EA2-12NU
EA2-12NU
    EMDEVICES(EM 设备公司)
    NEXEM - EA2-12NU - Signal Relay, 12 V, DPDT, 1 A, EA2, Through Hole, Non Latching
EA2-12NU 数据手册
DATA SHEET MINIATURE SIGNAL RELAY EA2/EB2 SERIES RoHS Compliant COMPACT SIZE, FLAT-PACKAGE DESCRIPTION NEXEM EA2/EB2 relay is a standard miniature signal relay, compact and flat. FEATURES Compact and light weight FCC (1500 V) surge capacity. UL recognized and CSA certified. Low power consumption (100-200 mW) APPLICATIONS Electronic switching system, PBX, Terminal equipment, Telephone system For Right Use of Miniature Relays DO NOT EXCEED MAXIMUM RATINGS. Do not use relays under exceeding conditions such as over ambient temperature, over voltage and over current. Incorrect use could result in abnormal heating, damage to related parts or cause burning. READ CAUTIONS IN THE SELECTION GUIDE. Read the cautions described in EM Devices' "Miniature Relays" when you choose relays for your application. The information in this document is subject to change without notice. © EM Devices Corporation 2017 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EB2 SERIES DIMENSIONS AND PAD LAYOUTS Unit: mm (inch) EA2 SERIES (mm) 9.2 max. (0.36) 14.2 max. (0.56) 2.54 2.54 2.54 2.54 10-Φ0.8 5.4 (0.21) max. 3.5 (0.14) 0.5 (0.02) 7.62 0.25 (0.01) 7.62 2.54 2.54 2.54 2.54 NOTE. General tolerance :±0.1 Lead size 0.5x0.25 ±0.1 is basic size. Other tolerances ±0.2mm (Bottom view) NJ type: Cover height 6.3mm, Lead length 2.8mm EB2 SERIES 2 . 5 4 2. 5 4 2.5 4 2.54 (mm) 9.3 max. (0.37) 14.3 max. (0.56) 7.5 (0.3) 1.35 (0.05) max. 9.56 2.94 7.62 2.54 2.54 2.54 2.54 is basic size. Other tolerances ±0.2mm 11.5 (0.45) 1.0 NOTE. General tolerance :±0.1 (Bottom view) (Top view) Lead size 0.5x0.25 ±0.1 2 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EBE2 SERIES PIN CONFIGURATIONS (Bottom view) Direction mark 1 2 3 4 5 7 6 + Non-latch type 10 9 8 Non-latch type (Not energized position) Direction mark Single coil latch type 1 2 3 4 5 7 6 +SR - + 10 9 8 S: Coil polarity for Set R: Coil polarity for Reset Single coil latch type (Reset position) Set coil 1 2 3 4 5 Direction mark Double coil latch type + - + 10 - 9 8 7 6 Reset coil Double coil latch type (Reset position) MARKINGS (top view) (1) (2) (1) Part number (2) Manufacturer (3) Country of origin (4) Date code (5) Direction mark (pin No. 1 and 10) (6) UL,CSA marking EA2-5NU JAPAN (5) 0501F (6) (3) (4) 3 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EB2 SERIES GENERAL SPECIFICATIONS Contact Form 2 Form C Contact Material Silver alloy with gold alloy overlay Contact Ratings Maximum Switching Power 30 W, 62.5 VA Maximum Switching Voltage 220 VDC, 250 VAC Maximum Switching Current 1A Maximum Carrying Current 2A Minimum Contact Ratings 10 m VDC, 10µA *1 Initial Contact Resistance 75 m Ω max. (initial) Operate Time (Excluding bounce) Approx. 2 ms Release Time (Excluding bounce) Approx. 1 ms Insulation Resistance 1000 MΩ at 500 VDC Withstanding Voltage Between open contacts Between adjacent contacts Between coil and contacts 1000 VAC (for one minute) 1500 V surge (10x160 µs *2) 1000 VAC (for one minute) 1500 V surge (10x160 µs *2) 1000 VAC (for one minute) , 1500 V surge (10x160 µs *2) 735 m/s2 (75G) (misoperation) 2 980 m/s (100G) (destructive failure) Shock Resistance 10 to 55 Hz, double amplitude 3 mm(20G) (misoperation) 10 to 55 Hz, double amplitude 5 mm(30G) (destructive failure) -40 to +85 °C Vibration Resistance Ambient Temperature Coil Temperature Rise Non-load Running Specifications Load Weight 18 °C at nominal coil voltage (140mW) 1x108 operations (Non-latch type) *3 7 1x10 operations (Latch type) 50 VDC 0.1A (resistive), 1x106 operations at 85 °C,5Hz 10 VDC 10mA (resistive), 1x106 operations at 85 °C,2Hz Approx. 