EGN.MM.304.XLM
EGN.MM.304.XLM
    LEMO(雷莫)
    EGN.MM.304.XLM
EGN.MM.304.XLM 数据手册
M SERIES CONNECTORS RATCHET COUPLING ® ® Introduction This catalogue gives the complete description of LEMO M series connectors. M series connectors are lightweight triplestart ratchet coupling type connectors designed for avionics, aerospace, military, security, motorsport and heavy duty applications. The LEMO manufacturing programme has been extended to almost 40 series divided into 7 product families with specific mating and environmental characteristics. Each series includes a wide variety of plug, socket and coupler models, available in contact configurations adapted to all round cables. Watertight models are also available. Since LEMO connectors are perfectly screened and designed to guarantee very low resistance to shell electrical continuity, they are particularly adapted to applications where electromagnetic compatibility (EMC) is important. Technical Characteristics Materials and Treatments Component Shell material code X Surface treatment (µm) Notes chrome nickel gold Cu Ni Cr Cu Ni Cu Ni Au Material (Standard) C Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Bronze (UNS C 54400) or special brass Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Special PEEK Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 34500) Bronze (UNS C 54400) Cu-Be or special steel PEEK Silicone FPM/FKM (Viton®) Epoxy (Araldite® or Stycast®) Fluorosilicone Stainless steel Outer shell Conical nut Earthing crown Coupling nut Ratchet Hexagonal nut Male crimp contact Female crimp contact Clips Insulator O-ring Sealing resin Cable rear seal Spring 0.5 – 0.5 – – – – 3 – 3 – – – – – – – – – – – – 0.3 – – – 0.3 – – – – – – 0.5 – 0.5 – 5 – 5 – 3 3 – – – – 0.5 – – – – 0.5 3 – – – 5 – – – – 0.5 – – – 0.5 without treatment – – – – – – – – – – – – – – – – – 1.5 – – – – 3 3 – – 1.0 1.5 1) 1) Notes: standards for surface treatment are as follows: chrome-plated SAE AMS 2460; nickel-plated SAE AMS QQ N 290 or MIL DTL 32119; gold-plated ISO 27874. 1) anthracite colour. Environmental performance Characteristics Operating temperature (mated) Ingress protection index Fungus Flammability Fluid contamination 1) Sand and dust 2) Lightning strike Altitude-low temp 3) Salt fog 4) Thermal shock Altitude immersion Humidity Value -55°C/+200°C (HEN model: -20°C/+80°C) IP 68 (at 2 m, 15Hr) Satisfied - by material analysis 60 sec. front and back face Fuels, gasoline, hydraulic oils, solvents, de-icing 6 hr, 55°C, blowing < 150 µm dust 10 K amps - 6 times -65°C; 40’000 feet and 400 VAC Alum. shell (slight pitting after 48Hr), Brass shell (500Hr) 5 cycles: -65° C to +150° C No moisture on contacts 21 days at 95% IEC international MIL-spec tests IEC 60529 IEC 60512-6 test 11f IEC 60512-11-4 IEC 60068-2 MIL-STD 810F-508.5 EIA-364-104A MIL-STD-810F method 504 MIL-STD 810F-510.4 EIA-364-75 EIA-364-105A EIA-364-26 EIA-364-32 test condition IV EIA-364-03 EIA-364-31 method IV Note: 1) Connectors immersed at both 70°C and 25°C according to specification. Connectors are then inspected, no visual signs of damage seen. Fuels: Kerosene, JP4, (Nato F40) at 70°C +/- 2°C. Gasoline: ASTM 4814. Hydraulic oils: Mineral oil based MIL-H-5606. Solvents: Isopropanol. De-icing fluids: 25% ethylene glycol. 2) No signs of damage, connectors opened and closed without difficulty. Dust or sand was not inside connector. 3) Wired mated connectors = no voltage breakdown, shell to all contacts (connected together) w/400 VAC after 1 hour at 65° C at 40’000 feet altitude. 4) Corrosion resistance. Inspection: salt deposits shall be removed by gentle wash in running water with light brushing using soft brush. Aluminium Shell (material code: X) max: 96 hours. Brass shell (material code: C) over 500 hours. www.lemo.com 1 ® ® Electrical performance Characteristics Value Insulation resist. (at ambient temp.) 6) Dielectric withstanding volt. (sea level) Contact resistance Current rating Shell to shell conductivity Shielding effectiveness, low frequency Shielding effectiveness, high frequency IEC international > 1012 Ω, > 1010 Ω (after humidity) See table page 22-23-24 See table below 7) See insulator configuration page 22-23-24 < 1.5mΩ ≥ 80 dB up to 1GHz ≥ 70 dB (3GHz), ≥ 58 dB (6GHz), ≥ 40 dB (10GHz) IEC 60512-2 test 3a IEC 60512-2 test 4a IEC 60512-2 test 2a IEC 60512-3 test 5a IEC 60512-2-6 MIL-spec tests EIA-364-21 EIA-364-20 EIA-364-06 EIA-364-83 EIA-364-66 EIA-364-66 Note: 6) After humidity test: 21 days at 95% RH according to IEC 60068-2. Insulation resistance measured between the contacts and contact/shell. Contact resistance 7) IEC 60512-2 test 2a 0.5 ≤ 8.7 0.7 0.9 1.3 ≤ 6.1 ≤ 4.8 ≤ 3.6 Value øA (mm) mΩ Notes: 7) after 5000 mating cycles and the salt spray test according to IEC 60512-6 test 11 f. Mechanical performance Characteristics Endurance Gunfire vibration Vibration-Sine 8) Vibration-Random Shock Acceleration Contact retention Torque Value IEC international 3000 cycles 25 to 2000 Hz, 3 axis (Apache helicopter) 30 g, 3 axis, 12 hr 50-2000 Hz, 37.8 g rms-3 axes; 4h amb 300 g - 3 msec 50 g acceleration > 22 N (ø 0.7mm), > 30N (ø 0.9 mm) See table below IEC 60512-5 test 9a IEC 60512-6-4 IEC 60512-6-3 MIL-spec tests EIA-364-09 MIL-STD-810F method 519.5 MIL-STD-202 method 204-G EIA-364-28 test cond. V letter I EIA-364-27 condition D MIL-STD-1344 - 2011-1, A IEC 60512-8 test 15a Note: 8) Amplitude: 30G. Frequency: 10 to 2000 Hz. Time per axis: 4 hours (X, Y, Z). No signal discontinuity above 1 µs. Series Coupling torque tightning (N.cm) Coupling torque untightning (N.cm) Series MM 0M 1M 2M 3M 8 4 10 20 34 4 5 11 14 29 TM 4M LM 5M Coupling torque tightning (N.cm) 26 26 48 9) 91 9) Coupling torque untightning (N.cm) 30 25 43 54 Note: 9) Higher contact density = larger torque force. 2 www.lemo.com M Series ® ® The M Series connector offers a new innovative design for avionics, aerospace, military, security, motorsport and heavy duty applications. Made of high-strength aluminium, this connector is one of the lightest and most compact of the LEMO product line. A one-grip ratchet screw system enables quick and secure coupling of the connectors. The arctic grip makes it easy to manipulate the connector while wearing gloves or when the connector is located in a difficult to access area. Features – Ratchet-coupling mechanism – Compact design for space savings – Oil and fuel resistant – 360° screening for full EMC shielding – Colour coding / keying – Scoop proof – Threaded for MIL-DTL-38999L backshell Metal housing models (page 5) FA FG – Quick mating: less than 3/4 turn to seat – Lightweight – High vibration and shock resistance – Sealed to IP68 when mated – Reverse sex configuration – Pin configuration from 2 to 114 contacts Straight plugs FM Free sockets Fixed sockets EG PB FA FG FM EG PM PB FA PV FG FM EC FW FX EC FW FX ED PE PF PH FW FX ED PE PF PH Straight plugs USB models (page 21) FG Fibre optic models (page 18) www.lemo.com PM PV PM PB Fixed sockets EG Fixed sockets Free sockets FM EG PM FG ED PH Straight plugs PH Watertight model (unmated) EG FM PV Fixed socket HE 3 ® ® Part Numbering System FM N . 1M . 305 . X L C FG N . 1M . 305 . X L C M Free socket PM N . 1M . 305 . X L M T Fixed socket HE N . 1M . 