FGG.1T.307.CLAC65
FGG.1T.307.CLAC65
    LEMO(雷莫)
    LEMO - FGG.1T.307.CLAC65 - Circular Connector, 1T Series, Cable Mount Plug, 7 Contacts, Solder Pin, ...
FGG.1T.307.CLAC65 数据手册
T SERIES IP 68 PUSH-PULL CONNECTORS ® ® T series T series connectors have been specifically designed for outdoor applications. They include an inner sleeve and seals to prevent penetration of solids or liquids.This series is watertight when mated to give a protection index of IP68 as per IEC 60529 standard and have the following main features: - IP68 mated - Push-Pull self-latching system - Mechanical key (FGG) with multiple keys to avoid cross-mating - High packing density for space savings - 360° shielding for full EMC shielding - Compatible with existing B sockets Same mounting hole as B sockets Black-chrome plated brass and plastic outershell available Multipole types 2 to 32 contacts For cables 1.0 up to 10.5 mm Solder, crimp or print contacts Technical Characteristics Mechanical and Climatical Value Standard Endurance > 5000 cycles IEC 60512-5 test 9a Humidity up to 95% at 60° C – Temperature range -55° C, +200° C – Resistance to vibration 10-2000 Hz, 15 g IEC 60512-4 test 6d Shock resistance 100 g, 6 ms IEC 60512-4 test 6c Salt spray corrosion test > 1000 h IEC 60512-6 test 11f Protection index (mated) IP68 IEC 60529 Latching retention force > 100 N – Electrical Value Standard Shielding efficiency at 10 MHz > 75 dB IEC 60169-1-3 Shielding efficiency at 1 GHz > 40 dB IEC 60169-1-3 Material and Treatments Outershell and collet nut Material Surface treatment Latch sleeve/earthing crown Material Surface treatment Other metallic components Material Surface treatment Brass Chrome Brass/Bronze Nickel Brass Nickel Brass Black chrome Brass/Bronze Nickel Brass Nickel POM – Brass/Bronze Nickel Brass Nickel Insulators Contacts Material Contact type Material Contact type Brass (UNS C 34500) Male contact PEEK Crimp, solder or print Bronze (UNS C 54400) Female contact Part Section Showing Internal Components Straight plug Fixed socket 4 1 outer shell 2 earthing crown 3 hexagonal nut 4 insulator 5 female contact 6 o-ring 7 locking washer 2 6 3 7 5 6 1 2 5 4 3 1 6 7 8 9 10 1 outer shell 2 latch sleeve 3 inner shell 4 insulator 5 male contact 6 split insert carrier 7 earthing cone 8 gasket 9 collet 10 collet nut www.lemo.com ® ® Interconnections Chrome-plated housing models Straight plugs FGG Fixed sockets Free sockets EGG PHG EEG PHG FFG FGG Plastic housing models Watertight or vacuumtight models Straight plug FGG Fixed socket Fixed sockets EGG HGG HEG HMG Part Numbering System Plug and free socket F G G. 1 T . 3 0 6 . C L A C 4 0 Z Variant Cable ø Model Collet type Alignment key Contact: A = male solder L = female solder C = male crimp M = female crimp Series Insert configuration Housing: C = Chrome plated brass K = Black Chrome plated brass B = POM Insulator: PEEK L = for solder contact Y = for crimp contact FGG.1T.306.CLAC40Z = Straight plug with key (G) and cable collet for bend relief, 1T series, multipole type with 6 contacts, outer shell in chrome-plated brass, PEEK insulator, male solder contacts, C type collet for 4.0 mm diameter cable and nut for fitting a bend relief. Fixed socket E G G. 1 T . 3 0 6 . C L L Model Alignment key Series Insert configuration Housing: C = Chrome plated brass K = Black Chrome plated brass B = POM Contact: L = female solder M = female crimp N = female print V = fem. elbow print Insulator: PEEK L = for solder contact Y = for crimp contact EGG.1T.306.CLL = fixed socket, nut fixing, with key (G), 1T series, multipole type with 6 contacts, outer shell in chrome-plated brass, PEEK insulator, female solder contacts. DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 1 ® ® Chrome-plated housing models FGG Straight plug, cable collet Reference ~L øA ~M Model Series FGG TT FGG Dimensions (mm) A L M Cable ø min. max. 6.5 33.2 25.2 2.4 3.0 0T 9.0 39.0 29.0 1.0 5.0 FGG 1T 12.0 46.0 35.0 1.3 6.5 FGG 2T 15.0 55.0 43.0 1.3 8.5 FGG 3T 17.0 64.0 49.0 2.6 10.5 Reference Dimensions (mm) FGG Straight plug, cable collet and nut for fitting a bend relief ~L øA ~M FFG Model Series FGG TT FGG A L M Cable ø min. max. 6.5 32.7 24.7 2.4 3.0 0T 9.0 38.0 28.0 1.0 