1.5 g * 1 This value is a reference value in the resistance load. Minimum capacity changes depending on switching frequency and environment temperature and the load. * 2 rise time: 10 µs, decay time to half crest: 160 µs 7 * 3 This shows the number of operations with fatal defects. Stable characteristics are maintained for 1×10 operations. 4 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EBE2 SERIES COIL SPECIFICATIONS Non-latch Type Nominal Coil Voltage (VDC) Coil Resistance (Ω)±10% Must Operate Voltage* (VDC) Must Release Voltage* (VDC) at 20 °C Nominal Operating Power (mW) 3 64.3 2.25 0.3 140 4.5 145 3.38 0.45 140 5 178 3.75 0.5 140 12 1028 9.0 1.2 140 24 2880 18.0 2.4 200 Set Voltage* (VDC) Reset Voltage* (VDC) at 20 °C Nominal Operating Power (mW) Single Coil Latch Type Nominal Coil Coil Voltage Resistance (VDC) (Ω)±10% 3 90 2.25 2.25 100 4.5 202.5 3.38 3.38 100 5 250 3.75 3.75 100 12 1440 9.0 9.0 100 24 3840 18.0 18.0 150 Double Coil Latch Type (Can not be driven by reverse polarity for reverse operation) Nominal Coil Set Reset Coil Voltage Resistance Voltage** Voltage** (VDC) (Ω)±10% (VDC) (VDC) 3 4.5 5 12 24 S 64.3 2.25 - R 64.3 - 2.25 S 145 3.38 - R 145 - 3.38 S 178 3.75 - R 178 - 3.75 S 1028 9.0 - R 1028 - 9.0 S 2880 18.0 - R 2880 - 18.0 at 20 °C Nominal Operating Power (mW) 140 140 140 140 200 Note * Test by pulse voltage ** S : Set coil (pin No.1 ... (+) , pin No.5 ...(-) ) R : Reset coil (pin No.10...(+) , pin No.6...(-) ) The latch type relays should be initialized at appointed position before using, and should be energized to specific polarity by above polarity to avoid wrong operation. Any special coil requirement, please contact EM Devices for availability. 5 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EB2 SERIES SAFETY STANDARD AND RATING UL Recognized (UL508)* File No E73266 CSA Certificated (CSA C22.2 No14) File No LR46266 30 VDC, 1 A (Resistive) 110 VDC, 0.3 A (Resistive) 125 VAC, 0.5 A (Resistive) * Spacing: UL114, UL478 RECOMMENDED RELAY DRIVE CONDITIONS Drive under conditions. If it is impossible, please inquire to EM Devices. Non-latch type Voltage: within ±5% of nominal voltage Single coil latch type Double coil latch type Square pulse (rise and fall time is rapid) Pulse height : within ±5% of nominal voltage Pulse width : More than 10 ms Ambient temperature - 40 to +85 °C PART NUMBER SYSTEM EA2-3SNU NU: Standard NJ: Trimmed lead type Nil: Non-latch type S: Single coil latch type T: Double coil latch type Nominal coil voltage (A numerical value of coil voltage) EA2 series EB2–3SNU–L Packing Nil: Tube L: Embossed carrying tape NU: Standard Nil: Non-latch type S: Single coil latch type T: Double coil latch type Nominal coil voltage (A numerical value of coil voltage) EB2 series 6 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EBE2 SERIES ORDERING PART NUMBERS EA2 series Option Terminal Packing Standard Tube Trimmed lead Nominal Coil Voltage (VDC) Coil Type Non-latch Single Coil Latch 3 EA2-3NU EA2-3SNU Double Coil Latch EA2-3TNU 4.5 EA2-4.5NU EA2-4.5SNU EA2-4.5TNU 5 EA2-5NU EA2-5SNU EA2-5TNU 12 EA2-12NU EA2-12SNU EA2-12TNU 24 EA2-24NU EA2-24SNU EA2-24TNU 3 EA2-3NJ EA2-3SNJ EA2-3TNJ 4.5 EA2-4.5NJ EA2-4.5SNJ EA2-4.5TNJ 5 EA2-5NJ EA2-5SNJ EA2-5TNJ 12 EA2-12NJ EA2-12SNJ EA2-12TNJ 24 EA2-24NJ EA2-24SNJ EA2-24TNJ EB2 series Option Terminal packing Tube Standard Taping Nominal Coil Voltage (VDC) Coil Type Non-latch Single Coil Latch 3 EB2-3NU EB2-3SNU Double Coil Latch EB2-3TNU 4.5 EB2-4.5NU EB2-4.5SNU EB2-4.5TNU 5 EB2-5NU EB2-5SNU EB2-5TNU 12 EB2-12NU EB2-12SNU EB2-12TNU 24 EB2-24NU EB2-24SNU EB2-24TNU 3 EB2-3NU-L EB2-3SNU-L EB2-3TNU-L 4.5 EB2-4.5NU-L EB2-4.5SNU-L EB2-4.5TNU-L 5 EB2-5NU-L EB2-5SNU-L EB2-5TNU-L 12 