305 . X L Plug N P Variant: T = Mold stop P = Potted M = MIL-DTL-38999L shell thread Model: (page 5) Contact: (page 25) Alignment key: (page 21) Insulator: L = PEEK (multipole page 22) R = PEEK (mixed multipole p. 24) Series: (page 5) Housing: C = Chrome-plated brass X = Nickel-plated aluminium alloy 1) Insert configuration: (page 22) Part Number Example Straight plug: FMN.1M.305.XLC = straight plug with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. Straight plug: FGN.1M.305.XLCM = straight plug with key (N), arctic grip, 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts and with MIL-DTL-38999L thread for additional backshell (not supplied). Free socket: PMN.1M.305.XLMT = free socket with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contacts and mold stop. Fixed socket: HEN.1M.305.XLNP = fixed socket, nut fixing, with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female print contacts, watertight. Note: 1) anthracite colour. Part Section Showing Internal Components Fixed socket 1 2 3 4 5 6 4 outer shell o-ring hexagonal nut insulator female contact earthing crown 5 4 6 3 2 1 1 3 2 7 5 6 Straight plug 4 1 2 3 4 5 6 7 outer shell insulator male contact rear seal tightening screw ratchet mechanism spring www.lemo.com ® ® Metal housing models FM● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip Reference Ls/Lr øA øC P øD øB X Dimensions (mm) Model Series A B C D Ls Lr P X FM● FM● FM● FM● FM● FM● FM● FM● FM● MM 0M 1M 2M 3M TM 4M LM 5M 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 21.3 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 21.3 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: FMN.1M.305.XLC Note: Ls = standard gender, Lr = reverse gender FM● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and mold stop Reference Ls/Lr øC øD øF øB X øA P M Dimensions (mm) Model Series A B C D F Ls Lr M P X FM● FM● FM● FM● FM● FM● FM● FM● FM● MM 0M 1M 2M 3M TM 4M LM 5M 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 7.8 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 24.3 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 24.3 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 8.8 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 1.5 Part number example: FMN.1M.305.XLCT Note: Ls = standard gender, Lr = reverse gender FM● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr øA P øC e 9 Model Series A C e Ls Lr P Code1) FM● FM● FM● FM● FM● FM● FM● 1M 2M 3M TM 4M LM 5M 14.6 17.6 19.6 22.5 25.0 28.5 34.0 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 3.9 3.9 3.9 3.4 3.4 3.4 3.4 A B C C D E G Part number example: FMN.1M.305.XLCM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). www.lemo.com 5 ® ® FG● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip Reference Ls/Lr øA øC øD øB P Dimensions (mm) Model Series A B C D Ls Lr P X FG● FG● FG● FG● FG● FG● FG● FG● FG● MM 0M 1M 2M 3M TM 4M LM 5M 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 21.3 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 21.3 24.1 24.1 24.5 24.5 28.6 28.6 28.6 28.6 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 X Part number example: FGN.1M.305.XLC Note: Ls = standard gender, Lr = reverse gender FG● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and mold stop Reference Ls/Lr X øA øC P øD øF øB M Dimensions (mm) Model Series A B C D F Ls Lr M P X FG● FG● FG● FG● FG● FG● FG● FG● FG● MM 0M 1M 2M 3M TM 4M LM 5M 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 7.8 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 24.3 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 24.3 27.1 27.1 27.5 27.5 31.6 31.6 31.6 31.6 8.8 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 1.5 Part number example: FGN.1M.305.XLCT Note: Ls = standard gender, Lr = reverse gender FG● Straight plug, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr øA P øC e 9 Model Series A C e Ls Lr P Code1) FG● FG● FG● FG● FG● FG● FG● 1M 2M 3M TM 4M LM 5M 15.9 18.9 20.9 23.4 25.9 29.4 34.9 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 26.4 26.4 26.4 30.0 30.0 30.0 30.0 3.9 3.9 3.9 3.4 3.4 3.4 3.4 A B C C D E G Part number example: FGN.1M.305.XLCM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 6 www.lemo.com ® ® FX● Straight plug with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip Reference Ls/Lr X 1.5 øC øV H ø A1 P øD øE øB øA N Dimensions (mm) Model Series A A1 B FX● FX● FX● FX● FX● FX● FX● FX● FX● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 34.6 38.0 40.3 43.7 47.0 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 C D Ls/Lr X 1.5 ø A1 øC P øD øF øB øE 1.5 M øV K 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 Ls Lr N V 26.1 26.1 17.0 29.1 29.1 20.6 29.1 29.1 23.8 29.5 29.5 26.1 29.5 29.5 26.1 34.8 34.8 28.5 34.8 34.8 30.1 34.8 34.8 32.5 34.8 34.8 37.0 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Straight plug with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and mold stop Reference H H 12.0 15.1 18.3 20.6 20.6 23.0 24.6 27.0 29.4 Note: The dimensions «P» and «X» are the same as the FM● models. Ls = standard gender, Lr = reverse gender. FX● øA G 17.0 18.9 18.9 18.9 18.9 22.5 22.5 22.5 22.5 Part number example: FXN.1M.305.XLC G K N E 10.7 5.6 9.5 12.7 8.0 12.2 14.2 9.7 13.7 17.2 13.0 16.7 19.2 15.0 18.7 22.0 16.7 21.5 24.5 19.5 24.0 28.0 22.7 27.5 33.5 28.5 33.0 Dimensions (mm) Model Series A A1 B FX● FX● FX● FX● FX● FX● FX● FX● FX● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 34.6 38.0 40.3 43.7 47.0 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 C D E 10.7 5.6 9.5 12.7 8.0 12.2 14.2 9.7 13.7 17.2 13.0 16.7 19.2 15.0 18.7 22.0 16.7 21.5 24.5 19.5 24.0 28.0 22.7 27.5 33.5 28.5 33.0 G H K 17.0 18.9 18.9 18.9 18.9 22.5 22.5 22.5 22.5 12.0 15.1 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 Ls Lr N V 29.1 29.1 17.0 32.1 32.1 20.6 32.1 32.1 23.8 32.5 32.5 26.1 32.5 32.5 26.1 37.8 37.8 28.5 37.8 37.8 30.1 37.8 37.8 32.5 37.8 37.8 37.0 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: FXN.1M.305.XLCT G K Note: The dimensions «F», «M», «P» and «X» are the same as the FM● models. Ls = standard gender, Lr = reverse gender. FX● Straight plug with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and MIL-DTL-38999L shell thread Reference Ls/Lr H 1.5 e Model Series A A1 C e E G H K Ls FX● FX● FX● FX● FX● FX● FX● 1M 2M 3M TM 4M LM 5M 31.4 34.6 34.6 38.0 40.3 43.7 47.0 14.6 17.6 19.6 22.5 25.0 28.5 34.0 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 13.7 16.7 18.7 21.5 24.0 27.5 33.0 18.9 18.9 18.9 22.5 22.5 22.5 22.5 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 2.0 2.0 2.0 2.0 31.4 31.4 31.4 36.2 36.2 36.2 36.2 Lr Code1) 31.4 31.4 31.4 36.2 36.2 36.2 36.2 A B C C D E F Part number example: FXN.1M.305.XLCM øV G K www.lemo.com P øC 9 ø A1 øA øE N Dimensions (mm) Note: The dimensions «N» and «V» are the same as the FX● models and the dimension «P» is the same as the FM● models. Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 7 ® ® FW● Straight plug with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip Reference Ls/Lr X 1.5 øC øV H ø A1 P øD øE øB øA N Dimensions (mm) Model Series A A1 B FW● FW● FW● FW● FW● FW● FW● FW● FW● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 34.6 38.0 40.3 43.7 47.0 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 C D E 10.7 5.6 9.5 12.7 8.0 12.2 14.2 9.7 13.7 17.2 13.0 16.7 19.2 15.0 18.7 22.0 16.7 21.5 24.5 19.5 24.0 28.0 22.7 27.5 33.5 28.5 33.0 G H K 17.0 18.9 18.9 18.9 18.9 22.5 22.5 22.5 22.5 12.0 15.1 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 Ls Lr N V 26.1 26.1 17.0 29.1 29.1 20.6 29.1 29.1 23.8 29.5 29.5 26.1 29.5 29.5 26.1 34.8 34.8 28.5 34.8 34.8 30.1 34.8 34.8 32.5 34.8 34.8 37.0 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: FWN.1M.305.XLC G K Note: The dimensions «P» and «X» are the same as the FM● models. Ls = standard gender, Lr = reverse gender. FW● Straight plug with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and mold stop Reference Ls/Lr øC P øD øF øB øE X 1.5 øV H 1.5 M ø A1 øA N Dimensions (mm) Model Series A A1 B FW● FW● FW● FW● FW● FW● FW● FW● FW● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 34.6 38.0 40.3 43.7 47.0 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 C D E 10.7 5.6 9.5 12.7 8.0 12.2 14.2 9.7 13.7 17.2 13.0 16.7 19.2 15.0 18.7 22.0 16.7 21.5 24.5 19.5 24.0 28.0 22.7 27.5 33.5 28.5 33.0 G H K 17.0 18.9 18.9 18.9 18.9 22.5 22.5 22.5 22.5 12.0 15.1 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 Ls Lr N V 29.1 29.1 17.0 32.1 32.1 20.6 32.1 32.1 23.8 32.5 32.5 26.1 32.5 32.5 26.1 37.8 37.8 28.5 37.8 37.8 30.1 37.8 37.8 32.5 37.8 37.8 37.0 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: FWN.1M.305.XLCT G K Note: The dimensions «F», «M», «P» and «X» are the same as the FM● models. Ls = standard gender, Lr = reverse gender. FW● Straight plug with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and MIL-DTL-38999L shell thread Reference Ls/Lr H 1.5 e Model Series A A1 C e E G H K Ls FW● FW● FW● FW● FW● FW● FW● 1M 2M 3M TM 4M LM 5M 31.4 34.6 34.6 38.0 40.3 43.7 47.0 15.9 18.9 20.9 23.4 25.9 29.4 34.9 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 13.7 16.7 18.7 21.5 24.0 27.5 33.0 18.9 18.9 18.9 22.5 22.5 22.5 22.5 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 2.0 2.0 2.0 2.0 31.4 31.4 31.4 36.2 36.2 36.2 36.2 Lr Code1) 31.4 31.4 31.4 36.2 36.2 36.2 36.2 A B C C D E F Part number example: FWN.1M.305.XLCM øV G K 8 P øC 9 ø A1 øA øE N Dimensions (mm) Note: The dimensions «N» and «V» are the same as the FW● models and the dimension «P» is the same as the FM● models. Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). www.lemo.com ® ® FA● Straight plug with square flange, non-latching, key (N) or keys (P, R, S, T, U, V, W and X) Reference Ls/Lr øA P øC øD øB X øE N øV H Dimensions (mm) Model Series A B C FA● FA● FA● FA● FA● FA● FA● FA● FA● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 34.6 38.0 40.3 43.7 47.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 D E G 5.6 9.5 17.0 8.0 12.2 18.9 9.7 13.7 18.9 13.0 16.7 18.9 15.0 18.7 18.9 16.7 21.5 22.5 19.5 24.0 22.5 22.7 27.5 22.5 28.5 33.0 22.5 H K 12.0 15.1 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 Ls Lr N 26.1 26.1 17.0 29.1 29.1 20.6 29.1 29.1 23.8 29.5 29.5 26.1 29.5 29.5 26.1 34.8 34.8 28.5 34.8 34.8 30.1 34.8 34.8 32.5 34.8 34.8 37.0 P V 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: FAN.1M.305.XLC G K Note: The dimension «X» is the same as the FM● models. Ls = standard gender, Lr = reverse gender. FA● Straight plug with square flange, non-latching, key (N) or keys (P, R, S, T, U, V, W and X) with mold stop Reference Ls/Lr øA øC X 1.5 øV H P øD øF øB M øE N Dimensions (mm) Model Series A B C FA● FA● FA● FA● FA● FA● FA● FA● FA● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 34.6 38.0 40.3 43.7 47.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 D E G 5.6 9.5 17.0 8.0 12.2 18.9 9.7 13.7 18.9 13.0 16.7 18.9 15.0 18.7 18.9 16.7 21.5 22.5 19.5 24.0 22.5 22.7 27.5 22.5 28.5 33.0 22.5 H K 12.0 15.1 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 Ls Lr N 29.1 29.1 17.0 32.1 32.1 20.6 32.1 32.1 23.8 32.5 32.5 26.1 32.5 32.5 26.1 37.8 37.8 28.5 37.8 37.8 30.1 37.8 37.8 32.5 37.8 37.8 37.0 P V 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: FAN.1M.305.XLCT G K Note: The dimensions «F», «M» and «X» are the same as the FM● models. Ls = standard gender, Lr = reverse gender. FA● Straight plug with square flange, non-latching, key (N) or keys (P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr øA H P e øC 9 øE N Series A C e E G H K Ls Lr FA● FA● FA● FA● FA● FA● FA● 1M 2M 3M TM 4M LM 5M 31.4 34.6 34.6 38.0 40.3 43.7 47.0 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 13.7 16.7 18.7 21.5 24.0 27.5 33.0 18.9 18.9 18.9 22.5 22.5 22.5 22.5 18.3 20.6 20.6 23.0 24.6 27.0 29.4 1.5 1.5 1.5 2.0 2.0 2.0 2.0 31.4 31.4 31.4 36.2 36.2 36.2 36.2 31.4 31.4 31.4 36.2 36.2 36.2 36.2 N Code1) 23.8 26.1 26.1 28.5 30.1 32.5 37.0 A B C C D E F Part number example: FAN.1M.305.XLCM øV G K www.lemo.com Model Note: The dimensions «P» and «V» are the same as the FA● models. Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 9 ® ® EG● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) Dimensions (mm) Reference Ls/Lr S1 e øC P Model Series C D e E Ls Lr P S1 S2 EG● EG● EG● EG● EG● EG● EG● EG● EG● MM 0M 1M 2M 3M TM 4M LM 5M 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.2 6.8 6.8 6.8 6.8 9.4 9.4 9.4 9.4 M7x0.5 M9x0.6 M11x1.0 M14x1.0 M16x1.0 M18x1.0 M21x1.0 M24x1.0 M30x1.0 4.5 5.0 4.5 4.5 4.0 4.0 4.0 4.0 4.0 15.0 18.3 18.3 18.3 18.3 20.0 20.0 20.0 20.0 15.0 18.3 18.3 18.3 18.3 21.9 21.9 21.9 21.9 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 6.3 8.2 9.5 12.5 14.5 16.5 19.5 22.5 28.5 9.0 11.0 13.0 17.0 19.0 22.0 25.0 30.0 36.0 D S2 E maxi Part number example: EGN.1M.305.XLM Panel cut-out (page 31). Note: Ls = standard gender, Lr = reverse gender EG● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit Dimensions (mm) Reference Ls/Lr G S2 P e øC S1 4.5 D E maxi 5.4 Model Series C D e E G Ls Lr P S1 S2 EG● EG● EG● EG● EG● EG● EG● EG● EG● MM 0M 1M 2M 3M TM 4M LM 5M 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.2 6.8 6.8 6.8 6.8 9.4 9.4 9.4 9.4 M7x0.5 M9x0.6 M11x1.0 M14x1.0 M16x1.0 M18x1.0 M21x1.0 M24x1.0 M30x1.0 4.5 5.0 4.5 4.5 4.0 4.0 4.0 4.0 4.0 13.8 16.8 16.8 16.8 16.8 18.9 18.9 18.9 18.9 15.0 18.3 18.3 18.3 18.3 20.0 20.0 20.0 20.0 15.0 18.3 18.3 18.3 18.3 21.9 21.9 21.9 21.9 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 6.3 8.2 9.5 12.5 14.5 16.5 19.5 22.5 28.5 9.0 11.0 13.0 17.0 19.0 22.0 25.0 30.0 36.0 Part number example: EGN.1M.305.XLN Panel cut-out (page 31). PCB drilling pattern (page 32). Note: Ls = standard gender, Lr = reverse gender EC● Fixed socket with two nuts, key (N) or keys (P, R, S, T, U, V, W and X) Dimensions (mm) Reference Ls/Lr S1 e E maxi G S2 øA P øB øC S3 Model Series A EC● EC● EC● EC● EC● EC● EC● EC● EC● MM 0M 1M 2M 3M TM 4M LM 5M 14 17 18 21 23 27 29 33 38 B C 2.85 13.5 4.72 18.2 5.95 19.2 8.95 21.5 10.95 25.0 12.30 28.0 13.95 34.0 17.95 36.0 22.90 41.0 E e G Ls Lr P S1 S2 S3 5.0 5.0 5.0 4.0 4.0 2.5 2.5 2.5 2.5 M10x0.50 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 13.8 16.8 16.8 16.8 16.8 18.9 18.9 18.9 18.9 15.0 18.3 18.3 18.3 18.3 20.0 20.0 20.0 20.0 15.0 18.3 18.3 18.3 18.3 21.9 21.9 21.9 21.9 3.7 9.0 11.0 12.0 5.3 11.5 14.0 16.0 5.3 12.5 16.0 17.0 5.3 15.5 18.0 19.0 5.3 17.5 20.0 22.0 7.9 20.5 23.0 25.0 7.9 22.5 25.0 30.0 7.9 26.5 29.0 32.0 7.9 31.5 34.0 37.0 Part number example: ECN.1M.305.XLM Panel cut-out (page 31). Note: Ls = standard gender, Lr = reverse gender. This model is not IP68 (no panel sealing). 10 www.lemo.com ® ® EC● Fixed socket with two nuts, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit Reference S3 Ls/Lr S1 e øA P øB øC 5.4 E maxi 4.5 S2 Dimensions (mm) Model Series A EC● EC● EC● EC● EC● EC● EC● EC● EC● MM 0M 1M 2M 3M TM 4M LM 5M 14 17 18 21 23 27 29 33 38 B C 2.85 13.5 4.72 18.2 5.95 19.2 8.95 21.5 10.95 25.0 12.30 28.0 13.95 34.0 17.95 36.0 22.90 41.0 E e G Ls Lr P S1 S2 S3 5.0 5.0 5.0 4.0 4.0 2.5 2.5 2.5 2.5 M10x0.50 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 13.8 16.8 16.8 16.8 16.8 18.9 18.9 18.9 18.9 15.0 18.3 18.3 18.3 18.3 20.0 20.0 20.0 20.0 15.0 18.3 18.3 18.3 18.3 21.9 21.9 21.9 21.9 3.7 9.0 11.0 12.0 5.3 11.5 14.0 16.0 5.3 12.5 16.0 17.0 5.3 15.5 18.0 19.0 5.3 17.5 20.0 22.0 7.9 20.5 23.0 25.0 7.9 22.5 25.0 30.0 7.9 26.5 29.0 32.0 7.9 31.5 34.0 37.0 Part number example: ECN.1M.305.XLN G Panel cut-out (page 31). PCB drilling pattern (page 32). Note: Ls = standard gender, Lr = reverse gender ED● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) Reference Ls/Lr K P øB øC øA N H øV Dimensions (mm) Model Series A B C G H K Ls Lr N P V ED● ED● ED● ED● ED● ED● ED● ED● ED● MM 0M 1M 2M 3M TM 4M LM 5M 18.6 20.6 23.8 26.9 29.0 31.4 34.6 38.0 43.7 4.70 4.72 5.95 8.95 10.95 12.30 13.95 17.95 22.90 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 12.3 12.8 12.8 12.8 12.8 14.5 14.5 14.5 14.5 9.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 27.0 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 17.0 18.3 18.3 18.3 18.3 20.0 20.0 20.0 20.0 17.0 18.3 18.3 18.3 18.3 21.9 21.9 21.9 21.9 14.5 16.0 18.4 20.6 22.1 23.8 26.1 28.5 32.5 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: EDN.1M.305.XLM G Panel cut-out (page 31). Note: Ls = standard gender, Lr = reverse gender ED● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit Reference Ls/Lr N K øA P øB øC 5.4 Dimensions (mm) Model Series A B C G H K Ls Lr N P V ED● ED● ED● ED● ED● ED● ED● ED● ED● MM 0M 1M 2M 3M TM 4M LM 5M 18.6 20.6 23.8 26.9 29.0 31.4 34.6 38.0 43.7 4.70 4.72 5.95 8.95 10.95 12.30 13.95 17.95 22.90 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 12.3 12.8 12.8 12.8 12.8 14.5 14.5 14.5 14.5 9.