ES-551
ES-551
    BRAINBOXES
    ISOLATED INDUSTRIAL ETHERNET TO
ES-551 数据手册
N EW ES-551 ETHERNET TO SERIAL DEVICE SERVER Ethernet Industrial Iso 1xRS232/422/485 CONNECT, CONFIGURE, CONTROL YOUR SERIAL DEVICES • 1 Serial port Software Selectable as RS232, RS422/485 Full Duplex, or RS485 Half Duplex • Total Galvanic Isolation • Max baud rate 1,000,000 (1 MegaBaud), any Custom Baud Rate • -30oC to +80oC Temperature range • Integral DIN Rail mount, small foot print Features • 1 Serial port Software Selectable as RS232, RS422/485 Full Duplex, or RS485 Half Duplex • Total Galvanic Isolation • 1 Port Ethernet • Integrated DIN rail mount and Slim Case • Brainboxes’ Easy Wire: Removable, colour coded, Screw Terminal blocks with individually numbered pins makes wiring fast, simple and error proof • Extended Temperature Range: -30ºC to +80ºC • IP-30 rated non-conducting polyamide enclosure • LED status indication • Wide Range Input Power Supply: +5VDC to +30VDC • Redundant Dual Power Input • Grounds on every 5th pin. Functional Earth via integral DIN rail mount • Brainboxes state of the art Autogating for trouble free RS485 Half Duplex flow control • Max baud rate 1,000,000 (1 MegaBaud), Custom Baud Rates • 10/100Base TX Ethernet port • Smart Ethernet: recognises straight and crossover Ethernet cables and works with either • Serial Port Tunneling allows serial cable replacement over any distance, no software required • User friendly interface, simple to use, powerful in operation • Web configuration and RFC2217 compliant interface for non-Windows users • Simple operation for each and every operating system! • Life time Support and Lifetime warranty with sign up +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N EW ES-551 Ethernet Industrial Iso Description Ethernet to Serial Device with 1 Port software selectable as RS232, RS422/485 Full duplex or RS422 Half duplex and 2 Ethernet ports. ES-551 has removable Screw Terminals Blocks for easy wiring, a slim ‘end on’ case and integral DIN rail mount. Our Industrial Ethernet to Serial has an operating temperature range of -30 to +80 degrees Celsius and with +5VDC to +30VDC Dual input reverse polarity protected power supply making it perfect for industrial applications. Data transfer rates up to 1,000,000 baud, coupled with 1Mbit/s line drivers deliver uncompromising performance. Our Industrial ES range provides simple instant networked serial ports in demanding environments. Serial Port Tunneling allows serial cable replacement over any distance, no software required. Suitable to be wired into existing power and network infrastructure or can be used with our PW-600 power supply. Windows Users - Our software drivers give you local COM ports, allowing you to retain your existing software applications and connect to your devices over the network. COM Port can be assigned from COM 1 to COM 255 and the Brainboxes Ethernet to serial device remembers your COM Port assignment on reboots. Web Interface Users (Linux/Apple OS/Android) - A web interface allows secure configuration and control of the serial ports over a local network or the internet using any browser. You can access the device via TCP/IP sockets from any networked device like an Android tablet, PC or phone. Extend your reach! Remote serial devices with local control. With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! Example Application ES-551 Factory Floor Application Factory floors can be harsh environments. Extreme temperatures can be generated in the manufacturing process, machinery can be noisy and generate electromagnetic interference and space is a premium. But engineers still need to be able to access and maintain equipment safely and without downtime. As factories expand and modernise older equipment and remote devices need to be networked, but cabling can be expensive and impractical, especially over larger areas. The ES-551 with total galvanic isolation has 1 serial port that is software selectable as either RS232, RS422 or RS485 and 1 Ethernet port. The ‘Easy Wire’ removable colour coded Screw Terminals Blocks are individually numbered for simple fast, error free wiring. The slim ‘end on’ case with integral mount clips straight on to a DIN Rail. The ES-551 has an operating temperature range of -30ºC to +80ºC and +5VDC to +30VDC Dual input reverse polarity protected power supply. Brainboxes proven technology supports legacy applications, whilst our Ethernet to Serial software ensures fast data transmission and a super easy installation whatever your operating system. Once your Serial equipment is connected to a Brainboxes Ethernet to Serial device you have the option of accessing it over a local network or connecting it to the internet. The devices can be fitted in areas where it would be dangerous for workers to monitor whilst the factory line is in operation. Manufacturing process and performance across a large site can be monitored and potential faults detected before they cause serious downtime costs. The total galvanic isolation prevents problems from sources of electromagnetic interference. Use two devices back to back for serial tunnelling over Ethernet, for when you need to extend the reach of your serial cables. +44(0) 151 151 220 220 2500 2500 sales@brainboxes.com sales@brainboxes.com www.brainboxes.com www.brainboxes.com +44(0) N EW ES-551 Ethernet Industrial Iso Feature Profile Slim Shape: Small foot print for when DIN rail space is a premium Only 22.5mm wide Extended Temperature Range: -30ºC to +80ºC operating range copes with changing temperatures for harsh environments Brainboxes’ Easy Wire Feature: Removable screw terminal