5.0 FGG 1T 12.0 45.0 34.0 1.3 6.5 FGG 2T 15.0 54.0 42.0 1.3 8.5 FGG 3T 17.0 62.0 47.0 2.6 10.5 Reference Dimensions (mm) Straight plug, non latching, cable collet ~L øA ~M Model Series FFG TT FFG A L M Cable ø min. max. 6.5 33.2 25.2 2.4 3.0 0T 9.0 39.0 29.0 1.0 5.0 FFG 1T 12.0 46.0 35.0 1.3 6.5 FFG 2T 15.0 55.0 43.0 1.3 8.5 FFG 3T 17.0 64.0 49.0 2.6 10.5 DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 2 www.lemo.com ® ® EGG Fixed socket, nut fixing L maxi Reference Dimensions (mm) Panel cut-out e øA ø C + 0.1 0 N B + 0.1 0 M E maxi Panel cut-out EEG Model Series A EGG TT 10.0 EGG 0T 12.0 EGG e E L M N B C M7x0.5 5.5 16.0 1.2 13.5 6.4 7.1 M9x0.6 6.0 21.0 1.5 19.1 8.3 9.1 1T 15.5 M12x1.0 6.0 23.0 1.8 21.5 10.6 12.1 EGG 2T 18.5 M15x1.0 7.5 26.5 1.8 24.6 13.6 15.1 EGG 3T 23.5 M18x1.0 9.6 30.1 2.5 25.0 16.6 18.1 Fixed socket, nut fixing, back panel mounting Reference L maxi ø C + 0.1 0 e øA N B + 0.1 0 E maxi Panel cut-out Dimensions (mm) Model Series A EEG TT 10.0 EEG 0T 12.0 EEG EEG EEG e E L Panel cut-out N B C M7x0.5 4.5 16.0 13.5 6.4 7.1 M9x0.6 6.5 21.0 19.1 8.3 9.1 1T 15.5 M12x1.0 6.5 23.0 21.5 10.6 12.1 2T 18.5 M15x1.0 7.5 26.5 24.6 13.6 15.1 3T 23.5 M18x1.0 7.5 30.1 25.0 16.6 18.1 PHG Free socket, cable collet Reference øA ~L Model Series PHG TT PHG Dim. (mm) A L Cable ø min. max. 6.5 32.0 2.4 3.0 0T 9.0 38.0 1.0 5.0 PHG 1T 12.0 43.5 1.3 6.5 PHG 2T 15.0 52.0 1.3 8.5 PHG 3T 17.0 61.5 2.6 10.5 Reference Dim. (mm) PHG Free socket, cable collet and nut for fitting a bend relief øA ~L Model Series PHG TT PHG A L Cable ø min. max. 6.5 31.5 2.4 3.0 0T 9.0 37.0 1.0 5.0 PHG 1T 12.0 42.5 1.3 6.5 PHG 2T 15.0 51.0 1.3 8.5 PHG 3T 17.0 60.0 2.6 10.5 DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 3 ® ® Watertight or vacuumtight models HGG Fixed socket, nut fixing, watertight or vacuumtight L maxi Reference ø C + 0.1 0 e øA N B + 0.1 0 M E maxi Panel cut-out Dimensions (mm) Model Series A HGG 0T 12.0 HGG HGG e E L Panel cut-out M N B C M9x0.6 6.5 22.0 1.5 18.5 8.3 9.1 1T 15.5 M12x1.0 6.0 26.0 1.8 21.5 10.6 12.1 2T 18.5 M15x1.0 8.0 30.5 2.0 25.0 13.6 15.1 Note: temperature range -20°C / +100°C HEG Fixed socket, nut fixing, watertight or vacuumtight, back panel mounting L maxi ø C + 0.1 0 Reference e øA N B + 0.1 0 E maxi Panel cut-out Dimensions (mm) Model Series A HEG 0T 12.0 HEG HEG e E L Panel cut-out N B C M9x0.6 6.5 22.0 18.5 8.3 9.1 1T 15.5 M12x1.0 6.5 26.0 21.5 10.6 12.1 2T 18.5 M15x1.0 7.5 30.5 25.0 13.6 15.1 Note: temperature range -20°C / +100°C HMG Fixed socket, nut fixing, watertight or vacuumtight, back panel mounting L maxi E maxi ø C + 0.1 0 Reference e øA N B + 0.1 0 Panel cut-out Dimensions (mm) Model Series A HMG 0T 12.0 HMG HMG e E L Panel cut-out N B C M9x0.6 6.5 22.0 18.5 8.3 9.1 1T 15.5 M12x1.0 6.5 26.0 21.5 10.6 12.1 2T 18.5 M15x1.0 7.5 30.5 25.0 13.6 15.1 Note: temperature range -20°C / +100°C DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 4 www.lemo.com ® ® Plastic housing models FGG Straight plug, cable collet and nut for fitting a bend relief, POM outer shell ~L øA ~M Reference Model Series FGG 0T FGG 1T Dimensions (mm) A L M Cable ø min. max. 9.7 38.5 28.5 1.0 5.0 13.0 45.0 34.0 1.3 6.5 EGG Fixed socket, nut fixing, POM outer shell L maxi e øA ø C + 0.1 0 N B + 0.1 0 M E maxi Panel cut-out Reference Dimensions (mm) Model Series A e E EGG 0T 12.0 M9x0.6 6 EGG 1T 15.5 M12x1.0 6 L Panel cut-out M N B C 21.0 1.5 19.1 8.3 9.1 22.2 1.8 18.5 10.6 12.1 Alignment Key Key Contact type G B A J Plug Socket G male female A male female B male female J female male DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 5 ® ® Insert configurations Multipole Contact type Solder contacts AWG max. Test voltage (kV rms) Test voltage (kV dc) 5.0 ● 22 32 20 1.00 1.05 10.0 ● ● 20 26 18 1.50 1.35 15.0 ● ● 16 18 12 2.10 1.75 25.0 ● 12 14 10 2.10 1.55 35.0 ● ● 30 32 28 0.80 0.95 3.0 0.9 ● ● ● ● 22 32 20 1.20 0.90 8.0 1T 1.3 ● ● ● ● 20 26 18 1.30 1.55 12.0 2T 1.6 ● ● ● ● 18 22 14 2.40 1.85 17.0 3T 2.0 ● ● ● 16 18 12 1.90 1.50 25.0 TT 0.5 ● ● 30 32 28 0.80 0.65 2.0 0T 0.7 ● ● ● ● 22 32 22 0.85 0.70 7.0 1T 0.9 ● ● ● ● 22 32 20 1.35 1.45 10.0 2T 1.3 ● ● ● ● 20 26 18 1.85 1.85 15.0 3T 2.0 ● ● ● ● 16 18 12 1.45 1.25 19.0 0T 0.7 ● ● ● ● 