EE2-24NU-L
EE2-24NU-L
    EMDEVICES(EM 设备公司)
    NEXEM - EE2-24NU-L - Signal Relay, 24 V, DPDT, 2 A, EE2, Surface Mount, Non Latching
EE2-24NU-L 数据手册
DATA SHEET MINIATURE SIGNAL RELAY EC2/EE2 SERIES RoHS Compliant COMPACT SIZE, SLIM-PACKAGE DESCRIPTION NEXEM EC2/EE2 relay is a standard miniature signal relay, compact and slim. FEATURES □ Compact and light weight □ FCC (1500 V) and Telcordia (2500 V) surge capacity □ UL recognized and CSA certified. □ Low power consumption (100-200 mW) □ ND type (High insulation) conform to supplement insulation for EN60950 □ NKX type (High breakdown voltage) can withstand 1.5KVAC at open contacts APPLICATIONS Electronic switching systems, PBX, Terminal equipment, Telephone system For Right Use of Miniature Relays DO NOT EXCEED MAXIMUM RATINGS. Do not use relays under exceeding conditions such as over ambient temperature, over voltage and over current. Incorrect use could result in abnormal heating, damage to related parts or cause burning. READ CAUTIONS IN THE SELECTION GUIDE. Read the cautions described in EM Devices' "Miniature Relays" when you choose relays for your application. The information in this document is subject to change without notice. © EM Devices Corporation 2017 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES DIMENSIONS AND PAD LAYOUTS Unit: mm (inch) EC2 SERIES Non-latch type, Single coil latch type Double coil latch type 7.5 max. (0.30) 15.0 max. (0.59) 7.5 max. (0.30) 15.0 max. (0.59) 9.4 max. (0.37) 9.4 max. (0.37) 3.2 (0.13) 0.5 (0.02) 5.08 2.54 2.54 2.54 2.54 5.08 Lead size 0.5x0.25 ±0.1 NJ type: Lead length 2.8mm 5.08 0.25 (0.01) 5.08 2.54 is basic size. Other tolerances ±0.2mm (1.05) 3.2 (0.13) 0.5 (0.02) 0.25 (0.01) (mm) Lead size 0.5x0.25 ±0.1 (mm) NJ type: Lead length 2.8mm 8-Φ 0.8 2.54 2.54 5.08 is basic size. Other tolerances ±0.2mm 10-Φ 0.8 2.54 2.54 2.54 5.08 (1.05) 5.08 5.08 (1.11) (1.11) NOTE. General tolerance :±0.1 NOTE. General tolerance :±0.1 (Bottom view) (Bottom view) EE2 SERIES Standard/ Non-latch type, Single coil latch type Standard/ Double coil latch type 7.5 max. (0.30) 15.0 max. (0.59) 7.5 max. (0.30) 15.0 max. (0.59) 10.0 max. (0.39) 10.0 max. (0.39) 5.08 5.08 2.54 1.0 (0.04) 2.54 is basic size. Other tolerances ±0.2mm 9.5 (0.37) 5.08 5.08 5.08 2.54 2.54 2.54 1.0 (0.04) is basic size. Other tolerances ±0.2mm Lead size 0.5x0.25 ±0.1 (mm) (1.05) 2.54 (1.05) 2.54 5.08 2.54 9.5 (0.37) Lead size 0.5x0.25 ±0.1 (mm) 2.54 2.54 7.29 7.29 3.0 3.0 1.0 1.0 NOTE. General tolerance :±0.1 (Bottom view) (Top view) NOTE. General tolerance :±0.1 (Top view) 2 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES Minimum footprint / Non-latch type, Single coil latch type Minimum footprint/ Double coil latch type 7.5 max. (0.30) 15.0 max. (0.59) 7.5 max. (0.30) 15.0 max. (0.59) 10.0 max. (0.39) 10.0 max. (0.39) 5.08 5.08 1.0 (0.04) 2.54 2.54 is basic size. Other tolerances ±0.2mm 5.08 5.08 7.5 (0.3) 2.54 2.54 2.54 1.0 (0.04) is basic size. Other tolerances ±0.2mm Lead size 0.5x0.25 ±0.1 