0T SERIES
IP 68 PUSH-PULL CONNECTORS
0T series
0T series connectors have been specifically designed for outdoor applications. They include an inner
sleeve and seals to prevent penetration of solids or liquids.This series is watertight when mated to give
a protection index of IP68 as per IEC 60529 standard and have the following main features:
- IP68 mated
- Push-Pull self-latching system
- Mechanical key (FGG) with multiple keys
to avoid cross-mating
- High packing density for space savings
- 360° shielding for full EMC shielding
- Compatible with existing 0B sockets
- Same mounting hole as 0B sockets
- Black-chrome plated brass and plastic outershell
available
- Multipole types 2 to 9 contacts
- For cables 1.0 up to 5.0 mm
- Solder, crimp or print contacts
Technical Characteristics
Mechanical and Climatical
Value
Standard
Endurance
> 5000 cycles
IEC 60512-5 test 9a
Humidity
up to 95% at 60° C
Temperature range
-55° C, +200° C
Resistance to vibration
10-2000 Hz, 15 g
IEC 60512-4 test 6d
Shock resistance
100 g, 6 ms
IEC 60512-4 test 6c
Salt spray corrosion test
> 144h
IEC 60512-6 test 11f
Protection index (mated)
IP68
IEC 60529
Latching retention force
> 150 N
Electrical
Value
Standard
Shielding efficiency at 10 MHz
> 75 dB
IEC 60169-1-3
Shielding efficiency at 1 GHz
> 40 dB
IEC 60169-1-3
Material and Treatments
Outershell and collet nut
Material
Surf. treat.
Latch sleeve/earthing crown
Material
Surf. treat.
Other metallic components
Material
Surf. treat.
Brass
Chrome
Brass/Bronze
Nickel
Brass
Nickel
Brass
Black chrome
Brass/Bronze
Nickel
Brass
Nickel
POM
Brass/Bronze
Nickel
Brass
Nickel
Contacts
Material
Insulators
Material
Contact type
Brass (UNS C 34500)
Male contact
Bronze (UNS C 54400)
Female contact
Contact type
PEEK
Crimp, solder or print
Part Section Showing Internal Components
Straight plug
Fixed socket
4
2
2
6
3
7
5
6
1
2
5
4
1
6
7
8
3
1 outer shell
1 outer shell
2 latch sleeve
2 earthing crown
3 collet nut
3 hexagonal nut
4 insulator
4 insulator
5 male contact
5 female contact
6 split insert carrier
6 o-ring
7 earthing cone
7 locking washer
8 gasket
Interconnections
Metal housing models
Straight plugs
FGG
Fixed sockets
Free sockets
EGG
PHG
EEG
PHG
FFG
FGG
Plastic housing models
Straight plug
FGG
Watertight or vacuumtight models
Fixed socket
Fixed sockets
EGG
HGG
HEG
HMG
Part Numbering System
Plug and free socket
F G G. 0 T . 3 0 4 . C L A C 4 0 Z
Variant
Cable ø
Model
Collet type
Alignment key
Contact:
A = male solder
L = female solder
C = male crimp
M = female crimp
Series
Insert configuration
Housing:
C = Chrome plated brass
K = Black Cr plated brass
D = POM
Insulator: PEEK
L = for solder contact
Y = for crimp contact
FGG.0T.304.CLAC40Z = Straight plug with key (G) and cable collet for bend relief, 0T series, multipole type with
4 contacts, outer shell in chrome-plated brass, PEEK insulator, male solder contacts, C type collet for 4.0 mm
diameter cable and nut for fitting a bend relief.
Fixed socket
E G G. 0 T . 3 0 4 . C L L
Model
Alignment key
Series
Housing:
D = POM
Contact:
L = female solder
M = female crimp
N = female print
V = fem. elbow print
Insulator: PEEK
EGG.0T.304.CLL = fixed socket, nut fixing, with key (G), 0T series, multipole type with 4 contacts, outer shell in
chrome-plated brass, PEEK insulator, female solder contacts.