22 32 22 1.00 0.70 6.5 1T 0.9 ● ● ● ● 22 32 20 1.25 1.15 9.0 2T 1.3 ● ● ● ● 20 26 18 1.75 1.60 14.0 3T 1.6 ● ● ● 18 22 14 1.90 1.25 19.0 0T 0.5 ● 0.85 0.65 2.5 1T 0.7 ● 2T 1.3 3T 1.6 0.5 ● ● 0T 0.9 ● ● ● 302 1T 1.3 ● ● 2T 2.0 ● ● 3T 3.0 ● 3 TT 0.5 0T 303 4 304 5 Print (straight) Reference 2 Rated current (A) min. 0.95 TT Crimp contacts Print (elbow) 1.00 Crimp 28 Solder 32 Contact ø (mm) 30 Series Solder (max.) Crimp 305 6 ● ● 28 ● ● ● 22 32 22 1.05 1.20 7.0 ● ● ● ● 20 26 18 1.35 1.45 12.0 ● ● ● ● 18 22 14 1.60 1.15 17.0 306 6 306 DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 6 www.lemo.com ® ® Multipole Contact type AWG 0.5 ● 1T 0.7 ● 2T 1.3 3T 2.5 22 0.95 1.05 7.0 26 18 1.75 1.60 11.0 18 22 14 1.70 1.25 15.0 ● 22 32 22 0.95 1.15 5.0 ● ● 22 32 20 1.50 1.25 10.0 ● ● 20 26 18 1.65 1.15 13.0 ● ● 28 0.60 0.50 2.0 1.35 1.05 6.0 15.0 0.90 1.50 2.5 ● 28 ● ● ● 22 32 ● ● ● ● 20 1.6 ● ● ● 1T 0.7 ● ● ● 2T 0.9 ● ● 3T 1.3 ● ● 0T 0.5 ● 3T 8x1.3 1x2.0 ● 1T 0.5 ● 2T 0.9 ● 3T 1.3 ● 0T 0.35 ● 2T 0.7 ● ● ● ● 22 32 3T 0.9 ● ● ● ● 22 32 min. ● Crimp Solder (max.) 0.70 Print (elbow) 0.80 Print (straight) Test voltage (kV dc) Solder Reference 7 Test voltage (kV rms) Contact ø (mm) 0T Crimp contacts max. Series Crimp Rated current (A) Solder contacts 307 8 308 8 308 9 309 10 310 ● 20 16 ● 26 18 18 12 ● ● 28 ● ● ● 22 32 20 1.45 1.30 8.0 ● ● ● 20 26 18 1.25 0.90 12.0 0.80 1.00 1.5 22 1.25 1.35 7.0 20 1.45 1.00 9.0 12 312 12 28 312 DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 7 ® ® Multipole Contact type Solder contacts AWG Test voltage (kV dc) Rated current (A) 22 1.15 1.35 6.5 20 1.20 1.20 9.0 0.80 1.25 1.5 22 0.95 1.25 6.0 32 20 1.20 0.85 8.0 22 32 22 0.85 1.20 5.5 ● 22 32 20 1.20 1.05 7.0 ● ● 22 32 22 0.95 1.25 5.0 ● ● ● 22 32 22 1.00 0.90 6.0 ● ● 22 32 22 1.00 0.90 5.5 2T 0.7 ● 3T 0.9 ● 1T 0.5 ● 2T 0.7 ● ● ● ● 22 32 3T 0.9 ● ● ● ● 22 2T 0.7 ● ● ● ● 3T 0.9 ● ● ● 319 2T 0.7 ● ● 320 3T 0.7 ● 322 3T 0.7 ● ● 28 ● ● ● 22 32 ● ● ● 22 32 min. ● Crimp Reference 314 Solder (max.) ● Print (elbow) 0.5 14 Print (straight) 1T Crimp contacts max. 2.0 Solder 1.20 Contact ø (mm) 0.80 Series Test voltage (kV rms) Crimp 16 316 16 ● 28 316 18 318 19 20 22 DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 8 www.lemo.com ® ® Multipole Contact type Solder contacts AWG Crimp Print (straight) Print (elbow) Solder (max.) min. ● ● ● ● 22 32 2T 0.5 ● 3T 0.7 ● 330 3T 0.7 ● 332 2T 0.5 ● Rated current (A) Solder 0.7 Test voltage (kV dc) Contact ø (mm) 3T Test voltage (kV rms) Series 324 Crimp contacts max. Reference Crimp 22 0.95 0.80 4.0 0.95 1.30 2.0 24 26 ● 28 ● ● 22 32 22 0.95 0.70 4.0 ● ● 22 32 22 0.80 0.70 3.5 0.80 1.20 1.5 326 30 ● 32 ● 28 DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 9 ® ® Collets Cable ø (mm) Cable ø (mm) Type TT 0T Cable ø (mm) Type min. max. C27 2.4 2.6 C31 2.7 3.0 C10 1.0 C15 Cable ø (mm) Type min. max. C15 1.3 1.5 C20 1.6 2.0 1.2 C25 2.1 1.3 1.5 C30 C20 1.6 2.0 C25 2.1 C30 Type min. max. min. max. C15 1.3 1.5 C20 1.6 2.0 C30 2.6 3.0 C35 3.1 3.5 2.5 C25 2.1 2.5 C40 3.6 4.0 2.6 3.0 C30 2.6 3.0 C45 4.1 4.5 C35 3.1 3.5 C35 3.1 3.5 C50 4.6 5.0 2.5 C40 3.6 4.0 C40 3.6 4.0 C55 5.1 5.5 2.6 3.0 C45 4.1 4.5 C45 4.1 4.5 C60 5.6 6.0 C35 3.1 3.5 C50 4.6 5.0 C50 4.6 5.0 C65 6.1 6.5 C40 3.6 4.0 C55 5.1 5.5 C55 5.1 5.5 C70 6.6 7.0 C45 4.1 4.5 C60 5.6 6.0 C60 5.6 6.0 C75 7.1 7.5 C50 4.6 5.0 C65 6.1 6.5 C65 6.1 6.5 C80 7.6 8.0 C70 6.6 7.0 C85 8.1 8.5 C75 7.1 7.5 C90 8.6 9.0 C80 7.6 8.0 C95 9.1 9.5 C85 8.1 8.5 C10 9.6 10.0 C11 10.1 10.5 1T 2T 3T DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 10 www.lemo.com ® ® Spare parts FGG-EGG Insulators for crimp contacts male female Insulator part number Insulator part number Type Type Male contact TT 0T 1T 2T Female contact 302 FGG.00.302.YL EGG.00.402.YL 303 FGG.00.303.YL EGG.00.403.YL 304 FGG.00.304.YL 302 Male contact Female contact 310 FGG.2B.310.YL EGG.2B.410.YL 312 FGG.2B.312.YL EGG.2B.412.YL EGG.00.404.YL 314 FGG.2B.314.YL EGG.2B.414.YL FGG.0B.302.YL EGG.0B.402.YL 316 FGG.2B.316.YL EGG.2B.416.YL 303 FGG.0B.303.YL EGG.0B.403.YL 318 FGG.2B.318.YL EGG.2B.418.YL 304 FGG.0B.304.YL EGG.0B.404.YL 319 FGG.2B.319.YL EGG.2B.419.YL 305 FGG.0B.305.YL EGG.0B.405.YL 302 FGG.3B.302.YL EGG.3B.402.YL 306 FGG.0B.306.YL – 303 FGG.3B.303.YL EGG.3B.403.YL 307 FGG.0B.307.YL – 304 FGG.3B.304.YL EGG.3B.404.YL 309 FGG.0B.309.YL – 305 FGG.3B.305.YL EGG.3B.405.YL 302 FGG.1B.302.YL EGG.1B.402.YL 306 FGG.3B.306.YL EGG.3B.406.YL FGG.3B.307.YL EGG.3B.407.YL 2T 3T 303 FGG.1B.303.YL EGG.1B.403.YL 307 304 FGG.1B.304.YL EGG.1B.404.YL 308 FGG.3B.308.YL EGG.3B.408.YL 305 FGG.1B.305.YL EGG.1B.405.YL 309 FGG.3B.309.ML EGG.3B.409.ML 306 FGG.1B.306.YL EGG.1B.406.YL 310 FGG.3B.310.YL EGG.3B.410.YL 307 FGG.1B.307.YL EGG.1B.407.YL 312 FGG.3B.312.YL EGG.3B.412.YL 308 FGG.1B.308.YL EGG.1B.408.YL 314 FGG.3B.314.YL EGG.3B.414.YL 310 FGG.1B.310.YL – 316 FGG.3B.316.YL EGG.3B.416.YL 314 FGG.1B.314.YL – 318 FGG.3B.318.YL EGG.3B.418.YL 316 FGG.1B.316.YL – 320 FGG.3B.320.YL EGG.3B.420.YL 302 FGG.2B.302.YL EGG.2B.402.YL 322 FGG.3B.322.YL EGG.3B.422.YL FGG.3B.324.YL EGG.3B.424.YL 303 FGG.2B.303.YL EGG.2B.403.YL 324 304 FGG.2B.304.YL EGG.2B.404.YL 326 FGG.3B.326.YL EGG.3B.426.YL 305 FGG.2B.305.YL EGG.2B.405.YL 330 FGG.3B.330.YL EGG.3B.430.YL 306 FGG.2B.306.YL EGG.2B.406.YL 307 FGG.2B.307.YL EGG.2B.407.YL 308 FGG.2B.308.YL EGG.2B.408.YL Note: each insulator can be used both for crimp contacts of normal shape (fig. 1) or with reduced solder cups (fig. 2) as shown on page 12. DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 11 ® ® FGG-EGG Fig. 1 Crimp contacts øA øC øA øC ø (mm) Fig. 2 C Male 2T ø (mm) 0.5 0.45 FGG.00.554.ZZC EGG.00.654.ZZM 303 0.5 0.45 FGG.00.554.ZZC EGG.00.654.ZZM 304 0.5 0.45 FGG.00.554.ZZC EGG.00.654.ZZM 302/303 0.9 1.10 FGG.0B.560.ZZC EGG.0B.660.ZZM 304/305 0.7 0.80 FGG.0B.555.ZZC EGG.0B.655.ZZM A 0T 1T Contact part number 302/303 1.3 1.40 FGG.1B.565.ZZC EGG.1B.665.ZZM 304/305 0.9 1.10 FGG.1B.560.ZZC EGG.1B.660.ZZM C Male Female 302/303 0.9 0.80 FGG.0B.561.ZZC EGG.0B.661.ZZM 302/303 0.9 0.45 FGG.0B.562.ZZC EGG.0B.662.ZZM 304/305 0.7 0.45 FGG.0B.556.ZZC EGG.0B.656.ZZM 302/303 1.3 1.10 FGG.1B.566.ZZC EGG.1B.666.ZZM 304/305 0.9 0.80 FGG.1B.561.ZZC EGG.1B.661.ZZM 306/307/308 0.7 0.45 FGG.1B.556.ZZC EGG.1B.656.ZZM – 302 2.0 1.90 FGG.2B.576.ZZC EGG.2B.676.ZZM 303 1.6 1.40 FGG.2B.571.ZZC EGG.2B.671.ZZM 306/307/308 0.7 0.80 FGG.1B.555.ZZC EGG.1B.655.ZZM 304/305 1.3 1.10 FGG.2B.566.ZZC EGG.2B.666.ZZM 310/314/316 0.5 0.45 FGG.1B.554.ZZC 306/307 1.3 1.10 FGG.2B.566.ZZC EGG.2B.666.ZZM 1.3 0.80 FGG.2B.567.ZZC EGG.2B.667.ZZM 2T – 302 2.0 2.40 FGG.2B.575.ZZC EGG.2B.675.ZZM 304/305 303 1.6 1.90 FGG.2B.570.ZZC EGG.2B.670.ZZM 306/307 1.3 0.80 FGG.2B.567.ZZC EGG.2B.667.ZZM 304/305 1.3 1.40 FGG.2B.565.ZZC EGG.2B.665.ZZM 308/310 0.9 0.80 FGG.2B.561.ZZC EGG.2B.661.ZZM 306/307 1.3 1.40 FGG.2B.565.ZZC EGG.2B.665.ZZM 308/310 0.9 0.45 FGG.2B.562.ZZC EGG.2B.662.ZZM 308/310 0.9 1.10 FGG.2B.560.ZZC EGG.2B.660.ZZM 312/314/316 0.7 0.45 FGG.2B.556.ZZC EGG.2B.656.ZZM 318/319 312/314/316 0.7 0.80 FGG.2B.555.ZZC EGG.2B.655.ZZM 3T øC Female 302 306/307/309 0.5 0.45 FGG.0B.554.ZZC 1T øA Types A 0T øC Contact part number Types TT øA 318/319 0.7 0.80 FGG.2B.555.ZZC EGG.2B.655.ZZM 302 3.0 3.20 FGG.3B.580.ZZC EGG.3B.680.ZZM 3T 0.7 0.45 FGG.2B.556.ZZC EGG.2B.656.ZZM 303/304/309 2.0 1.90 FGG.3B.576.ZZC EGG.3B.676.ZZM 305/306/307 1.6 1.40 FGG.3B.571.ZZC EGG.3B.671.ZZM 303/304/309 2.0 2.40 FGG.3B.575.ZZC EGG.3B.675.ZZM 308/309/310 1.3 1.10 FGG.3B.566.ZZC EGG.3B.666.ZZM 305/306/307 1.6 1.90 FGG.3B.570.ZZC EGG.3B.670.ZZM 312/314 0.9 0.80 FGG.3B.561.ZZC EGG.3B.661.ZZM 308/309/310 1.3 1.40 FGG.3B.565.ZZC EGG.3B.665.ZZM 316/318 0.9 0.80 FGG.3B.561.ZZC EGG.3B.661.ZZM 312/314 0.9 1.10 FGG.3B.560.ZZC EGG.3B.660.ZZM 316/318 0.9 0.45 FGG.3B.562.ZZC EGG.3B.662.ZZM 316/318 0.9 1.10 FGG.3B.560.ZZC EGG.3B.660.ZZM 320/322/324 0.7 0.45 FGG.3B.556.ZZC EGG.3B.656.ZZM 320/322/324 0.7 0.80 FGG.3B.555.ZZC EGG.3B.655.ZZM 326/330 326/330 0.7 0.45 FGG.3B.556.ZZC EGG.3B.656.ZZM 0.7 0.80 FGG.3B.555.ZZC EGG.3B.655.ZZM DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 12 www.lemo.com ® ® GBA Locking washers Dimensions (mm) Part number Series øA A C L L øC GBA.00.250.FN TT 9.5 7.1 1.0 GBA.0S.250.FN 0T 12.5 9.1 1.0 GBA.1S.250.FN 1T 16.0 12.1 1.0 GBA.2S.250.FN 2T 19.5 15.1 1.2 GBA.3S.250.FN 3T 25.0 18.1 1.4 Note: to order this accessory separately, use the above part numbers. ● Material: Nickel-plated bronze (3 μm) GEA Hexagonal nuts