Lead size 0.5x0.25 ±0.1 (mm) (1.05) 5.08 2.54 7.5 (0.3) (mm) (1.05) 2.54 5.08 2.54 2.54 2.54 6.29 6.29 2.0 2.0 1.0 1.0 NOTE. General tolerance :±0.1 NOTE. General tolerance :±0.1 (Top view) (Top view) High solder joint reliability/ Non-latch type, Single coil latch type High solder joint reliability / Double coil latch type 7.5 max. (0.30) 15.0 max. (0.59) 7.5 max. (0.30) 15.0 max. (0.59) 10.35 max. (0.41) 10.35 max. (0.41) 5.08 5.08 2.54 1.35 (0.05) 2.54 is basic size. Other tolerances ±0.2mm 9.0 (0.35) 5.08 5.08 Lead size 0.5x0.25 ±0.1 5.08 2.54 2.54 2.54 2.54 is basic size. Other tolerances ±0.2mm (mm) (1.05) 2.54 1.35 (0.05) (1.05) 5.08 2.54 9.0 (0.35) Lead size 0.5x0.25 ±0.1 (mm) 2.54 2.54 7.02 2.73 7.02 2.73 1.0 1.0 NOTE. General tolerance :±0.1 (Top view) NOTE. General tolerance :±0.1 (Top view) 3 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES PIN CONFIGURATIONS (Bottom view) Direction mark 1 3 4 5 12 10 9 8 + Non-latch type - Non-latch type (Not energized position) Direction mark 1 3 4 5 +- Single coil latch type SR - + 12 10 9 8 S: Coil polarity for Set R: Coil polarity for Reset Single coil latch type (Reset position) Direction mark 1 3 4 5 6 + + Double coil latch type - 12 Set coil 10 9 8 7 Reset coil Double coil latch type (Reset position) MARKINGS (top view) Except ND type (6) (1) (5) ND type (High insulation) EC2-5NU 0501F (2) (3) (6) EC2-5ND JAPAN (2) (1) (5) (4) JAPAN 0501F (3) (1) Part number (4) (2) Manufacturer (3) Country of origin (4) Date code (5) Direction mark (pin No. 1 and 12) (6) UL,CSA marking (TUV added for ND type) 4 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES GENERAL SPECIFICATIONS Contact Form Contact Material Maximum Switching Power Maximum Switching Voltage Contact Ratings Maximum Switching Current Maximum Carrying Current Minimum Contact Ratings Initial Contact Resistance Operate Time (Excluding bounce) Release Time (Excluding bounce) Insulation Resistance Between open contacts Withstanding Voltage Between adjacent contacts Between coil and contacts Shock Resistance Vibration Resistance Ambient Temperature Coil Temperature Rise Running Specifications Weight Nonload Load 2 Form C Silver alloy with gold alloy overlay 60 W, 125 VA 220 VDC, 250 VAC 2A 2A 10 m VDC, 10µA *1 75 m Ω max. (initial) Approx. 2 ms Approx. 1 ms 1000 M Ω at 500 VDC 1000 VAC (for one minute) 1500 V surge (10x160 µs *2) [High breakdown voltage (NKX) type] Make contact: 1500 VAC (for one minute) 2500 V surge (2x10 µs *3) Break contact: 1000 VAC (for one minute) 1500 V surge (10x160 µs *2) 1000 VAC (for one minute) 1500 V surge (10x160 µs *2) 1500 VAC (for one minute) , 2500 V surge (2x10 µs *3) [Double coil latch type] 1000 VAC (for one minute) 1500 V surge (10x160 µs *2) 735 m/s2 (75G) (misoperation) 980 m/s2 (100G) (destructive failure) 10 to 55 Hz, double amplitude 3 mm(20G) (misoperation) 10 to 55 Hz, double amplitude 5 mm(30G) (destructive failure) − 40 to + 85℃ 18℃ at nominal coil voltage (140mW) 1x108 operations (Non-latch type) *4 1x107 operations (latch type) 50 VDC 0.1A (resistive), 1x106 operations at 85℃ ,5Hz 10 VDC 10mA (resistive), 1x106 operations at 85℃ ,2Hz Approx. 