blocks make installation easier and quicker Colour coded blocks and ports prevents incorrect connection Numbered Pins simplifies wiring and removes confusion Redundant Dual Power Input: A second power supply can be fitted as a back-up to prevent down time should one power source fail. Wide Range Input Power Supply: +5VDC to +30VDC accommodates variation in the +24VDC factory floor and allows alternative power sources. Can use 5 Volt power from any computer USB port. Total Galvanic Isolation: The power supply, Serial port and Ethernet ports are all mutually isolated from each other. Prevents electromagnetic interference problems, this is useful for applications in electromagnetically noisy environments such as processes involving power generators, motors, arc furnaces, induction heaters etc. Grounding: Correctly wired grounds help cut down on electromagnetic interference 5 pin terminals allow a ground on the 5th pin of each block Functional earth connection to the DIN rail Smart Ethernet: Recognises and works with both straight and crossover Ethernet cables (Auto MDI/MDIX) Mag Jacks are isolated offsetting any difference in grounds between Ethernet nodes. Inbuilt Ethernet Switch (ES-571 only): Allows two port devices to be ‘daisy chained’ extending the reach of Ethernet cabling for an instant infrastructure upgrade +44(0) 151 151 220 220 2500 2500 sales@brainboxes.com sales@brainboxes.com www.brainboxes.com www.brainboxes.com +44(0) N ES-551 Ethernet Industrial Iso EW Enclosure Specification Housing IP-30 rated non-conducting polyamide case with integrated DIN rail mount Environmental Operating Temperature o o o o -30 C to +80 C Storage Temperature -40 C to +85 C Ambient Relative Humidity 5 to 95% (non-condensing) LED Information Status LED Serial Port LEDs Network LED Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Green light on Port Open Flashing Green Data RX/TX Green light on Link Established Flashing Green Data RX/TX +44(0) 151 151 220 220 2500 2500 sales@brainboxes.com sales@brainboxes.com www.brainboxes.com www.brainboxes.com +44(0) N EW ES-551 Ethernet Industrial Iso Port - Serial Ports 1 port Software Selectable as RS232, RS422/485 Full Duplex, or RS485 Half Duplex Connector Removable Screw terminal block connector - 3.5 mm pitch Power Input Redundant DC Dual Power Inputs, reverse polarity protected +5 VDC to +30VDC Power Consumption Conductor Wire 1.6 Watt typical 60mA@24V - 2.9 Watt Max 28 to 16 AWG, 0.14mm to 1.5mm Max Port Settings - Software Selectable as RS232, RS422/485 Full Duplex, or RS485 Half Duplex Baud Rate Any custom Baud rate between 60 - 1,000,000 (1 MegaBaud) can be selected Data Bits 5,6,7 or 8 Parity Odd, Even, None, Mark or Space Stop Bits 1, 1.5 or 2 Flow Control RTS/CTS, DSR/DTR, XON/XOFF Tx/Rx Modes RS232 Standard: RS232 allows point to point communication between 2 devices. RS422 Standard: RS422 allows one transmitter and up to 10 receivers with data transmitter rates up to 10 megabits per second for distances up to 40 feet and up to 100 Kilobits per second for distances up to 4,000 feet (1219 metres). To achieve good long distance noise immunity, 2 wires are used to carry each signal, configured as a twisted pair of cables. The TXD pair and RXD pair are used to carry the data whilst the RTS pair and CTS pair lines are used for handshaking. Thus 2 twisted pairs are used without handshaking and 4 twisted pair cable is used with handshaking both these schemes allow full duplex data communications. RS485 Standard: RS485, based on the RS422 standard allows up to 32 driver/receivers pairs on a standard load or 128 low load devices per port can be connected. Whilst only one of these should be transmitting data at any time, the rest can all simultaneously listen to the data. Handshaking is performed by software protocol. Two twisted pairs form a full duplex system. Often only one twisted pair cable is used as the TXD and RXD lines are tied together; this is known as half duplex mode. Brainboxes RS422/485 products implement a state of the art hardware autogating circuit ensuring error free communications in half duplex configurations. Industrial Ethernet to Serial RS485: recievers are 1/8th load allowing upto 256 nodes on the bus. Fail safe open circuit and short circuit protection, protects the Industrial Ethernet to Serial against wiring faults. Line Terminating Resistor: On board RS485 line termination resistor can be enabled by a user selectable jumper. The RS422/485 line terminating resister prevents signal reflections when the ES device is at the end of transmission line. Bias Resistors: On board RS485 Half Duplex fail safe bias resistors enabled by user selectable jumpers. The fail safe biasing resistors pull the line to a known good state during idle times preventing phantom character detection. Port Settings - Ethernet Data Rate 10/100 Mega bits/second Cabling Normal / AUTO MDI/MDIX and IEEE Auto crossover support IEEE802.1q VLAN support for up to 128 VLAN groups. Broadcast storm protection. IEEE 802.1d rapid spanning tree protocol RSTP support. Software Network Protocols ICMP, IP, TCP, UDP, DHCP, BOOTP, Telnet, HTTP, RFC2217 Connection to Network Ethernet 10BaseT / 100BaseTX Configuration Options Windows Utility, Web Interface Performance Industry leading Performance Throughput guaranteed minimum of 95% of theoretical bi-direction full duplex band width at 1 MBaud Input CTS False to Transmitter stop: 3 characters max, 1.5 typical XOFF recieved to Transmitter stop: 3 characters max, 1.5 typical RS485 Autogating Turn around time:
ES-551 价格&库存
很抱歉,暂时无法提供与“ES-551”相匹配的价格&库存,您可以联系我们找货
ES-551
    • 1+2964.24665
    库存:6
