ED211SY-R5
ED211SY-R5
    EASYDETEK(易探)
    微波感应传感器
ED211SY-R5 数据手册
ED211S-Y Product Specification (Ver1.0) SHENZHEN EASYDETEK TECHNOLOGY CO.,LTD 1 EasyDetek·Focus on Radar ED211S-Y The microwave motion switch is designed based on the Doppler principle,it transmits the high frequency electromagnetic wave through the antenna and receivesthe reflected wave.Based on this principle it judges the movement of the object within the coverage range, and feedback corresponding electricity signal. It is widely used in motion sensor lighting,security, small household electrical appliances,smart home, automatic door control switch, greeting device and other products, as wellas garage, corridor, courtyard, balcony, bathroom and other places that need automaticmotion sensor control. Feature & Advantage Compared with PIR module,microwave motion sensor is better (with more wide detection range,no dead area,no lens,no lens aging problem,no environment interference) Strong anti-interference ability -- It is not affected by temperature, humidity, airflow,dust, noise, brightness and other factors Microwave can penetrate Acrylic,glass or thin non-metal materials Complying with environmental requirements Characteristic Description Distance Customize Daylight Optional Delay Time Customize Constant Light On Mode: On/Off Three times 2 EasyDetek·Focus on Radar Application Place It is widely applied in motion sensor lighting, security, small household electrical appliances, smart home, automatic door control switch, greeting device and other products, as well as garage, corridor,courtyard, balcony, bathroom and other places that need automatic motion sensor control. Washroom Corridor Garage Structural Drawing 64.5mm 48mm 34mm 1:Live Wire:L Input Φ3mm 2:Naught Wire:N Input 3:Live Wire:L’Output Top View Unit:mm 4:Naught Wire:N’Output 68mm 48mm 22.1mm 13.4mm 5.55mm 21mm 13mm 10.8mm 1.6mm Bottom View Unit:mm 3 EasyDetek·Focus on Radar Application Demo The light does not trigger on when detect moving The light triggers on when the sensor detect moving object with the ambient brightness is enough object with the ambient brightness is lower than the preset threshold of photo-transistor After the moving object leaves or object keep still After the preset delay time over and no moving during delay time cycle, the light will keep lighting object detect, the light will automatically off on till delay time cycle over Installation Method Antenna Area Installation Method: A variety of installation options are available: 1. install the fixed bracket with CDS Daylight Sensor card slot and layering. Adjustable Code Switch 2. install the fixed bracket with screws or rivets. Fixed Hole N’ L’ Output Connect Load L N Input 4 EasyDetek·Focus on Radar 参数 Specification 单位 典型值 Parameter Min Typical Max Unit Transmit Frequency 100 - 277 V - Surge Protection - - 400 W @100V-277V Rated Power 5.725 5.8 5.875 GHz - Power Dissipation - 0.5 - W - 3dB beam angle - 93 - ° XZ Plane - 99 - ° YZ Plane Antenna Gain - 4 - dB Detect Distance 5 6 7 m - Delay Time 5 180 300 s Remark 1 Daylight Sensor Lux - 25 - Lux - Work Temperature -25 - 85 °C Remark 2 Storage Temperature -50 - 125 °C - Remark 1:Test Environment affect detect distance of motion switch..For example:the detect distance is longer when tested in corridor, because corridor is empty space. And the distance will be affected if there are many stuffs or obstacles. Remark 2:Daylight sensor lux is tested under natural brightness Working sequence when Power on ON ON OFF ON/OFF OFF 0 Timing Hight Output Low Triger Monitor light on When power on 9 Hight Low Low Initializatio No Motion Low Level Voltage Output Normal Trigger Mode Hight 断电 Stop Initialization Mode:7 Seconds 6 Hold Power off 5 Trigger No Trigger Trigger Triggering On 无运动保 持低电平 5 EasyDetek·Focus on Radar Adjustable Code Switch Setting: 2.Delay Time Setting: The 2 nd and 3 rd code switch 1. Detect Distance Setting -- The 1 st code switch 1 2 3 100% ON 5s ON ON 50% - 1min ON - 3min - ON 5min - - Remark: According to different application occasions, the induction distance can be adjusted by setting the code switch to choose 100%, 50%. Remark:Delay time refers to the time when the moving object moves away from the 3. Daylight Sensor Setting: The 4th code switch sensing area. The code switch can be set as 4 5S, 1min, 3min and 5min. 25Lux ON Disable - Only when the ambient illuminance is lower than the setting valve, there is an object moving in the sensing area. The daylight sensor limit value is: 25LUX / day. Naming Rules ED Type Item No Antenna Type Configuration No Delay Time Holding Time Version ED 2 11 N 2s R6 2s R6 D 5s-180s-300s 1Radar Module 11 S Single Layer Antenna Y With LDR 2Radar Switch D Stacked Antenna N No LDR H High Precision P Programming 5s-180s-300s Antenna C Ceramic Antenna 6 EasyDetek·Focus on Radar Additional Remarks Warning: IFI/IFQ output signal is sensitive to ESD(electrostatic damage),if exposure to high electrostatic or power source areas may cause irreversible damage to the radar module Recommendation: It is recommended to use a qualified DC voltage stabilizing power supply.That is,DC voltage, current, and ripple coefficient that are all up to the standard, otherwise it will affect the stability of this product and may cause some anomalies, such as: false alarm, no detection, circulation, self-start, etc. Attentions  Avoid installing together with metal accessories or shell,when install microwave motion sensor,metal will absorb microwave and affect the effect.  Please use power supply circuit with tiny ripple current, especially the low frequency ripple, which disturb the sensor's work easily.  The output current of the sensor is very weak, If driver too large current easy to cause misinformation. Better us drive the load by isolation drive, and can also use MCU to read the output state.  The recommend distance between each switch is 1.5m,for better performance and no interface. History Revision Records No Revision 7 Easy Detek http://www.easydetek.com/ Telephone:0755-2778-8421 Email:sales@easydetek.com Address:Room 601,A2 Building,Hangcheng Industrial Zone, Bao’an District,Shenzhen 518102,Guangdong PR.,China 8
ED211SY-R5 价格&库存
很抱歉,暂时无法提供与“ED211SY-R5”相匹配的价格&库存,您可以联系我们找货