EB2-12NU-L EB2-12SNU-L EB2-12TNU-L 24 EB2-24NU-L EB2-24SNU-L EB2-24TNU-L 7 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EB2 SERIES PERFORMANCE DATA COIL TEMPERATURE RISE Temperature is measured by coil resistance Coil temperature rise (°C ) Coil temperature rise (°C) 60 Applied power 0.2W 30 40 20 20 10 Applied power 0.14W Applied power 0.1W 0 0 100 200 0 300 0 5 10 15 20 Applied time (minute) Applied power (mW) SWITCHING CAPACITY MAXIMUM COIL VOLTAGE These are maximum values. This is a maximum value of permissible alteration. Inquire with EM Devices under continuous use. Inquire with EM Devices for maximum values under continuous use. DC(Resistive) 2.0 200 AC(Resistive) Contact current (A) 1.0 0.5 Ratio nominal of 150 coil voltage 0.2 0.1 (%) 10 20 50 100 Operate time (ms) 50 -40 -20 250VAC Contact voltage (V) APPLIED VOLTAGE VS. TIMING 100 3 3 Release 2 time (ms) 1 100 150 40 60 80 100 (Sample: EA2-5NU) 4 0 20 Ambient temperature (° C) 220VDC 4 0 0 200 Applied power (mW) 250 (Without coil diode) 2 1 0 0 100 200 300 400 Applied power (mW) 8 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EBE2 SERIES OPERATE AND RELEASE VOLTAGE VS.AMBIENT TEMPERATURE This shows a typical change of operate (release) voltage. The value of must operate is estimated, so coil voltage must be applied more than this value for safety operation. For hot start operation, please inquire with EM Devices. 100 Must operate voltage 80 Ratio of nominal Operate voltage (typical) 60 coil voltage (%) 40 Release voltage (typical) 20 0 -40 -20 0 20 40 60 80 100 Ambient temperature (°C) RUNNING TEST (Non-load) (Load: none, Drive:5VDC,50Hz,50%duty, Ambient temperature :room temperature, Sample:EA2-5NU ,20pieces) 10000 5 Contact 1000 (mΩ) Operate voltage Operate 4 resistance voltage 3 (V) Release 2 100 10 0 20 50 100 500 voltage 1 (V) 0 1000 Release voltage 0 20 50 4 Operations (×10 ) 100 500 1000 4 Operations (×10 ) RUNNING TEST(Load) (Load: 50VDC 0.1A resistive, Drive: 5VDC,5Hz,50%duty,Ambient temperature:85 °C, Sample:EA2-5NU ,10pieces) 5 10000 Operate voltage 4 Contact resistance 1000 Operate 3 voltage 2 (V) 100 Release 1 (mΩ) Release voltage 0 0 10 0 2 5 10 50 100 2 5 10 50 100 4 Operations (×10 ) 4 Operations (×10 ) 9 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EB2 SERIES BREAKDOWN VOLTAGE Sample: EA2-5NU 10peices (a) Between open contacts (b) Between adjacent contacts 100 100 50 Distribution 50 Distribution (%) 0 0.5 0 1.0 1.5 2.0 Breakdown voltage (K V) (C) 1.0 1.5 2.0 2.5 Breakdown voltage (K V) Between coil and 100 50 Distribution (%) 0 0.5 1.5 2.0 2.5 Breakdown voltage (K V) ALTERNATION OF VOLTAGE IN DENSE MOUNTING (magnet interference) Alternation of operate voltage Alternation of operate voltage +40 +40 +30 +30 +20 +20 +10 Ratio of +10 Ratio of 0 alternation (%) -10 0 alternation (%) -10 -20 -20 -30 -30 -40 a b c d e -40 f a ON ON OFF 2.54mm OFF b d e f OFF ON 2.54mm OFF ON a c Mounting layout Mounting layout Device under test b c d 2.54mm ON OFF ON OFF ON OFF e f 10 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EBE2 SERIES PAKING DIMENSIONS (Unit: mm) TUBE PACKING (EA2/EB2) 40 pieces / Tube (anti-static) 12.0 586 13.7 Rubber stopper (Red) Rubber stopper (Green) Direction of relay direction mark TAPE PACKING (EB2) APPEARANCE 750 pieces / Reel Reel diameter: 380mm Reel Emboss Carrying tape Top cover tape TAPE DIMENSIONS max. 8.1 1.75 2.0 Φ1.5 16 0.4 4 Φ2.2 11.5 14.7 24.0 12.1 RELAY DIRECTION MARK AND TAPE CARRYING DIRECTION Sprocket hole Direction mark Direction of unreeling 11 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EB2 SERIES SOLDERING TEMPERATURE CONDITION THROUGH-HOLE MOUNTING (EA2) 1. Automatic soldering Preheating: 110~ 120°C /110 sec. (max.) Solder temperature: 260°C max. Solder time: 5 seconds max. Note: EM Devices recommends cooling down a printed circuit board less than 110°C within 40 seconds after soldering. 