ER14505
ER14505
    EVE(亿纬锂能)
    锂亚电池3.6V锂原电池锂电池2700mAh
ER14505 数据手册
T echnical Specification ENERGY VERY ENDURE ER14505 Lithium-thionyl Chloride (Li-SOCl2) Battery International size reference: AA ELECTRICAL CHARACTERISTICS (typical values for cells stored for one year or less, at 25 C) 2.6Ah Nominal capacity (at 2.0 mA, +25 C, 2.0V cut off. The capacity restored by the cell varies according to current drain, temperature and cut off voltage.) 3.6V Rated voltage 100mA Maximum recommended continuous current (To get 50% of the nominal capacity at +25 C with 2.0V cut off. Higher currents possible, consult EVE.) Pulse capability: Typically up to 200mA (200mA /0.1 second pulses, drained every 2 min at 25 C from undischarged cells with 10μA base current, yield voltage readings above 3.0 V. The readings may vary according to the pulse characteristics, the temperature, and the cell's previous history. Fitting cell with a capacitor may be recommended in severe conditions. consult EVE.) Storage (recommended) 30 C max (for more severe condition consult EVE) Operating temperature range -55 C / +85 C (Operation at temperatur e different from ambient may lead to reduced capacit y and lower voltage plateau readings .) Typical weight 19g WARNING: Fire, explosion and severe burn hazard. Do not recharge, crush, disassemble, heat above 100 C, incinerate, or expose contents to water. Note: Any representations in this data sheet concerning performance are for informational purpose only and are not construed as warranties, either expressed or implied, of future performance. 11-08 ER14505 1.DISCHARGE CHARACTERISTICS@+25 C 4.0 5.6mm Max. 3.5 2.5 50.5mm Max. VOLTAGE (V) 3.0 2.0 1.5 1.0 1 100 10 1,000 10,000 TIME (h) 2. VOLTAGE VS. TEMPERATURE 14.5mm Max. AVAILABLE TERMINATIONS VOLTAGE (V) Suffix-/S Suffix-/P Suffix-/T Suffix-/2PT Suffix-/3PT/3TP Standard Axial Pins Solder Tabs Radial Pins Radial Pins View available terminations TEMPERATURE( C) 3. CAPACITY VS. CURRENT 4. STORAGE CHARACTERISTICS Discharge current: 2.0mA Temperature: 25 C VOLTAGE (V) CAPACITY (Ah) 4.0 3.0 stored for 200 days at 60 C (*Equivalent to storage at 25 C for 10 years) 2.0 Initial 1.0 0 0 CURRENT(mA) 100 1,000 10,000 TIME (h) EVE ENERGY CO., LTD. Address.:EVE Industrial Park, XiKeng Industrial zone, Huihuan Town, Huizhou, Guangdong, China Operator: (86-752)260 6966 Direct:(86-752)261 0582 Fax: (86-752)260 6033 P.C.516006 http://www. evebattery.com Email: sales@evebattery.com Latest version can be downloaded from the EVE website
ER14505 价格&库存
很抱歉,暂时无法提供与“ER14505”相匹配的价格&库存,您可以联系我们找货
