ES-020
ES-020
    BRAINBOXES
    ETHERNET 1 PORT RS232 10XSCREW T
ES-020 数据手册
N EW ES-020 ETHERNET TO SERIAL DEVICE SERVER Ethernet 1 Port RS232 10xScrew Terminals Connect, Configure, control your serial devices Features l l l l l l l l l l 1 port RS232 Max baud rate 1,000,000 (1 MegaBaud) 10/100Base TX Ethernet port User friendly interface, simple to use, powerful in operation Web configuration and RFC2217 compliant interface for non-Windows users IP-30 rated enclosure LED status indication Optional DIN rail mounting kit Serial Port Tunneling (individually configurable) allows serial cable replacement over any distance, no software required Simple operation for each and every operating system! Description Ethernet 1 Port RS232 10xScrew Terminals Blocks perfect for industrial applications. Data transfer rates up to 1,000,000 baud, coupled with 1Mbit/s line drivers deliver uncompromising performance. Our ES range provides simple instant networked serial ports. A web interface allows secure configuration and control of the serial ports over a local network or the internet using any browser. For Windows our in-house designed (32 bit and 64 bit) driver gives you local COM ports, retaining existing software applications and allowing you to connect across your network to remote devices just as if they were attached locally. You can access the device via TCP/IP sockets from any networked device like an Android tablet, PC or phone. Serial Port Tunneling (individually configurable) allows serial cable replacement over any distance, no software required. On Windows OS TCP/IP sockets are handled by the Winsock API, this will differ on other OSs. Suitable to be wired into existing power and network infrastructure or can be used with our PW-600 power supply . Windows Users - Our software drivers gives you local COM ports, allowing you to retain your existing software applications and connect to your devices over the network. COM Port can be assigned from COM1 to COM255 and the Brainboxes Ethernet to serial device remembers your COM Port assignment on reboots. Web Interface Users (Linux/Apple OS/Android) - Alternatively access the device via TCP/IP socket from any networked device. Configure options via web interface. Extend your reach! Remote serial devices with local control. With Brainboxes industry renowned Lifetime Warranty and Lifetime Support! Example Application ES-511 Factory Floor Application Factory floors can be harsh environments. Extreme temperatures can be generated in the manufacturing process, machinery can be noisy and dangerous and space is a premium. But engineers still need to be able to access and maintain equipment safely and without downtime. As factories expand and modernise older equipment and remote devices need to be networked, but cabling can be expensive and impractical, especially over larger areas. The ES-511 has 1 serial port that is software selectable as either RS232, RS422 or RS485 and 1 Ethernet port. The ‘Easy Wire’ removable colour coded Screw Terminals Blocks are individually numbered for simple fast, error free wiring. The slim ‘end on’ case with integral mount clips straight on to a DIN Rail. The ES-511 has an operating temperature range of -30ºC to +80ºC and +5VDC to +30VDC Dual input reverse polarity protected power supply. Brainboxes proven technology supports legacy applications, whilst our Ethernet to Serial software ensures fast data transmission and a super easy installation whatever your operating system. Once your Serial equipment is connected to a Brainboxes Ethernet to Serial device you have the option of accessing it over a local network or connecting it to the internet. The devices can be fitted in areas where it would be dangerous for workers to monitor whilst the factory line is in operation. Manufacturing process and performance across a large site can be monitored and potential faults detected before they cause serious downtime costs. Use two devices back to back for serial tunnelling over Ethernet, for when you need to extend the reach of your serial cables. +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-020 Ethernet 1 Port RS232 10xScrew Termi- EW Box Information LED Information Status LED Serial Port LEDs Network LED Green Device Ready Flashing Yellow Changing Settings Flashing between Red & Green Querying IP Flashing Green/Red User performing Hard Reset Flashing between Green & Red/Yellow IP address diagnostic Flashing between Green & Yellow Initialization