TCP, DHCP, BOOTP, Telnet, HTTP, RFC2217 Configuration Options Windows Utility, Web Interface OS Compatibility Microsoft Windows 7 32 bit 64 bit Editions / Windows Server 2008 32 bit 64 bit Editions / Windows Vista 32 bit 64 bit Editions / Windows Server 2003 32 bit 64 bit Editions / Windows XP 32 bit 64 bit Editions / Microsoft Windows 2000 /Fully RFC2217 compliant / Interface for other OS’s & Linux Connection to Network Ethernet 10BaseT / 100BaseTX Approvals Industry Approvals AEO C-TPAT Microsoft Certified Gold Partner WEEE RoHS EMC: CE TAA Microsoft Approvals Microsoft Certified Gold Partner Microsoft Signed Drivers Windows 7 32 bit 64 bit Editions +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-842 Ethernet 8 Port RS422/485 EW Packing Information Packaging Installation CD including manual, Microsoft signed drivers & utilities Device Ethernet 8 Port RS422/485 Accessory Items Global Power Supply - PW-500 (included), Snap In DIN Clip lit for 48 ports - MK-070 Wall Mounting Kit for 48 ports - MK-059 Packaged Weight 1.25 kg Packaged Dims 260l x 240w x 80h mm Product Support Warranty Lifetime - online registration required Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Additional Information OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards ‘Manufacturer of the Year’ Customisable Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info: sales@brainboxes.com Accessory Items ORDER CODE - Snap In DIN Clip lit for 48 ports - MK-070 Wall Mounting Kit for 48 ports - MK-059 ORDER CODE - Additional Global Power Supply - PW-500 Brainboxes Ethernet to Serial Range +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
ES-842 价格&库存
很抱歉,暂时无法提供与“ES-842”相匹配的价格&库存,您可以联系我们找货
ES-842
    库存:2
    ES-842
    • 1+6436.470431+836.58420
    • 5+6208.254555+806.92170
    • 10+5934.3954810+771.32670
    ES-842
    • 1+5107.21645
    库存:3