2. Manual soldering Solder temperature: 350°C max. Solder time: 3 seconds max. SURFACE-MOUNTING TYPE (EB2) IRS Method Temperature (℃) max. 240 ℃ 220 200 180 45 (max.70) Time (sec.) 70 (max.120) 190 (max.300) Note: 1. Temperature profile shows printed circuit board surface temperature on the relay terminal portion. 2. Please consult EM Devices if you wish to use a temperature profile other than above. 12 ●All specifications in this catalog and production status of products are subject to change without notice. Prior to the purchase, please contact EM Devices for updated product data. ●Please request for a specification sheet for detailed product data prior to the purchase. ●Before using the product in this catalog, please read "Precautions" and other safety precautions listed in the printed version catalog. 0886EMDD03VOL01E EA2/EBE2 SERIES NOTE ON CORRECT USE 1. Notes on contact load at a temperature outside this range may adversely affect Make sure that the contact load is within the specified range; insulation or contact performance. otherwise, the lifetime of the contacts will be shortened - If the relay is used for a long period of time in highly humid considerably. (RH 85% or higher) environment, moisture may be absorbed Note that the running performance shown is an example, into the relay. This moisture may react with the NOx and and that it SOx generated by glow discharges that occur when the varies depending on parameters such as the type of load, switching frequency, driver circuit, and ambient temperature under the actual operating conditions. Evaluate the performance by using the actual circuit before contacts are opened or closed, producing nitric or sulfuric acid. If this happens, the acid produced may corrode the metallic parts of the relay, causing operational malfunction. 2. Driving relays - If any material containing silicon (silicon rubber, silicon oil, and silicon based coating material) is used in the - If the internal connection diagram of a relay shows + and - neighborhood of relay, there is some possibility that these symbols materials will emit silicon gas that will penetrate the relay. In using the relay. on the coil, apply the rated voltage to the relay in the specified direction. If a rippled DC current source is used, abnormalities such as beat at the coil may occur. this case, the switching contact may generate silicon compounds on the surface of contacts. This silicon - The maximum voltage that can be applied to the coil of the compound may result in contact failure. Avoid use of relay in relay such an environment. varies depending on the ambient temperature. Generally, the higher the voltage applied to the coil, the - Because the operating temperature range varies shorter the operating time. Note, however, that a high depending on the humidity, use the relay in the temperature voltage also increases the bounce of the range illustrated in the figure below. Prevent the relay from contacts and the contact opening and closing frequency, which may being frozen and avoid the generation of condensation. shorten the lifetime of the contacts. - If the driving voltage waveform of the relay coil rises and falls gradually, the inherent performance of the relay may not be fully realized. Make sure that the voltage waveform instantaneously rises and falls as a pulse. Nominal coil voltage 85 80 60 Humidity (%RH) 40 20 5 -60 -40 -20 0 20 40 0 60 80 100 Temperature (°C )
EA2-12NU 价格&库存
很抱歉,暂时无法提供与“EA2-12NU”相匹配的价格&库存,您可以联系我们找货
EA2-12NU
    • 1+21.858091+2.84634
    • 10+19.5068210+2.54016
    库存:18