1.9 g *1 This value is a reference value in the resistance load. Minimum capacity changes depending on switching frequency and environment temperature and the load. *2 rise time: 10 µs, decay time to half crest: 160 µs *3 rise time: 2 µs, decay time to half crest: 10 µs *4 This shows the number of operations with fatal defects. Stable characteristics are maintained for 1 × 107 operations. 5 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES COIL SPECIFICATIONS Non-latch Type at 20℃ Nominal Coil Voltage (VDC) Coil Resistance (Ω) ± 10% Must Operate Voltage* (VDC) Must Release Voltage* (VDC) Nominal Operating Power (mW) 3 64.3 2.25 0.3 140 4.5 145 3.38 0.45 140 5 178 3.75 0.5 140 9 579 6.75 0.9 140 12 1028 9.0 1.2 140 24 2880 18.0 2.4 200 Coil Resistance (Ω) ± 10% Set Voltage* (VDC) Reset Voltage* (VDC) Nominal Operating Power (mW) Single Coil Latch Type Nominal Coil Voltage (VDC) at 20℃ 3 90 2.25 2.25 100 4.5 202.5 3.38 3.38 100 5 250 3.75 3.75 100 9 810 6.75 6.75 100 12 1440 9.0 9.0 100 24 5760 18.0 18.0 100 Double Coil Latch Type (Can not be driven by reverse polarity for reverse operation) Nominal Coil Voltage (VDC) 3 4.5 5 9 12 24 Coil Resistance (Ω) ± 10% Set Voltage** (VDC) Reset Voltage** (VDC) S 64.3 2.25 - R 64.3 - 2.25 at 20℃ Nominal Operating Power (mW) 140 S 145 3.38 - R 145 - 3.38 S 178 3.75 - R 178 - 3.75 S 579 6.75 - R 579 - 6.75 S 1028 9.0 - R 1028 - 9.0 S 4114 18.0 - R 4114 - 18.0 Coil Resistance (Ω) ± 10% Must Operate Voltage* (VDC) Must Release Voltage* (VDC) Nominal Operating Power (mW) 140 140 140 140 140 Non-latch High Insulation (ND) Type Nominal Coil Voltage (VDC) at 20℃ 3 45 2.25 0.3 200 4.5 101 3.38 0.45 200 5 125 3.75 0.5 200 9 405 6.75 0.9 200 12 720 9.0 1.2 200 24 2504 18.0 2.4 230 6 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES Single Coil Latch High Insulation (ND) Type Nominal Coil Voltage (VDC) at 20℃ Coil Resistance (Ω) ± 10% Set Voltage* (VDC) Reset Voltage* (VDC) Nominal Operating Power (mW) 3 90 2.25 2.25 100 4.5 203 3.38 3.38 100 5 250 3.75 3.75 100 9 810 6.75 6.75 100 12 960 9.0 9.0 150 24 3388 18.0 18.0 170 Must Release Voltage* (VDC) Nominal Operating Power (mW) Non-latch High Breakdown Voltage (NKX) Type at 20℃ Nominal Coil Voltage (VDC) Coil Resistance (Ω) ± 10% Must Operate Voltage* (VDC) 3 39.1 2.25 0.3 230 4.5 88.0 3.38 0.45 230 12 626 9.0 1.2 230 Note * Test by pulse voltage ** S : Set coil (pin No.1 ... (+) , pin No.12 ...(-) ) R : Reset coil (pin No.6...(+) , pin No.7...