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 27.0 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 17.0 18.3 18.3 18.3 18.3 20.0 20.0 20.0 20.0 17.0 18.3 18.3 18.3 18.3 21.9 21.9 21.9 21.9 14.5 16.0 18.4 20.6 22.1 23.8 26.1 28.5 32.5 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 4.5 H øV G Part number example: EDN.1M.305.XLN Panel cut-out (page 31). PCB drilling pattern (page 32). Note: Ls = standard gender, Lr = reverse gender www.lemo.com 11 ® ® PE● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) with mold stop (back panel mounting) Reference Ls/Lr e S2 E maxi X øA øD øF øB øC P S1 M Dimensions (mm) Model Series A PE● PE● PE● PE● PE● PE● PE● PE● PE● MM 0M 1M 2M 3M TM 4M LM 5M 14 17 18 21 23 27 29 33 38 B C D E 6.4 13.8 5.6 8.8 16.8 8.0 10.5 17.8 9.7 14.0 20.8 13.0 16.0 22.8 15.0 17.9 25.8 16.7 20.7 27.8 19.5 23.9 31.8 22.7 29.7 36.8 28.5 e Ls 4.0 M10x0.50 5.0 M13x0.75 5.0 M14x1.00 5.0 M17x1.00 5.0 M19x1.00 4.0 M22x1.00 4.0 M24x1.00 4.0 M28x1.00 4.0 M33x1.00 Lr M P R 21.4 21.4 8.8 3.7 10.5 25.6 25.6 9.7 5.3 13.8 25.6 25.6 9.7 5.3 13.8 26.0 26.0 10.1 5.3 13.8 26.0 26.0 10.1 5.3 13.8 29.5 30.1 10.6 7.9 16.9 29.5 30.1 10.6 7.9 16.9 29.5 30.1 10.6 7.9 16.9 29.5 30.1 10.6 7.9 16.9 S1 S2 9.0 11.5 12.5 15.5 17.5 20.5 22.5 26.5 31.5 11 14 16 18 20 23 25 29 34 Part number example: PEN.1M.305.XLMT R Panel cut-out (page 31). 1.5 Note: this model is only available with mold stop. The dimensions «F» and «X» are the same as the PB● models. Ls = standard gender, Lr = reverse gender. PE● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr e E maxi øA P S1 e1 øC 9 Model Series A C E e e1 Ls PE● PE● PE● PE● PE● PE● PE● 1M 2M 3M TM 4M LM 5M 18 21 23 27 29 33 38 17.8 20.8 22.8 25.8 27.8 31.8 36.8 5.0 5.0 5.0 4.0 4.0 4.0 4.0 M14x1.0 M17x1.0 M19x1.0 M22x1.0 M24x1.0 M28x1.0 M33x1.0 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 Lr R S1 S2 Code1) 26.4 26.4 13.8 12.5 26.4 26.4 13.8 15.5 26.4 26.4 13.8 17.5 28.2 30.1 16.9 20.5 28.2 30.1 16.9 22.5 28.2 30.1 16.9 26.5 28.2 30.1 16.9 31.5 16 18 20 23 25 29 34 A B C C D E G Part number example: PEN.1M.305.XLMM S2 Panel cut-out (page 31). R Note: Ls = standard gender, Lr = reverse gender. The dimension «P» is the same as the PB● models. 1) MIL-DTL-38999L shell size code (backshell not supplied). PF● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with mold stop Reference N Ss/Sr K øA G P H øV øC øD øF øB øE M X Dimensions (mm) Model Series A B C D PF● PF● PF● PF● PF● PF● PF● PF● PF● MM 0M 1M 2M 3M TM 4M LM 5M 18.6 20.6 23.8 26.9 29.0 31.4 34.6 38.0 47.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 E F 7.8 7.8 10.7 10.7 12.4 12.4 15.5 15.5 17.5 17.5 19.8 19.8 22.6 22.6 25.8 25.8 33.0 31.4 G H K 12.3 12.8 12.8 12.8 12.8 14.5 14.5 14.5 14.5 9.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 29.4 1.5 1.5 1.5 1.5 1.5 2.0 2.0 2.0 2.0 N Ss Sr 14.5 10.6 10.6 16.0 11.3 11.3 18.4 11.3 11.3 20.6 11.7 11.7 22.1 11.7 11.7 23.8 13.0 13.6 26.1 13.0 13.6 28.5 13.0 13.6 37.0 13.0 13.6 V 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 Part number example: PFN.1M.305.XLMT 1.5 Panel cut-out (page 31). Note: this model is only available with mold stop. The dimensions «M», «P» and «X» are the same as the PB● models. Ss = standard gender, Sr = reverse gender. 12 www.lemo.com ® ® PF● Fixed socket with square flange, key (N) or keys (P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Ss/Sr N G K øA P øC e øE 9 Model Series A C e E G H K N Ss PF● PF● PF● PF● PF● PF● PF● 1M 2M 3M TM 4M LM 5M 23.8 26.9 29.0 31.4 34.6 38.0 47.0 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 12.4 15.5 17.5 19.8 22.6 25.8 33.0 12.8 12.8 12.8 14.5 14.5 14.5 14.5 12.9 15.1 16.6 18.3 20.6 23.0 29.4 1.5 1.5 1.5 2.0 2.0 2.0 2.0 18.4 20.6 22.1 23.8 26.1 28.5 37.0 12.2 12.2 12.2 11.7 11.7 11.7 11.7 Sr Code1) 12.2 12.2 12.2 13.6 13.6 13.6 13.6 A B C C D E G Part number example: PFN.1M.305.XLMM ø 3.3 H Panel cut-out (page 31). Note: The dimension «P» is the same as the PB● models. Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). PB● Fixed socket with antivibration flange, key (N) or keys (P, R, S, T, U, V, W and X), 2 holes fixing Reference P Ss/Sr N 1.5 (MM) 2.0 (0M-5M) A øD øB H øC X Dimensions (mm) Model Series A B C PB● PB● PB● PB● PB● PB● PB● PB● PB● MM 0M 1M 2M 3M TM 4M LM 5M 21.0 27.0 29.0 32.0 35.0 38.5 41.0 44.0 51.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 11.3 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 D G 5.6 6.7 8.0 8.3 9.7 8.3 13.0 8.3 15.0 8.3 16.7 11.0 19.5 11.0 22.7 11.0 28.5 11.0 H N P Ss Sr X 16.2 21.4 23.4 26.4 29.0 32.5 35.0 38.0 45.0 12.5 16.0 18.0 21.0 23.0 26.0 29.0 32.0 39.0 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 13.2 15.3 15.3 15.7 15.7 15.2 15.2 15.2 15.2 13.2 15.3 15.3 15.7 15.7 17.1 17.1 17.1 17.1 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PBN.1M.305.XLM 2.7 (MM) 3.3 (0M-5M) G Panel cut-out (page 31). Note: Ss = standard gender, Sr = reverse gender PB● Fixed socket with antivibration flange, key (N) or keys (P, R, S, T, U, V, W and X), 2 holes fixing with mold stop Reference P Ss/Sr 1.5 (MM) 2.0 (0M-5M) N A øC øD øB H øF M X 2.7 (MM) 3.3 (0M-5M) Dimensions (mm) Model Series A B C PB● PB● PB● PB● PB● PB● PB● PB● PB● MM 0M 1M 2M 3M TM 4M LM 5M 21.0 27.0 29.0 32.0 35.0 38.5 41.0 44.0 51.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 11.3 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 D F G 5.6 7.8 6.7 8.0 10.7 8.3 9.7 12.4 8.3 13.0 15.5 8.3 15.0 17.5 8.3 16.7 19.8 11.0 19.5 22.6 11.0 22.7 25.8 11.0 28.5 31.4 11.0 H M N 16.2 21.4 23.4 26.4 29.0 32.5 35.0 38.0 45.0 8.8 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 12.5 16.0 18.0 21.0 23.0 26.0 29.0 32.0 39.0 P Ss Sr 3.7 16.2 16.2 5.3 18.3 18.3 5.3 18.3 18.3 5.3 18.7 18.7 5.3 18.7 18.7 7.9 18.2 18.2 7.9 18.2 18.2 7.9 18.2 18.2 7.9 18.2 18.2 X 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PBN.1M.305.XLMT 1.5 G Panel cut-out (page 31). Note: Ss = standard gender, Sr = reverse gender www.lemo.com 13 ® ® PB● Fixed socket with antivibration flange, key (N) or keys (P, R, S, T, U, V, W and X), 2 holes fixing with MIL-DTL-38999L shell thread Reference P Ss/Sr N 2 A e H øC 9 Dimensions (mm) Model Series A C e G H N P Ss PB● PB● PB● PB● PB● PB● PB● 1M 2M 3M TM 4M LM 5M 29.0 32.0 35.0 38.5 41.0 44.0 51.0 16.5 19.5 21.5 24.5 27.5 30.5 37.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 8.3 8.3 8.3 11.0 11.0 11.0 11.0 23.4 26.4 29.0 32.5 35.0 38.0 45.0 18.0 21.0 23.0 26.0 29.0 32.0 39.0 5.3 5.3 5.3 7.9 7.9 7.9 7.9 17.2 17.2 17.2 16.2 16.2 16.2 16.2 Sr Code1) 17.2 17.2 17.2 17.1 17.1 17.1 17.1 A B C C D E G Part number example: PBN.1M.305.XLMM Panel cut-out (page 31). 3.3 G Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). PV● Fixed socket with antivibration square flange, key (N) or keys (P, R, S, T, U, V, W and X) Reference P Ss/Sr øA øC øB 1.5 (MM) 2.0 (0M-5M) øD øC N X H øV Dimensions (mm) Model Series A B C PV● PV● PV● PV● PV● PV● PV● PV● PV● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 38.0 40.3 43.7 47.1 54.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 11.3 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 D G H 5.6 6.7 12.0 8.0 8.3 15.1 9.7 8.3 18.3 13.0 8.3 20.6 15.0 8.3 23.0 16.7 11.0 24.6 19.5 11.0 27.0 22.7 11.0 29.4 28.5 11.0 34.9 N P Ss Sr V X 17.0 20.6 23.8 26.1 28.5 30.1 32.5 34.9 40.4 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 13.2 15.3 15.3 15.7 15.7 15.2 15.2 15.2 15.2 13.2 15.3 15.3 15.7 15.7 17.1 17.1 17.1 17.1 2.7 2.7 3.3 3.3 3.3 3.3 3.3 3.3 3.3 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PVN.1M.305.XLM G Panel cut-out (page 31). Note: Ss = standard gender, Sr = reverse gender PV● Fixed socket with antivibration square flange, key (N) or keys (P, R, S, T, U, V, W and X) with mold stop Reference N P Ss/Sr øA 1.5 (MM) 2.0 (0M-5M) øC øB øD øF øC M H Model Series A B C PV● PV● PV● PV● PV● PV● PV● PV● PV● MM 0M 1M 2M 3M TM 4M LM 5M 21.5 26.9 31.4 34.6 38.0 40.3 43.7 47.1 54.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 11.3 14.5 16.5 19.5 21.5 24.5 27.5 30.5 37.5 D F G 5.6 7.8 6.7 8.0 10.7 8.3 9.7 12.4 8.3 13.0 15.5 8.3 15.0 17.5 8.3 16.7 19.8 11.0 19.5 22.6 11.0 22.7 25.8 11.0 28.5 31.4 11.0 H M N P Ss Sr X 12.0 15.1 18.3 20.6 23.0 24.6 27.0 29.4 34.9 8.8 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 17.0 20.6 23.8 26.1 28.5 30.1 32.5 34.9 40.4 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 16.2 16.2 18.3 18.3 18.3 18.3 18.7 18.7 18.7 18.7 18.2 18.2 18.2 18.2 18.2 18.2 18.2 18.2 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PVN.1M.305.XLMT X øV Dimensions (mm) 1.5 G Panel cut-out (page 31). Note: Ss = standard gender, Sr = reverse gender. The dimension «V» is the same as the PV● models without mold stop. 14 www.lemo.com ® ® PV● Fixed socket with antivibration square flange, key (N) or keys (P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Reference øA N P Ss/Sr 2 øC e øC 9 Dimensions (mm) Model Series A C e G PV● PV● PV● PV● PV● PV● PV● 1M 2M 3M TM 4M LM 5M 31.4 34.6 38.0 40.3 43.7 47.1 54.9 16.5 19.5 21.5 24.5 27.5 30.5 37.