ED-549
ED-549
    BRAINBOXES
    ED-549
ED-549 数据手册
Ethernet to Analogue In ED-549 ED-549 ETHERNET TO ANALOGUE 8 INPUTS ED-549 • Ideal for all kinds of industry standard sensors and transducers • 8 Analogue Inputs + RS485 Gateway • High-precision measurements of voltages and currents • Great for process control applications • -30oC to +80oC Temperature range • +5V to +30V DC Input Power Supply Key Specifications • 8 analogue inputs, independently configurable as differential voltage inputs or current inputs • Voltage input ranges: ±10V, ±5V, ±2.5V, ±1V, ±500mV, ±250mV, ±150mV or ±75mV • Current input ranges: ±20mA, 0-20mA or 4-20mA • Built-in current sense resistors for current measurement • Analogue inputs are isolated from the power, network and RS-485 ports • 16 bit resolution • Measurement accuracy: • 0.1% of full-scale range at 25°C • 0.3% of full-scale range over -30 to +80°C • Measurement rate: 12 measurements per second, divided between all enabled inputs • Input impedance (voltage mode) > 10MΩ • Low Noise: CMRR > 120dB • Rejects Mains Hum: NMRR > 100dB at 50Hz and 60Hz Connect, Configure, Control ED-549 Ethernet 8 Analogue In Analogue Inputs 0-3 RS485 Gateway for NuDAM/ADAM Modules Ethernet port Easy to use Interface: Great features for remote monitoring LED Status Indication Integral DIN rail mount Analogue Inputs 4-7 +5V to +30V Power Supply Ethernet to IO Device Server: The Ethernet to IO device is implemented using a Windows COM port driver that is completely compatible with all popular PC packages such as LabView, MATLAB and Agilent VEE and support a range of popular APIs. Continue to get value from your existing development and process control system. Slim Shape: Small footprint for when DIN rail space is a premium Only 22.6mm wide Extended Temperature Range: -30ºC to +80ºC operating range copes with changing temperatures for harsh environments. Monitor CPU temperature via the web interface or programmatically using ASCII commands. Brainboxes’ Easy Wire Feature: Removable screw terminal blocks make installation easier and quicker Colour coded blocks and ports prevents incorrect connection Numbered Pins simplifies wiring and removes confusion +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-549 Ethernet 8 Analogue In Grounding: Correctly wired grounds help cut down on electromagnetic interference 5 pin terminals allow a ground on the 5th pin of each block Functional earth connection to the DIN rail Gateway RS485 Serial Port: Half duplex RS485 port allows connection and control of industry standard NuDAM, eDAM and ADAM modules using ASCII protocols. Wide Range Redundant Dual Power Input: +5VDC to +30VDC accommodates variation in the +24VDC factory floor supply and allows alternative power sources. A second power supply can be fitted as a back-up to prevent down time should one power source fail. Power from any USB Port: Can use 5 Volt power from any computer USB port via optional accessory cable PW-650 - Useful for configuring the device from a laptop in the field. Signed Drivers and Rigorous testing: We use continuous automated testing of our in-house drivers and software to ensure when you install one of our devices ‘it just works’. Our software allows hassle free installation, configuration and monitoring via our easy to use webpage. The software gives local COM ports that are backwards compatible enabling legacy applications and the device to work with a myriad of different 3rd party software. We make all our software versions available to download from our website. Lifetime Warranty and Support: We can help with every aspect of your project, from getting you up and running to custom application. +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-549 Ethernet 8 Analogue In Familiar ASCII Command Protocol: The ED range of devices uses the de facto industry standard ASCII command protocol implemented in the popular ADAM/NuDAM/EDAM modules. Typical examples include: $01M !01ED-549 $01F !013.50 #010 >+04.987 $0150F !01 Read the name of the device address 01 Device with address 01 replies that its name is ED-549 Read firmware version number of device address 01 Device with address 01 replies with the firmware version 3.50 Reads the analogue input of channel 0 from device address 01 Analogue input data from the channel specified Enable channels 0-3 and disable channels 4-7 of the device address 01 Command was successfully sent to device address 01 The ED device’s webpage has an interactive console where any command can be entered and it is immediately executed showing the device’s response. Software Development COM Port on Windows On a PC running the Microsoft Windows family of OS’s the ED Boost.IO Manager provides a standard COM port interface so enabling thousands of proven legacy applications to work straight out of the box. COM port compatibility allows you to continue to get value from your existing application software investment. Moreover your engineers don’t need to retrain to use the Brainboxes ED range of I/O devices. Industry Standard Packages The COM port based driver means that ED-xxx devices are completely compatible with all popular packages such