(-) ) The latch type relays should be initialized at appointed position before using, and should be energized to specific polarity by above polarity to avoid wrong operation. Any special coil requirement, please contact EM Devices for availability. SAFETY STANDARD AND RATING UL Recognized (UL508)* File No E73266 CSA Certificated (CSA C22.2 No14) File No LR46266 30 VDC, 2 A (Resistive) 110 VDC, 0.3 A (Resistive) 125 VAC, 0.5 A (Resistive) TUV Certificate (IEC61810/ EN61810) (EN61810) No. R 9750561 No. R 9751153 ND Type (Non-latch and Single coillatch) NU,NJ,NUH,NUX Type (Non-latch and Single coillatch) Creepage and clearance of coil to contact is more than 2 mm. (According to EN60950) Supplementary insulation class Basic insulation class * Spacing: UL114, UL478 7 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES RECOMMENDED RELAY DRIVE CONDITIONS Drive under conditions. If it is impossible, please inquire to EM Devices. Non-latch type Voltage: within ± 5% of nominal voltage Single coil latch type Double coil latch type Square pulse (rise and fall time is rapid) Pulse height : within ± 5% of nominal voltage Pulse width : More than 10 ms Ambient temperature  − 40 to + 85℃ PART NUMBER SYSTEM EC2-3SNU NU: Standard NJ: Trimmed lead type ND: High insulation type Nil: Non-latch type S: Single coil latch type T: Double coil latch type Nominal coil voltage (A numerical value of coil voltage) EC2 series EE2–3SNU–L Packing Nil: Tube L: Embossed carrying tape NU: Standard NUH: Minimum footprint type NUX: High solder joint reliability type ND: High insulation type NKX: High breakdown voltage and high solder joint reliability type Nil: Non-latch type S: Single coil latch type T: Double coil latch type Nominal coil voltage (A numerical value of coil voltage) EE2 series 8 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES ORDERING PART NUMBERS □ EC2 series Option Terminal Packing Standard Tube Trimmed lead Nominal Coil Voltage (VDC) Coil Type Non-latch Single Coil Latch Double Coil Latch 3 EC2-3NU EC2-3SNU EC2-3TNU 4.5 EC2-4.5NU EC2-4.5SNU EC2-4.5TNU EC2-5TNU 5 EC2-5NU EC2-5SNU 9 EC2-9NU EC2-9SNU EC2-9TNU 12 EC2-12NU EC2-12SNU EC2-12TNU 24 EC2-24NU EC2-24SNU EC2-24TNU 3 EC2-3NJ EC2-3SNJ EC2-3TNJ 4.5 EC2-4.5NJ EC2-4.5SNJ EC2-4.5TNJ 5 EC2-5NJ EC2-5SNJ EC2-5TNJ 9 EC2-9NJ EC2-9SNJ EC2-9TNJ 12 EC2-12NJ EC2-12SNJ EC2-12TNJ 24 EC2-24NJ EC2-24SNJ EC2-24TNJ □ EC2 series High Insulation Type (ND Type) Option Terminal Packing Standard Tube Nominal Coil Voltage (VDC) Coil Type Non-latch Single Coil Latch 3 EC2-3ND EC2-3SND 4.5 EC2-4.5ND EC2-4.5SND 5 EC2-5ND EC2-5SND 9 EC2-9ND EC2-9SND 12 EC2-12ND EC2-12SND 24 EC2-24ND EC2-24SND □ EE2 series Option Terminal Packing Tube Standard Taping Minimum footprint Tube Nominal Coil Voltage (VDC) Coil Type Non-latch Single Coil Latch Double Coil Latch 3 EE2-3NU EE2-3SNU EE2-3TNU 4.5 EE2-4.5NU EE2-4.5SNU EE2-4.5TNU 5 EE2-5NU EE2-5SNU EE2-5TNU 9 EE2-9NU EE2-9SNU EE2-9TNU 12 EE2-12NU EE2-12SNU EE2-12TNU 24 EE2-24NU EE2-24SNU EE2-24TNU 3 EE2-3NU-L EE2-3SNU-L EE2-3TNU-L 4.5 EE2-4.5NU-L EE2-4.5SNU-L EE2-4.5TNU-L 5 EE2-5NU-L EE2-5SNU-L EE2-5TNU-L 9 EE2-9NU-L EE2-9SNU-L EE2-9TNU-L 12 EE2-12NU-L EE2-12SNU-L EE2-12TNU-L 24 EE2-24NU-L EE2-24SNU-L EE2-24TNU-L 3 EE2-3NUH EE2-3SNUH EE2-3TNUH 4.5 EE2-4.5NUH EE2-4.5SNUH EE2-4.5TNUH EE2-5TNUH 5 EE2-5NUH EE2-5SNUH 9 EE2-9NUH EE2-9SNUH EE2-9TNUH 12 EE2-12NUH EE2-12SNUH EE2-12TNUH 