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 H 8.3 18.3 8.3 20.6 8.3 23.0 11.0 24.6 11.0 27.0 11.0 29.4 11.0 34.9 N P Ss Sr 23.8 26.1 28.5 30.1 32.5 34.9 40.4 5.3 5.3 5.3 7.9 7.9 7.9 7.9 17.2 17.2 17.2 16.2 16.2 16.2 16.2 17.2 17.2 17.2 17.1 17.1 17.1 17.1 V Code1) 3.3 3.3 3.3 3.3 3.3 3.3 3.3 A B C C D E G Part number example: PVN.1M.305.XLMM øV H G Panel cut-out (page 31). Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). PM● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip Reference Ls/Lr øA øC P øD øB X Dimensions (mm) Model Series A B C D Ls Lr P X PM● PM● PM● PM● PM● PM● PM● PM● PM● MM 0M 1M 2M 3M TM 4M LM 5M 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 21.4 25.6 25.6 26.0 26.0 28.2 28.2 28.2 28.2 21.4 25.6 25.6 26.0 26.0 30.1 30.1 30.1 30.1 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PMN.1M.305.XLM Note: Ls = standard gender, Lr = reverse gender PM● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and mold stop Reference Ls/Lr X 1.5 øA øC P øD øF øB M Dimensions (mm) Model Series A B C D F Ls Lr M P X PM● PM● PM● PM● PM● PM● PM● PM● PM● MM 0M 1M 2M 3M TM 4M LM 5M 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 7.8 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 24.4 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 24.4 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 8.8 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PMN.1M.305.XLMT Note: Ls = standard gender, Lr = reverse gender www.lemo.com 15 ® ® PM● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with knurled grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr 9 øA e øC P Model Series A C e Ls Lr P Code1) PM● PM● PM● PM● PM● PM● PM● 1M 2M 3M TM 4M LM 5M 14.6 17.6 19.6 22.5 25.0 28.5 34.0 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 27.9 27.9 27.9 29.6 29.6 29.6 29.6 27.9 27.9 27.9 30.1 30.1 30.1 30.1 5.3 5.3 5.3 7.9 7.9 7.9 7.9 A B C C D E G Part number example: PMN.1M.305.XLMM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). PH● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip Reference Ls/Lr øC øB øD øA P X Dimensions (mm) Model Series A B C D Ls Lr P X PH● PH● PH● PH● PH● PH● PH● PH● PH● MM 0M 1M 2M 3M TM 4M LM 5M 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 21.4 25.6 25.6 26.0 26.0 28.2 28.2 28.2 28.2 21.4 25.6 25.6 26.0 26.0 30.1 30.1 30.1 30.1 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PHN.1M.305.XLM Note: Ls = standard gender, Lr = reverse gender PH● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and mold stop Reference Ls/Lr X 1.5 øA øC P øD øF øB M Dimensions (mm) Model Series A B C D F Ls Lr M P X PH● PH● PH● PH● PH● PH● PH● PH● PH● MM 0M 1M 2M 3M TM 4M LM 5M 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 6.4 8.8 10.5 14.0 16.0 17.9 20.7 23.9 29.7 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 5.6 8.0 9.7 13.0 15.0 16.7 19.5 22.7 28.5 7.8 10.7 12.4 15.5 17.5 19.8 22.6 25.8 31.4 24.4 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 24.4 28.6 28.6 29.0 29.0 31.2 31.2 31.2 31.2 8.8 9.7 9.7 10.1 10.1 10.6 10.6 10.6 10.6 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 5.8 6.7 6.7 7.1 7.1 7.6 7.6 7.6 7.6 Part number example: PHN.1M.305.XLMT Note: Ls = standard gender, Lr = reverse gender 16 www.lemo.com ® ® PH● Free socket, key (N) or keys (P, R, S, T, U, V, W and X) with arctic grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Ls/Lr øC e øA P 9 Model Series A C e Ls Lr P Code1) PH● PH● PH● PH● PH● PH● PH● 1M 2M 3M TM 4M LM 5M 15.9 18.9 20.9 23.4 25.9 29.4 34.9 14.2 17.2 19.2 22.0 24.5 28.0 33.5 M12x1.0 M15x1.0 M18x1.0 M18x1.0 M22x1.0 M25x1.0 M31x1.0 27.9 27.9 27.9 29.6 29.6 29.6 29.6 27.9 27.9 27.9 30.1 30.1 30.1 30.1 5.3 5.3 5.3 7.9 7.9 7.9 7.9 A B C C D E G Part number example: PHN.1M.305.XLMM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). Watertight model (unmated) HE● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) for printed circuit, watertight (back panel mounting) Reference Ls/Lr 3 e H E maxi S2 øA P øC S1 Dimensions (mm) Model Series A C e HE● HE● HE● HE● HE● HE● HE● HE● HE● MM 0M 1M 2M 3M TM 4M LM 5M 14 17 18 21 23 27 29 33 38 13.8 16.8 17.8 20.8 22.8 25.8 27.8 31.8 36.8 M10x0.50 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 E H 4.0 5.08 5.0 5.08 5.0 7.62 5.0 8.89 5.0 10.16 4.0 12.70 4.0 13.97 4.0 16.51 4.0 20.32 Ls Lr N P R 20.4 20.8 20.8 20.8 20.8 24.6 24.6 24.6 24.6 20.4 21.0 21.0 21.0 21.0 24.6 24.6 24.6 24.6 15.3 16.8 16.8 16.8 16.8 19.9 19.9 19.9 19.9 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 10.5 13.8 13.8 13.8 13.8 16.9 16.9 16.9 16.9 S1 S2 9.0 11.5 12.5 15.5 17.5 20.5 22.5 26.5 31.5 11 14 16 18 20 23 25 29 34 Part number example: HEN.1M.305.XLNP R N Panel cut-out (page 31). PCB drilling pattern (page 32). Note: Ls = standard gender, Lr = reverse gender. Operating temperature: -20°C to +80°C. www.lemo.com 17 ® ® Fibre optic models FM● Straight plug, keys (S or W) with knurled grip Dimensions (mm) Part number A C L P S1 S2 14 29 14 29 L FM•.2M.03A.XLZT••Z FM•.5M.03W.XLZT••Z S2 Contact part number (to be ordered separately): PSS.F7.12•.LCE23 (2M series). FFS.F7.12•.LCE23 (5M series). øA øC P 17.6 17.2 100.6 3.9 34.0 33.5 148.4 3.4 S1 Note: •• Cable adaptor defined upon request. The bend relief must be ordered separately (see page 29). FG● Straight plug, keys (S or W) with arctic grip Dimensions (mm) Part number A C L P S1 S2 14 29 14 29 L FG•.2M.03A.XLZT••Z FG•.5M.03W.XLZT••Z S2 Contact part number (to be ordered separately): PSS.F7.12•.LCE23 (2M series). FFS.F7.12•.LCE23 (5M series). øA øC P 18.9 17.2 100.6 3.9 34.9 33.5 148.4 3.4 S1 Note: •• Cable adaptor defined upon request. The bend relief must be ordered separately (see page 29). PM● Free socket, keys (S or W) with knurled grip Dimensions (mm) Part number A C L P S1 S2 16 32 14 29 L PM•.2M.03A.XLZT••Z PM•.5M.03W.XLZT••Z S2 18 S1 øA øC P 17.6 17.2 105.8 5.3 34.0 33.5 155.2 7.9 Contact part number (to be ordered separately): FFS.F7.12•.LCL23 (2M series). PSS.F7.12•.LCL23 (5M series). Note: •• Cable adaptor defined upon request. The bend relief must be ordered separately (see page 29). www.lemo.com ® ® PH● Free socket, keys (S or W) with arctic grip Dimensions (mm) Part number A C L P S1 S2 16 32 14 29 L øA øC S1 S2 18.9 17.2 105.8 5.3 34.9 33.5 155.2 7.9 PM•.2M.03A.XLZT••Z PM•.5M.03W.XLZT••Z P Contact part number (to be ordered separately): FFS.F7.12•.LCL23 (2M series). PSS.F7.12•.LCL23 (5M series). Note: •• Cable adaptor defined upon request. The bend relief must be ordered separately (see page 29). EG● Fixed socket, nut fixing, key (N) or keys (P, R, S, T, U, V, W and X) Dimensions (mm) Part number L S1 C P e øC EG•.2M.03A.XLZ EG•.5M.03W.XLZ D 17.2 6.8 33.5 9.4 e E L P S1 S2 M14x1.0 4.5 28.9 5.3 12.5 17.0 M30x1.0 4.0 30.8 7.9 28.5 36.0 Panel cut-out (page 31). D S2 Contact part number (to be ordered separately): FFS.F7.12•.LCE23 (2M series). PSS.F7.12•.LCE23 (5M series). E maxi ED● Fixed socket with square flange, keys (S or W) Dimensions (mm) Part number L A øC P øB N K øA ED•.2M.03A.XLZT ED•.5M.03W.XLZT B C G H K L N P 26.9 8.95 17.2 12.8 15.1 1.5 28.9 20.6 5.3 43.7 22.90 33.5 14.5 27.0 2.0 30.8 32.5 7.9 Panel cut-out (page 31). H ø 3.3 G Contact part number (to be ordered separately): FFS.F7.12•.LCE23 (2M series). PSS.F7.12•.LCE23 (5M series). More information on F7 fibre optic contact in LEMO F7 catalog. www.lemo.com 19 ® ® Fibre Type The choice of the ferrule hole diameter is dependent upon the fibre cladding size. LEMO offers a range of ferrule hole diameters to suit the users’ specific requirements. ● First choice alternative ● Special order alternative Reference ø Core/Cladding (µm) Ferrule hole diameter (µm) Note 125 126 128 9/125 50/125 62.5/125 125 126 128 ● ● ● Accessories PSS Alignment device for F7 fibre optic contact ø 3.2 8.2 Part number PSS.F7.290.NZZ Note: Alignment device should be ordered as replacement item. Tooling DCP Set of flat spanners for collet nuts Part number DCP.2M.110.TN DCP.5M.110.TN DCS F7 contact alignment device tool Simple tool with two threaded end for installation/extraction of the F7 contact alignment device. Part number DCS.F7.035.PN WST Cleaning kit Fibre optic cleaning kit of 2 cotton buds, 1 dry and 1 being soaked in Isopropyl Alcohol used for cleaning the fibre optic contacts. Part number See also F7 tooling in the F7 fibre optic catalog. 