Dimensions (mm) Part number A Series A B e L M7 x 0.5 2.0 GEA.00.240.LN TT 9 10.2 GEA.0S.240.LN 0T 11 12.4 M9 x 0.6 2.0 GEA.1S.240.LN 1T 14 15.8 M12 x 1.0 2.5 GEA.2S.240.LN 2T 17 19.2 M15 x 1.0 2.7 GEA.3S.240.LN 3T 22 25.0 M18 x 1.0 3.0 L øB e Note: to order this part separately, use the above part numbers. The last letters «LN» of the part number refer to the nut material and treatment. If a nut in aluminium alloy or stainless steel is desired, replace the last letters of the part number by «PT» or «AZ» respectively. ● Material: Nickel-plated brass (3 μm), Natural anodized aluminium alloy, Stainless steel GEG Notched nuts øA L øB e Dimensions (mm) Model 1 Part number øA L øB e Model 2 Series Model A B e L GEG.00.240.LC TT 8.6 10 M7 x 0.5 2.5 1 GEG.0S.240.LC 0T 10.5 12 M9 x 0.6 2.5 1 GEG.1S.240.LC 1T 14.0 16 M12 x 1.0 3.5 1 GEG.2S.240.LC 2T 17.5 20 M15 x 1.0 3.5 2 Note: TT, 0T, 1T and 2T series fixed and free sockets for back panel mounting are always delivered with this notched nut. To order this accessory separately, use the above part numbers. ● Material: Chrome-plated brass (Ni 3 μm + Cr 0.3 μm) DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 13 ® ® GEC Conical nuts Dimensions (mm) Part number A Series A B e L GEC.00.240.LC TT 8 10 M7 x 0.5 2.5 GEC.0S.240.LC 0T 10 12 M9 x 0.6 2.5 GEC.1S.240.LC 1T 13 16 M12 x 1.0 3.2 GEC.2S.240.LC 2T 17 20 M15 x 1.0 3.8 GEC.3S.240.LC 3T 20 24 M18 x 1.0 4.5 L øB e Note: 3T series fixed and free sockets for back panel mounting are always delivered with a conical nut. To order this accessory separately, use the part numbers in the adjacent table. ● Material: Chrome-plated brass (Ni 3 μm + Cr 0.3 μm) Accessories BFG Blanking caps for plugs Dimensions (mm) Part number L B N øA BFG.TT.100.CAS B L N 6.5 4.0 9.0 60 BFG.0T.100.CAS 9.0 5.0 11.0 85 BFG.1T.100.CAS 12.0 6.0 12.4 85 BFG.2T.100.CAS 15.0 6.0 13.8 85 BFG.3T.100.CAS 17.0 6.0 17.6 120 ● ● ● ● ● ● sliding loop A Body material: Chrome-plated brass (Ni 3 μm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 BHG Blanking caps for fixed plugs Dimensions (mm) Part number A B L N BHG.TT.100.CAS 6.5 4.0 9.0 60 BHG.0T.100.CAS L N øA B ø 3.5 9.0 5.0 11.0 85 BHG.1T.100.CAS 12.0 6.0 12.4 85 BHG.2T.100.CAS 15.0 6.0 13.8 85 BHG.3T.100.CAS 17.0 6.0 17.6 120 ● ● ● ● ● ● Body material: Chrome-plated brass (Ni 3 μm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 14 www.lemo.com ® BRF ® Blanking caps for free sockets Dimensions (mm) Part number B A B L 6.5 6.5 10.5 M N 2.5 60 L øA BRF.TT.200.CAZ N M 9.0 7.7 12.7 2.7 85 BRF.1T.200.CAZ 12.0 9.5 14.4 3.5 85 BRF.2T.200.CAZ 15.0 10.4 16.3 4.4 85 BRF.3T.200.CAZ 17.0 11.4 20.2 5.4 120 ● ● ● ● ● sliding loop BRE BRF.0T.200.CAZ Body material: Chrome-plated brass (Ni 3 μm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 Blanking caps for sockets Dimensions (mm) Part number A B M N BRE.TT.200.CAZ 6.5 6.5 10.5 2.5 60 BRE.0T.200.CAZ 9.0 7.7 12.7 2.7 85 BRE.1T.200.CAZ 12.0 9.5 14.4 3.5 85 BRE.2T.200.CAZ 15.0 10.4 16.3 4.4 85 BRE.3T.200.CAZ 17.0 11.4 20.2 5.4 120 B øA L N M ● ● ● ● ● ø 3.5 L Body material: Chrome-plated brass (Ni 3 μm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 GCA Earthing washers Dimensions (mm) øA L N øB Part number Series A B L N GCA.00.255.LT TT 9.5 7.1 0.4 18.2 GCA.0S.255.LT 0T 13.0 9.1 0.4 22.0 GCA.1S.255.LT 1T 17.0 12.2 0.5 27.5 GCA.2S.255.LT 2T 20.0 15.2 0.5 32.0 GCA.3S.255.LT 3T 25.0 18.2 0.5 39.0 ● Material: CuSnZn plated brass (2 μm) DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 15 ® ® Bend relief Bend relief øA L Cable ø Bend relief Part number TT 0T 1T Ref. Cable ø Part number A L min. max. A L min. max. GMA.00.012.DG 1.2 22 1.1 1.4 GMA.2B.040.DG 4.0 36 4.0 4.5 GMA.00.018.DG 1.8 22 1.8 2.1 GMA.00.025.DG 2.5 22 2.5 2.8 GMA.2B.045.DG 4.5 36 4.5 5.0 GMA.2B.050.DG 5.0 36 5.0 5.5 GMA.00.028.DG 2.8 22 2.8 3.1 GMA.2B.060.DG 6.0 36 6.0 6.5 GMA.00.032.DG 3.2 22 3.2 3.5 GMA.2B.070.DG 7.0 36 7.0 7.7 GMD.00.025.DG 2.5 22 2.5 2.8 GMA.2B.080.DG 7.8 36 7.8 8.8 GMD.00.028.DG 2.8 22 2.8 3.1 GMA.3B.050.DG 4.5 42 4.5 5.2 GMA.3B.060.DG 6.0 42 6.0 6.9 2T 3T GMD.00.032.DG 3.2 22 3.2 3.5 GMA.0B.025.DG 2.5 24 2.5 2.9 GMA.3B.070.DG 7.0 42 7.0 7.9 GMA.0B.030.DG 3.0 24 3.0 3.4 GMA.3B.080.DG 8.0 42 8.0 8.9 