ED-527
ED-527
    BRAINBOXES
    ED-527
ED-527 数据手册
Ethernet to Digital In/Out ED-527 ED-527 ETHERNET TO Digital IO 16 Outputs ED-527 • 16 Digital Outputs • Drives high current and high voltage loads • Ideal for inductive, capacitive & resistive loads • Gateway Port for NuDAM/ADAM modules • -30oC to +80oC Temperature range • +5V to +30V DC Input Power 1 2 3 4 5 A Digital Channels Outputs B Output Channels 8 non-isolated output channels Maximum output current Sinks up to 1 Amp per pin, 40V max load Max combined load 4.0 Amps per ED device Characteristic: Open drain output, protected MosFET with intelligent short circuit protection up to 36V Over temperature shutdown:1750C typical 1500C min Maximum output load Voltage 40V ESD Protection 16kV ED-588 ED-588 External Circuit C External Circuit 24VOLTS 24VOLTS LAMP= OFF 1 OUTPUT PIN=24V 2 Resistor current= 24mA OUTPUT PIN=~0V D OUT2 (Pin 4) D OUT1 (Pin 3) 1 Bit=1 UN_OUT02 0 1K D OUT3 (Pin 5) Resistor current= 0 D OUT2 (Pin 4) Bit=0 UN_OUT02 LAMP= ON 1K D OUT3 (Pin 5) 1 D OUT0 (Pin 2) 2 D OUT1 (Pin 3) D OUT0 (Pin 2) SWITCH D GND ALWAYS CONNECT (Pin 1) GND ALWAYS CONNECT (Pin 1) EXTERNAL GROUND EXTERNAL GROUND Title ETHE Number 90 Date: 10-7-20 Drawn By: EA 1 2 Connect, Configure, Control 3 4 5 ED-527 Ethernet 16 DO Usage Model for ED-527 Digital Outputs Ethernet Connection Gateway RS485 Digital Outputs 5V Power Power from laptop for configuration 24V Power Dual redundant power supply ASCII software commands - LabView, MATLAB, Agilent VEE Remote access for maintenance and monitoring Integral horsepower motors Relays Stepper Motors Lighting Contactors Andon Lights Heating Starters Fans/ Air conditioning systems Fluid and fuel flow Two-position actuators Alarms/ Safety devices +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-527 Ethernet 16 DO 8 Digital Outputs RS485 Gateway for NuDAM/ADAM Modules Easy to use Interface: Great features for remote monitoring Integral DIN rail mount Ethernet port LED Status Indication 8 Digital Outputs +5V to +30V Power Supply Continue to get value from your existing development and process control system. The COM port based driver means that the Ethernet to DIO devices are completely compatible with all popular packages such as LabView, MATLAB and Agilent VEE and support a range of popular APIs. Slim Shape: Small foot print for when DIN rail space is a premium Only 22.6mm wide Extended Temperature Range: -30ºC to +80ºC operating range copes with changing temperatures for harsh environments. Monitor CPU temperature via the web interface or programmatically using ASCII commands. Brainboxes’ Easy Wire Feature: Removable screw terminal blocks make installation easier and quicker Colour coded blocks and ports prevents incorrect connection Numbered Pins simplifies wiring and removes confusion +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-527 Ethernet 16 DO Grounding: Correctly wired grounds help cut down on electromagnetic interference 5 pin terminals allow a ground on the 5th pin of each block Functional earth connection to the DIN rail Gateway RS485 Serial Port: Half duplex RS485 port allows connection and control of industry standard NuDAM, eDAM and ADAM modules using ASCII protocols. Wide Range Redundant Dual Power Input: +5VDC to +30VDC accommodates variation in the +24VDC factory floor and allows alternative power sources. A second power supply can be fitted as a back-up to prevent down time should one power source fail. Can use 5 Volt power from any computer USB port via optional accessory cable PW-650 - Useful for configuring the device from a laptop in the field. Watchdog feature: Allows independent known good states to be set for power up, comms link watchdog and hardware watchdog. Programmable time range allows full control. Signed Drivers and Rigorous testing: We use continuous automated testing of our in-house drivers and software to ensure when you install one of our devices ‘it just works’. Our software allows hassle free installation, configuration and monitoring via our easy to use webpage. The software gives local COM ports that are backwards compatible enabling legacy applications and the device to work with a myriad of different 3rd party software. We make all our software versions available to download from our website. Lifetime Warranty and Support: We can help with every aspect of your project, from getting you up and running to custom application. +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-527 Ethernet 16 DO Software Development COM Port on Windows On a PC running the Microsoft Windows family of OS’s the ED Boost.IO Manager provides a standard COM port interface so enabling thousands of proven legacy applications to work straight out of the box. COM port compatibility allows you to continue to get value from your existing application software investment. Moreover your engineers don’t need to retrain to use the Brainboxes ED range of I/O devices. Industry Standard Packages The COM port based driver means that ED-xxx devices are completely compatible with all popular packages such as: LabView, MATLAB, Agilent VEE. You can continue to get value from your existing development and process control system. Hundreds of thousands program with these packages every day. Software Platforms The future is mobile, with data available everywhere on demand; Brainboxes has designed a software suite which allows you to design your new systems with mobile in mind with most popular