20 WST.KI.125.34 www.lemo.com USB models FG●.LM.U2A.XPAT Straight plug, key (W) or key (R) with arctic grip and mold stop FM●.LM.U2A.XPAT Straight plug, key (W) or key (R) with knurled grip and mold stop 31.6 31.6 3.4 ø 28 ø 22.7 ø 23.9 ø 25.8 ø 28 ø 28.5 10.6 1.5 ø 29.4 3.4 ø 22.7 ø 25.8 ø 23.9 10.6 1.5 7.6 7.6 EG●.LM.U2A.XPP ® ® EG●.LM.U2A.XPL Fixed socket, female to female, nut fixing, key (W) or key (R) Fixed socket, nut fixing, key (W) or key (R) 40.5 18.9 S 22.5 S 30 7.9 M 24 x 1 ø 28 M 24 x 1 7.9 4 maxi S 30 ø 28 S 22.5 4 maxi 9.4 9.4 31 Alignment Key Alignment Key and Polarized Keying System M series connector model part numbers are composed of three letters. The LAST LETTER indicates the keys corresponding to a particular contact type. For example, straight plugs with N, P, R, U or W keys, are fitted with male contacts; whereas with S, T, V or X keys, plugs are fitted with female contacts. Sockets with N, P, R, U or W keys, are fitted with female contacts; whereas with S, T, V or X keys, sockets are fitted with male contacts. N P ●●U blue yellow green male female 3 165° 150° 130° 30° 60° 100° S T red orange female male 3 155° 135° 50° 90° ●● γ ●● ●● Model Front view of a socket Colour code Plug Socket Contact type Plug Socket Nb of keys β γ Angles α β γ δ β W R blue yellow male female 5 95° 105° 115° 115° 35° 30° 25° 20° X V red orange female male 5 100° 110° 125° 120° 40° 35° 20° 25° ●● ●● δ γ TM to 5M Angles Nb of keys Colour code ●● α Contact type Model β MM to 3M Front view of a socket ●● ●● www.lemo.com 21 ® Insert configuration Test voltage (kV rms)1) Contact-shell Rated current (A)1) Contact type Test voltage (kV rms)1) Contact-contact 2 AWG 3 Print (straight)2) 1 Crimp 4 3 ø A (mm) 4 2 303 3 0.5 ● ● 28-30-32 1.15 0.95 3.0 304 4 0.5 ● ● 28-30-32 0.95 0.90 2.0 302 2 0.9 ● ● 20-22-24 1.45 1.00 10.0 303 3 0.9 ● ● 20-22-24 1.70 1.40 8.0 304 4 0.7 ● ● 22-24-26 1.35 0.90 7.0 305 5 0.7 ● ● 22-24-26 1.25 1.00 6.5 302 2 1.3 ● ● 16-18-20 1.55 1.10 19.0 303 3 1.3 ● ● 16-18-20 1.05 0.95 15.5 305 5 0.9 ● ● 20-22-24 1.30 1.30 9.0 307 7 0.7 ● ● 22-24-26 1.45 1.20 7.0 308 8 0.7 ● ● 22-24-26 1.30 1.10 5.0 304 4 1.3 ● ● 16-18-20 1.55 1.35 15.5 308 8 0.9 ● ● 20-22-24 1.95 1.10 10.0 310 10 0.9 ● ● 20-22-24 1.80 1.20 8.0 312 12 0.7 ● ● 22-24-26 1.65 1.15 7.0 319 19 0.7 ● ● 22-24-26 1.20 1.00 4.0 322 22 0.7 ● ● 22-24-26 1.25 1.15 4.0 330 30 0.7 ● ● 22-24-26 1.10 1.00 3.5 øA 1 Number of contacts Multipole Reference ® MM 0M 1M 2M 3M Male crimp contacts for plug Female crimp contacts for sockets Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. 22 www.lemo.com Multipole Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Contact type AWG 2 Print (straight)2) 3 Crimp 1 3 ø A (mm) 4 2 Number of contacts 4 Reference 1 325 25 0.9 ● ● 20-22-24 1.10 1.25 5.0 340 40 0.7 ● ● 22-24-26 1.05 1.20 3.0 340 40 0.7 ● ● 22-24-26 1.20 1.35 3.5 348 48 0.7 ● ● 22-24-26 1.10 1.35 3.0 355 55 0.9 ● ● 20-22-24 1.65 1.95 3.5 368 68 0.7 ● ● 22-24-26 1.40 1.65 2.5 366 66 0.9 ● ● 20-22-24 1.60 1.70 3.0 114 114 0.7 ● ● 22-24-26 1.37 1.34 2.0 øA TM 4M LM 5M ® ® Male crimp contacts for plug Female crimp contacts for sockets Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. www.lemo.com 23 ® ® Mixed multipole AWG Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Contact type Print (straight)2) 2 Crimp 1 3 ø A (mm) 4 3 Number of contacts 4 2 304 2 2 0.7 1.3 ● ● 22-24-26 16-18-20 1.20 1.45 1.30 2.00 11.0 18.5 306 3 3 0.7 1.3 ● ● 22-24-26 16-18-20 1.55 2.05 1.40 1.35 10.5 18.0 308 6 2 0.7 1.3 ● ● 22-24-26 16-18-20 1.95 1.75 1.40 1.60 7.0 23.0 310 8 2 0.7 1.3 ● ● 22-24-26 16-18-20 1.35 1.90 1.35 1.15 6.0 23.0 1M Male crimp contacts for plug Female crimp contacts for sockets 2M Reference øA 1 FGN.1M.304.XRCT2: straight plug with key (N), 1M series, multipole type with 4 mixed contacts (2 x ø 0.7 mm and 2 x ø 1.3 mm), outer shell with mold stop in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. FGN.2M.308.XRC6: straight plug with key (N), 2M series, multipole type with 8 mixed contacts (6 x ø 0.7 mm and 2 x ø 1.3 mm), outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. Solder contact Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Female front view Number of contacts LM Male front view Reference USB U2A 4 ● 1.20 0.95 n.a. 5M 24 Female contacts for sockets Number of contacts 2M Male contacts for plug Reference Fibre optique 03A 2 03W 21 Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. www.lemo.com ® ® Contacts Contact type Reference C B D Contact type Reference Male crimp with standard crimp barrel (fig. 1) Male crimp with reduced crimp barrel (fig. 2) Male straight print M P N Female crimp with standard crimp barrel (fig. 1) Female crimp with reduced crimp barrel (fig. 2) Female straight print Crimp contacts for plugs, free or fixed sockets Fig. 1 øA øC øA øC Fig. 2 øA øC øA øC Dimension of crimp barrels øA (mm) øC (mm) Form per fig. Male Female MM Conductor AWG Section (mm2) min. max. min. max. 0.5 0.42 1 C M 32 28 0.035 0M to 3M Ref. contact type 1.3 0.9 0.9 0.7 0.7 1.60 1.10 0.87 0.87 0.44 1 1 2 1 2 C C B C B M M P M P 20 24 26 26 32 16 20 22 22 28 TM to 5M Contact 1.3 0.9 0.9 0.7 0.7 1.60 1.10 0.87 0.87 0.44 1 1 2 1 2 C C B C B M M P M P 20 24 26 26 32 16 20 22 22 28 Part number For male contacts For female contacts 0.090 FGG.00.554.ZZC EGG.00.654.ZZM 0.616 0.204 0.128 0.128 0.032 2.000 0.616 0.382 0.382 0.092 FGN.0M.565.ZZC FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGN.0M.665.ZZM EGN.0M.660.ZZM EGN.0M.661.ZZM EGN.0M.655.ZZM EGN.0M.656.ZZM 0.616 0.204 0.128 0.128 0.032 2.000 0.616 0.382 0.382 0.092 FGN.0M.565.ZZC FGN.0M.560.ZZC FGN.0M.561.ZZC FGN.0M.555.ZZC FGN.0M.556.ZZC EGN.0M.665.ZZM EGW.TM.660.ZZM EGW.TM.661.ZZM EGW.TM.655.ZZM EGW.TM.656.ZZM Note: In order to satisfy crimp pull-test requirements to the IEC 60352-2 standard, the use of single strand cables should be avoided. www.lemo.com 25 ® ® Accessories BMF Blanking caps for plugs Part number L N øA P øC X sliding loop BMF.MM.100.•AV BMF.0M.100.•AV BMF.1M.100.•AV BMF.2M.100.•AV BMF.3M.100.•AV BMF.TM.100.•AV BMF.4M.100.•AV BMF.LM.100.•AV BMF.5M.100.•AV A 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 Dimensions (mm) C L N P 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 17.8 24.6 24.6 24.6 24.6 31.1 31.1 31.1 31.1 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 X 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 BGF Blanking caps for plugs Part number L N øA P øC X sliding loop BGF.MM.100.•AV BGF.0M.100.•AV BGF.1M.100.•AV BGF.2M.100.•AV BGF.3M.100.•AV BGF.TM.100.•AV BGF.4M.100.•AV BGF.LM.100.•AV BGF.5M.100.•AV A 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 Dimensions (mm) C L N P 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 17.8 24.6 24.6 24.6 24.6 31.1 31.1 31.1 31.1 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 3.7 5.3 5.3 5.3 5.3 7.9 7.9 7.9 7.9 X 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 BME Blanking caps for fixed sockets Part number L N øA P øC X ø 3.5 BME.MM.200.•AZ BME.0M.200.•AZ BME.1M.200.•AZ BME.2M.200.•AZ BME.3M.200.•AZ BME.TM.200.•AZ BME.4M.200.•AZ BME.LM.200.•AZ BME.5M.200.•AZ A 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 Dimensions (mm) C L N P 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 19.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 BGE Blanking caps for fixed sockets Part number L N ø 3.5 26 øA P øC X BGE.MM.200.•AZ BGE.0M.200.•AZ BGE.1M.200.•AZ BGE.2M.200.•AZ BGE.3M.200.•AZ BGE.TM.200.•AZ BGE.4M.200.•AZ BGE.LM.200.•AZ BGE.5M.200.