diagnostic Green light on Port Open Flashing Green Data RX / TX Green light on Link Established Flashing Green Data RX / TX Port Ports 1 port RS232 Connector Screw terminal block connector - 0.1 inch pitch Power Input 5 - 30V DC input, reverse polarity protected Power Consumption awaiting +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-020 Ethernet 1 Port RS232 10xScrew Termi- EW Port Settings - RS232 Baud Rate From 110 - 1,000,000 (1 MegaBaud) Data Bits 5,6,7 or 8 Parity Odd, Even, None, Mark or Space Stop Bits 1 or 2 Flow Control RTS/CTS, DSR/DTR, XON/XOFF Tx/Rx Modes Point to Point Standards Available with Screw Terminals Versions RS232 Standard: RS232 allows point to point communication between 2 devices. RS422 Standard: RS422 allows one transmitter and up to 10 receivers with data transmitter rates up to 10 megabits per second for distances up to 40 feet and up to 100 Kilobits per second for distances up to 4,000 feet (1219 metres). To achieve good long distance noise immunity, 2 wires are used to carry each signal, configured as a twisted pair of cables. The TXD pair and RXD pair are used to carry the data whilst the RTS pair and CTS pair lines are used for handshaking. Thus 2 twisted pairs are used without handshaking and 4 twisted pair cable is used with handshaking both these schemes allow full duplex data communications. RS485 Standard: RS485, based on the RS422 standard allows up to 32 driver/receivers pairs on a standard load or 128 low load devices per port can be connected. Whilst only one of these should be transmitting data at any time, the rest can all simultaneously listen to the data. Handshaking is performed by software protocol. Two twisted pairs form a full duplex system. Often only one twisted pair cable is used as the TXD and RXD lines are tied together; this is known as half duplex mode. Brainboxes RS422/485 products implement a state of the art hardware autogating circuit ensuring error free communications in half duplex configurations. • • • ES-020 : RS232 ES-031 : RS422/485 ES-057 : RS232 + RS422/485 Port Settings - Ethernet Data Rate 10/100 Mega bits/second Cabling Normal / Crossover auto-sensing (Auto-MDIX) Environmental o Operating Temperature 0 to 55 c Storage Temperature -20 to 85 c Ambient Relative Humidity 5 to 95% (non-condensing) Housing IP-30 rated case o Software Network Protocols ICMP, IP, TCP, UDP, DHCP, BOOTP, Telnet, HTTP, RFC2217 Configuration Options Windows Utility, Web Interface OS Compatibility Microsoft Windows 7 32 bit & 64 bit Editions / Windows Server 2008 32 bit & 64 bit Editions / Windows Server 2008 & Windows 2000 / Windows Vista 32 bit & 64 bit Editions / Windows XP 32 bit & 64 bit Editions / Microsoft Windows 2000 /Fully RFC2217 compliant / Interface for other OS’s & Linux Connection to Network Ethernet 10BaseT / 100BaseTX Approvals Industry Approvals AEO (C-TPAT) Microsoft Certified Gold Partner WEEE RoHS EMC: CE TAA Microsoft Approvals Microsoft Certified Gold Partner Microsoft Signed Drivers Windows 7 32 bit & 64 bit Editions Windows Vista 32 bit & 64 bit editions Windows XP 32 bit & 64 bit editions Windows 2000 +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com N ES-020 Ethernet 1 Port RS232 10xScrew Termi- EW Packing Information Packaging Installation CD including manual, Microsoft signed drivers & utilities Device Ethernet 1 Port RS232 10xScrew Terminals Accessory Items Global Power Supply - PW-600 DIN-Rail Mounting Kit - MK-048 Packaged Weight 0.33 kg, 0.73 pounds Packaged Dims 150(l) x 145(w) x 40(h) mm, 5.91(l) x 5.71(w) x 1.57(h) inches Product Support Warranty Lifetime - online registration required Support Lifetime Web, Email and Phone Support from fully qualified, friendly staff who work in and alongside the Product Development Team Additional Information OEM option Available for bulk buy OEM Made In Manufactured in the UK by Brainboxes Winner 2005 European Electronics Industry Awards ‘Manufacturer of the Year’ Customisable Brainboxes operate a ‘Perfect Fit Custom Design’ policy for volume users. More info: sales@brainboxes.com Accessory Items ORDER CODE - DIN-Rail Mounting Kit - MK-048 ORDER CODE - Global Power Supply - PW-600 Brainboxes Ethernet to Serial Range +44(0) 151 220 2500 sales@brainboxes.com www.brainboxes.com
ES-020 价格&库存
很抱歉,暂时无法提供与“ES-020”相匹配的价格&库存,您可以联系我们找货
ES-020
    库存:2
    ES-020
    • 1+1793.985421+232.07940
    • 5+1723.581675+222.97160
    • 10+1664.9701110+215.38930
    ES-020
    • 1+1479.48342
    库存:3