GMA.0B.035.DG 3.5 24 3.5 3.9 GMA.3B.090.DG 9.0 42 9.0 10.0 GMA.0B.040.DG 4.0 24 4.0 4.4 GMA.0B.045.DG 4.5 24 4.5 5.2 GMA.1B.025.DG 2.5 30 2.5 2.9 GMA.1B.030.DG 3.0 30 3.0 3.4 GMA.1B.035.DG 3.5 30 3.5 3.9 GMA.1B.040.DG 4.0 30 4.0 4.4 GMA.1B.045.DG 4.5 30 4.5 4.9 GMA.1B.054.DG 5.4 30 5.4 6.0 GMA.1B.065.DG 6.5 30 6.5 7.0 Colour Ref. Colour Note: all dimensions are in millimetres. Ref. Colour A blue J yellow R red B white M brown S orange G grey N black V green Note: the last letter «G» of the part number indicates the grey colour of the bend relief. For ordering a bend relief with another colour, see table above and replace the letter «G» by the letter of the required colour. DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 16 www.lemo.com ® ® Tooling DCG Spanners for hexagonal nuts N Dimensions (mm) Part number Part number of the nut Series B L N TT 14 40 50 GEA.00.240.LN DCG.91.161.1TN 0T 16 45 52 GEA.0S.240.LN DCG.91.201.4TN 1T 20 52 65 GEA.1S.240.LN DCG.91.231.7TN 2T 23 62 68 GEA.2S.240.LN DCG.91.282.2TN 3T 28 76 73 GEA.3S.240.LN L DCG.91.149.0TN øB ● Material: blackened steel DCA Spanners for hexagonal nuts with locator for flats on socket thread N Dimensions (mm) L max Part number øB Part number of the nut Series B L N DCA.91.149.0TN TT 14 65 50 GEA.00.240.LN DCA.91.161.1TN 0T 16 73 52 GEA.0S.240.LN DCA.91.201.4TN 1T 20 85 65 GEA.1S.240.LN DCA.91.231.7TN 2T 23 100 68 GEA.2S.240.LN DCA.91.282.2TN 3T 28 120 73 GEA.3S.240.LN ● Material: blackened steel DCH Spanners for conical nuts øA øB Dimensions (mm) Part number Series L A N B L N Part number of the nut DCH.91.101.PN TT 10.1 12.8 124 48.3 GEC.00.240.LC DCH.91.121.PN 0T 12.1 14.8 124 49.3 GEC.0S.240.LC DCH.91.161.PN 1T 16.1 21.0 124 51.9 GEC.1S.240.LC DCH.91.201.PN 2T 20.1 22.8 129 53.5 GEC.2S.240.LC ● Material: dark grey polyurethane DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 17 ® DCP ® Flat spanners for TT collet nut M N S1 L Dimensions (mm) Part number S1 L M N S1 DCP.99.050.TC 78 2 12.6 5.0 DCP.99.055.TC 78 2 12.6 5.5 DCP.99.060.TC 78 2 12.6 6.0 ● Material: chrome-plated steel DCH Spanners for notched nuts øA øB Dimensions (mm) Part number L A N DCP Part number of the nut Series B L N DCH.91.101.PA TT 10.1 12.8 124 48.3 GEG.00.240.LC DCH.91.121.PA 0T 12.1 14.8 124 49.3 GEG.0S.240.LC DCH.91.161.PA 1T 16.1 21.0 124 51.9 GEG.1S.240.LC DCH.91.201.PA 2T 20.1 22.8 129 53.5 GEG.2S.240.LC ● Material: blue polyurethane Set of flat spanners for collet nuts N S1 S2 M Dimensions (mm) Part number L 0T Series L M N S1 S2 7.55 7.05 DCP.0T.110.TN 0T 95 2.5 21 DCP.0T.110.TN 1T 95 2.5 25 11.05 9.05 DCP.2T.110.TN 2T 115 3.0 30 14.05 12.05 DCP.2T.110.TN 3T 115 3.0 35 16.05 14.05 1T ● Material: blackened steel DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 18 www.lemo.com ® ® Crimping tools for electrical contacts Manual crimping tools Fig. A Part number contact ø 0.5-0.7 contact ø 1.6-2.0 contact ø 3.0-4.0 0.9-1.3 (Fig. A) (Fig. B) (Fig. B) Fig. B Supplier DPC.91.701.V1) DPC.91.101.A2) DPC.91.102.V LEMO MH8601) AF82) M300BT DANIELS 6163361) 6157082) – ASTRO 1) 2) According to specification MIL-C-22520/7-01. According to specification MIL-C-22520/1-01. Pneumatic crimping tools Part number Supplier DPC.91.701.C LEMO 85230 BALMAR 621101 BUCHANAN According to specification MIL-C-22520/7-01. For LEMO contacts ø 0.5-0.7-0.9-1.3 mm DCK Retention testing tools for crimp contacts 0.5-0.7-0.9 and 1.3 mm diameter Testing tool part number Contact øA Test force (N) DCK.91.050.8LRC DCK.91.050.8LRM 0.5 8 DCK.91.071.0LRC DCK.91.071.0LRM 0.7 10 DCK.91.091.4LRC DCK.91.091.4LRM 0.9 14 DCK.91.132.5LRC DCK.91.132.5LRM 1.3 25 For male contact F For female contact DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 19 ® ® DCE Positioners for crimp contacts ø 0.5-0.7-0.9 and 1.3 mm TT male female These positioners are suitable for use with both manual and pneumatic crimping tools according to the MIL-C-22520/7-01 standard. 