ES-413
ES-413
    BRAINBOXES
    2 PORT RS422/485 POE ETHERNET TO
ES-413 数据手册
GB AEOF 00031/11 ES-413 PoE ETHERNET TO SERIAL DEVICE SERVER Ethernet 2 Port RS422/485 Power Over Ethernet PoE CONNECT, CONFIGURE, CONTROL YOUR SERIAL DEVICES Features • • • • • 2 Port RS-422/485 with Power over Ethernet IEEE802.3af Ethernet to Serial Device Server Data rate from 110 to 1,000,000 baud User friendly interface, simple to use, powerful in operation Serial Port Tunnelling allows serial cable replacement over any distance, no software required • Optional DIN rail mounting kit and stand alone power supply Description Ethernet to Serial device server with Power over Ethernet providing access to two RS422/485 serial ports. Data transfer rates up to 1,000,000 baud, coupled with 1Mbit/s line drivers deliver uncompromising performance. Power over Ethernet PoE uses IEEE 802.3af standard, compatible with any PoE switch.Our ES range provides simple instant networked serial ports. RS485 - 1 twisted pair - half duplex configuration with autogating provides trouble free data transmission due to automatic control of data direction. A web interface allows secure configuration and control of the serial ports over a local network or the internet using any browser. For Windows our in-house designed 32 bit and 64 bit driver gives you local COM ports, retaining existing software applications and allowing you to connect across your network to remote devices just as if they were attached locally. Serial Port Tunnelling individually configurable allows serial cable replacement over any distance, no software required. You can access the device via TCP/ IP sockets from any networked device like an Android tablet, PC or phone. On Windows OS TCP/IP sockets are handled by the Winsock API, this will differ on other OSs. Extend your reach! Remote serial devices with local control. With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! Example Application PoE Switch PoE Single Cable Connect, Configure, Control Serial ES-413 Ethernet 2 Port RS422/485 Power Over Ethernet PoE Box Information Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 97 29 TXDTXD+ RTSRTS+ GND RXDRXD+ CTS CTS+ RS422/485 Pinout (9 Pin) Pin 1 Pin 5 Pin 6 Pin 9 77 101 LED Information Status LED Serial Port LEDs Network LED Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Green light on Port Open Flashing Green Data RX / TX Green light on Link Established Flashing Green Data RX / TX Port Ports 2 port RS422/485 Connector DB9 Connector - 9 Pin Male Power Input Power Over Ethernet OR 5 - 30V DC input, reverse polarity protected Power Consumption 2.15W +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ES-413 Ethernet 2 Port RS422/485 Power Over Ethernet PoE Port Settings - RS422/485 Baud Rate From 110 - 1,000,000 1 MegaBaud Data Bits 5,6,7 or 8 Parity Odd, Even, None, Mark or Space Stop Bits 1 or 2 Flow Control RTS/CTS, XON/XOFF Tx/Rx Modes Full Duplex, Half Duplex Autogating - Hardware Autogating Port Settings - Ethernet Data Rate 10/100 Mega bits/second Cabling Normal / Crossover auto-sensing (Auto-MDIX) Power over Ethernet Power Over Ethernet OR 5 - 30V DC input, reverse polarity protected IEEE 802.3af Environmental Operating Temperature 0 °C to +60 °C / 32 °F to +140 °F Ambient Relative Humidity 5 to 95% (non-condensing) Housing IP-30 rated case Software Network Protocols ICMP, IP, TCP, UDP, DHCP, BOOTP, Telnet, HTTP, RFC2217 Data Transfer Protocol TCP Configuration Options Windows Utility, Web Interface OS Compatibility Communicate with Device over TCP from any OS / Microsoft Windows 8 32 bit 64 bit Editions / Windows Server 2012 /Microsoft Windows 7 32 bit 64 bit Editions / Windows Server 2008 32 bit 64 bit Editions / Windows Vista 32 bit 64 bit Editions / Fully RFC2217 compliant / Interface for other OS’s & Linux Approvals Industry Approvals AEO C-TPAT Microsoft Certified Gold Partner WEEE RoHS EMC: CE TAA Microsoft Approvals Microsoft Certified Gold Partner Microsoft Signed Drivers Windows 8 32 bit 64 bit Editions Windows 7 32 bit 64 bit Editions Packing Information Packaging Quick Start Guide, Installation CD including manual, Microsoft signed drivers & utilities Device Ethernet 2 Port RS422/485 Power Over Ethernet PoE Accessory Items Available from Brainboxes : Optional Global Power Supply - PW-800, DIN-Rail Mounting Kit - MK-048 Packaged Weight 0.244 kg, 8.61 ounces Packaged Dims 160x135x45 mm, 6.3x5.3x1.8 inches UPC number 837324003789 +1 855 958 2502 sales@brainboxes.com www.brainboxes.com ES-413 Ethernet 2 Port RS422/485 Power Over Ethernet PoE Product Support Warranty Lifetime - online registration required Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Additional Information OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards ‘Manufacturer of the Year’ Customisable Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info: sales@brainboxes.com Accessory Items ORDER CODE - DIN-Rail Mounting Kit - MK-048 ORDER CODE - Optional Global Power Supply - PW-800 +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
ES-413 价格&库存
很抱歉,暂时无法提供与“ES-413”相匹配的价格&库存,您可以联系我们找货
ES-413
  • 1+2067.090621+267.93430
  • 5+1997.434965+258.90560
  • 10+1916.1845510+248.37400
ES-413
  • 1+1752.60712
库存:7