24 EE2-24NUH EE2-24SNUH EE2-24TNUH 9 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES Minimum footprint Taping Tube High solder joint reliability Taping 3 EE2-3NUH-L EE2-3SNUH-L EE2-3TNUH-L 4.5 EE2-4.5NUH-L EE2-4.5SNUH-L EE2-4.5TNUH-L 5 EE2-5NUH-L EE2-5SNUH-L EE2-5TNUH-L 9 EE2-9NUH-L EE2-9SNUH-L EE2-9TNUH-L 12 EE2-12NUH-L EE2-12SNUH-L EE2-12TNUH-L 24 EE2-24NUH-L EE2-24SNUH-L EE2-24TNUH-L 3 EE2-3NUX EE2-3SNUX EE2-3TNUX 4.5 EE2-4.5NUX EE2-4.5SNUX EE2-4.5TNUX 5 EE2-5NUX EE2-5SNUX EE2-5TNUX 9 EE2-9NUX EE2-9SNUX EE2-9TNUX 12 EE2-12NUX EE2-12SNUX EE2-12TNUX 24 EE2-24NUX EE2-24SNUX EE2-24TNUX 3 EE2-3NUX-L EE2-3SNUX-L EE2-3TNUX-L 4.5 EE2-4.5NUX-L EE2-4.5SNUX-L EE2-4.5TNUX-L 5 EE2-5NUX-L EE2-5SNUX-L EE2-5TNUX-L 9 EE2-9NUX-L EE2-9SNUX-L EE2-9TNUX-L 12 EE2-12NUX-L EE2-12SNUX-L EE2-12TNUX-L 24 EE2-24NUX-L EE2-24SNUX-L EE2-24TNUX-L □ EE2 series High Insulation Type (ND Type) Option Terminal Packing Tube Standard Taping Nominal Coil Voltage (VDC) Coil Type Non-latch Single Coil Latch 3 EE2-3ND EE2-3SND 4.5 EE2-4.5ND EE2-4.5SND 5 EE2-5ND EE2-5SND 9 EE2-9ND EE2-9SND 12 EE2-12ND EE2-12SND 24 EE2-24ND EE2-24SND 3 EE2-3ND-L EE2-3SND-L 4.5 EE2-4.5ND-L EE2-4.5SND-L 5 EE2-5ND-L EE2-5SND-L 9 EE2-9ND-L EE2-9SND-L 12 EE2-12ND-L EE2-12SND-L 24 EE2-24ND-L EE2-24SND-L □ EE2 series High Breakdown Voltage Type (NKX Type) Option Terminal Packing Tube High solder joint reliability Taping Nominal Coil Voltage (VDC) Coil Type Non-latch 3 EE2-3NKX 4.5 EE2-4.5NKX 12 EE2-12NKX 3 EE2-3NKX-L 4.5 EE2-4.5NKX-L 12 EE2-12NKX-L 10 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES PERFORMANCE DATA □ COIL TEMPERATURE RISE Temperature is measured by coil resistance Coil temperature rise (℃) Coil temperature rise (℃) 60 40 20 20 10 0 0 100 200 Applied power 0.2W 30 Applied power 0.14W Applied power 0.1W 0 300 0 5 10 This is a maximum value of permissible alteration. These are maximum value. Inquire with EM Devices under continuous use. Inquire with EM Devices for maximum values under continuous 2.0 current (A) 200 1.0 Ratio nominal 0.5 voltage (%) DC(Resistive) AC(Resistive) 10 20 50 100 □ APPLIED VOLTAGE VS. TIMING time (ms) 100 50 -40 -20 250VAC Contact voltage (V) Operate of 150 coil 0.2 0.1 220VDC 3 3 Release 2 time (ms) 1 100 150 20 40 60 80 100 (Sample:EE2-5NU) 4 0 0 Ambient temperature (℃ ) 4 0 20 □ MAXIMUM COIL VOLTAGE □ SWITCHING CAPACITY Contact 15 Applied time (minute) Applied power (mW) 200 Applied power (mW) 250 (Without coil diode) 2 1 0 0 100 200 300 400 Applied power (mW) 11 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES □ OPERATE AND RELEASE VOLTAGE VS.AMBIENT TEMPERATURE This shows a typical change of operate (release) voltage. The value of must operate is estimated, so coil voltage must be applied more than this value for safety operation. For hot start operation, please inquire with EM Devices. 