EGG.0T.303.CLL
EGG.0T.303.CLL
    LEMO(雷莫)
    EGG.0T.303.CLL
EGG.0T.303.CLL 数据手册
0T SERIES IP 68 PUSH-PULL CONNECTORS 0T series 0T series connectors have been specifically designed for outdoor applications. They include an inner sleeve and seals to prevent penetration of solids or liquids.This series is watertight when mated to give a protection index of IP68 as per IEC 60529 standard and have the following main features: - IP68 mated - Push-Pull self-latching system - Mechanical key (FGG) with multiple keys to avoid cross-mating - High packing density for space savings - 360° shielding for full EMC shielding - Compatible with existing 0B sockets - Same mounting hole as 0B sockets - Black-chrome plated brass and plastic outershell available - Multipole types 2 to 9 contacts - For cables 1.0 up to 5.0 mm - Solder, crimp or print contacts Technical Characteristics Mechanical and Climatical Value Standard Endurance > 5000 cycles IEC 60512-5 test 9a Humidity up to 95% at 60° C – Temperature range -55° C, +200° C – Resistance to vibration 10-2000 Hz, 15 g IEC 60512-4 test 6d Shock resistance 100 g, 6 ms IEC 60512-4 test 6c Salt spray corrosion test > 144h IEC 60512-6 test 11f Protection index (mated) IP68 IEC 60529 Latching retention force > 150 N – Electrical Value Standard Shielding efficiency at 10 MHz > 75 dB IEC 60169-1-3 Shielding efficiency at 1 GHz > 40 dB IEC 60169-1-3 Material and Treatments Outershell and collet nut Material Surf. treat. Latch sleeve/earthing crown Material Surf. treat. Other metallic components Material Surf. treat. Brass Chrome Brass/Bronze Nickel Brass Nickel Brass Black chrome Brass/Bronze Nickel Brass Nickel POM – Brass/Bronze Nickel Brass Nickel Contacts Material Insulators Material Contact type Brass (UNS C 34500) Male contact Bronze (UNS C 54400) Female contact Contact type PEEK Crimp, solder or print Part Section Showing Internal Components Straight plug Fixed socket 4 2 2 6 3 7 5 6 1 2 5 4 1 6 7 8 3 1 outer shell 1 outer shell 2 latch sleeve 2 earthing crown 3 collet nut 3 hexagonal nut 4 insulator 4 insulator 5 male contact 5 female contact 6 split insert carrier 6 o-ring 7 earthing cone 7 locking washer 8 gasket Interconnections Metal housing models Straight plugs FGG Fixed sockets Free sockets EGG PHG EEG PHG FFG FGG Plastic housing models Straight plug FGG Watertight or vacuumtight models Fixed socket Fixed sockets EGG HGG HEG HMG Part Numbering System Plug and free socket F G G. 0 T . 3 0 4 . C L A C 4 0 Z Variant Cable ø Model Collet type Alignment key Contact: A = male solder L = female solder C = male crimp M = female crimp Series Insert configuration Housing: C = Chrome plated brass K = Black Cr plated brass D = POM Insulator: PEEK L = for solder contact Y = for crimp contact FGG.0T.304.CLAC40Z = Straight plug with key (G) and cable collet for bend relief, 0T series, multipole type with 4 contacts, outer shell in chrome-plated brass, PEEK insulator, male solder contacts, C type collet for 4.0 mm diameter cable and nut for fitting a bend relief. Fixed socket E G G. 0 T . 3 0 4 . C L L Model Alignment key Series Insert configuration Housing: C = Chrome plated brass K = Black Cr plated brass D = POM Contact: L = female solder M = female crimp N = female print V = fem. elbow print Insulator: PEEK L = for solder contact Y = for crimp contact EGG.0T.304.CLL = fixed socket, nut fixing, with key (G), 0T series, multipole type with 4 contacts, outer shell in chrome-plated brass, PEEK insulator, female solder contacts. 