N
EW
ES-701 ETHERNET TO SERIAL DEVICE SERVER
Ethernet 4 Port RS232
CONNECT, CONFIGURE, CONTROL YOUR SERIAL DEVICES
Features
l 4 port RS232
l Max baud rate 230,400
l 10/100Base TX Ethernet port
l User friendly interface, simple to use, powerful in operation
l Web configuration and RFC2217 compliant interface for non-Windows
users
l IP-30 rated enclosure
l LED status indication
l Optional DIN rail mounting kit
l Serial Port Tunneling (individually configurable) allows serial cable
replacement over any distance, no software required
l Power supply included (power input 5-30V DC)
l Simple operation for each and every operating system!
Description
Ethernet to Serial device server providing access to four RS232 serial port. Data transfer rates up to 230,400 baud rates, coupled with 1Mbit/s
line drivers deliver uncompromising performance. Our ES range provides simple instant networked serial ports. A web interface allows secure
configuration and control of the serial ports over a local network or the internet using any browser. For Windows our in-house designed 32 bit and
64 bit driver gives you local COM ports, retaining existing software applications and allowing you to connect across your network to remote devices
just as if they were attached locally. Serial Port Tunneling individually configurable allows serial cable replacement over any distance, no software
required. You can access the device via TCP/IP sockets from any networked device like an Android tablet, PC or phone. On Windows OS TCP/IP
sockets are handled by the Winsock API, this will differ on other OSs.
Windows Users - Our software drivers gives you local COM ports, allowing you to retain your existing software applications and connect to your
devices over the network. COM Port can be assigned from COM1 to COM255 and the Brainboxes Ethernet to serial device remembers your COM
Port assignment on reboots.
Web Interface Users (Linux/Apple OS/Android) - Alternatively access the device via TCP/IP socket from any networked device. Configure options
via web interface.
Extend your reach! Remote serial devices with local control. With Brainboxes industry renowned Lifetime Warranty and Lifetime Support!
Example Application
Industrial PC
WWW
ES-701
CNC Machine(s)
+44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
N
ES-701 Ethernet 4 Port RS232
EW
Box Information
Top
Side
Pinout
122.5mm
Pin 1
Pin 2
Pin 3
Pin 4
Pin 5
Pin 6
Pin 7
Pin 8
Pin 9
DCD
RXD
TXD
DTR
GND
DSR
RTS
CTS
RI
4
Pin 6
Pin 9
ETHERNET TO SERIAL
ES-701 4xRS232
STATUS
NETWORK
34mm
3
Pin 5
Back
Front
2
Pin 1
34mm
215mm
1
RS232 Pinout (9 Pin Male)
215mm
Box
Size: 122.5 x 215.0 x 34.0 mm
Product weight: 0.772 kg
IP30 rated case
LED Information
Status LED
Serial Port LEDs
Network LED
Green
Device Ready
Flashing Yellow
Changing Settings
Flashing between Red & Green
Querying IP
Flashing Green/Red
User performing Hard Reset
Flashing between Green & Red/Yellow
IP address diagnostic
Flashing between Green & Yellow
Initialization diagnostic
Green light on
Port Open
Flashing Green
Data RX / TX
Green light on
Link Established
Flashing Green
Data RX / TX
Port
Ports
4 port RS232
Connector
DB9 Connector - 9 Pin Male
Power Input
5 - 30V DC input, reverse polarity protected
Power Consumption
1.35W Typical
N
EW
Port Settings - RS232
Baud Rate
From 110 - 230,400
Data Bits
5,6,7 or 8
Parity
Odd, Even, None, Mark or Space
Stop Bits
1, 1.5 or 2
Flow Control
RTS/CTS, DSR/DTR, XON/XOFF
Tx/Rx Modes
Point to Point
Port Settings - Ethernet
Data Rate
10/100 Mega bits/second
Cabling
Normal / Crossover auto-sensing (Auto-MDIX)
Environmental
o
Operating Temperature
0 to 55 c
Storage Temperature
-20 to 85 c
Ambient Relative Humidity
5 to 95% (non-condensing)
Housing
IP-30 rated case
o
Software
Network Protocols
ICMP, IP, TCP, UDP, DHCP, BOOTP, Telnet, HTTP, RFC2217
Data Transfer Protocol
TCP
Configuration Options
Windows Utility, Web Interface
OS Compatibility
Microsoft Windows 7 32 bit 64 bit Editions / Windows Server 2008 32 bit 64 bit Editions / Windows Vista
32 bit 64 bit Editions /Windows Server 2003 32 bit 64 bit Editions / Windows XP 32 bit 64 bit Editions /
Microsoft Windows 2000 / Fully RFC2217 compliant / Interface for other OS’s & Linux
Approvals
Industry Approvals
AEO C-TPAT Microsoft Certified Gold Partner WEEE RoHS EMC: CE TAA
Microsoft Approvals
Microsoft Signed Drivers
Windows Vista 32 bit 64 bit editions
Windows XP 32 bit 64 bit editions
Packing Information
Packaging
Quick Start Guide, Country Specific Power Supply, Installation CD including manual, Microsoft signed drivers
& utilities
Device
Accessory Items
Global Power Supply - PW-800 (included), Wall Mounting kit for 48 ports - MK-059 Snap In DIN Clip kit
for 48 ports - MK-070
Packaged Weight
1.009 kg
Packaged Dims
240l x 250w x 65h mm
N
EW
Product Support
Warranty
Lifetime - online registration required
Support
Lifetime Web, Email and Phone Support from fully qualified, friendly staff who
work in and alongside the Product Development Team
Additional Information
OEM option
Available for bulk buy OEM
Made In
Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards
‘Manufacturer of the Year’
Customisable
Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info:
Accessory Items
ORDER CODE - Wall Mounting kit for 48 ports - MK-059
Snap In DIN Clip kit for 48 ports - MK-070
ORDER CODE - Additional Global Power Supply - PW-800
很抱歉,暂时无法提供与“ES-701”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3857.540281+500.01067
- 国内价格 香港价格
- 1+3768.467221+488.46510
- 5+3632.468685+470.83710
- 10+3472.2345110+450.06770