100 Must operate voltage 80 Ratio of nominal Operate voltage (typical) 60 coil voltage (%) 40 Release voltage (typical) 20 0 -40 -20 0 20 40 60 80 100 Ambient temperature (℃) □ RUNNING TEST (Non load) (Load: none, Drive:5VDC,50Hz,50%duty, Ambient temperature :room temperature, Sample:EE2-5NU ,20pieces) 10000 5 Contact 1000 Operate 4 100 voltage 3 (V) Release 2 10 voltage 1 (V) 0 resistance (mΩ) 0 20 50 100 500 1000 Operate voltage Release voltage 0 20 50 4 Operations (×10 ) 100 500 1000 4 Operations (×10 ) □ RUNNING TEST(Load) (Load:50VDC 0.1A resistive,Drive:5VDC,5Hz,50%duty,Ambient temperature:85℃, Sample:EE2-5NU ,10pieces) 5 10000 Operate voltage 4 Contact resistance 1000 Operate 3 voltage 2 (V) 100 Release 1 voltage 0 (V) (mΩ) Release voltage 0 10 0 2 5 10 50 100 2 5 10 50 100 4 Operations (×10 ) 4 Operations (×10 ) 12 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES □ BREAKDOWN VOLTAGE Sample: EC2-5NU 10peices (a) Between open contacts (b) Between adjacent contacts 100 100 50 Distribution 50 Distribution (%) 0 0.5 0 1.0 1.5 2.0 Breakdown voltage (K V) 1.0 1.5 2.0 2.5 Breakdown voltage (K V) (C) Between coil and contact 100 50 Distribution (%) 0 0.5 1.5 2.0 2.5 Breakdown voltage (K V) □ ALTERNATION OF VOLTAGE IN DENSE MOUNTING (Magnetic interference) Alternation of operate voltage Alternation of operate voltage +40 +40 +30 +30 +20 +20 +10 Ratio of +10 Ratio of 0 alternation (%) -10 0 alternation (%) -10 -20 -20 -30 -30 -40 a b c d e -40 f Device under test ON ON OFF OFF ON 2.54 mm OFF b b c d f e 2.54mm OFF ON a a Mounting layout Mounting layout c d 2.54 mm ON OFF ON OFF ON OFF e f 13 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES PACKING DIMENSION (Unit: mm) TUBE PACKING (EC2/EE2) 35 pieces / Tube (anti-static) 15.5 543 11.9 Rubber stopper (Red) Rubber stopper (Green) Direction of relay direction mark TAPE PACKING (EE2) APPEARANCE Number of storage: 500 pieces / Reel Reel diameter: 380mm Reel Emboss Carrying tape Top cover tape TAPE DIMENSIONS A 1.75 2.0 Φ 1.5 16 0.4 4 Φ 2.2 A 11.5 24.0 15.5 B B EE2-xxNU-L EE2-xxND-L EE2-xxNUX-L EE2-xxNKX-L Max.10.9 10.0 EE2-xxNUH-L Max.11.1 8.0 RELAY DIRECTION MARK AND TAPE CARRYING DIRECTION Sprocket hole Direction mark Direction of unreeling 14 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES SOLDERING TEMPERATURE CONDITION THROUGH-HOLE MOUNTING (EC2) 1. Automatic soldering Preheating: 110~ 120℃ /110 sec. (max.) Solder temperature: 260℃ max. Solder time: 5 seconds max. Note: NEC TOKIN recommends cooling down a printed circuit board less than 110℃ within 40 seconds after soldering. 2. Manual soldering Solder temperature: 350℃ max. Solder time: 3 seconds max. SURFACE-MOUNTING TYPE (EE2) IRS Method Temperature (℃) max. 240 ℃ 220 200 180 45 (max.70) Time (sec.) 70 (max.120) 190 (max.300) Note: 1. Temperature profile shows printed circuit board surface temperature on the relay terminal portion. 2. Check the actual soldering condition to use other method except above mentioned temperature profiles. 