•AZ A 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 Dimensions (mm) C L N P 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 19.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 www.lemo.com ® ® BMF Blanking caps for free sockets L Part number N øA P øC X sliding loop BMF.MM.200.•AZ BMF.0M.200.•AZ BMF.1M.200.•AZ BMF.2M.200.•AZ BMF.3M.200.•AZ BMF.TM.200.•AZ BMF.4M.200.•AZ BMF.LM.200.•AZ BMF.5M.200.•AZ A 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 Dimensions (mm) C L N P 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 19.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 BGF Blanking caps for free sockets L Part number N øA P øC X sliding loop BGF.MM.200.•AZ BGF.0M.200.•AZ BGF.1M.200.•AZ BGF.2M.200.•AZ BGF.3M.200.•AZ BGF.TM.200.•AZ BGF.4M.200.•AZ BGF.LM.200.•AZ BGF.5M.200.•AZ A 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 Dimensions (mm) C L N P 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 19.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 X 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 BMK Blanking caps, large washer for EC●/PE●/HE● fixed sockets L P øE øB N øA Part number øC X BMK.MM.200.•AZ BMK.0M.200.•AZ BMK.1M.200.•AZ BMK.2M.200.•AZ BMK.3M.200.•AZ BMK.TM.200.•AZ BMK.4M.200.•AZ BMK.LM.200.•AZ BMK.5M.200.•AZ A B 11.1 13.1 14.6 17.6 19.6 22.5 25.0 28.5 34.0 10.1 13.1 14.1 17.2 19.2 22.2 24.2 28.2 33.2 Dimensions (mm) C E L N 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 14.0 17.0 18.0 21.0 23.0 27.0 29.0 33.0 38.0 19.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 P X 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 BGK Blanking caps, large washer for EC●/PE●/HE● fixed sockets L P øE øB N øA Part number øC X BGK.MM.200.•AZ BGK.0M.200.•AZ BGK.1M.200.•AZ BGK.2M.200.•AZ BGK.3M.200.•AZ BGK.TM.200.•AZ BGK.4M.200.•AZ BGK.LM.200.•AZ BGK.5M.200.•AZ A B 12.0 14.4 15.9 18.9 20.9 23.4 25.9 29.4 34.9 10.1 13.1 14.1 17.2 19.2 22.2 24.2 28.2 33.2 Dimensions (mm) C E L N 10.7 12.7 14.2 17.2 19.2 22.0 24.5 28.0 33.5 14.0 17.0 18.0 21.0 23.0 27.0 29.0 33.0 38.0 19.5 23.4 23.4 23.4 23.4 31.0 31.0 31.0 31.0 60.0 85.0 85.0 85.0 120.0 120.0 120.0 150.0 150.0 P X 5.5 3.9 3.9 3.9 3.9 3.4 3.4 3.4 3.4 4.0 6.0 6.0 6.0 6.0 10.0 10.0 10.0 10.0 Note: these caps are suitable for use with any alignment key configuration. The position «•» of the part number indicates the housing material. See page 4. www.lemo.com 27 ® ® GEA Hexagonal nuts for EC ● model Part number A GEA.MM.241.RL GEA.0M.241.RL GEA.0E.240.RL GEA.2M.241.RL GEA.3M.241.RL GEA.TM.241.RL GEA.4M.241.RL GEA.LM.241.RL GEA.5M.241.RL L øB e Series MM 0M 1M 2M 3M TM 4M LM 5M A 12 16 17 19 25 25 30 32 37 Dimensions (mm) B e L 13.5 18.2 19.2 21.5 22.0 28.0 34.0 36.0 41.0 M10x0.50 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 2.5 2.5 2.5 3.0 3.0 3.0 3.0 3.0 3.0 ● Material: Nickel-plated aluminium alloy (anthracite colour) GEA Hexagonal nuts for EG ● model Part number A GEA.00.240.RL GEA.0S.240.RL GEA.1M.240.RL GEA.0E.240.RL GEA.1E.240.RL GEA.3S.240.RL GEA.4M.240.RL GEA.3E.240.RL GEA.5M.240.RL L øB e Series MM 0M 1M 2M 3M TM 4M LM 5M A 9 11 13 17 19 22 25 30 36 Dimensions (mm) B e L 10.2 12.4 14.5 19.2 21.5 25.0 28.0 34.0 40.5 M7x0.50 M9x0.60 M11x1.00 M14x1.00 M16x1.00 M18x1.00 M21x1.00 M24x1.00 M30x1.00 2.0 2.0 2.5 2.5 3.0 3.0 4.0 5.0 5.0 ● Material: Nickel-plated aluminium alloy (anthracite colour) GEC Conical nut for models HE ●, EC ●, PE ● Part number A L øB e GEC.MM.240.RN GEC.0M.240.RN GEC.0E.240.RN GEC.2M.240.RN GEC.3M.240.RN GEC.TM.240.RN GEC.4M.240.RN GEC.LM.240.RN GEC.5M.240.RN Series MM 0M 1M 2M 3M TM 4M LM 5M A 11 14 16 18 20 23 25 29 34 Dimensions (mm) B e L 14 17 18 21 23 27 29 33 38 M10x0.50 M13x0.75 M14x1.00 M17x1.00 M19x1.00 M22x1.00 M24x1.00 M28x1.00 M33x1.00 2.5 3.2 3.0 3.2 3.2 5.0 5.0 5.0 5.0 ● Material: Nickel-plated aluminium alloy (anthracite colour) 28 www.lemo.com ® ® Straight boot BEFORE HEATING Elbow boot Heatshrink boot BEFORE HEATING MM 0M-2M 2M-4M 4M-5M LEMO AFTER HEATING AFTER HEATING Note Part number Series Supplier Raychem® Straight Elbow 90° GMA.10.290.DN 202 A 111-25/86 202 A 121-25/86 202 A 142-25/86 GHA.10.210.DN 222 A 111-25/86 222 A 121-25/86 222 A 142-25/86 cable ø min. (mm) 2) 1) 1) 1) 2.2 3.8 5.3 7.4 Note: 1) modified elastomer resistant to fluids with hot melt sealant. 2) elastomer resistant to fluids. We recommend a thermosetting sealant with this type of boot. GMA Bend relief (for M series fibre optic model only) A bend relief made from thermoplastic polyurethane elastomer (Desmopan 786) can be fitted over LEMO plugs and sockets that are supplied with nut for fitting such bend relief. An other bend relief has been designed for connectors used in applications at high temperature or requiring vapour sterilization. These bend reliefs are different from previous ones as for their material, a silicone elastomer which is noted for its retention of flexibility over a wide temperature range. Main characteristics Part number (Polyurethane) Series Part number (Silicone) GMA.2B.0••.DG 2M GMA.2B.0••.RG GMA.4B.0••.DG 5M GMA.4B.0••.RG Note: Please see unipole/multipole catalogue for bend relief dimensions. The last letter «G» of the part number indicates the grey colour of the bend relief. For ordering a bend relief with another colour, see table on the right and replace the letter «G» by the letter of the required colour. ● Material: Polyurethane elastomer ● Temperature range in dry atmosphere: ● Material: Silicone elastomer VMQ ● Temperature range in dry atmosphere: -60°C ● Temperature range in water steam: +140°C Ref. A B G www.lemo.com -40°C +80°C Colour blue white grey Ref. J M N Colour yellow brown black Ref. R S V +200°C Colour red orange green 29 ® ® Tooling DCE Positioners for crimp contacts Contact Male Contact ø Size 1.3 0.9 0.7 0.5 0M-5M 0M-5M 0M-5M MM For male contacts DCE.91.130.5MVC DCE.91.090.5MVC DCE.91.070.5MVC DCE.91.050.0VC Contact Female Positioners part number Contact ø Size 1.3 0M-5M 0M-3M TM-5M 0M-3M TM-5M MM 0.9 0.7 These positioners are suitable for use with both manual and pneumatic crimping tools according to the MIL-C-22520/7-01 standard. Positioners part number 0.5 For female contacts DCE.91.130.5MVM DCE.91.090.3MVM DCE.91.09T.5MVM DCE.91.070.3MVM DCE.91.07T.5MVM DCE.91.050.0VM DCF Extractors for crimp contacts Contact ø 1.3 0.9 0.7 0.5 Part number DCF.93.131.4LT DCF.93.090.4LT DCF.93.070.4LT DCF.91.050.2LT Note: this model is used for male and female contacts. DCV Female contact insertion tool Contact ø 1.3 0.9 0.7 DCV.13.05M.LA DCV.09.05M.LA DCV.07.05M.LA DCM Front conical nut tightening tools Part number Front conical nut Spanner 30 DCM.65.120.AZ DCM.65.140.AZ DCM.65.160.AZ DCM.65.180.AZ DCM.65.200.AZ DCM.65.230.AZ DCM.65.250.AZ DCM.65.290.AZ DCM.65.340.AZ Spanner Series Front conical nut Part number MM 0M DCM.65.000.4PA 1M 2M 3M TM 4M DCM.65.040.8PA LM 5M Torque (Nm) For models 1.0 1.0 1.5 2.0 2.5 4.0 5.0 6.5 8.0 EC● , HE● , PE● EC● , HE● , PE● EC● , HE● , PE● EC● , HE● , PE● EC● , HE● , PE● EC● , HE● , PE● EC● , HE● , PE● EC● , HE● , PE● EC● , HE● , PE● www.lemo.com ® ® DPC Manual crimping tool Part number According to specification MIL-C-22520/7-01. For LEMO contacts ø 0.5-0.7-0.9-1.3 mm DPC.91.701.V Banding tool GLEN-AIR® Banding tool Tie wrap 600-061 600-057 Part number TIE-DEX® A30199 A31189 AXON® ACDBS100 AXCL0Z Note: the banding tool is to be used with screened cables to ensure a good ground contact. Panel Cut-Out Cut-outs Mounting nut torque (on panel) EG● -EC● -HE● -PE● Series øA + 0.1 0 MM 0M 1M 2M 3M TM 4M LM 5M B + 0.1 0 EG● øA B EC● /HE● /PE● øA B 7.1 9.1 11.1 14.1 16.1 18.1 21.1 24.1 30.1 6.4 8.3 9.6 12.6 14.6 16.6 19.6 22.6 28.6 10.1 13.1 14.1 17.1 19.1 22.1 24.1 28.1 33.1 øA ED● B H 5.0 5.1 6.1 9.1 11.1 12.5 14.1 18.1 23.2 M2.5 M2.5 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 9.