FGG.1T.304.CLAC60Z
FGG.1T.304.CLAC60Z
    LEMO(雷莫)
    LEMO - FGG.1T.304.CLAC60Z - Circular Connector, 1T Series, Cable Mount Plug, 4 Contacts, Solder Pin,...
FGG.1T.304.CLAC60Z 数据手册
FGG.1T.304.CLAC60Z www.lemo.com SUMMARY # Wires Low 4 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 1T Termination type Male solder IP rating 68 Cable Ø 5.60 - 6.00 mm Status active Image is for illustrative purpose only Download Request a quote Catalog Alternative part Matching parts EGG.1T.304.CLL TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 16.91 g Performance Configuration T.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1450 V (AC), 2050 V (DC) Vtest (contact-contact): 1350 V (AC), 1910 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr IP Rating: 68 DRAWINGS Draws Dimensions A L M S1 S2 mm. 12 45 34 11 9 in. 0.47 1.77 1.34 0.43 0.35 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools None Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1T.304.CLAC60Z 价格&库存
很抱歉,暂时无法提供与“FGG.1T.304.CLAC60Z”相匹配的价格&库存,您可以联系我们找货
FGG.1T.304.CLAC60Z
  • 1+323.11013
  • 5+316.65355
  • 10+307.13530
库存:14
FGG.1T.304.CLAC60Z
  • 1+577.352541+75.04175
  • 10+490.7267110+63.78251
  • 30+454.1403830+59.02718
  • 50+438.0794150+56.93964
  • 100+417.19722100+54.22547
库存:1
