ENOCEAN PI 315
ENOCEAN PI 315
    ENOCEAN(易能森)
    ENOCEAN - ENOCEAN PI 315 - MOD, SOC GATEWAY TRX, 8051 MCU, 315MHZ
ENOCEAN PI 315 数据手册
DATA SHEET Transceiver Modules TCM 310, TCM 310C, and TCM 310U TCM 310 enables the realization of gateways for the EnOcean 868 MHz, 315 MHz, and 902 MHz radio systems. It provides a bidirectional radio interface at one end and a bi-directional serial interface at the other end. Radio messages are sent transparently through the serial interface in both directions from and to an externally connected host processor or host PC. In addition control commands can be sent from the host, e.g. to configure the repeater functionality or to manage the Smart Ack functions. TCM 310 can act as postmaster for up to 15 bidirectional sensors using Smart Ack technology. Features  Smart Ack controller functionality  Transparent radio channel  Programmable repeater functionality (1 / 2 Level)  ESP3 support (EnOcean Serial Protocol V3)  Not API programmable! Product variants  TCM 310/310C/TCM310U: SMD mountable module for use with external antenna (868/315/902MHz) Type Ordering Code TCM 310 TCM 310C TCM 310U S3003-K310 S3033-K310 S3053-K310 Features overview Antenna Frequency Radio Standard Data rate/Modulation type Receiver Sensitivity (at 25°C) Conducted Output Power Power Supply Serial Interface Current Consumption Dimensions of PCB External whip or 50Ω antenna mountable 315.0 MHz (TCM 310C) / 868.3 MHz (TCM 310) / 902.875 (TCM 310U) Enocean 868 MHz/315 MHz: ISO/IEC 14543-3-10 125 kbps / ASK(868 MHz, 315 MHz), FSK (902MHz) typ. –96 dBm (868MHz), -98 dBm (315MHz, 902MHz) typ. 3 dBm (868MHz, 315MHz), typ. 1 dBm (902MHz) 2.85…3.5V UART Receive mode: 33 mA Transmit mode: 24 mA 22x19x3 mm Operating temperature Radio Regulations 0 to +65°C R&TTE EN 300 220 (TCM 310) FCC CFR-47 Part 15 (TCM 310C, TCM 310U) © 2013 EnOcean | www.enocean.com Subject to modifications | Mar 2013
ENOCEAN PI 315 价格&库存
很抱歉,暂时无法提供与“ENOCEAN PI 315”相匹配的价格&库存,您可以联系我们找货