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 27.0 øA PB● B H 11.6 14.8 16.8 19.8 21.8 M2.5 M3.0 M3.0 M3.0 M3.0 16.2 21.4 23.4 26.4 29.0 9.1 11.6 12.6 15.6 17.6 20.6 22.6 26.6 31.6 Series Torque (Nm) MM 0M 1M 2M 3M TM 4M LM 5M 1.0 1.0 1.5 2.0 2.5 4.0 5.0 6.5 8.0 Cut-outs ED● -FA● -FW● -FX● -PV● -PF● + 0.1 0 H øA + 0.1 0 + 0.1 0 H Series B MM 0M 1M 2M 3M TM 4M LM 5M FA● /FW● /FX● øA B H øA PV● B H øA PF● B H 9.6 12.3 13.8 16.8 18.8 21.6 24.1 27.6 33.1 12.0 15.1 18.3 20.6 20.6 23.0 24.6 27.0 29.4 11.6 14.8 16.8 19.8 21.8 24.8 27.8 30.8 37.8 M2.5 M2.5 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 12.0 15.1 18.3 20.6 23.0 24.6 27.0 29.4 34.9 7.9 10.8 12.5 15.6 18.1 19.9 22.7 25.9 33.1 M2.5 M2.5 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 9.5 11.0 12.9 15.1 16.6 18.3 20.6 23.0 29.4 øA PB● B H 24.8 27.8 30.8 37.8 M3.0 M3.0 M3.0 M3.0 32.5 35.0 38.0 45.0 M2.5 M2.5 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 M3.0 Cut-outs PB● øA + 0.1 H 0 + 0.1 0 Series MM 0M 1M 2M 3M Series TM 4M LM 5M B www.lemo.com 31 ® ® PCB drilling pattern Fixed socket with straight print contact For HE● models For EG● , EC● and ED● models MM.304 0M.303 2 x ø 0.8 +0.1 0 4xø1 12 5.08 ø 2.5 5.08 1M.305 4xø1 ° 72 +0.1 0 +0.1 0 5 x ø 0.8 ø 2.8 +0.1 0 7.62 2 x ø 0.8 ø 3.4 +0.1 0 7.62 +0.1 0 2 x ø 1.1 1M.308 2M.304 +0.1 0 °2 51 4xø1 6' +0.1 0 45 4xø1 ° +0.1 0 +0.1 0 5.1 8 x ø 0.8 60 ° 8.89 +0.1 0 6 x ø 0.8 +0.1 0 +0.1 0 45° 4 5° 90° ø 6.2 5 0° 2.4 4xø1 50 ° 8.89 ø 6.2 10 x ø 0.8 2 x ø 1.1 +0.1 0 2M.312 5.1 ø 2.15 45 ° 22°30' 4 x ø 1 +0.1 0 8 x ø 0.8 +0.1 0 2 x ø 1.1 +0.1 0 12 x ø 0.8 22°30' 4 x ø 1 +0.1 0 8.89 2M.310.•R +0.1 0 8.89 2M.310 +0.1 0 ø 6.2 60 +0.1 0 4xø1 ø 6.5 3 x ø 0.8 ø 6.4 ø 6.2 +0.1 0 ° 8.89 0° 12 3 x ø 1.1 45 4xø1 2.4 +0.1 0 ø 2.8 4xø1 2M.308.•R ø 5.1 ° +0.1 0 8.89 2M.308 60 32 4 x ø 1.1 ° 2M.306.•R +0.1 0 7.62 8 x ø 0.8 ø 3.8 +0.1 0 7.62 7 x ø 0.8 ø 3.7 8.89 60 ° 4xø1 ø 2.3 90° 3 x ø 1.1 +0.1 0 1M.307 30° +0.1 0 ø 4.8 2 x ø 1.1 ø 3.1 ø 2.8 +0.1 0 +0.1 0 +0.1 0 4xø1 +0.1 0 4xø1 5.08 ø 2.8 5 x ø 0.8 4xø1 +0.1 0 7.62 4xø1 ° 72 4 x ø 0.8 1M.304.•R 1M.303 +0.1 0 +0.1 0 ø 3.8 1M.302 3 x ø 0.8 7.62 0M.305 +0.1 0 0° 4 x ø 0.6 4xø1 45° 12 +0.1 0 5.08 ø 1.35 3 x ø 0.6 0M.304 +0.1 0 0° +0.1 0 5.08 4xø1 90° 12 4xø1 +0.1 0 5.08 45° 0° 4xø1 0M.302 +0.1 0 ø 1.6 MM.303 +0.1 0 ø 2.2 4xø1 +0.1 0 www.lemo.com ® ® 3M.322 3M.330 36° 22°30' +0.1 0 30 40 x ø 0.8 LM.355 10.16 13.97 ø 11.64 ø 7.94 4xø1 18° +0.1 0 16.51 36° 13.97 ø 8.5 ø 11.9 ø 4.24 10°35’18’’ 5’’ ’3 ø15.3 48 x ø 0.8 ø 5.2 ø 1.9 120 ° 45 ° +0.1 0 ø 2.8 21 °1 0 ° +0.1 0 4xø1 24 16 ° 12° 22°30' +0.1 0 7°30’ ° 15 8°10'55'' '' '49 21 9° 27°4 1'3 2 18° 12.7 ø 6.8 +0.1 0 4M.348 4xø1 '' ø 10.2 27° 41 '3 18° 40 x ø 0.8 26' 51° +0.1 0 ø11.1 4xø1 9° 12.7 ø 9.8 +0.1 0 2.6 20.32 0° 2'' ø 5.8 25 x ø 0.8 6 24° 3.23 +0.1 0 4M.340 +0.1 0 ø 3.4 4xø1 ø9 2.2 TM.340 40° ø 5.7 22° 30 x ø 0.8 +0.1 0 ø19.84 TM.325 +0.1 0 ' 4.45 ø5 22 x ø 0.8 10.16 25° 8.89 ø 6.7 +0.1 0 19 x ø 0.8 4xø1 11°15' +0.1 0 43 ' ø 3.5 45 ° 12°52' 4xø1 ø 6.9 4xø1 15° ø 8.8 ° 60 ° 30 ø14.96 2M.319 +0.1 0 55 x ø 0.8 +0.1 0 5M.366 LM.368 6°40’ 1 ' °26 51 ' 1 °5 13 9° 8° 13°51’ 4xø1 +0.1 0 4xø1 +0.1 0 ø 10.08 16.51 ø15.5 ø8 ø11.75 ø 4.25 27° 41 ’30 ’’ 51°25’30’’ 6°55'30'' ø 5.6 ° 13 2 0’ 27°41'30'' 66 x ø 0.8 +0.1 0 18°57' 68 x ø 0.8 5M.114 10° +0.1 0 5° 6°12’25’’ 8°10’55’’ 4xø1 +0.1 0 114 x ø 0.8 24° 20.7 20.32 ø 17.1 ø 13.5 ø 9.9 ø 6.3 ø 2.7 12 0° 16 ° 0’’ 4’5 °2 12 ’’ ’49 21 + 0.1 0 40° www.lemo.com 33 ® ® Assembly instructions for plugs and sockets 2 1 2 1 FG● PH● PB● 1. L ± 0.5 First place the heatshrink boot ➀ over the cable. Strip the cable according to dimensions of the table, then widen the shield. 1 T ± 0.2 Cable preparation Series L S T 0M to 5M 20 15 3.5 Note : dimensions are in mm. S ± 0.5 2. 2 Crimp 2 Crimp Cable termination 2.1 With shielded cables, widen and pull the shield all the way to the back. Fix the appropriate positioner onto the crimping tool and set the selector to the number corresponding to the AWG of the conductor used as indicated on the positioner label. Fit the conductor into the contact ➁; make sure it is visible through the contact’s inspection hole. Slide the conductor-contact assembly into the open crimping tool; make sure that the contact is pushed fully into the positioner. Close the tool. Remove from crimping tool and check that conductor is secure in contact and shows in inspection hole. 2.2 Arrange the conductor-contact assemblies according to the markings, into the rear cable seal. Push them deeply into the insulator, using tweezers if necessary; check that all the contacts are correctly located in the insulator: 1) by verifying the alignment of the contacts at the front of the insulator and 2) by gently pulling on each conductor. Verification should also be made using the appropriate retention testing tool. 2.3 Bring the shield around the rear of connector. Secure it with a band-it tie-wrap (not furnished) to fix the shield in place. Cut off the possible shield surplus. Steel tie-wrap band (~3 mm wide) Steel tie-wrap band (~3 mm wide) Heat 34 Heat 2.4 Put the heatshrink boot in place and heat gently until it retracts. www.lemo.com ® ® Assembly instructions for plugs and sockets (with optional mold stop) 1 FG● PH● 1 PB● 1. L ± 0.5 Cable preparation Strip the cable according to dimensions of the table, then widen the shield. T ± 0.2 Series L S T 0M to 5M 20 15 3.5 Note : dimensions are in mm. S ± 0.5 2. 1 Crimp 1 Crimp Cable termination 2.1 With shielded cables, widen and pull the shield all the way to the back. Fix the appropriate positioner onto the crimping tool and set the selector to the number corresponding to the AWG of the conductor used as indicated on the positioner label. Fit the conductor into the contact ➀; make sure it is visible through the contact’s inspection hole. Slide the conductor-contact assembly into the open crimping tool; make sure that the contact is pushed fully into the positioner. Close the tool. Remove from crimping tool and check that conductor is secure in contact and shows in inspection hole. 2.2 Arrange the conductor-contact assemblies according to the markings, into the rear cable seal. Push them deeply into the insulator, using tweezers if necessary; check that all the contacts are correctly located in the insulator: 1) by verifying the alignment of the contacts at the front of the insulator and 2) by gently pulling on each conductor. Verification should also be made using the appropriate retention testing tool. Steel tie-wrap band (~3 mm wide) 2.3 Bring the shield around the rear of connector until the mold stop. Secure it with a band-it tie-wrap (not furnished) to fix the shield in place. Cut off the possible shield surplus. Steel tie-wrap band (~3 mm wide) Overmolding 2.4 Custom overmold cable assembly. Overmolding www.lemo.com 35 ® ® Notes 36 www.lemo.com Product safety notice ® ® PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. Data subject to change No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO reserve the right at all times to modify and improve specifications without any notification. www.lemo.com 37 LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax:(+43 1) 914 23 20 11 sales@lemo.at JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: (+81 3) 54 46 55 10 Fax: (+81 3) 54 46 55 11 lemoinfo@lemo.co.jp CANADA LEMO Canada Inc 44 East Beaver Creek Road, unit 20 Richmond Hill, Ontario L4B 1G8 Tel: (+1 905) 889 56 78 Fax: (+1 905) 889 49 70 info-canada@lemo.com NETHERLANDS / BELGIUM LEMO Connectors Benelux De Trompet 1060 1967 DA Heemskerk Tel. (+31) 251 25 78 20 Fax (+31) 251 25 78 21 info@lemo.nl CHINA LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com NORWAY / ICELAND LEMO Norway A/S Stanseveien 6B 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com DENMARK LEMO Denmark A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de HONG KONG LEMO Hong Kong Ltd Unit 1207, 12/F, Corporation Square, 8 Lam Lok Street, Kowloon Bay, Kowloon - Hong Kong Tel: (+852) 2174 0468 Fax: (+852) 2174 0492 hk.sales@lemo.com HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com LEMO SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com SWEDEN / FINLAND LEMO Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing, West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax:(+1 707) 578 08 69 info@lemousa.com DISTRIBUTORS AUSTRALIA, BRAZIL, CHILE, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TAIWAN, TURKEY, UKRAINE www.lemo.com © CAT.MM.LEN.P0811 - Updated September 2014 LEMO
EGN.MM.304.XLM 价格&库存
很抱歉,暂时无法提供与“EGN.MM.304.XLM”相匹配的价格&库存,您可以联系我们找货
