FGG.1T.308.CLAC60Z
FGG.1T.308.CLAC60Z
    LEMO(雷莫)
    LEMO - FGG.1T.308.CLAC60Z - Circular Connector, 1T Series, Cable Mount Plug, 8 Contacts, Solder Pin,...
FGG.1T.308.CLAC60Z 数据手册
FGG.1T.308.CLAC60Z www.lemo.com SUMMARY # Wires Low 8 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 1T Termination type Male solder IP rating 68 Cable Ø 5.60 - 6.00 mm Status active Image is for illustrative purpose only Download Request a quote Catalog Alternative part Matching parts EGG.1T.308.CLL TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 17.01 g Performance Configuration 1T.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) Others Endurance (Shell): >3000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr IP Rating: 68 DRAWINGS Draws Dimensions A L M S1 S2 mm. 12 45 34 11 9 in. 0.47 1.77 1.34 0.43 0.35 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools None Cables CMN.08.T22.059PGCE PVC GREY CMN.08.T22.059PNCE PVC Black CMN.08.T22.059PGZE Grey CMN.08.T22.059PNZE CMN.08.T22.059QGC TPR Grey CMN.08.T22.059QGZE TPR (medical) Grey 016 080 PVC Grey 042 265 PVC Yellow 080 140 PVC Grey 180 260 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1T.308.CLAC60Z 价格&库存
很抱歉,暂时无法提供与“FGG.1T.308.CLAC60Z”相匹配的价格&库存,您可以联系我们找货
FGG.1T.308.CLAC60Z
  • 1+443.59676
  • 5+430.28423
  • 10+417.36324
  • 25+404.84567
  • 50+396.75374
  • 100+388.66181
库存:31
FGG.1T.308.CLAC60Z
  • 1+387.82171
  • 5+376.17904
  • 10+364.89044
库存:14