15 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 2017.03.30 EMDSD2VOL01E1704H EC2/EE2 SERIES NOTE ON CORRECT USE 1. Notes on contact load a temperature outside this range may adversely affect Make sure that the contact load is within the specified range; insulation or contact performance. otherwise, the lifetime of the contacts will be shortened - If the relay is used for a long period of time in highly humid considerably. (RH 85% or higher) environment, moisture may be absorbed Note that the running performance shown is an example, and into the relay. This moisture may react with the NOx and SOx that it varies depending on parameters such as the type of generated by glow discharges that occur when the contacts load, switching frequency, driver circuit, and ambient are opened or closed, producing nitric or sulfuric acid. If this temperature under the actual operating conditions. happens, the acid produced may corrode the metallic parts of Evaluate the performance by using the actual circuit before the relay, causing operational malfunction. using the relay. - If any material containing silicon (silicon rubber, silicon oil, 2. Driving relays and silicon based coating material) is used in the neighborhood - If the internal connection diagram of a relay shows + and - of relay, there is some possibility that these materials will emit symbols on the coil, apply the rated voltage to the relay in the silicon gas that will penetrate the relay. In this case, the specified direction. If a rippled DC current source is used, switching contact may generate silicon compounds on the abnormalities such as beat at the coil may occur. surface of contacts. This silicon compound may result in - The maximum voltage that can be applied to the coil of the contact failure. Avoid use of relay in such an environment. relay varies depending on the ambient temperature. - Because the operating temperature range varies depending Generally, the higher the voltage applied to the coil, the shorter on the humidity, use the relay in the temperature range the operating time. Note, however, that a high voltage also illustrated in the figure below. Prevent the relay from being increases the bounce of the contacts and the contact opening frozen and avoid the generation of condensation. and closing frequency, which may shorten the lifetime of the contacts. 85 80 - If the driving voltage waveform of the relay coil rises and falls gradually, the inherent performance of the relay may not be fully realized. Make sure that the voltage waveform instantaneously rises and falls as a pulse. 60 Humidity (%RH) 40 20 Nominal coil voltage 5 -60 -40 -20 0 20 40 60 80 100 Temperature (℃ ) 0 - The relay maintains constant sealability under normal atmospheric pressure (810 to 1,200 hpa). Its sealability may be
EE2-24NU-L
PDF文档中包含的物料型号为:ATMEGA328P-AU。
器件简介指出ATMEGA328P-AU是一款低功耗的8位CMOS微控制器,适用于需要复杂计算、I/O接口以及与其他系统的通信能力的应用。
引脚分配包括44个引脚,且具有不同的功能,如电源、地、I/O端口等。
参数特性包括工作电压范围、工作频率、存储器容量等。
功能详解部分描述了其核心功能,如中央处理单元、存储器、I/O端口等。
应用信息说明了这款微控制器适用于哪些类型的应用场景。
封装信息指出ATMEGA328P-AU的封装类型为TQFP44。
这些信息有助于用户了解ATMEGA328P-AU的主要特性和应用场景。
EE2-24NU-L 价格&库存
很抱歉,暂时无法提供与“EE2-24NU-L”相匹配的价格&库存,您可以联系我们找货
