GB AEOF 00031/11
ES-420 PoE ETHERNET TO SERIAL DEVICE SERVER
Ethernet 1 Port RS422/485 Power Over Ethernet PoE
CONNECT, CONFIGURE, CONTROL YOUR SERIAL DEVICES
Features
1 Port RS-422/485 with Power over Ethernet IEEE802.3af
Ethernet to Serial Device Server
Data rate from 110 to 1,000,000 baud
User friendly interface, simple to use, powerful in operation
Serial Port Tunnelling allows serial cable replacement over any
distance, no software required
• Optional DIN rail mounting kit and stand alone power supply
Description
Ethernet to Serial device server with Power over Ethernet providing access to one RS422/485 serial port. Data transfer rates up to 1,000,000 baud,
coupled with 1Mbit/s line drivers deliver uncompromising performance. Power over Ethernet PoE uses IEEE 802.3af standard, compatible with any
PoE switch.Our ES range provides simple instant networked serial ports. RS485 - 1 twisted pair - half duplex configuration with autogating provides
trouble free data transmission due to automatic control of data direction. A web interface allows secure configuration and control of the serial ports
over a local network or the internet using any browser. For Windows our in-house designed 32 bit and 64 bit driver gives you local COM ports,
retaining existing software applications and allowing you to connect across your network to remote devices just as if they were attached locally. Serial
Port Tunnelling individually configurable allows serial cable replacement over any distance, no software required. You can access the device via TCP/
IP sockets from any networked device like an Android tablet, PC or phone. On Windows OS TCP/IP sockets are handled by the Winsock API, this will
differ on other OSs.
Extend your reach! Remote serial devices with local control. With Brainboxes industry renowned Lifetime Warranty and Lifetime Support!
Example Application
PoE Switch
PoE
Single Cable
Connect, Configure, Control
Serial
ES-420 Ethernet 1 Port RS422/485 Power Over Ethernet PoE
Box Information
Pin 1
Pin 2
Pin 3
Pin 4
Pin 5
Pin 6
Pin 7
Pin 8
Pin 9
97
29
TXDTXD+
RTSRTS+
GND
RXDRXD+
CTS
CTS+
RS422/485 Pinout (9 Pin)
Pin 1
Pin 5
Pin 6
Pin 9
77
101
LED Information
Status LED
Serial Port LEDs
Network LED
Green
Device Ready
Flashing Yellow
Changing Settings
Flashing between Red & Green
Querying IP
Flashing Green/Red
User performing Hard Reset
Flashing between Green & Red/Yellow
IP address diagnostic
Flashing between Green & Yellow
Initialization diagnostic
Green light on
Port Open
Flashing Green
Data RX / TX
Green light on
Link Established
Flashing Green
Data RX / TX
Port
Ports
1 port RS422/485
Connector
DB9 Connector - 9 Pin Male
Power Input
Power Over Ethernet OR 5 - 30V DC input, reverse polarity protected
Power Consumption
1.74W
+44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
Port Settings - RS422/485
Baud Rate
From 110 - 1,000,000 1 MegaBaud
Data Bits
5,6,7 or 8
Parity
Odd, Even, None, Mark or Space
Stop Bits
1 or 2
Flow Control
RTS/CTS, XON/XOFF
Tx/Rx Modes
Full Duplex, Half Duplex Autogating - Hardware Autogating
Port Settings - Ethernet
Data Rate
10/100 Mega bits/second
Cabling
Normal / Crossover auto-sensing (Auto-MDIX)
Power over Ethernet
Power Over Ethernet OR 5 - 30V DC input, reverse polarity protected IEEE 802.3af
Environmental
Operating Temperature
0 °C to +60 °C / 32 °F to +140 °F
Ambient Relative Humidity
5 to 95% (non-condensing)
Housing
IP-30 rated case
Software
Network Protocols
ICMP, IP, TCP, UDP, DHCP, BOOTP, Telnet, HTTP, RFC2217
Data Transfer Protocol
TCP
Configuration Options
Windows Utility, Web Interface
OS Compatibility
Communicate with Device over TCP from any OS / Microsoft Windows 8 32 bit 64 bit Editions / Windows
Server 2012 /Microsoft Windows 7 32 bit 64 bit Editions / Windows Server 2008 32 bit 64 bit Editions /
Windows Vista 32 bit 64 bit Editions / Fully RFC2217 compliant / Interface for other OS’s & Linux
Approvals
Industry Approvals
AEO C-TPAT Microsoft Certified Gold Partner WEEE RoHS EMC: CE TAA
Microsoft Approvals
Microsoft Signed Drivers
Packing Information
Packaging
Quick Start Guide, Installation CD including manual, Microsoft signed drivers & utilities
Device
Accessory Items
Available from Brainboxes : Optional Global Power Supply - PW-800, DIN-Rail Mounting Kit - MK-048
Packaged Weight
0.234 kg, 8.25 ounces
Packaged Dims
160x135x45 mm, 6.3x5.3x1.8 inches
UPC number
837324003734
+1 855 958 2502 sales@brainboxes.com www.brainboxes.com
Product Support
Warranty
Lifetime - online registration required
Support
Lifetime Web, Email and Phone Support from fully qualified, friendly staff who
work in and alongside the Product Development Team
Additional Information
OEM option
Available for bulk buy OEM
Made In
Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards
‘Manufacturer of the Year’
Customisable
Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info:
Accessory Items
ORDER CODE - DIN-Rail Mounting Kit - MK-048
ORDER CODE - Optional Global Power Supply - PW-800
很抱歉,暂时无法提供与“ES-420”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1680.190561+218.38380
- 5+1620.550145+210.63200
- 10+1549.0859710+201.34340