as: LabView, MATLAB, Agilent VEE. You can continue to get value from your existing development and process control system. Hundreds of thousands program with these packages every day. Software Platforms The future is mobile, with data available everywhere on demand; Brainboxes has designed a software suite which allows you to design your new systems with mobile in mind with most popular platforms and development environments supported. With APIs and sample program code for: Microsoft .NET, C#, Visual Basic, C++, JavaScript, PHP, Java, Objective-C Devices Supported The ED sample codes running on Operating Systems such as Windows XP, Server 2008, Server 2012, Windows 7, Windows 8, and Linux based systems such as Android and Raspberry Pi allow you to run your applications on Servers, Desktops, Laptops, Tablets, Phones or low cost embedded devices, almost any device you wish. Configuration Options Windows Utility, Web Interface: Boost.IO driver provides familiar Serial COM port interface OS Compatibility Legacy COM porty drivers for: Microsoft Windows 8.1 32 bit & 64 bit Editions / Microsoft Windows 7 32 bit & 64 bit Editions / Windows Server 2008 32 bit & 64 bit Editions / Windows Server 2008 R2 & Windows 2000 / Windows Vista 32 bit & 64 bit Editions /Windows XP / Windows Server 2012 & R2 / Windows Server 2003 32 bit & 64 bit Editions. TCP and web browser interface for other OS’s & Linux, e.g. Android, Raspberry Pi +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-549 Ethernet 8 Analogue In Browser Interface Webserver Interface Configure IP address, monitor state of i/o lines Programming Interface No device driver needed, just open a TCP connection and send simple ASCII commands. Software drivers give local COM Port interface for configuration Utility Programs Find device, configure IP address Ethernet Ethernet Port 1 x RJ45 jack, 10/100Mhz autosensing, crossover auto sensing (Auto MDIX) Protection 1,500Volts magnetic isolation between I/O ports and network Network Protocols ICMP, IP, TCP, DHCP, HTTP Connection to Network Ethernet 10BaseT / 100BaseTX Housing 102 mm IP-20 rated non-conducting polyamide case with integrated DIN rail mount 22.6 mm 128 mm Terminal Block Yellow Orange Grey Green Blue Black Pin 1 Pin 2 Pin 3 Pin 4 AGND AIn 0AIn 0+ AIn 1AGND AIn 2AIn 2+ AIn 3GND RS-485 D- RS-485 D+ RS-485 D+ AGND AIn 4AIn 4+ AIn 5AGND AIn 6AIn 6+ AIn 7Power GND +Vin A +Vin B Power GND Input +5V to +30V DC 100mA@24V 2.5W Max Pin 5 AIn 1+ AIn 3+ RS-485 DAIn 5+ AIn 7+ Func GND +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-549 Ethernet 8 Analogue In Connectors Screw Terminals 3.5mm pitch, #22 - #14, 0.5mm2-2.5mm2 pin power supply Wire Thickness 0.150 inch, 3.81mm, 20 pins, 12+8 screw terminals, #26 - #16 AWG, 0.14mm2-1.3mm2 Power Supply Environmental o o o o Power Consumption 2.5 Watt Max Operating Temperature -30 C to +80 C, -22ºF to +176ºF Power Supply input unregulated +5V to +30Volts DC, reverse polarity protection Storage Temperature -40 C to +85 C, -40ºF to +185ºF Isolation 1500VRMS Magnetic isolation from Ethernet Ambient Relative Humidity 5 to 95% (non-condensing) LED Information Status LED Gateway Link LED Activity Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Flashing Red RS-485 Comms error Flashing Green RS-485 Green light on Network Link Established Flashing Green Network Data RX/TX Flashing Green Input Read Flashing Red Input Error Approvals Industry Approvals C-Tick, AEO (C-TPAT), WEEE, RoHS Microsoft Approvals Microsoft Certified Gold Partner Microsoft Signed Drivers Windows 8 & 8.1 32 bit & 64 bit Editions Windows 7 32 bit & 64 bit Editions Windows XP 32 bit & 64 bit Editions Windows Server 2012 & R2 32 bit & 64 bit Editions Windows Server 2008 32 bit & 64 bit Editions Windows Server 2008 R2 & Windows 2000 Windows Vista 32 bit & 64 bit editions GB AEOF 00031/11 +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com ED-549 Ethernet 8 Analogue In Packaging Information Packaging Installation CD including manual, Microsoft signed drivers & utilities, Quick Start Guide Device Ethernet 8 AI Packaged Weight 0.215 kg, 0.47 pounds Packaged Dims 235(l) x 170(w) x 62(h) mm, 9.25(l) x 6.69(w) x 2.44(h) inches GTIN Universal Code 837324003369 Product Support Warranty Lifetime - online registration required Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Additional Information OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards ‘Manufacturer of the Year’ Customisable Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info: sales@brainboxes.com Optional Accessory Items PW-600 Global Power supply PW-650 5V from USB Power supply Power supply with connectors for UK, USA, EU and AUS mains socket. ‘Tails’ are suitable for connecting to screw terminal blocks USB connector fits any standard USB port, such as on a laptop or desktop PC, providing 5V power to a prewired screw terminal block useful for when you are configuring your ED device Trademarks and logos are the property of Brainboxes Ltd. All other trademarks are the property of their respective owners. +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
ED-549 价格&库存
很抱歉,暂时无法提供与“ED-549”相匹配的价格&库存,您可以联系我们找货