3 FGG Straight plug, cable collet ~39 ø9 ~29 FGG Straight plug, cable collet and nut for fitting a bend relief ~38 ø9 ~28 FFG Straight plug, non latching, cable collet ~39 ø9 ~29 EGG Fixed socket, nut fixing 21 maxi 1.5 ø 9.1+ 0.1 0 ø 12 19.1 8.3 + 0.1 0 6 maxi Panel cut-out 4 EEG Fixed socket, nut fixing, back panel mounting 21 maxi ø 12 ø 9.1+ 0.1 0 19.1 8.3 + 0.1 0 6.5 maxi Panel cut-out HGG Fixed socket, nut fixing, watertight or vacuumtight 22 maxi ø 9.1+ 0.1 0 ø 12 18.5 8.3 + 0.1 0 1.5 9 maxi Panel cut-out Note: temperature range -20°C / +100°C HEG Fixed socket, nut fixing, watertight or vacuumtight, back panel mounting 22 maxi ø 12 ø 9.1+ 0.1 0 18.5 8.3 + 0.1 0 6.5 maxi Panel cut-out Note: temperature range -20°C / +100°C HMG Fixed socket, nut fixing, watertight or vacuumtight, back panel mounting 22 maxi ø 12 ø 9.1+ 0.1 0 18.5 6.5 maxi 8.3 + 0.1 0 Panel cut-out Note: temperature range -20°C / +100°C 5 PHG Free socket, cable collet ø9 ~38 PHG Free socket, cable collet and nut for fitting a bend relief ø9 ~37 FGG Straight plug, cable collet and nut for fitting a bend relief, POM outer shell ~38.5 ø 9.7 ~28.5 EGG Fixed socket, nut fixing, POM outer shell 21 maxi 1.5 ø 9.1+ 0.1 0 ø 12 19.1 8.3 + 0.1 0 6 maxi Panel cut-out 6 Insert configurations Contact type Solder contacts AWG Contact ø (mm) Solder Crimp Print (straight) Print (elbow) Solder (max.) min. max. 302 2 0.9 ● ● ● ● 22 32 20 1.00 1.05 10.0 303 3 0.9 ● ● ● ● 22 32 20 1.20 0.90 8.0 304 4 0.7 ● ● ● ● 22 32 22 0.85 0.70 7.0 305 5 0.7 ● ● ● ● 22 32 22 1.00 0.70 6.5 306 6 0.5 ● ● ● 28 32 28 0.85 0.65 2.5 307 7 0.5 ● ● ● 28 32 28 0.80 0.70 2.5 309 9 0.5 ● ● ● 28 32 28 0.60 0.50 2.0 Crimp contacts Collets Rated current (A) Number of contacts Test voltage (kV rms) Reference Test voltage (kV rms) Crimp Alignment Key Key Contact type G Cable ø (mm) Cable ø (mm) Type Type min. max. min. max. C10 1.0 1.2 C35 3.1 3.5 C15 1.3 1.5 C40 3.6 4.0 C20 1.6 2.0 C45 4.1 4.5 C25 2.1 2.5 C50 4.6 5.0 C30 2.6 3.0 B A Plug Socket G male female A male female B male female J female male J Bend relief Bend relief Cable ø Part number øA L A L min. max. GMA.0B.025.DG 2.5 24 2.5 2.9 GMA.0B.030.DG 3.0 24 3.0 3.4 GMA.0B.035.DG 3.5 24 3.5 3.9 GMA.0B.040.DG 4.0 24 4.0 4.4 GMA.0B.045.DG 4.5 24 4.5 5.2 Note: all dimensions are in millimetres. Ref. Colour Ref. Colour Ref. Colour A blue J yellow R red B white M brown S orange G grey N black V green Note: the last letter «G» of the part number indicates the grey colour of the bend relief. For ordering a bend relief with another colour, see table and replace the letter «G» by the letter of the required colour. 7 PCB drilling pattern Fixed socket with straight print contact 304 ° 72 ø 2.2 ø 2.8 12 0° ø 0.8 ø 0.8 305 45° ø 0.6 303 ø 0.6 302 ø 2.5 ø 2.3 60 ° 45° ø 3.2 ° 60 ø3 ø3 ø 0.6 309 ø 0.6 307 ø 0.6 306 Fixed socket with elbow print contact 303 304 1 2.54 1 2 1.27 2 2.54 306 4 3 1 2 5 4 2 3 1 ø 0.7 3 1.27 ø 0.7 305 ø 0.7 ø 0.7 1.27 302 2.54 2.54 2.54 2.54 307 309 ø 0.7 ø 0.6 1 3 4 7 1 3 2 1.27 1.27 1.27 2 6 ø 0.7 4 2.54 2.54 5 5 6 2.54 2.54 2.54 2.54 8 7 6 1 9 5 2 3 4 2.54 2.54 Tooling For crimp contact tooling see 0B series in the unipole/multipole catalogue. L Reference T S ø contact (mm) Cable asssembly Cable stripping lengths (mm) L Solder S T L Crimp S T 302/303 0.9 14.5 7 3.5 17 7 4 304/305 0.7 14.5 7 3.5 17 7 4 306/307/309 0.5 14.0 7 2.5 18 7 3 LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com www.lemo.com © CAT.0T.LEN.P1113 CHF 1.50 / EURO 1 / USD 1.1 / RMB 10 Data subject to change, printed in Switzerland, November 2013 Updated June 2014
EGG.0T.303.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.0T.303.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.0T.303.CLL
    库存:10