platforms and development environments supported. With APIs and sample program code for: Microsoft .NET, C#, Visual Basic, C++, JavaScript, PHP, Java, Objective-C Devices Supported The ED sample codes running on Operating Systems such as Windows XP, Server 2008, Server 2012, Windows 7, Windows 8, and Linux based systems such as Android and Raspberry Pi allow you to run your applications on Servers, Desktops, Laptops, Tablets, Phones or low cost embedded devices, almost any device you wish. Configuration Options Windows Utility, Web Interface: Boost.IO driver provides familiar Serial COM port interface OS Compatibility Legacy COM porty drivers for: Microsoft Windows 8 32 bit & 64 bit Editions / Microsoft Windows 7 32 bit & 64 bit Editions / Windows Server 2008 32 bit & 64 bit Editions / Windows Server 2008 & Windows 2000 / Windows Vista 32 bit & 64 bit Editions / Windows Server 2003 32 bit & 64 bit Editions. TCP and web browser interface for other OS’s & Linux, e.g. Android, Raspberry Pi Ethernet Ethernet Port 1 x RJ45 jack, 10/100Mhz autosensing, crossover auto sensing (Auto MDIX) Protection 1,500Volts magnetic isolation between I/O ports and network Network Protocols ICMP, IP, TCP, DHCP,, Telnet, HTTP Connection to Network Ethernet 10BaseT / 100BaseTX Watchdog Power up On power up all outputs go to user programmable power on known good state Watchdog coms link On loss of communications link all outputs go to a user programmable watchdog comms known good state. Watchdog hardware timer If the firmware does not refresh the watchdog timer within a predetermined interval then all outputs go to a user programmable watchdog hardware good state E-Stop function When a user programmable input transitions to a preconfigured high or low state then all outputs go to a user programmable E-Stop known good state +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-527 Ethernet 16 DO Housing IP-20 rated non-conducting polyamide case with integrated DIN rail mount Terminal Block Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Digital Out Yellow GND DOut 0 DOut 1 DOut 2 DOut 3 Digital Out Orange GND DOut 4 DOut 5 DOut 6 DOut 7 Gateway Grey GND Digital Out Green GND DOut 8 DOut 9 DOut 10 DOut 11 Digital Out Blue GND DOut 12 DOut 13 DOut 14 DOut 15 Power Black Power GND +Vin A +Vin B Power GND Func GND 102 mm Type of Port RS-485 D- RS-485 D+ RS-485 D+ RS-485 D- Link LED Ethernet Port Status LED Activity LED Gateway LED Reset Hole 22.6 mm 128 mm Connectors Screw Terminals 3.5mm pitch, #22 - #14, 0.5mm2-2.5mm2 pin power supply Wire Thickness 0.150 inch, 3.81mm, 20 pins, 12+8 screw terminals, #26 - #16 AWG, 0.14mm2-1.3mm2 Power Supply Environmental Power Consumption 2.5 Watt Max Operating Temperature Power Supply input unregulated +5V to +30Volts DC, reverse polarity protection Storage Temperature o o -30 C to +80 C o o -40 C to +85 C Isolation 1500VRMS Magnetic isolation from Ethernet Ambient Relative Humidity 5 to 95% (non-condensing) LED Information Status LED Gateway Link LED Activity Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Flashing Red RS-485 Comms error Flashing Green RS-485 Green light on Network Link Established Flashing Green Network Data RX/TX Flashing Green Output set / Input Read Flashing Red Output overload +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-527 Ethernet 16 DO Browser Interface Webserver Interface Configure IP address, monitor state of i/o lines, set the Watchdog Timers Output Reset Value, Set Power on digital output value Programming Interface No device driver needed, just open a TCP connection and send simple ASCII commands. Software drivers give local COM Port interface for configuration Utility Programs Find device, configure IP address Packaging Information Packaging Installation CD including manual, Microsoft signed drivers & utilities, Quick Start Guide Device Ethernet 8 DI + 8 DO Packaged Weight 0.515 kg, 1.14 pounds Packaged Dims 235(l) x 170(w) x 62(h) mm, 9.25(l) x 6.69(w) x 2.44(h) inches GTIN Universal Code 837324003178 Approvals Industry Approvals CCC-Mark, C-Tick, Microsoft Certified Gold Partner, WEEE, RoHS, METL Microsoft Approvals AEO (C-TPAT) Microsoft Signed Drivers Windows 8 32 bit & 64 bit Editions Windows 7 32 bit & 64 bit Editions Windows Server 2008 32 bit & 64 bit Editions Windows Server 2008 & Windows 2000 Windows Vista 32 bit & 64 bit editions GB AEOF 00031/11 Product Support Warranty Lifetime - online registration required Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Additional Information OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards ‘Manufacturer of the Year’ Customisable Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info: sales@brainboxes.com Trademarks and logos are the property of Brainboxes Ltd. All other trademarks are the property of their respective owners. +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-527 Ethernet 16 DO Optional Accessory Items PW-600 Global Power supply PW-650 5V from USB Power supply Power supply with connectors for UK, USA, EU and AUS mains socket. ‘Tails’ are suitable for connecting to screw terminal blocks USB connector fits any standard USB port, such as on a laptop or desktop PC, providing 5V power to a prewired screw terminal block useful for when you are configuring your ED device +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
ED-527 价格&库存
很抱歉,暂时无法提供与“ED-527”相匹配的价格&库存,您可以联系我们找货
ED-527
  • 1+2288.699901+296.13290
库存:37
ED-527
  • 1+1997.97795
库存:37