0T Fig. 1 øA øC 1T øA øC Fig. 2 øA C Conductor AWG Positioners part number For male contact For female contact 302 0.5 0.45 1 28-30-32 DCE.91.050.0VC DCE.91.050.0VM 303 0.5 0.45 1 28-30-32 DCE.91.050.0VC DCE.91.050.0VM 304 0.5 0.45 1 28-30-32 DCE.91.050.0VC DCE.91.050.0VM 302/303 0.9 1.10 1 20-22-24 DCE.91.090.BVC DCE.91.090.BVM 302/303 0.9 0.80 2 22-24-26 DCE.91.090.BVC DCE.91.090.BVM 302/303 0.9 0.45 2 28-30-32 DCE.91.090.AVC DCE.91.090.AVM 304/305 0.7 0.80 1 22-24-26 DCE.91.070.BVC DCE.91.070.BVM 304/305 0.7 0.45 2 28-30-32 DCE.91.070.BVC DCE.91.070.BVM 306/307/309 0.5 0.45 1 28-30-32 DCE.91.050.BVC DCE.91.050.BVM 302/303 1.3 1.40 1 18-20 DCE.91.131.BVC DCE.91.131.BVM 302/303 1.3 1.10 2 20-22-24 DCE.91.131.BVC DCE.91.131.BVM 304/305 0.9 1.10 1 20-22-24 DCE.91.091.BVC DCE.91.091.BVM 304/305 0.9 0.80 2 22-24-26 DCE.91.091.BVC DCE.91.091.BVM 306/307/308 0.7 0.80 1 22-24-26 DCE.91.071.BVC DCE.91.071.BVM 306/307/308 0.7 0.45 2 28-30-32 DCE.91.071.BVC DCE.91.071.BVM 310/314/316 0.5 0.45 1 28-30-32 DCE.91.051.BVC DCE.91.051.BVM 304/305/306/307 1.3 1.40 1 18-20 DCE.91.132.BVC DCE.91.132.BVM 304/305/306/307 1.3 1.10 2 20-22-24 DCE.91.132.BVC DCE.91.132.BVM 304/305/306/307 1.3 0.80 2 22-24-26 DCE.91.132.CVC DCE.91.132.CVM 308/310 0.9 1.10 1 20-22-24 DCE.91.092.BVC DCE.91.092.BVM 308/310 0.9 0.80 2 22-24-26 DCE.91.092.BVC DCE.91.092.BVM 308/310 0.9 0.45 2 28-30-32 DCE.91.092.AVC DCE.91.092.AVM 312/314/316/318/319 0.7 0.80 1 22-24-26 DCE.91.072.BVC DCE.91.072.BVM 312/314/316/318/319 0.7 0.45 2 28-30-32 DCE.91.072.BVC DCE.91.072.BVM 308/309/310 1.3 1.40 1 18-20 DCE.91.133.BVC DCE.91.133.BVM 308/309/310 1.3 1.10 2 20-22-24 DCE.91.133.BVC DCE.91.133.BVM 312/314/316/318 0.9 1.10 1 20-22-24 DCE.91.093.BVC DCE.91.093.BVM 312/314/316/318 0.9 0.80 2 22-24-2 DCE.91.093.BVC DCE.91.093.BVM 320/322/324/326/330 0.7 0.80 1 22-24-26 DCE.91.073.BVC DCE.91.073.BVM 320/322/324/326/330 0.7 0.45 2 28-30-32 DCE.91.073.BVC DCE.91.073.BVM øC 2T øA A Fig. ø (mm) Types øC Note: a wide variation of strand number and diameter combinations are quoted as being AWG, some of which do not have a large enough cross section to guarantee a crimp as per either MIL-C-22520/1-01 or /7-01. Our technical department is at your disposal to study and propose a solution to all your applications. 3T DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 20 www.lemo.com ® ® DCE Turret for crimp contacts 1.6-2.0-3.0 and 4.0 mm diameter ø (mm) 2T Note: these turrets can be used with manual crimping tool according to MILC-22520/1-01 standard. DCF 3T Conductor AWG Positioners part number C Fig. Types 302 2.0 2.4 1 12-14-16 DCE.91.202.BVCM 302 2.0 1.9 2 14-16-18 DCE.91.202.BVCM 303 1.6 1.9 1 14-16-18 DCE.91.162.BVCM 303 1.6 1.4 2 18-20-22 DCE.91.162.BVCM 302 3.0 3.2 1 10-12-14 DCE.91.303.BVCM 303/304/309 2.0 2.4 1 12-14-16 DCE.91.203.BVCM 303/304/309 2.0 1.9 2 14-16-18 DCE.91.203.BVCM 305/306/307 1.6 1.9 1 14-16-18 DCE.91.163.BVCM 305/306/307 1.6 1.4 2 18-20-22 DCE.91.163.BVCM A Automatic extraction tools for crimp contacts Types TT 0T 1T 2T 3T Note: 1) Contact ø A (mm) Extractors part number for male and female contacts 302 0.5 DCF.91.050.2LT 303 0.5 DCF.91.050.2LT 304 0.5 DCF.91.050.2LT 302/303 0.9 DCF.91.090.2LT 304/305 0.7 DCF.92.070.3LT 306/307/309 0.5 DCF.91.050.2LT 302/303 1.3 DCF.91.131.2LT 304/305 0.9 DCF.91.090.2LT 306/307/308 0.7 DCF.91.070.2LT 310/314/316 0.5 DCF.91.050.2LT 302 2.0 DCC.91.202.5LA1) 303 1.6 DCF.91.162.2LT 304/305/306/307 1.3 DCF.91.131.2LT 308/310 0.9 DCF.91.090.2LT 312/314/316/318/319 0.7 DCF.91.070.2LT 302 3.0 DCF.91.303.5LT 303/304/309 2.0 DCC.91.202.5LA1) 305/306/307 1.6 DCF.91.163.5LT 308/309/310 1.3 DCF.91.133.5LT 312/314/316/318 0.9 DCF.91.093.5LT 320/322/324/326/330 0.7 DCF.91.073.5LT this model is thumb-operated. DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 21 ® ® PCB drilling pattern Fixed socket with straight print contact 302 303 Dimensions Dimensions Series Series A B 0T 0.8 2.2 1T 0.8 2.8 2T 0.8 4.4 A B C 0T 0.8 2.3 120° 1T 0.8 3.0 120° 2T 0.8 4.6 120° 3T 0.8 5.6 120° 304 C° øA øB øA øB 305 Dimensions Dimensions Series øB B C 0T 0.6 2.5 45° 1T 0.8 3.1 45° 2T 0.8 5.0 3T 0.8 6.2 306 A B C 0T 0.6 2.8 72° 1T 0.8 3.4 72° 45° 2T 0.8 5.2 72° 45° 3T 0.8 6.7 72° C° øB A øA øA C° Series 306 Dimensions Dimensions Series Series C 0.6 3.0 60° øB øB 0T C° 0.8 1T 307 3.7 C° 60° 3.00 60° 1T 0.8 3.70 60° 2T 0.8 5.80 60° 3T 0.8 7.08 60° 72° 3T 0.8 7.1 72° C° 1T A B C 0.8 3.8 51°26’ 309 Dimensions Series A B C 2T 0.8 6.4 45° 3T 0.8 7.5 45° øA 310 