UK +44 (0)151 220 2500 // USA +1 855 958 2502 // JAPAN +81-3-3683-0509
www.brainboxes.com // sales@brainboxes.com
CB-534 Industrial Isolated RS232 Booster
RS232 Booster
• Boosts and isolates RS232 signals
• Max baud rate 120,000
• Works at all data word lengths, parity
options and stop bit combinations
• -30°C to +80°C/-22ºF to +176ºF
Temperature range
CB-512
CB-523
CB-534
ISOLATION
OUTPUT SWING
-11V to +11V
ü
RS232
RS422/485
PROTOCOL
CONVERSION
MAX
BAUD
1 Mb
1Mb
120 kb
Connect to legacy equipment
Protect with Isolation
Boost RS232 signal
Some machines require a larger
voltage input than the RS232
standard. The CB-534 conditions the
signal to make it suitable for legacy
equipment.
CB-534 isolates the connected devices
from each other. This protects
against relative differences in ground
voltages.
RS232 signal can degrade over long
cable runs. The CB-534 boosts the
RS232 signal enabling additional
distance between connections.
GB AEOF 00031/11
CB-534
Easy Wire Removable screw terminal blocks
2 Port Serial RS232
Integral DIN rail clip with earth
-30ºC to +80ºC/-22ºF to
+176ºF temperature range
LED status indication
IP20 Non-conducting
polyamide case with vents
Wide Range Input Power: +5VDC to
+30VDC
Booster for RS232 signal can extend cable length. Works with a wide voltage swing and outputs
-11V to +11V signal making it suitable for legacy and non-conforming RS232 equipment.
Provides isolation between two RS232 devices. This product doesn't require any software, simply
connect using the easy-wire numbered terminal blocks.
Connectors
Screw Terminals
Conductor Wire
Environmental
Operating Temperature
Storage Temperature
Ambient Relative Humidity
Serial Port
Ports
Port Settings
Baud Rate
Output signal swing
Signals supported
Power Supply
Power Supply input
Power Consumption
3.5mm pitch, #22 - #14, 0.5mm2-2.5mm2 pin
28 to 16 AWG, 0.14mm to 1.5mm Max
-30oC to +80oC / -22ºF to +176ºF
-40oC to +85oC / -40ºF to +185ºF
5 to 95% (non-condensing)
2 RS232
120,000 max
Typ. +/- 11V into RS-232 compliant load
TXD, RXD, RTS, CTS
Redundant DC Dual Power Inputs, reverse polarity protected +5 VDC to
+30VDC
2.5 Watt typical 110mA@24V
CB-534
Housing
IP-20 rated non-conducting polyamide case
Terminal Block Pin Outs: Yellow: Port 1 / Grey: Port 2
RS232
Pin 1
Pin 2
Pin 3
Pin 4
Pin 5
SIG GND
CTS
RxD
RTS
TxD
+VB
-V
Func
GND
Black: +5V to +30V DC Power Input
Power
-V
+VA
Lifetime Warranty and Support:
We can help with every aspect of your project, from getting you up and running to
custom application.
CB-534
Packaging Information
Packaging
Installation CD including manual, Quick Start Guide, Device
Packaged Weight
0.206 kg, 7.27 ounces
Packaged Dims
160x135x49 mm, 6.3x5.3x1.9 inches
GTIN Universal Code
837324004045
Approvals
Industry Approvals
Microsoft Certified Gold Partner, WEEE, RoHS, AEO (C-TPAT), CE
Product Support
Warranty
Lifetime - online registration required
Support
Lifetime Web, Email and Phone Support from fully qualified, friendly staff
who work in and alongside the Product Development Team
Additional Information
OEM option
Available for bulk buy OEM
Made In
Manufactured in the UK by Brainboxes Winner 2005 European Electronics
Industry Awards ‘Manufacturer of the Year’
Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users.
More info:sales@brainboxes.com
Customisable
PW-600
PW-650
ES Range
Power supply with connectors
for UK, USA, EU and AUS mains
socket. ‘Tails’ are suitable for
connecting to screw terminal
blocks.
Power supply with USB
connector and prewired screw
terminal block. Suitable for use
with 5V USB ports.
Ethernet to Serial products are
available in a range of formats
and specifications.
www.brainboxes.com
© Brainboxes 2017
BBCB170530
很抱歉,暂时无法提供与“CB-534”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2680.989251+348.51993
- 国内价格 香港价格
- 1+2696.160201+350.49210
- 5+2600.629365+338.07340
- 10+2485.8880410+323.15740