3
FGG Straight plug, cable collet
~39
ø9
~29
FGG Straight plug, cable collet and nut for fitting a bend relief
~38
ø9
~28
FFG
Straight plug, non latching, cable collet
~39
ø9
~29
EGG Fixed socket, nut fixing
21 maxi
1.5
ø 9.1+ 0.1
ø 12
19.1
8.3 + 0.1
6 maxi
Panel cut-out
4
EEG Fixed socket, nut fixing, back panel mounting
21 maxi
ø 12
ø 9.1+ 0.1
8.3 + 0.1
6.5 maxi
Panel cut-out
HGG Fixed socket, nut fixing, watertight or vacuumtight
22 maxi
ø 9.1+ 0.1
ø 12
18.5
8.3 + 0.1
9 maxi
Panel cut-out
Note: temperature range -20°C / +100°C
HEG Fixed socket, nut fixing, watertight or vacuumtight, back panel mounting
22 maxi
ø 12
ø 9.1+ 0.1
8.3 + 0.1
6.5 maxi
Panel cut-out
HMG Fixed socket, nut fixing, watertight or vacuumtight, back panel mounting
22 maxi
ø 12
ø 9.1+ 0.1
6.5 maxi
8.3 + 0.1
Panel cut-out
5
PHG Free socket, cable collet
ø9
~38
PHG Free socket, cable collet and nut for fitting a bend relief
ø9
~37
FGG Straight plug, cable collet and nut for fitting a bend relief, POM outer shell
~38.5
ø 9.7
~28.5
EGG Fixed socket, nut fixing, POM outer shell
21 maxi
1.5
ø 9.1+ 0.1
ø 12
19.1
8.3 + 0.1
6 maxi
Panel cut-out
6
Insert configurations
Contact
type
Solder contacts
AWG
Contact ø (mm)
Solder
Crimp
Print (straight)
Print (elbow)
Solder (max.)
min.
max.
302
2
0.9
22
32
20 1.00 1.05 10.0
303
3
0.9
22
32
20 1.20 0.90
8.0
304
4
0.7
22
32
22 0.85 0.70
7.0
305
5
0.7
22
32
22 1.00 0.70
6.5
306
6
0.5
28
32
28 0.85 0.65
2.5
307
7
0.5
28
32
28 0.80 0.70
2.5
309
9
0.5
28
32
28 0.60 0.50
2.0
Crimp contacts
Collets
Rated current (A)
Number of contacts
Test voltage (kV rms)
Reference
Crimp
Alignment Key
Key
Contact type
G
Cable ø (mm)
Cable ø (mm)
Type
Type
min.
max.
min.
max.
C10
1.0
1.2
C35
3.1
3.5
C15
1.3
1.5
C40
3.6
4.0
C20
1.6
2.0
C45
4.1
4.5
C25
2.1
2.5
C50
4.6
5.0
C30
2.6
3.0
B
A
Plug
Socket
G
male
female
A
male
female
B
male
female
J
female
male
J
Bend relief
Bend relief
Cable ø
Part number
øA
L
A
L
min.
max.
GMA.0B.025.DG
2.5
24
2.5
2.9
GMA.0B.030.DG
3.0
24
3.0
3.4
GMA.0B.035.DG
3.5
24
3.5
3.9
GMA.0B.040.DG
4.0
24
4.0
4.4
GMA.0B.045.DG
4.5
24
4.5
5.2
Note: all dimensions are in millimetres.
Ref.
Colour
Ref.
Colour
Ref.
Colour
A
blue
J
yellow
R
red
B
white
M
brown
S
orange
G
grey
N
black
V
green
Note: the last letter «G» of the part number indicates the grey
colour of the bend relief. For ordering a bend relief with
another colour, see table and replace the letter «G» by the
letter of the required colour.
7
PCB drilling pattern
Fixed socket with straight print contact
304
72
ø 2.2
ø 2.8
12
0°
ø 0.8
ø 0.8
305
45°
ø 0.6
303
ø 0.6
302
ø 2.5
ø 2.3
60
45°
ø 3.2
60
ø3
ø3
ø 0.6
309
ø 0.6
307
ø 0.6
306
Fixed socket with elbow print contact
303
304
1
2.54
1
2
1.27
2
2.54
306
4
3
1
2
5
4
2
3
1
ø 0.7
3
1.27
ø 0.7
305
ø 0.7
ø 0.7
1.27
302
2.54 2.54
2.54
2.54
307
309
ø 0.7
ø 0.6
1
3
4
7
1
3
2
1.27
1.27
1.27
2
6
ø 0.7
4
2.54 2.54
5
5
6
2.54 2.54
2.54 2.54
8
7
6
1
9
5
2
3
4
2.54 2.54
Tooling
For crimp contact tooling see 0B series in the unipole/multipole catalogue.
L
Reference
T
S
ø contact
(mm)
Cable asssembly
Cable stripping lengths (mm)
L
Solder
S
T
L
Crimp
S
T
302/303
0.9 14.5
7
3.5
17
7
4
304/305
0.7 14.5
7
3.5
17
7
4
306/307/309
0.5 14.0
7
2.5
18
7
3
LEMO HEADQUARTERS
SWITZERLAND
LEMO SA
Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens
Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com
www.lemo.com
© CAT.0T.LEN.P1113
CHF 1.50 / EURO 1 / USD 1.1 / RMB 10
Data subject to change, printed in Switzerland, November 2013
Updated June 2014
很抱歉,暂时无法提供与“EGG.0T.309.CLL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+285.91190
- 5+274.48792
- 10+263.05353
- 25+257.57585