A B C 0T 0.6 3.2 45° 3T 0.8 7.5 45° C° øB øA øB 5.6 øB øB 0.6 Dimensions 312 Dimensions Dimensions Series Series C D H C° 2T 0.8 6.30 45° 22°30’ 2.15 3T 0.8 7.90 45° 22°30’ 2.80 øH 0.6 3.95 45° 22°30’ 1.40 øA 1T A B C D H D° øB B H A øB 0.8 C Series C° 2T Dimensions øA øA C° B 0T 308 øA C Series A D° B 308 Dimensions Series C° A øA B øA A 2T 0.8 6.50 45° 22°30’ 2.80 3T 0.8 8.20 45° 22°30’ 3.40 Note: all views are from the side of the socket. DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 22 www.lemo.com ® ® 316 Dimensions Dimensions Series øB øA I B 1T 0.6 4.4 90° 1.90 1.80 2T 0.8 6.5 90° 2.65 2.65 3T 0.8 8.2 90° 3.40 3.40 316 C H I øA A øH H ° 36 36° 1T 0.6 4.4 32°44’ 2.0 Dimensions D E H 2T 0.8 6.6 32°44’ 16°22’ 3.10 3T 0.8 8.4 32°44’ 16°22’ 3.86 C° A E° D° øB B øH A øB H Series E° øH D 318 Dimensions D° B 72 ° Series ° 72 A B C D E H 2T 0.8 6.7 60° 30° 15° 3.50 3T 0.8 8.4 60° 30° 15° 4.34 øA øA 319 320 Dimensions Dimensions Series A E° C D E H 0.8 6.7 60° 30° 15° 3.5 øB ø 0.6 2T øH B B C D H 8.62 51°26’ 27°42’ 4.78 3T øB D° øH C° Series D° øA C° 324 Dimensions H ø 0.6 3T.326 ø 0.6 36° ø 2.2 ° 72 ø9 2.2 22° 30 ' ø 5.6 11°15' ø 0.6 ø9 40° 36° ° 90 ø 2.1 12 0° ø 4.2 ø7 40° ø 1.6 12 0° ø 0.6 H 2T.332 ø 5.7 25°43' E øE 3T.330 25°43' D 8.8 45° 25°43’ 1.8 5.30 3T ø 0.6 2T.326 C øB 5 øH 45° 25°43’ 22°30’ B ø 0.6 øH E ø 8.8 D° D Series D° C E° 3T Dimensions C° Series C° ø7 322 4.6 C° Series D° øB 314 21°11' 2.6 Note: all views are from the side of the socket. DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 23 ® ® Cable assembly L T S ø contact (mm) TT 0T 1T 2T 3T Cable stripping lengths (mm) L 302 0.5 8.0 4 2.5 11.0 4 3.0 303 0.5 8.0 4 2.5 11.0 4 3.0 304 0.5 8.0 4 2.5 11.0 4 3.0 302/303 0.9 9.0 5 4.0 9.0 5 4.0 304/305 0.7 8.0 5 3.5 9.0 5 4.0 306/307/309 0.5 7.0 5 2.5 312 0.35 7.0 5 2.5 302/303 1.3 10.5 7 3.5 14.5 7 4.0 304/305 0.9 10.5 7 3.0 14.5 7 4.0 306/307/308 0.7 10.5 7 3.0 14.5 7 4.0 310/314/316 0.5 13.0 7 2.5 302 2.0 16.5 8 4.0 19.5 8 5.5 303 1.6 16.5 8 3.5 19.5 8 5.5 304/305/306/307 1.3 15.5 8 3.5 17.5 8 4.0 308/310 0.9 14.5 8 3.0 17.5 8 4.0 312/314/316/318/319 0.7 14.5 8 3.0 17.5 8 4.0 326/332 0.5 14.5 8 2.5 302 3.0 19.0 10 4.5 23.0 10 5.5 303/304 2.0 18.0 10 4.0 22.0 10 5.5 305/306/307 1.6 18.0 10 3.5 22.0 10 5.5 308/310 1.3 17.0 10 3.5 20.0 10 4.0 309 1.3 2.0 17.0 10 3.5 4.0 20.0 10 4.0 5.5 312/314/316/318 0.9 16.0 10 3.0 20.0 10 4.0 320/322/324/326/330 0.7 16.0 10 3.0 20.0 10 4.0 Reference Solder S T L Crimp S T DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. 24 www.lemo.com ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. Data subject to change No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO reserve the right at all times to modify and improve specifications without any notification. DISCLAIMER The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 25 LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax:(+43 1) 914 23 20 11 sales@lemo.at NETHERLANDS / BELGIUM LEMO Connectors Benelux De Trompet 1060 1967 DA Heemskerk Tel. (+31) 251 25 78 20 Fax (+31) 251 25 78 21 info@lemo.nl CANADA LEMO Canada Inc 44 East Beaver Creek Road, unit 20 Richmond Hill, Ontario L4B 1G8 Tel: (+1 905) 889 56 78 Fax: (+1 905) 889 49 70 info-canada@lemo.com NORWAY / ICELAND LEMO Norway A/S Stanseveien 6B 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com CHINA / HONG KONG LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com SINGAPORE LEMO  Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com DENMARK LEMO Denmark A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com SWEDEN / FINLAND LEMO  Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing, West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax:(+1 707) 578 08 69 info-US@lemo.com JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: (+81 3) 54 46 55 10 Fax: (+81 3) 54 46 55 11 lemoinfo@lemo.co.jp LEMO DISTRIBUTORS AUSTRALIA, BRAZIL, CHILE, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TAIWAN, TURKEY, UKRAINE www.lemo.com U.S. Air Force photo/Tech. Sgt. Shane A. GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com © CAT.MT.LEN.P0115, updated June 2015 LEMO
FGG.1T.307.CLAC65 价格&库存
很抱歉,暂时无法提供与“FGG.1T.307.CLAC65”相匹配的价格&库存,您可以联系我们找货
